How to install Domoticz on a Synology NAS
Michel13
- Domoticz version: 2024.7
Re: How to install Domoticz on a Synology NAS
I have just installed Domoticz V3.5877 Stable DSM 6.0 on my DS214+ and have a problem with the version.
The .spk I have loaded is from http://www.jadahl.com/domoticz_stable_6 ... 5877-7.spk but when installed it is in fact :
Version: 3.5876
Build Hash: b97777b
Compile Date: 2016-11-09 12:33:42
So I have a message telling me that the package is to be updated. Clicking on "Update now" loads the update, but after installation, version is still the same and the message comes over again.
I have reboot the NAS in the hope to get Domoticz updated, but there is no change.
I have actually 2 Raspberry RPI (2 and 3) running Domoticz. My goal with Domoticz on my NAS is to make it as the master with the 2 Rasp connected as Slaves. I wonder if it is possible to do so with two systems : Rasp and Syno, and if that is stable. However, I need to have the same rev on the three units for the exchange to work.
How can I do to upgrade to 5877, or is it possible to get the correct file for the above link ?
Thanks in advance for your help.
Version: 3.5876
Build Hash: b97777b
- jumbotroll
I have fixed a typo...Michel13 wrote:Hello,
Version: 3.5876
Build Hash: b97777b
Try this package http://www.jadahl.com/domoticz_stable_6 ... 5877-7.spk
https://paypal.me/Jumbotroll
Jumbotroll
Jumbotroll
Michel13
Thank you jumbotroll for your prompt action.
I have downloaded from your link, remove Domoticz from the package center and reinstall it from the fresh file.
Unfortunately, there is no change at all.
Version is still 5876 and Domoticz asks for an update.
- jumbotroll
Sorry, but it seem that the problem is in the source code.Michel13 wrote:Thank you jumbotroll for your prompt action.
Maybe better you update to beta version, it's more than stable
domoticz_armadaxp-6.0_3.0.6500-7.spk
http://www.jadahl.com/domoticz_beta_6/p ... 6500-7.spk
Jumbotroll
Jumbotroll
- jumbotroll
Edit:
Maybe better you update to latest beta version, it's more than stable
http://www.jadahl.com/domoticz_beta_6/?arch=armadaxp
Edit:
Jumbotroll
Jumbotroll
Michel13
OK, I understand.
The problem with the beta is that I have to upgrade also my RPI to be able to use my NAS as master. And I am not very keen to run beta. I even give time before loading final release. Probably due to my experience with Synology : always bugs with their first new releases (DSM 5, DSM 6). Believe me or not, I have just installed today DSM 6.0....
So, I am not in a hurry and will wait for stable new version of Domoticz and hope it will be ok also with my NAS.
Thank you for your time and also for your effort to keep Domoticz working on our Synos.
bertbigb
Of course I respect that you don't want run beta. I also have Synology and Domiticz. I'm running the beta package from Jadahl now 2 years without any problems. By the way I run also Synology as Master en Raspberry as slave.
Best regards Bert
Synology DS1517+ - DSM 6.2
Michel13
You are probably right bertbigb regarding the beta version.
Which Domoticz versions are you running on your RPI and the Syno ?
Because from today the RPI available for download is 6544 https://domoticz.com/downloads/ and the version packed by jumbotroll is 6518 http://www.jadahl.com/domoticz_beta_6/?arch=armadaxp
From https://www.domoticz.com/wiki/Setting_up_Device_sharing
As you have exactly the configuration I intend to install, can you tell me if its stable ?
It seems impossible to run 2 different versions for master and slaves.All software should be at the latest version and all master and slaves must be running the same version.
teachingbirds
I'm totally new to this, and can't seem to find my Domoticz folder in my Synology nas. Anyone have any clue why or how I can find it?
I'm also wondering - I installed Domoticz using the package manager and the ready-made package and nog don't have python as an option in events. Do I have to re-install in another way to get Python? I've read it's good for scripts.
- jumbotroll
Check this thread: http://www.domoticz.com/forum/viewtopic.php?f=4&t=15856teachingbirds wrote:I'm totally new to this, and can't seem to find my Domoticz folder in my Synology nas. Anyone have any clue why or how I can find it?
and this: http://www.domoticz.com/forum/viewtopic ... 65&t=15233
Domoticz folder on Synology is /usr/local/domoticz
Jumbotroll
Jumbotroll
teachingbirds
Thank you, I will try this later!jumbotroll wrote:Check this thread: http://www.domoticz.com/forum/viewtopic.php?f=4&t=15856teachingbirds wrote:I'm totally new to this, and can't seem to find my Domoticz folder in my Synology nas. Anyone have any clue why or how I can find it?
- EdwinK
- Domoticz version: BETA
Thanks. Have been looking for that one myself.jumbotroll wrote:Domoticz folder on Synology is /usr/local/domoticz
GSV3Miac
- Domoticz version: latest
I've installed the version fairly easily (thanks Jumbotroll) despite being a 'nix newbie (my NAS mostly just sits there and backs things up), and have also seen the 'upgrade' message when I login, followed by the 'upgrade failed'. I can ignore that one. More annoyingly I can't get SolarEdge API to work - it works fine from my windows installation, but on the Synology it just never comes back with any data (I get the 2017-02-12 13:18:41.781 SolarEdgeAPI Worker started... message, but nothing more). I copied all the credentials from the PC version, and there is no hint of anything being wrong, just no
data, A Weather Underground connection works fine, so it is not a generic internet issue.
**Solved** .. you just don't get any data (and thus any devices to select) until/unless it is day time.
GSV3Miac
Another issue I could use help with .. I had the Aeontec HEM gen5 working just fine, for a while, but at about 20:45 last night the devices stopped receiving data, and I can't get them to revive (I have not disconnected them from the Z-wave network, but I've tried everything else). I can get them fine from a copy of the domoticz installation running on the PC, but on the Synology 'no data'.
Looking at the log, it seems I am getting copious timeouts for whatever reason. I see them occasionally on the PC too, but the PC seems to retry and eventually succeed, whereas the Synology version just seems to give up .. log attached. Suggestions welcome - is there some way to tell the Synology package to 'keep trying', or do I just have an issue with the Energy Meter itself?
download/file.php?mode=view&id=9710
- SynZWave.png (170.36 KiB) Viewed 6358 times
rjblake
Quick question regards OpenZwave on Synology. I have noticed that there is nothing recorded in the OpenZwave Control Panel 'Log Output' when running this on my Synology, but if i create and install in Mac OS or Windows I do get OpenZwave data being logged. Are others experiencing the same?
GSV3Miac
On synology the log is 'elsewhere' and you can review it from the package centre synology package, rather than inside the setup tab on Domoticz itself.
Click the Domotiz package (I'm using 6.x but I assume other versions are similar) and then select 'view log' (at the bottom). No, I don't know why it is that way, but it is.
GSV3Miac
I have a problem with my Aeotec Gen5 energy meter on Synology - it doesn't seem to create any devices when it starts. On the PC version it starts fine. Here are the appropriate bits of the logs .. can someone suggest a fix? I upgraded the synology install to the latest beta version, but no difference.
synology startup ..
2017-02-16 21:16:17.594 OpenZWave: Starting...
2017-02-16 21:16:17.595 OpenZWave: Version: 1.4-2398-g0623c10-dirty
2017-02-16 21:16:17.595 OpenZWave: using config in: /usr/local/domoticz/Config/
2017-02-16 21:16:17.785 OpenZWave: Driver Ready
2017-02-16 21:16:17.797 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Count, Instance: 1
2017-02-16 21:16:17.798 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-02-16 21:16:19.651 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Count, Instance: 1
2017-02-16 21:16:19.763 OpenZWave: All Nodes queried
Windows7 PC version
2017-02-16 21:25:38.952 OpenZWave: Starting...
2017-02-16 21:25:38.952 OpenZWave: Version: 1.4.2340.g63fa7f6.dirty
2017-02-16 21:25:38.953 OpenZWave: using config in: C:\Program Files (x86)\Domoticz\Config/
2017-02-16 21:25:39.127 OpenZWave: Driver Ready
2017-02-16 21:25:39.132 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Energy, Instance: 1
2017-02-16 21:25:39.132 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Power, Instance: 1
2017-02-16 21:25:39.132 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Voltage, Instance: 1
2017-02-16 21:25:39.132 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Current, Instance: 1
2017-02-16 21:25:39.132 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Unknown, Instance: 1
2017-02-16 21:25:39.134 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
The OZW control panel shows the device (in both cases) with data coming in and the same parameters (as far as I can tell) so the issue is maybe with the way OZW is linking into domoticz devices.
synology startup ..
Windows7 PC version
SailsAndSkis
I'm trying to get a linear GD00Z-4 garage door controller working with Domoticz running on my Synology NAS. From what I've been reading it appears that support needs to be added for COMMAND_CLASS_BARRIER_OPERATOR in order to make it work.
I found this thread viewtopic.php?f=24&t=10973&p=82509&hilit=Barrier#p82509 that talks about patching Domoticz and OpenZwave to add support. I think this is probably beyond my skill set but does anyone have any experience with this?
Is this something that could be added into the package for the Synology?
stephenmhall
New user here I have 3.7708 installed on my Synology 412+, I had a stop last night and found some issues when looking at the log file.
1 On start it is unable to connect to secure port 8443 but checking the ports nothing else seems to be using this.
2 It showed python errors when trying to load domoticz.py in the /usr/local/domoticz/var/scripts/python folder. This was because it seems to be a python 2.7 file but domoticz uses 3.5, I had to add () to all the print statements. Also there was a mix of tabs and spaces that caused it to fail after fixing this, also fixed.
3 Also python, the script_device_PIRsmarter.py file in same folder reports that "changed_device" is not configured, which it isn't but not knowing how the python plugins work I was unable to fix this so deleted it.
4 not connected to the stop but I added the Honeywell web api for my heating but no devices ever appeared. I believe there was an error found in this last weekend and assume it has not filtered down to the Synology branch.
EDIT: Upgraded to V3.7972-7. No python script errors, a different secure socket error asking that I check privileges on ports lower than 1024 it seems to be trying to use port 443 on address 0.0.0.0 But I now my Evohome gear has added itself so Yay.
I'm also looking for support for the garage door opener. I feel like I could work through the steps to get it going on a computer, but trying to learn how to do it all through SSH on the synology is taking more time than I have available. It would be awesome if Jumbotroll could update the beta package to include the latest beta of openzwave and the patch mentioned in that post.SailsAndSkis wrote:Hello,
I found this thread https://www.domoticz.com/forum/viewtopi ... ier#p82509 that talks about patching Domoticz and OpenZwave to add support. I think this is probably beyond my skill set but does anyone have any experience with this?
