Page 10 of 14
Re: Zigbee2MQTT
Posted: Saturday 16 November 2019 19:04
by gschmidt
snellejellep wrote: Saturday 16 November 2019 16:53
gschmidt wrote: Saturday 16 November 2019 16:44
I am trying to install Zigbee2MQTT on my Domoticz system (Rpi3b).
The CC2531 USB is inserted directly on the same system.
When I run the service with "npm start", I get the error "Not connected to MQTT Server"
I have attached the LOG and the configuration.yaml.
Could somebody help me out with this?
do you have authentication enabled on your mqtt server?
checkout my video on this topic, maby it will help you:
https://www.youtube.com/watch?v=28Whi98 ... A&index=17
Thanx...Working Now! I first didn't perform the mosquitto part!
Re: Zigbee2MQTT
Posted: Monday 18 November 2019 7:44
by RichardBokker
snellejellep wrote: Saturday 16 November 2019 16:56
RichardBokker wrote: Friday 15 November 2019 8:38
The Zigbee2MQTT is really awesome plugin, finally getting rid of the Xiaomi Gateway crap!
Has anyone a step-by-step explaination to install the Zigbee2MqttAssistant on a rPI?
https://github.com/yllibed/Zigbee2MqttAssistant
Or should i use the Docker installation method in my sitation?
Thats new for me to, so have to figure it out.
the zigbee2mqtt assistant is really hard to use withoud home assistant, i am working on a video about a similar tool but then created in nodered so it can easily be used with domoticz. for now i would like to redirect you to try:
https://github.com/ben423423n32j14e/zig ... adminpanel
make sure you have it running on the same machine as your mqtt server.
if you have enabled authentication you may run in to problems but that is a little hard to explain this way. i hope to make a video about it soon.
Oke, cool. THnx.
I think i should try this..?
My pi is running everything on the same system: Domoticz + MQTT + Zigbee2MQTT
Re: Zigbee2MQTT
Posted: Wednesday 20 November 2019 15:26
by opex
Mayki wrote: Saturday 09 February 2019 12:52
Is there anyone who uses it on Synology NAS? With CC2531 USB Sniffer? Is there any manual for Synology?
Hi, I am newbie in this forum and actually home automation area. I have Synology NAS DS216j and now wondering which is the best way to connect eg temperature sensors to Synolgy. I just installed Domoticz and saw your post.
Did you manage to get CC2531 USB sniffer working in your NAS or how you are connecting devices? I would like to avoid old fashioned 433Mhz solutions and go for zigbee or BLE sensors instead.
Re: Zigbee2MQTT
Posted: Thursday 21 November 2019 10:12
by RichardBokker
You got two options.
Buy an xiaomi gateway + sensors, then no need for this plugin and you can add the gatewat direclty.
Use this sniffer, then you need install all kind of packages to get it working (Node-red, mqtt etc).
Synology is based on linux, so you should able to perform most of same commands as raspberry, but i'm not complety sure.
or buy a RPI and do everything on that device..
Re: Zigbee2MQTT
Posted: Thursday 21 November 2019 17:20
by Thorgal789
You have more options. There is others plugins that can work too with NAS and zigbee.
Or like he said, use a small raspberry just with he zigbee stuff and connect to it with keeping your home application on the NAS.
Re: Zigbee2MQTT
Posted: Monday 25 November 2019 20:41
by hsluis
When I reboot the Raspberry Pi the Zigbee2MQTT plugin isn't able to communicate with the Zigbee devices, but when I make the plugin inactive and then active it works fine. I already updated the raspbian OS and the plugin, Is anyone else also experiencing this problem and is there a fix?
Re: Zigbee2MQTT
Posted: Wednesday 27 November 2019 7:22
by RichardBokker
I'm using the zigbee2mqtt sniffer now, pretty good product but:
The stability of the zigbee network is like crap now. Continounsly down. Some devices work fine, but most of them do not work fine.
I got multiple powered xiaomi 230V switches, so they should work as repeater.
i have to activate 2 or 3 230v switches through domoticz to get everything working again.
Any ideas?
Re: Zigbee2MQTT
Posted: Thursday 30 January 2020 14:01
by Jan Jansen
After some trial and error, I managed to install zigbee2mqtt and the corresponding plugin (thanks a lot to developers, it all works great). The admin panel also looks great and seems very useful. However, I can't get it running.
1. Install Node-Red (succeeded)
2. Create a Flow called "Zigbee2MQTT Admin Panel" (succeeded)
3. Settings > "Manage palette" > Install, search for and install "node-red-dashboard" (succeeded)
4. Import flow into "Zigbee2MQTT Admin Panel" flow (I got stuck on this step. Even after consulting the node-red site I can't figure it out)
Hopefully someone can guide me in the right direction.
Thanks in advance.
Re: Zigbee2MQTT
Posted: Wednesday 05 February 2020 0:42
by Phantom
Jan Jansen wrote: Thursday 30 January 2020 14:01
Thanks in advance.
What is not working?
Did you try to open the UI
http://192.168.150.139:1880/ui/
and it could be that you need to change the mqtt in and mqtt out in the subflows.
Re: Zigbee2MQTT
Posted: Thursday 13 February 2020 11:09
by Jan Jansen
@ Phantom,
After updating the plugin my problems are solved, thanks anyway for your respons
Re: Zigbee2MQTT
Posted: Thursday 13 February 2020 12:29
by pfloryann
I have an error when i trying to pair any device(xiaomi door sensor, xioami motion sensor, Ikea plug). The device is paired with succes but in domoticz logs show only this message. To be displayed the new device must be restarted the domoticz.
(Zigbee2mqtt) Device 0x00158d0001daf6e5 (0x00158d0001daf6e5) doesn't have "model" attribute, skipped
CC2531 firmware CC2531_DEFAULT_20190608 ,domoticz 4.11674, the latest zigbee2mqtt plugin for domoticz
Re: Zigbee2MQTT
Posted: Sunday 23 February 2020 17:16
by EddyG
I have zigbee2mqtt running for some time now and it is working fine.
Recently I have a few devices in my networkmap not connected to any router or coordinator anymore.
These devices are working fine and in the logging I can see that there is a linkquality.
In Graphviz they are just devices connected to nothing.
Anyone having a solution?
Re: Zigbee2MQTT
Posted: Sunday 23 February 2020 17:42
by ben53252642
EddyG wrote: Sunday 23 February 2020 17:16
are they battery operated devices?
Re: Zigbee2MQTT
Posted: Sunday 23 February 2020 20:05
by EddyG
Yes, but not all. Some battery operated devices are part of the networkmap.
Re: Zigbee2MQTT
Posted: Sunday 15 March 2020 21:31
by qwerk
Today I installed zigbee2mqtt. the first part is fast and working fine. all changes are written to mqtt on my domoticz server.
The plugin takes sometimes up to 20 seconds (no joke) to read them and apply them into domoticz.
My mosquitto daemon runs on my domoticz server. this is a raspberry 3+
I have more sensors ( esp8266) that use mosquitto to inform domoticz ( via the build in mqtt client) those are transferred to domoticz right away.
only the zigbee updates take a long time.
I use mosquitto 1.5.7
Re: Zigbee2MQTT
Posted: Tuesday 17 March 2020 1:27
by Varazir
Hello, I guess this had been answered.
I'm trying to migrate Trådfri devices from my Ikea gateway to my domoticz system. I have 2 Ikea bulbs that I never connected to the gateway that works. But I'm trying to migrate 6 spotlights and 2 normal bulbs.
Is there any guide how to do something like this?
Skickat från min EML-L29 via Tapatalk
Re: Zigbee2MQTT
Posted: Tuesday 17 March 2020 7:21
by jake
Varazir wrote:Hello, I guess this had been answered.
Search for unpair ikea tradfri on YouTube:
https://youtu.be/QiOyMY3LbOA
Click on off 6x
Re: Zigbee2MQTT
Posted: Tuesday 17 March 2020 9:03
by Varazir
jake wrote: Tuesday 17 March 2020 7:21
Click on off 6x
No reaction in the logs on my Domoticz
Re: Zigbee2MQTT
Posted: Tuesday 17 March 2020 10:22
by jake
You better first check the zigbee to mqtt log whether they show up there at all
Re: Zigbee2MQTT
Posted: Tuesday 17 March 2020 10:36
by Varazir
jake wrote: Tuesday 17 March 2020 10:22
Nothing there
http://paste.debian.net/1135241/
