Thanx...Working Now! I first didn't perform the mosquitto part!snellejellep wrote: Saturday 16 November 2019 16:53do you have authentication enabled on your mqtt server?gschmidt wrote: Saturday 16 November 2019 16:44 Hi,
I am trying to install Zigbee2MQTT on my Domoticz system (Rpi3b).
The CC2531 USB is inserted directly on the same system.
When I run the service with "npm start", I get the error "Not connected to MQTT Server"
I have attached the LOG and the configuration.yaml.
Could somebody help me out with this?
checkout my video on this topic, maby it will help you: https://www.youtube.com/watch?v=28Whi98 ... A&index=17
Zigbee2MQTT
gschmidt
Re: Zigbee2MQTT
RichardBokker
- Domoticz version: 3.9317
Re: Zigbee2MQTT
Oke, cool. THnx.snellejellep wrote: Saturday 16 November 2019 16:56the zigbee2mqtt assistant is really hard to use withoud home assistant, i am working on a video about a similar tool but then created in nodered so it can easily be used with domoticz. for now i would like to redirect you to try: https://github.com/ben423423n32j14e/zig ... adminpanelRichardBokker wrote: Friday 15 November 2019 8:38 The Zigbee2MQTT is really awesome plugin, finally getting rid of the Xiaomi Gateway crap!
Has anyone a step-by-step explaination to install the Zigbee2MqttAssistant on a rPI?
https://github.com/yllibed/Zigbee2MqttAssistant
Or should i use the Docker installation method in my sitation?
Thats new for me to, so have to figure it out.
make sure you have it running on the same machine as your mqtt server.
if you have enabled authentication you may run in to problems but that is a little hard to explain this way. i hope to make a video about it soon.
I think i should try this..?
My pi is running everything on the same system: Domoticz + MQTT + Zigbee2MQTT
opex
Re: Zigbee2MQTT
Hi, I am newbie in this forum and actually home automation area. I have Synology NAS DS216j and now wondering which is the best way to connect eg temperature sensors to Synolgy. I just installed Domoticz and saw your post.Mayki wrote: Saturday 09 February 2019 12:52 Is there anyone who uses it on Synology NAS? With CC2531 USB Sniffer? Is there any manual for Synology?
Did you manage to get CC2531 USB sniffer working in your NAS or how you are connecting devices? I would like to avoid old fashioned 433Mhz solutions and go for zigbee or BLE sensors instead.
RichardBokker
Re: Zigbee2MQTT
You got two options.
Buy an xiaomi gateway + sensors, then no need for this plugin and you can add the gatewat direclty.
Use this sniffer, then you need install all kind of packages to get it working (Node-red, mqtt etc).
Synology is based on linux, so you should able to perform most of same commands as raspberry, but i'm not complety sure.
or buy a RPI and do everything on that device..
Thorgal789
- Target OS: -
Re: Zigbee2MQTT
You have more options. There is others plugins that can work too with NAS and zigbee.
Or like he said, use a small raspberry just with he zigbee stuff and connect to it with keeping your home application on the NAS.
hsluis
Re: Zigbee2MQTT
When I reboot the Raspberry Pi the Zigbee2MQTT plugin isn't able to communicate with the Zigbee devices, but when I make the plugin inactive and then active it works fine. I already updated the raspbian OS and the plugin, Is anyone else also experiencing this problem and is there a fix?
RichardBokker
Re: Zigbee2MQTT
I'm using the zigbee2mqtt sniffer now, pretty good product but:
The stability of the zigbee network is like crap now. Continounsly down. Some devices work fine, but most of them do not work fine.
I got multiple powered xiaomi 230V switches, so they should work as repeater.
i have to activate 2 or 3 230v switches through domoticz to get everything working again.
Any ideas?
Any ideas?
Jan Jansen
- Domoticz version: Stable
Re: Zigbee2MQTT
After some trial and error, I managed to install zigbee2mqtt and the corresponding plugin (thanks a lot to developers, it all works great). The admin panel also looks great and seems very useful. However, I can't get it running.ben53252642 wrote: Wednesday 05 September 2018 4:51 Created an admin panel in Node-Red
1. Install Node-Red (succeeded)
2. Create a Flow called "Zigbee2MQTT Admin Panel" (succeeded)
3. Settings > "Manage palette" > Install, search for and install "node-red-dashboard" (succeeded)
4. Import flow into "Zigbee2MQTT Admin Panel" flow (I got stuck on this step. Even after consulting the node-red site I can't figure it out)
Hopefully someone can guide me in the right direction.
Thanks in advance.
- Phantom
- Domoticz version: 4.11652
Re: Zigbee2MQTT
What is not working?Jan Jansen wrote: Thursday 30 January 2020 14:01After some trial and error, I managed to install zigbee2mqtt and the corresponding plugin (thanks a lot to developers, it all works great). The admin panel also looks great and seems very useful. However, I can't get it running.ben53252642 wrote: Wednesday 05 September 2018 4:51 Created an admin panel in Node-Red
Thanks in advance.
Did you try to open the UI http://192.168.150.139:1880/ui/
and it could be that you need to change the mqtt in and mqtt out in the subflows.
Jan Jansen
Re: Zigbee2MQTT
After updating the plugin my problems are solved, thanks anyway for your respons@ Phantom,
pfloryann
- Domoticz version: 2026.3
Re: Zigbee2MQTT
I have an error when i trying to pair any device(xiaomi door sensor, xioami motion sensor, Ikea plug). The device is paired with succes but in domoticz logs show only this message. To be displayed the new device must be restarted the domoticz.
(Zigbee2mqtt) Device 0x00158d0001daf6e5 (0x00158d0001daf6e5) doesn't have "model" attribute, skipped
CC2531 firmware CC2531_DEFAULT_20190608 ,domoticz 4.11674, the latest zigbee2mqtt plugin for domoticz
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
Re: Zigbee2MQTT
I have zigbee2mqtt running for some time now and it is working fine.
Recently I have a few devices in my networkmap not connected to any router or coordinator anymore.
These devices are working fine and in the logging I can see that there is a linkquality.
In Graphviz they are just devices connected to nothing.
Anyone having a solution?
ben53252642
Re: Zigbee2MQTT
are they battery operated devices?EddyG wrote: Sunday 23 February 2020 17:16 I have zigbee2mqtt running for some time now and it is working fine.
Re: Zigbee2MQTT
Yes, but not all. Some battery operated devices are part of the networkmap.
qwerk
Re: Zigbee2MQTT
Today I installed zigbee2mqtt. the first part is fast and working fine. all changes are written to mqtt on my domoticz server.
The plugin takes sometimes up to 20 seconds (no joke) to read them and apply them into domoticz.
My mosquitto daemon runs on my domoticz server. this is a raspberry 3+
I have more sensors ( esp8266) that use mosquitto to inform domoticz ( via the build in mqtt client) those are transferred to domoticz right away.
only the zigbee updates take a long time.
I use mosquitto 1.5.7
- Varazir
Re: Zigbee2MQTT
Hello, I guess this had been answered.
I'm trying to migrate Trådfri devices from my Ikea gateway to my domoticz system. I have 2 Ikea bulbs that I never connected to the gateway that works. But I'm trying to migrate 6 spotlights and 2 normal bulbs.
Is there any guide how to do something like this?
Skickat från min EML-L29 via Tapatalk
jake
Re: Zigbee2MQTT
Search for unpair ikea tradfri on YouTube:Varazir wrote:Hello, I guess this had been answered.
https://youtu.be/QiOyMY3LbOA
Click on off 6x
- Varazir
Re: Zigbee2MQTT
No reaction in the logs on my Domoticzjake wrote: Tuesday 17 March 2020 7:21Search for unpair ikea tradfri on YouTube:Varazir wrote:Hello, I guess this had been answered.
Click on off 6x
jake
Re: Zigbee2MQTT
You better first check the zigbee to mqtt log whether they show up there at all
- Varazir
Re: Zigbee2MQTT
Nothing there http://paste.debian.net/1135241/jake wrote: Tuesday 17 March 2020 10:22 You better first check the zigbee to mqtt log whether they show up there at all
