Page 10 of 28
Re: Dashticz - Bug report
Posted: Thursday 24 August 2017 11:05
by MarceldeJongNL
Block parameters for multivalue blocks don't work:
blocks['222_2']['switch'] = true;
blocks['222_2']['hide_lastupdate'] = true;
blocks['222_2']['unit'] = 'x;y';
doesn't work, I can use
blocks[222]['switch'] = true;
blocks[222]['hide_lastupdate'] = true;
blocks[222]['unit'] = 'x;y';
But that logically applies to all the 222_* blocks.
blocks['222_2']['title'] = 'title';
works just fine
Posted: Thursday 24 August 2017 18:47
by dutchdevil83
robgeerts wrote: Saturday 19 August 2017 16:16
Do you mean it still shows the last update
Hi Rob, thanks for you fix! The total blocks are now fixed but i have 2 other blocks now which gives a "undefined" error. It`s the "CounterDeliv" and "CounterDelivToday" in the following Json output of my P1 energy meter:
- Spoiler: show
"ActTime" : 1503593114,
"ServerTime" : "2017-08-24 18:45:14",
"Sunrise" : "06:39",
"Sunset" : "20:42",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"Counter" : "17145.002",
"CounterDeliv" : "2346.261",
"CounterDelivToday" : "3.181 kWh",
"CounterToday" : "6.481 kWh",
"CustomImage" : 0,
"Data" : "9906088;7238914;610321;1735940;130;0",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 10,
"HardwareName" : "Toon",
"HardwareType" : "Toon Thermostat",
"HardwareTypeVal" : 34,
"HaveTimeout" : false,
"ID" : "1",
"LastUpdate" : "2017-08-24 18:43:39",
"Name" : "Elektra Meter",
"Notifications" : "false",
"PlanID" : "6",
"PlanIDs" : [ 6 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "Energy",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "P1 Smart Meter",
"TypeImg" : "counter",
"Unit" : 1,
"Usage" : "130 Watt",
"UsageDeliv" : "0 Watt",
"Used" : 1,
"XOffset" : "101",
"YOffset" : "392",
"idx" : "120"
"status" : "OK",
"title" : "Devices"
Posted: Thursday 24 August 2017 19:07
by dutchdevil83
I think i found another bug... I want to change my icons of my energy meters but the following code isn`t working:
- Spoiler: show
- //Slimme meters
blocks[29] = {} //Zonnepanelen
blocks[29]['width'] = 4;
blocks[29]['icon'] = 'fa-sun-o'; //Icon is not working
blocks[29]['title'] = 'Zon';
blocks[29]['switch'] = true;
blocks[121] = {} //Gas meter
blocks[121]['width'] = 4;
blocks[121]['title'] = '';
blocks[121]['switch'] = true;
blocks[120] = {} //Elektra meter
blocks[120]['width'] = 4;
blocks[120]['title'] = '';
blocks[120]['switch'] = false;
blocks[900] = {} //Water meter
blocks[900]['width'] = 4;
blocks[900]['icon'] = 'shower'; //Icon is not working
blocks[900]['title'] = '';
blocks[900]['switch'] = false;
It just keeps on the standard power plug icon for energy and sun and on the flame image for gas and water meters
Posted: Thursday 24 August 2017 20:59
by robgeerts
MarceldeJongNL wrote: Thursday 24 August 2017 11:05
works just fine
Should be fixed in latest beta!
dutchdevil83 wrote: Thursday 24 August 2017 18:47
- Spoiler: show
"Sunset" : "20:42",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Description" : "",
"Favorite" : 1,
"HardwareID" : 10,
"ID" : "1",
"PlanID" : "6",
"PlanIDs" : [ 6 ],
"Timers" : "false",
"Unit" : 1,
"Used" : 1,
"XOffset" : "101",
"YOffset" : "392",
"idx" : "120"
"status" : "OK",
"title" : "Devices"
This works in latest beta:
columns[1] = {};
columns[1]['blocks'] = ['120_1','120_2','120_3','120_4','120_5'];
columns[1]['width'] = 5;
dutchdevil83 wrote: Thursday 24 August 2017 19:07
- Spoiler: show
- //Slimme meters
What if you try, in latest beta:
blocks['121_1'] = {} //Gas meter
blocks['121_1']['width'] = 4;
blocks['121_1']['title'] = '';
blocks['121_1']['switch'] = true;
blocks['120_1'] = {} //Elektra meter
blocks['120_1']['width'] = 4;
blocks['120_1']['title'] = '';
blocks['120_1']['switch'] = false;
Posted: Thursday 24 August 2017 21:28
by dutchdevil83
For 120_4 /120_5:
Deliver & DeliverToday should be switched
For icon part i don`t understand what your solution is? It isn`t working now.
Posted: Thursday 24 August 2017 23:06
by robgeerts
Fixed in latest version!
What do you mean with the icon part?
Posted: Friday 25 August 2017 9:43
by dutchdevil83
robgeerts wrote: Thursday 24 August 2017 23:06
I want to use a custom icon for my energy readings from mine solar panels. If i define the fa-sun-o icon in config.js this isn`t working. Its using the default power plug icon which is (i think?) hardcoded.
For normal switches i can configure custom icon but not for my energy readings.
Is there someway you can make this possible?
Not a bug but more improvement on the language settings, i have edited the file in such way that someone can give a custom title and there is more unify between all energy readings:
- Spoiler: show
- "energy": {
"energy_delivered": "Totaal geleverd",
"energy_deliveredtoday": "Vandaag geleverd",
"energy_now": "Nu",
"energy_today": "Vandaag",
"energy_total": "Totaal",
"energy_totals": "Totaal",
"energy_usage": "Nu",
"energy_usagetoday": "Vandaag",
"gas_usagetoday": "Vandaag",
"temp_toon": "Woonkamer"
Posted: Friday 25 August 2017 11:39
by robgeerts
Ok, could you send me the part of the config.js for the icon?
(Didnt see that yet??)
Posted: Friday 25 August 2017 12:44
by gielie
Something strange is going on with my temp sensors, they all have the code 'switch' and this is the result, it was fine before.
Posted: Friday 25 August 2017 12:49
by gielie
I can't get the news feed working, it was working before.
i use this code
blocks['news_2']['feed'] = 'http://feeds.feedburner.com/tweakers/nieuws'
and this is the error i see, this is also with the Nu.nl news feed.
XMLHttpRequest cannot load
http://feeds.feedburner.com/tweakers/nieuws due to access control checks
Posted: Friday 25 August 2017 14:01
by robgeerts
try :
blocks['news_2']['feed'] = 'https://cors-anywhere.herokuapp.com/http://feeds.feedburner.com/tweakers/nieuws'
Posted: Friday 25 August 2017 14:02
by robgeerts
gielie wrote: Friday 25 August 2017 12:44
whats your config.js?
Posted: Friday 25 August 2017 15:00
by dutchdevil83
robgeerts wrote: Friday 25 August 2017 11:39
- Spoiler: show
- //Slimme meters
blocks[29]['switch'] = false;
Posted: Friday 25 August 2017 15:49
by robgeerts
Try latest beta, but use:
blocks[29]['icon'] = 'fa fa-sun-o';
Posted: Friday 25 August 2017 16:02
by lukbe
Hello I have problem with last beta Version: 3.8364 of the domoticz.
I use in domoticz script for sending temperature to the thingspeak. Script worked fine, only after last update it does not work and in the log i have error. Error: Error opening url.
Is there any solution ?
My script here:
- Spoiler: show
-- script_time_misc.lua
local sensor_name1 = 'Loznice' -- name of the sensor
local sensor_name2 = 'Venku' -- name of the sensor
local Thingspeak_API= 'xxxxx' -- your thingspeak api key
local set_time= 10 -- time in min
local m = os.date('%M')
if (m % set_time == 0) then
--print('Ubehl nastaveny cas: ' .. set_time .. ' min')
Temp_loznice, Humidity_loznice, sHumFeelsLike_loznice = otherdevices_svalues[sensor_name1]:match("([^;]+);([^;]+);([^;]+)") -- save values from the sensor in to each variable
Temp_loznice = tonumber(Temp_loznice)
Humidity_loznice = tonumber(Humidity_loznice)
Temp_venku, Humidity_venku, sHumFeelsLike_venku = otherdevices_svalues[sensor_name2]:match("([^;]+);([^;]+);([^;]+)") -- save values from the sensor in to each variable
Temp_venku = tonumber(Temp_venku)
Humidity_venku = tonumber(Humidity_venku)
-- print('Teplota - Obyvaci pokoj:' ..Temp_loznice )
--print('Vlhkost - Obyvaci pokoj:' .. Humidity_loznice)
commandArray['OpenURL']=('https://api.thingspeak.com/update?api_key='..
Thingspeak_API.. '&field1=' ..Temp_loznice.. '&field2=' ..Humidity_loznice..
'&field3='..Temp_venku..'&field4='.. Humidity_venku)
--print('Odesilani na Thingspeak')
Posted: Friday 25 August 2017 16:04
by EdwinK
lukbe wrote: Friday 25 August 2017 16:02
I think you are in the wrong part of the forum. This is about Dashticz, a add-on to Domoticz.
For bugs on Domoticz, go to
viewforum.php?f=6
Posted: Friday 25 August 2017 18:49
by dutchdevil83
robgeerts wrote: Friday 25 August 2017 15:49
Ok now it`s showing the same symbol as the gas readings (fa-fire). But no custom icon (also tried other icons but it stays on fa-fire)
Posted: Sunday 27 August 2017 20:30
by dutchdevil83
dutchdevil83 wrote: Friday 25 August 2017 18:49
Ok looked into your change in the code and figured out what went wrong. I have to specify the icon with the _1 / _2 / _3 and then it works. So "blocks[29]['icon'] = ' fa fa-sun-o'; does not work but "blocks[29_1]['icon'[ = ' fa fa-sun-o'; does work. Here the working code:
//Slimme meters
blocks[29]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks[29]['icon'] = 'fa fa-sun-o'; //Dit werkt niet (specificeren als 29_1 29_2 & 29_3)
blocks['29_1'] = {} //Zonnepanelen Nu
blocks['29_1']['icon'] = 'fa fa-sun-o';
blocks['29_2'] = {} //Zonnepanelen Vandaag
blocks['29_2']['icon'] = 'fa fa-sun-o';
blocks['29_3'] = {} //Zonnepanelen Totaal
blocks['29_3']['icon'] = 'fa fa-sun-o';
Posted: Tuesday 29 August 2017 13:14
by gielie
robgeerts wrote: Friday 25 August 2017 14:02
This is my code for the 4 temp sensors.
blocks[304] = {} //Toon huiskamer temp
blocks[304]['switch'] = true
blocks[304]['width'] = 3
blocks[47] = {} //badkamer temp/hum
blocks[47]['switch'] = true
blocks[47]['width'] = 3
blocks[383] = {} //Temp buiten
blocks[383]['switch'] = true
blocks[383]['width'] = 3
blocks[605] = {} //Washok
blocks[605]['switch'] = true
blocks[605]['title'] = 'Washok'
blocks[605]['width'] = 3
When i remove the switch command at huiskamer and buiten it works, but the other 2 doesn't, it did work some time ago.
I think it has something to do with the type of sensor, the 2 with the reversed data/text also have a hum sensor, so in my config i put '47_1' and 47_2 for temp and hum, but i don't use the hum data. I tried to change the blocks info to blocks[47_1]['switch'] = true but this doesn't work.
The thing i never got to work is my Toon thermostaat to switch title/data, how can i do this, the simple [blocks]['switch'] = true doesn't work
Posted: Tuesday 29 August 2017 13:27
by gielie
robgeerts wrote: Friday 25 August 2017 14:01
try :
For tweakers it works but for nu.nl it doesn't and i figured how it does work.
For nu.nl i took out the feeds.feedburner and it works, i don't know why.
