Dashticz - Module - Calendar
Derik
Re: Dashticz - Module - Calendar
Post by Derik »
my calendar give the wrong format...
First the end time...
And then the start
Hope some one get......
gielie
Domoticz version: latest β
Post by gielie »
When i have a recurrent appointment on a weekly base, i get 2 strings with the same info.
The first one is recurrent every week form 20.00 - 22.30
the second is only one item, here the date and time is correct
the third is also recurrent every week from 19.30 - 21:30
What is going wrong?
btw this is an apple iCloud calendar
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Currently i'm fixing the recurring events... stay tuned, hopefully this will be ready tomorrow!
robgeerts
Post by robgeerts »
Could you please test latest beta?
I've changed the calendar script. Recurring is working correct for me now.
Trigun
Domoticz version: 4.10717
Post by Trigun »
Sounds great Rob! Will test it asap. Cheers!
Derik
Post by Derik »
did replace:[ the file changes on github ]
main.js
calendar.js
.gitignore
Now the calendar hangs, keep loading.
Do i need to change more?
htilburgs
Post by htilburgs »
Please update complete, not just files.
Download, extract and overwrite your current installation (make sure you make back-up of your \dashticz\custom directory)
Or do a git pull to update
Hardware:
robgeerts
Post by robgeerts »
Derik wrote:did replace:[ the file changes on github ]
main.js
calendar.js
.gitignore
Could you refresh to check if it loads now?
Derik
Post by Derik »
did replace all files and set back my custom
Still hangs
robgeerts
Post by robgeerts »
Maybe a hard refresh, pressing CTRL and F5 at the same time on windows.
Tried it with your calender (wich you've sent through email) and that works fine....
Derik
Post by Derik »
mm
That did the trick,,,, [ did not now that ]
Time settings are now ok.
Only see not all day and week events...
robgeerts
Post by robgeerts »
What if you increase 'maxitems' in config.js ?
Derik
Post by Derik »
set it to 10 and 12 in stead of 6.
ctrl F5 make no different
Strange part. the line that are visible stays on 4 for lines
See some day event and some not week events not @all.
take a look with my calendar
robgeerts
Post by robgeerts »
Wich event you dont see?
Derik
Post by Derik »
kirsty jarig [ thursday event every year ]
ryan whole week event
stuffer
Domoticz version: 3.6367
Post by stuffer »
Hi Rob and all,
I have the same weird thing as above:
var _ICALENDAR_DATEFORMAT     = 'DD/MM/YYYY HH:mm';
var _ICALENDAR_LOCALE         = 'nl_NL'; //en,hu, etc.
var calendars = {}
var calendars = {}
calendars.prive = {width:12, maxitems: 20, url: url: 'https://calendar.google.com/calendar/em ... /Amsterdam', icalurl: 'https://calendar.google.com/calendar/ic ... /basic.ics'}
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big','weather','calendars.prive']
columns[2]['width'] = 5;
All the recurrent work items are not shown and the birtday's are almost there (My own birthday is not displayed :?: )
Between the red lines there is an vacation (2 weeks, all day events) that is not in place.
This is on the latest Beta branch (Gitcloned today)
I hope that you can do something about it.
For the rest, keep up the good work! I love dashticz!
Derik
Post by Derik »
Dear...
Are there more people that cannot see the weekly and whole day events???
Did see them for 2 days...
Now they are not visible any more... grrr
Hope there is some support//
MsbS
Post by MsbS »
My calendar had mostly recurring events, and now I only see three instances of one annual event (March 2018, 2019 and 2020).
Maybe it is something to do with sorting (selecting the upcoming events)?
Derik
Post by Derik »
the strange part/....
One day is see ore recurring events and the other day not..
jake
Post by jake »
I have 3 Google calendars and all show their info on the dashboard. Events that are in the past are also erased from the dashboard. So far so good.
The problem is that the calendars don't refresh with new information. Only when I go into the Android settings for apps and I delete there the cache of the Chrome browser, the dashboard will download fresh information from the calendar. After it downloads the up to date info, the problem continues when information in the Google agenda is added or altered.
