Dashticz - Feature Requests
Locked
robgeerts
Domoticz version: 3.7067
Re: Dashticz - Feature Requests
Post by robgeerts »
garethhowell wrote:Ability to vary the column layout depending on the display device.
My dashboard is a pretty standard 5,5,2 column layout with the main switches and scenes in the middle column. This makes sense on a tablet display, but not on a phone.
What I'd like to be able to do is present column 2 first if the display device is less that a certain width.
Check!
http://www.domoticz.com/forum/viewtopic ... 67&t=18517
garethhowell
Domoticz version: 3.9317
Post by garethhowell »
Excellent. Thanks, Rob; I'll try it this evening.
ztorm
Domoticz version: 3.8153
Post by ztorm »
Is it possible to get some blank space between the last block of a group and a blocktitle? Just like half a blocktitle or something like that.
BTW: great work! Really love dashticz!
benbammens
Post by benbammens »
Would it be possible to add the graphs from Buienalarm.be instead of the buienradar map?
freakshock
Post by freakshock »
Hi Rob,
In the Show your dashboard topic you said you might work on a feature to increase the size of the media player buttons.
Any update on this? Would love this feature since clicking the buttons is really hard on my 10" wall mounted tablet, takes like 10x to get a song to pause :lol:
EDIT: Figured out myself how to do this with CSS.
Add to custom.css (and change amount of pixels to preference):
/* logitech media buttons */
.fa.fa-arrow-circle-left.fa-small {
    font-size: 50px !important;
.fa.fa-stop-circle.fa-small {
.fa.fa-play-circle.fa-small {
.fa.fa-arrow-circle-right.fa-small {
.fa.fa-pause-circle.fa-small {
freakshock
benbammens wrote:Would it be possible to add the graphs from Buienalarm.be instead of the buienradar map?
Not exactly what you want, but what I did is create a popup with a buienalarm graph when the buienradar image is clicked on:
Using this code (change the lat & lon):
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.buienalarm.nl/widget/graphic?lat=xx&lon=xx&title=Amsterdam%20BOLO&color=4395c7'}
Found this info here, dont know if it also works for Belgium.
benbammens
Thank you, but I had it already set up that way :)
robgeerts
Post by robgeerts »
I didnt, so thanks freakshock!
EdwinK
Post by EdwinK »
Yes, thanks Freakshock.
Steven84
Re: Dashticz - Feature Requests HEOS by DENON
Post by Steven84 »
Is it possible to add this functionality in the dash: https://github.com/cold-logic/heos-controller?
robgeerts
Post by robgeerts »
Dont you get any other media buttons now?
MarceldeJongNL
Domoticz version: 3.5108
Post by MarceldeJongNL »
Could you add Subtype 'Voltage' ?
json:
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "230.000 V",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 12,
         "HardwareName" : "APC",
         "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
         "HardwareTypeVal" : 15,
         "HaveTimeout" : false,
         "ID" : "00082438",
         "LastUpdate" : "2017-08-24 14:43:01",
         "Name" : "UPS Volt",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "Voltage",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "current",
         "Unit" : 1,
         "Used" : 1,
         "Voltage" : 230.0,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "438"
Hardware: Raspberry Pi 2B | RFXCOM RFXtrx433E v1 | Synology DS213+ | KaKu Clones | Conrad RSL switches | KAKu Doorbell Clone | USB Webcam | ICY Thermostat | Resol DL2 | Imatic Relay Board | Eminent 6230 | Eminent 6220 | iMatic 16 ports Relay Board
robgeerts
Post by robgeerts »
MarceldeJongNL wrote: Thursday 24 August 2017 14:47 Could you add Subtype 'Voltage' ?
json:
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 12,
         "ID" : "00082438",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Timers" : "false",
         "Type" : "General",
         "Unit" : 1,
         "Used" : 1,
         "Voltage" : 230.0,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "438"
Check latest beta!
MarceldeJongNL
robgeerts wrote: Thursday 24 August 2017 21:02
Check latest beta!
Working! Thanks!
gielie
Domoticz version: latest β
Post by gielie »
I use buttons for the selector switch in stead of the dropdown menu but the font is too large, how can i change the font size?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
robgeerts
Post by robgeerts »
Isn't it better to change the width of the block to 4/6/8/ ?
MarceldeJongNL
Another option I would love:
the possibility to add a link to a block.
For example, I have some blocks that show the ping time to specific network devices.
It would be great if a click on a block would open the management page.
blocks[202] = {} // Ping Esx
blocks[202]['width'] = 3;
blocks[202]['icon'] = 'fa-server';
blocks[202]['title'] = 'ESX';
blocks[202]['link'] = 'http://ESX_URL';
blocks[202]['link_target'] = 'iframe'; // iframe, tab, window
robgeerts
Post by robgeerts »
in latest version (BETA), this will work:
blocks[97] = {};
blocks[97]['link'] = 'http://www.nu.nl';
blocks[97]['target'] = 'iframe'; // iframe, _blank
Its not possible to configurate whether it will open in a tab or separate window..
If window stays blank, it's forbidden to include the website in an iframe, you will have to use _blank
MarceldeJongNL
Is there anything that you can't do?? Great, thanks! Beer money is on it's way
robgeerts
Post by robgeerts »
Thanks @MarceldeJongNL !
Locked
