Cheap chinese z-wave products
LouiS22
Re: Cheap chinese z-wave products
Post by LouiS22 »
Derik wrote:cannot set my Xiaomi coolcam motion ..
The sensuality level stays on 2..
what i try, i cannot set it on 3 or 4..?
There's no Xiaomi coolcam. Are you referring to NEO COOLCAM? (Once again: Xiaomi is not into Z-wave).
geezerrr
Post by geezerrr »
My bad... I'm talking about the Neo one...
Hedda
Post by Hedda »
How can we tell if these Neo devices are really based on 500 series chips and uses Z-Wave+ protocol?
http://www.pepper1.net/zwavedb/?sort=na ... ric_class=
I know that "Z-Wave Plus" (500 series) controllers are fully backwards compatible, but I only want "Z-Wave+" devices.
Reason for this is that mixing 300 series and 500 series devices then the mesh old/low encryption.
Just want to be sure that these Neo devices don't use 300 series chips that dont support "Z-Wave+".
LouiS22
Post by LouiS22 »
Hedda wrote:How can we tell if these Neo devices are really based on 500 series chips and uses Z-Wave+ protocol?
They're 500 and you'll see that once you add them to your network.
geezerrr
Post by geezerrr »
See for yourself Image
Derik
Post by Derik »
geezerrr wrote:My bad... I'm talking about the Neo one...
Sorry me too..
Justintime
Post by Justintime »
Received my neocoolcam powerplug today.
Good quality... Reacts direct. Very happy with it.
Derik
Post by Derik »
This i my Carport sensor:
Cannot set the other 3 groups:
And cannot set the 2 to 3 or 4: [ chapter 1 ]
Perhaps a update for OpenZwave perhaps necessary ?
lost
Post by lost »
Well, just got my neo coolcam from 11/11 aliexpress discount and... That's OK on the plugs side, not on the PIR one: After inclusion, both modules were seen as ID=0x0000 & TYPE=0x0000. From z-wave nodes, they didn't looked to be fully included as well (no link in network topology to controller or any other included device). As they had included automagically when setting the batteries, i.e without pressing 3 times on the inside button after setting controller in inclusion mode, I had doubts...
So tried to exclude them, factory reset, then reinclude: Exact same problem.
My controller is a z-stick gen 5, OK with every other devices... Any suggestion?
I think that if they sent non EU frequencies, the devices would not be seen at all: Nothing on the package/devices shows device type (US/EU)...
lost
Post by lost »
Well, we'll get a refund for neo coolcam PIRs... 2 z-wave power plugs were also received & OK... so I confirmed command OK on this side but one just failed tonight & I think for this one after confirmation I'm just over for a reclaim.
I think this will be my first & last direct order from China!
As they say: Buy Chinese = buy two times... But on my side, it's 3 items of 4 that does not work. And maybe tomorrow will be another fail for last one!
salvation
Post by salvation »
Hmm... the same for me, I also tried to set 12 and 14 instead of 2 and 4 which the sensor takes.. only not seeing any difference in sensitivity.
For parameter 9. Basic Set Level: (lux) (huidig: 100)
It looks like it doesn't accept any other value than 100.. which is to much for my situations.
Any one else have the same?
If so we can better start a new topic for this..
I have the same problem. Did you find a solution already?
zalsson
Post by zalsson »
Need som help my coolcam pir motion senor, just get ID 0x0000 Type 0x0000 status Sleep
Feels like something isnt right ;)
how do i add the configuration xml file to the coolcam pir motion sensor.
dgonneau
Post by dgonneau »
zalsson wrote:Need som help my coolcam pir motion senor, just get ID 0x0000 Type 0x0000 status Sleep
Same problem here with door sensor.
Haven't received the PIR yet but the only working neo Coolcam device is the power plug.
booster
Post by booster »
I also received my set of NEO motion sensors and door sensors, orderred on Black Friday. They all got recognized fine.
I'm running latest build and have a zwave aeotec s2 stick (non plus)
I had to use the sync button on the devices to get the devices identified correctly - with pluggin in the battery, they got somehow recognized, but the devices were not updating in Domoticz. After including them again, they worked.
still need to assign names though, but still deciding where i'm gonna place/use them ;)
Connected to:
-Pi3; Aeon Labs Z-Stick; Fibaro Switches, Roller Shutter and Motion Sensors; Qubino Dimmers; P1 Port + Youless, MiLight; HUE Bridge; Forest shuttle Z-Wave; RFLink + KAKU; Voltcraft CO20; Everspring floodsensors; GreenWave PN-6; NEO Sensors
booster
Post by booster »
just one weird thing with the motion sensors:
when activity is detected a whole bunch of devices get triggered in Domoticz... I just want the sensor to be updated, as i'm not using it for security purposes..more for motion based activity scenarios. I can ofcourse just ignore, but wonder why it's behaving this way.
anyone has any ideas/tips on this?
Connected to:
zalsson
Post by zalsson »
Got my working now, buy removing and adding it in the interface inserted of the buttons.
Skickat från min A0001 via Tapatalk
nieass4
Domoticz version: 2024.7
Post by nieass4 »
I recently recieved my Neo Coolcam Sensors.
5 door/window sensors
8 power plugs
1 flood sensor
1 siren alarm
They are working great so far but the signal doesn't reach that far (with all these sensors together the mesh network looks pretty fine though).
One of the power plugs doesn't seem to work by the way, got it paired but after that it's not working at all and no options to hard reset the plug.
Have to get a new one for that.
I didn't include the siren alarm yet because there is no xml file for it yet and I'm pretty new to domoticz.
Anyone else here also got the siren alarm and created a xml file for it yet?
LouiS22
Post by LouiS22 »
nieass4 wrote:I recently recieved my Neo Coolcam Sensors.
8 power plugs
1 flood sensor
1 siren alarm
Congratulations on your purchase.
The xml file has nothing to do with Domoticz, you have to create and submit into openzwave github (they have a how to manual). The needed info can be obtained from pepper1 database or from the users manual. ;)
lost
Post by lost »
zalsson wrote:Got my working now, buy removing and adding it in the interface inserted of the buttons.
I had the same pb with 2 PIRs : IDs = 0000.
Indeed, the led triggers when some motion is detected so they are only failed on the z-wave side.
As said hereupper I already tried to exclude them/factory reset (long press of internal associate button)/reinclude. No way, still IDs at 0000.
At first, they were included on battery insertion (I have a z-stick gen 5 as a controller and I already set it in pairing mode before plugging the battery, so it flashing & presumed this was OK). I already thinked this may have been a problem (as another user hereupper) & tried re-association.
But no way!
So, what's the exact procedure you followed?
zalsson
Post by zalsson »
Added them by pushing button z-stick gen5, got id 0*0000 tried removing by push button twice. Didn't work, removed the pir/device in control panel, then I added it again true the control panel / add device.
