Page 90 of 123
Posted: Saturday 19 August 2017 16:33
by islandman
corbin wrote: Saturday 19 August 2017 4:47 Thanks, I've submitted the changes to be included in the main beta, there is a problem compiling but I don't think it is related to my changes.
Also if it does get added to the beta, existing wall switches will need to be deleted and re-added in Domoticz due to the new unit codes being used.
Great Job, re-added my 12 Switches :roll: and also my single Wall Switches with neutral are working now!!!! :mrgreen:
Posted: Monday 21 August 2017 15:04
by pandemicz
Guys, I'm a little confused with all the switches :oops: Just to be sure, is there solution for Wireless Two-Button Switch LEFT click problem with 149 firmware in latest build or we all suppose to wait for an update from Xiaomi?
Posted: Monday 21 August 2017 18:13
by deennoo
pandemicz wrote:Guys, I'm a little confused with all the switches :oops: Just to be sure, is there solution for Wireless Two-Button Switch LEFT click problem with 149 firmware in latest build or we all suppose to wait for an update from Xiaomi?
You have to wait about a Fw update, that not à domoticz problème.
Posted: Tuesday 22 August 2017 16:31
by Luigi87
I have just ordered the Xiaomi Gateway. But it seems the gateway has an AU plug. Is there an EU plug?
Of do you have to put allways an adapter between the Power plug/ and the power socket?
Posted: Tuesday 22 August 2017 16:46
by pandemicz
Luigi87 wrote: Tuesday 22 August 2017 16:31 I have just ordered the Xiaomi Gateway. But it seems the gateway has an AU plug. Is there an EU plug?
Yes, we have to put an adapter, there's only Chinese version available.
Posted: Wednesday 23 August 2017 0:51
by Pyros
Hello
Just bought that new model of XIAOMI (EDIT) ceiling : https://www.gearbest.com/flush-ceiling- ... 33589.html
Unfortunatly, it's no more seen in yeelight app but in smart home only.
Since it's not a device managed by the gateway nor a pure yeelight device, it's not visible in domoticz.
Any advice to manage it ?
thx
Posted: Wednesday 23 August 2017 7:45
by deennoo
Pyros wrote:Hello
Just bought that new model of yeelight ceiling : https://www.gearbest.com/flush-ceiling- ... 33589.html
thx
Where have you read that à yeelight device ? That à Philips One...once again search about product before buy a price...now you have :
- to search some source (i already give some)
- dévelop à python plugin for this, (thanks you)
Posted: Wednesday 23 August 2017 9:53
by pandemicz
Pyros wrote: Wednesday 23 August 2017 0:51 Hello
thx
Been there, bought xioami philips table lamp once, thought it's compatible with yeelight, unfortunately no developer gateway for xiaomi-philips products :(
Posted: Wednesday 23 August 2017 15:11
by Pyros
deennoo wrote: Wednesday 23 August 2017 7:45 Where have you read that à yeelight device ? That à Philips One...once again search about product before buy a price...now you have :
Some guys worked on it : https://github.com/aholstenson/miio/issues/57
I've just succeded with light on/light off the ceiling with miio.
So next step is to work on domoticz plugin with those informations
Posted: Wednesday 23 August 2017 15:30
by Mozart
Pyros wrote: Wednesday 23 August 2017 15:11
A priori y a du monde qui bosse dessus : https://github.com/aholstenson/miio/issues/57 et qui a trouvé des infos.
Je vais regarder coté plugin mais je risque d'être léger en niveau
Please use english in this forum so everyone can understand what you say.
Posted: Wednesday 23 August 2017 22:04
by snuiter
So I installed some Xiaomi stuff, like the gateway, a switch button and some other devices, all are working pretty good. My question is now how can i control the coloring of the gateway light in my script I have tried a couple of things. I want to change color on specific occassions.
Any suggestions as I want to change the colors of the gateway light via a script?
Posted: Wednesday 23 August 2017 22:44
by hekm77
snuiter wrote: Wednesday 23 August 2017 22:04 So I installed some Xiaomi stuff, like the gateway, a switch button and some other devices, all are working pretty good. My question is now how can i control the coloring of the gateway light in my script I have tried a couple of things. I want to change color on specific occassions.
Xiaomi Gateway Light Scenes
http://4pda.ru/forum/index.php?act=find ... 60482495-2
Posted: Thursday 24 August 2017 9:57
by snuiter
Had to analyze the script and play with it to understand how it worked. But it does. Thanks hekm77!
Posted: Thursday 24 August 2017 11:43
by hekm77
snuiter wrote: Thursday 24 August 2017 9:57 Had to analyze the script and play with it to understand how it worked. But it does. Thanks hekm77!
Create a dummy selector switch with levels
Posted: Thursday 24 August 2017 19:36
by xraken
Hello, I tried to follow the instructions from the Wiki https://www.domoticz.com/wiki/Xiaomi_Ga ... ateway_MP3 to make the gateway playback a recorded message using a dimmer control from Domoticz. I am not getting any sound from the gateway though when I move the slider. I do see the log messages corresponding to the script so I know the script is firing off the command to play back "10001", "10002" etc.. Has anyone got this to work and if yes please help.
I am able to change the ringtone etc. to the recorded message via the Xiaomi App so I know that the recording is on the gateway.
Posted: Friday 25 August 2017 20:39
by xbox2610
Hi everyone i would like to ask if xiaomi smart plug (zigbee) works with Domoticz?
Posted: Friday 25 August 2017 22:00
by deennoo
xbox2610 wrote:Hi everyone i would like to ask if xiaomi smart plug (zigbee) works with Domoticz?
Yes it is using last stable
Posted: Friday 25 August 2017 22:47
by xbox2610
Thank
Posted: Sunday 27 August 2017 8:35
by mikeoo
I am using the Xiaomi Smart Home Gateway 2 now for a while with door sensors and temp sensors. I notice then the updates on the dashboard are not always the latest.
When i open Domoticz you see the date and time when the sensor is last seen. Some temp sensors are correct and one is 30 min behind. The happens random with them. But when I open the chart I the time is correct.
Anyone have a explanation for it.
Posted: Sunday 27 August 2017 14:09
by xbox2610
Hi all, I have a few days restarted domoticz + homebridge + mqtt + broadlink and it all works well apart from the gateway functionality (sound effects + RGB light) and xiaomi smart plug somebody to the same problem?
Thank you
