Posted: Tuesday 15 August 2017 14:44
I have few double-button wireless switches - left click is not working after 149 update on gateway. So I confirm that - fix needed.
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
@corbin Looking forward to use my neutral line switches as well, how can I help? New to this!corbin wrote: Thursday 17 August 2017 11:12 Waiting on some testing done for https://github.com/corbinmunce/domoticz
code is slightly modified to make the new neutral line switches easier to add in
Any update on this, glad i did not update yet.pandemicz wrote: Tuesday 15 August 2017 14:44 I have few double-button wireless switches - left click is not working after 149 update on gateway. So I confirm that - fix needed.
They change the Order in order to be able to use the new square button.quack3d wrote: Thursday 17 August 2017 17:51 I see now that my wireless button (the old circular one) Double Click is reported as Long Click and Long Click is reported as Long Click Release - Double Click. Is that the same bug you guys have been talking about the last few days?
Excellent. Thanks a bunch.islandman wrote: Thursday 17 August 2017 19:30 They change the Order in order to be able to use the new square button.
The new sequence is off, click, double click, long click and long release.
Yours will be different, just reorder them using the arrows at the end of the level name.
Couple of clicks and you're done.
Don't forget to save the new sequence.
What about "Xiaomi Wireless Singl Wall Switch"? It seams that it stopped processing data from it. At least it used to work but now I cant get even event in log. Ive tried to remove it and add it again but no reaction from domoticz side. I do see click events in Mi Home logislandman wrote: Thursday 17 August 2017 19:30They change the Order in order to be able to use the new square button.quack3d wrote: Thursday 17 August 2017 17:51 I see now that my wireless button (the old circular one) Double Click is reported as Long Click and Long Click is reported as Long Click Release - Double Click. Is that the same bug you guys have been talking about the last few days?
Can you enable message output for the gateway, and report back what you see when pressing the switch? egislandman wrote: Thursday 17 August 2017 15:38 @corbin Looking forward to use my neutral line switches as well, how can I help? New to this!
2017-08-18 08:55:05.463 {"cmd":"report","model":"ctrl_neutral1","sid":"158d0001d5c914","short_id":4343,"data":"{\"channel_0\":\"on\"}" }
I only see this:corbin wrote: Friday 18 August 2017 0:56Can you enable message output for the gateway, and report back what you see when pressing the switch? egislandman wrote: Thursday 17 August 2017 15:38 @corbin Looking forward to use my neutral line switches as well, how can I help? New to this!Code: Select all
2017-08-17 22:06:20.870 XiaomiGateway: unhandled model: ctrl_ln1
2017-08-17 22:06:23.649 XiaomiGateway: unhandled model: ctrl_ln1Did you update the Gateway to 149 recently? If so this caused the single wall Switch not to work anymore also the double button left switch stopped working.bublikOff wrote: Friday 18 August 2017 0:04What about "Xiaomi Wireless Singl Wall Switch"? It seams that it stopped processing data from it. At least it used to work but now I cant get even event in log. Ive tried to remove it and add it again but no reaction from domoticz side. I do see click events in Mi Home logislandman wrote: Thursday 17 August 2017 19:30They change the Order in order to be able to use the new square button.quack3d wrote: Thursday 17 August 2017 17:51 I see now that my wireless button (the old circular one) Double Click is reported as Long Click and Long Click is reported as Long Click Release - Double Click. Is that the same bug you guys have been talking about the last few days?
Thanks, that should be enough to add the devices, assuming they work the same as the existing neutral line wall switches.islandman wrote: Friday 18 August 2017 4:10 I only see this:
How can i switch on message output?Code: Select all
2017-08-17 22:06:20.870 XiaomiGateway: unhandled model: ctrl_ln1 2017-08-17 22:06:23.649 XiaomiGateway: unhandled model: ctrl_ln1
okay, after some ups and downs, it worked. But the best thing, the neutral line Switch are working, great work @corbincorbin wrote: Friday 18 August 2017 5:04 after someone that has the switches has tested it and confirms it is working. I don't have these switches setup to test.
Great Job. Do we have to just to Re-add the wall switches for inside the wall, or also the one flat ones for on the wall?corbin wrote: Saturday 19 August 2017 4:47 Thanks, I've submitted the changes to be included in the main beta, there is a problem compiling but I don't think it is related to my changes.
Also if it does get added to the beta, existing wall switches will need to be deleted and re-added in Domoticz due to the new unit codes being used.
