Madomo wrote: Wednesday 05 February 2020 18:17
If I install Domotics without python on my synology DS715, it works.
On the other hand, if I install the package with python, the launching tries to be done then fails.
I requested assistance from Synology which (of course) let me know that no assistance was planned for non synology packages.
The only indication at my disposal is the log:
2020-02-05 17:51:30.374 Status: Domoticz V4.10717 (c)2012-2019 GizMoCuz
2020-02-05 17:51:30.374 Status: Build Hash: b38b49e-modified, Date: 2019-05-09 13:04:08
2020-02-05 17:51:30.374 Status: Startup Path: /usr/local/domoticz/
2020-02-05 17:51:30.562 Error: Domoticz(pid:20930, tid:20930('domoticz')) received fatal signal 6 (Aborted)
2020-02-05 17:51:30.562 Error: siginfo address=0x51c2, address=0x76524fe8
2020-02-05 17:51:30.567 Error: Failed to start gdb, will use backtrace() for printing stack frame
2020-02-05 17:51:30.568 Error: #0 /usr/local/domoticz/bin/domoticz() [0x2549c2]
2020-02-05 17:51:30.568 Error: #1 /usr/local/domoticz/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x22d [0x255256]
2020-02-05 17:51:30.568 Error: #2 /lib/libc.so.6 : __default_rt_sa_restorer + 0 [0x76524e80]
2020-02-05 17:51:30.568 Error: #3 /lib/libc.so.6 : gsignal + 0x34 [0x76523c54]
2020-02-05 18:05:59.646 Status: Domoticz V4.10717 (c)2012-2019 GizMoCuz
2020-02-05 18:05:59.646 Status: Build Hash: b38b49e-modified, Date: 2019-05-09 13:04:08
2020-02-05 18:05:59.646 Status: Startup Path: /usr/local/domoticz/
2020-02-05 18:05:59.696 Error: Domoticz(pid:27792, tid:27792('domoticz')) received fatal signal 6 (Aborted)
2020-02-05 18:05:59.696 Error: siginfo address=0x6c90, address=0x76594fe8
2020-02-05 18:05:59.701 Error: Failed to start gdb, will use backtrace() for printing stack frame
2020-02-05 18:05:59.701 Error: #0 /usr/local/domoticz/bin/domoticz() [0x2549c2]
2020-02-05 18:05:59.702 Error: #1 /usr/local/domoticz/bin/domoticz : signal_handler(int, siginfo_t*, void*) + 0x22d [0x255256]
2020-02-05 18:05:59.702 Error: #2 /lib/libc.so.6 : __default_rt_sa_restorer + 0 [0x76594e80]
2020-02-05 18:05:59.702 Error: #3 /lib/libc.so.6 : gsignal + 0x34 [0x76593c54]
If someone could help me, I've been looking for several months.
Thank you in advance.
