suborb
Post by suborb »
The order of the actions changed to support the square button, so you'll need to edit the switch and change the order.
The new order is: Off, Click, Double Click, Long Click, Long Click Release
Revers59
Post by Revers59 »
suborb wrote:The order of the actions changed to support the square button, so you'll need to edit the switch and change the order.
Hey ! thanks suborb !
theo69
Domoticz version: la. beta
Post by theo69 »
Also thanks, however long click is not working. Anybody able to see this button in homebridge like this:
Love my Xiaomi Gateway in connection with homebridge and domoticz on my PI3
Xiaomi Gateway Domoticz Wiki
snuiter
Post by snuiter »
Hi theo69,
guess you need a different shaped button ;)
"The order of the actions changed to support the square button"
I guess the mi cube is meant
Cheers,
Ivo
theo69
Post by theo69 »
snuiter wrote:Hi theo69,
Cheers,
Ivo
Just look at the image, (never mind the button style) how can i get the aquara button act like a button in homebridge?
theo69
Post by theo69 »
Cheers,
Ivo
Ando also, no I do have the square button but only single and double click is working
StefanoA
Post by StefanoA »
AQARA AC-CONTROLLER
http://www.mi.com/ac-controller/
I just bought one of this to control AC unit in my bedroom
Documentation is (as always) mostly in chinese and not very complete
I only found this pdf https://files.xiaomi-mi.com/files/aqara ... tka-EN.pdf
I tested only briefly the unit, and my understanding is as follows:
  • basically looks like another kind of xiaomi zigbee gateway
  • it has passing input-output power plugs (big size 16amps) to measure AC consumption
  • it has also receiving/emitting IR section to learn and control AC units by infrared
  • pairing, communication, control of subdevices (temp&humid, motion sensor, switch) seems exactly as gateway
  • also has a speaker for messages and radio/music
  • automation / scenes / management looks very very similar to gateway's one
I tried to add a temp&humid sensor previously connected to my gateway and it went well but sensor was disconnected from gateway (cannot be used by both devices at the same time I guess)
I think this new kind of gateway could be easily added and managed by domoticz,
I would be happy to help with logs and testing if useful :D
Emtec
Post by Emtec »
StefanoA wrote:AQARA AC-CONTROLLER
Interesting device. Again we have two types of devices, one round shaped with Mi branding and square shaped one with Aqara branding.
Just wondering if it could be added as sub-device on existing smarthub using just zigbee, but right now it is not available in subdevice menu.
Anyway most important thing is to get support for this device in domoticz, then you can create yours rules based on different sensors inputs.
warmaniac
Post by warmaniac »
Is some way to count Atmospheric pressure in Domoticz in hPa/kPa units ? Now is supported Xiaomi Aqara Temperature sensor , and it is showing units in bar , but if I want to show it in kPa , I think it must be counted from height about sea level .
Emtec
Post by Emtec »
warmaniac wrote:Is some way to count Atmospheric pressure in Domoticz in hPa/kPa units ? Now is supported Xiaomi Aqara Temperature sensor , and it is showing units in bar , but if I want to show it in kPa , I think it must be counted from height about sea level .
977 bar is very very High pressure :)
I assume real pressure is 977 kPa. You have wrong units for sure. Just use kPa instead.
warmaniac
Post by warmaniac »
You were right , but it is set by domoticz after adding to devices , it is I think bug, or not developed yet.
Derik
Post by Derik »
Dear,
See in my log:
017-07-30 09:57:40.277 (ESP-1xx: Dummy) General/Custom Sensor (ESP: Tuin links)
2017-07-30 09:57:41.825 (D.M.: RFXcomE) Temp (Garage)
2017-07-30 09:57:42.428 XiaomiGateway: unhandled model: weather.v1
2017-07-30 09:57:42.430 XiaomiGateway: unhandled model: weather.v1
2017-07-30 09:57:42.466 XiaomiGateway: unhandled model: weather.v1
2017-07-30 09:57:42.748 (D.M.: P1) P1 Smart Meter (D.M. P1: Stroom)
I did try to learn this sensor:
http://www.ebay.com/itm/Original-Xiaomi ... SwKFRZdvAf
Is this sensor perhaps working?
Or how can i remove this sensr from the bridge?
Because i see the sensor not on my android app....?
mikeoo
Post by mikeoo »
Derik wrote:Dear,
See in my log:
I am using the same sensor and it is working without errors.
You first need to add the sensor in the Mi App (Choose Aqara one) and then it will show in Domoticz.
Try to remove the senor in Domoticz and add it again. Still errors, try to remove it also in de Mi App and add it again and then again in Domoticz.
You will need to run Domoticz Beta latest version for working.
p.s Sensor is very expense there. Try Banggood or other one for much beter price.
tuspam
Post by tuspam »
Hi, i got problem with "blocky" and xiaomi switch. When i set for example turn on light when press "Long Click" and another rule dimm light when press "Long Click Release" then domoticz execute both commands - probably for blocky "Long Click" and "Long Click Release" it's thats same.
PS. there is already an option to turn on/off radio via domoticz?
Please help.
theo69
Post by theo69 »
Is there a plan to integrate the alarm system from xiaomi into domoticz?
DannyElfman
Domoticz version: 3.8136
Post by DannyElfman »
theo69 wrote: Did anybody try the new motion sensor with LUX Sensor?motion sensor LUX
I did (with the latest stable) and no luck so far (but I knew it :) )
XiaomiGateway: unhandled model: sensor_motion.aq2
Bought that one because I "need" lux detection so the first version is useless to me :)
Debian Jessie VM on EsxI on a Gen 8 Proliant + RFXCom + AeonLabs Zwave+ + Fibaro eye + Fibaro Smoke + Fibaro FGS211 Philips Hue + Harmony Hub + Somfy RTS + Oregon Temp sensors + Xiaomi Gateway + Xiaomi sensors + Sonoff basic
salvacalatayud
Post by salvacalatayud »
I've got one of this, but I can't find a way to enable developer mode.
Enviado desde mi Lenovo K3 Note mediante Tapatalk
theo69
Post by theo69 »
Its in the work i think...
Revers59
Post by Revers59 »
theo69 wrote:Is there a plan to integrate the alarm system from xiaomi into domoticz?
the alarm is in.
theo69
Post by theo69 »
the alarm is in.
Yes you can see the items, but you can not use the integrated system, you have to program you own with all items!
