Page 84 of 123
Posted: Tuesday 18 July 2017 6:09
by levynger
@corbin,
new code doesnt deal with ctrl_ln* anymore ? (so it seems..)
i have only ctrl_ln1, so this is the only one i can help with testing .. with the former code, it works pretty well though.
Xiami added Power Consumtiopn (Watt) , however i couldnt find any refernece in message for that, only volttage..
- Screenshot_20170718-070535.png (78.59 KiB) Viewed 3787 times
2017-07-18 06:55:31.685 {"cmd":"heartbeat","model":"ctrl_ln1","sid":"158d00014ab142","short_id":13820,"data":"{\"voltage\":3600,\"channel_0\":\"on\"}"}
Posted: Tuesday 18 July 2017 11:02
by warmaniac
Hi there . After update of gateway FW I can see in domotocz logs my aqara magnet / door sensor , will be some update of beta domoticz available soon ? I compiled official beta today, but I still can't see it in new devices
2017-07-18 10:57:51.033 {"cmd":"report","model":"sensor_magnet.aq2","sid":"158d00016c402b","short_id":30460,"data":"{\"status\":\"open\"}"}
2017-07-18 10:57:53.485 XiaomiGateway: unhandled model: sensor_magnet.aq2
2017-07-18 10:57:53.485 {"cmd":"report","model":"sensor_magnet.aq2","sid":"158d00016c402b","short_id":30460,"data":"{\"status\":\"close\"}"}
Posted: Tuesday 18 July 2017 17:24
by chatainsim
I have some strange logs in Domoticz :
2017-07-18 17:16:11.336 XiaomiGateway: unknown cmd received: read
2017-07-18 17:16:11.336 {"cmd": "read", "sid": "158d00015e9683"}
2017-07-18 17:16:11.336 {"cmd": "read", "sid": "158d0001a64ef5"}
2017-07-18 17:16:11.336 {"cmd": "read", "sid": "158d00012a42ca"}
2017-07-18 17:16:11.336 {"cmd": "read", "sid": "158d00015a8d79"}
2017-07-18 17:16:11.337 XiaomiGateway: unknown cmd received: read
2017-07-18 17:16:11.337 {"cmd": "read", "sid": "158d000182ec9e"}
Do you know what is it ?
Posted: Tuesday 18 July 2017 17:25
by chatainsim
theo69 wrote:chatainsim wrote:
I tried but it failed.
I will try again later. Thanks
The learning button is on the side (not the small hole on top)
Yes, I've tried that and on the Mi Home app I have something that let me thing button is added but it failed.
Posted: Tuesday 18 July 2017 17:47
by theo69
Strange, mine is added and working with automation within the Mi Home app
Posted: Tuesday 18 July 2017 21:50
by booster
I've got a Xiaomi temp + humidity sensor, and was hoping I could use the humidity value in blockly to trigger the ventilator based on its value.
however, the humidity value doesn't seem to be populated...instead I now see a value 3 for some reason.
same happens with another sensor...Is there a way to get the real humidity value in my blockly?
hope the screendumps help to understand the issue
- xiaomi_devices.JPG (43.22 KiB) Viewed 3687 times
ok on the dashboard
- xiaomi_dashboard.JPG (69.77 KiB) Viewed 3687 times
here it says temp+hum+3... humidity is loaded with value 3 and not 67
- xiaomi_values.JPG (25.88 KiB) Viewed 3687 times
Posted: Thursday 20 July 2017 14:17
by warmaniac
now I can see logs of Aqara temperature/humidity/pressure sensor !
2017-07-20 14:10:54.391 XiaomiGateway: unhandled model: weather.v1
2017-07-20 14:10:54.392 {"cmd":"report","model":"weather.v1","sid":"158d00017200ff","short_id":26405,"data":"{\"temperature\":\"2577\"}"}
2017-07-20 14:10:54.403 XiaomiGateway: unhandled model: weather.v1
2017-07-20 14:10:54.403 {"cmd":"report","model":"weather.v1","sid":"158d00017200ff","short_id":26405,"data":"{\"humidity\":\"5625\"}"}
2017-07-20 14:10:54.424 XiaomiGateway: unhandled model: weather.v1
2017-07-20 14:10:54.424 {"cmd":"report","model":"weather.v1","sid":"158d00017200ff","short_id":26405,"data":"{\"pressure\":\"97046\"}"}
2017-07-20 14:10:54.435 XiaomiGateway: unhandled model: weather.v1
I think pressure must be calculated in domoticz by the height above sea level , but it is positive that Xiaomi fix it finally , hope it will be soon implemented in Domoticz
Posted: Thursday 20 July 2017 19:31
by ben53252642
After using Xiaomi Gateway successfully with Domoticz for about 2 -3 months, one day recently I found my gateway had stopped working and was flashing yellow. Couldn't see it on the network or broadcasting it's setup wifi SSID after power cycling it, I ended up doing a hard reset, this is where it gets awesome...
I named it the same as it was before during the setup, the app restored all device associations to the Gateway, the only thing I had to do was re-enable "local area network communication protocol", which after doing so my Xiaomi devices attached to the Gateway started working in Domoticz again. Needless to say I am very impressed! Really wish Z-Wave had such easy backup / restore functionality.
Posted: Sunday 23 July 2017 12:22
by doxikus
Does anybody have info when support for new aqara temp sensor will be merged in official beta!?
Posted: Sunday 23 July 2017 16:46
by theo69
doxikus wrote:Hi,
Waiting also for the merge for the neutral line Switches
Posted: Tuesday 25 July 2017 14:41
by chatainsim
theo69 wrote:doxikus wrote:Hi,
Merge is here :
https://github.com/domoticz/domoticz/co ... e1ab829e55
Update and compile your Domoticz !
Thanks @corbin !
Posted: Tuesday 25 July 2017 14:51
by benbammens
chatainsim wrote:theo69 wrote:doxikus wrote:Hi,
Merge is here :
Thanks @corbin !
I guess, just like me, he has no idea how to do this
I'm also waiting for the beta to implement this...
Posted: Tuesday 25 July 2017 15:30
by theo69
Looks like its in the beta now, updating now (first backup my SD) and will report back...
Posted: Tuesday 25 July 2017 15:34
by benbammens
Yes, it's working now!
Posted: Tuesday 25 July 2017 15:40
by theo69
Just to report Aquara Square Button is working now.
However the single Wall Switch with Zero Line still shows:
2017-07-25 09:36:56.708 XiaomiGateway: unhandled model: ctrl_ln1
Posted: Tuesday 25 July 2017 17:32
by bublikOff
Any way to handle Aqara Smart Curtains?
Posted: Tuesday 25 July 2017 18:32
by theo69
theo69 wrote:Just to report Aquara Square Button is working now.
However it shows "not supported" in HomeKit. With the mi-aqua homebrige plugin its working like a button!
Posted: Tuesday 25 July 2017 19:03
by jjnj
bublikOff wrote:Any way to handle Aqara Smart Curtains?
+1 for the curtains
Verstuurd vanaf mijn LG-H870 met Tapatalk
Posted: Wednesday 26 July 2017 2:42
by bublikOff
---deleted---
Posted: Thursday 27 July 2017 9:44
by Revers59
please can you test circle wireless switch double click fonction with the last beta ?
I have a double click fonction on my script and all work well before some beta upgrade. Now the when I double click some time I have Simple click and some time I have long click
