Page 82 of 123
Posted: Monday 03 July 2017 11:03
by doxikus
HI,
I think someone already post a question. I have on new temperature sensor ordered from gearbest, cube shape, with additional pressure sensor. Can someone confirm that he had in domoticz sensor registered or we need to wait for update on code. Problem with android is resolved I can add sensor via Mi Home app.
Posted: Monday 03 July 2017 11:04
by benbammens
doxikus wrote:HI,
No, it does not work yet
Verstuurd vanaf mijn SM-G930F met Tapatalk
Posted: Wednesday 05 July 2017 7:54
by jeroenkl
levynger wrote:Does any one knows how to trigger "alert" and "swing" with the cube?
Wondering it as well, somebody knows?
Posted: Wednesday 05 July 2017 19:51
by Yevrashka
Is it possible to turn on/off the Gateway's radio and switch it's channels from Domoticz?
Posted: Friday 07 July 2017 18:45
by mvveelen
Swifty wrote:Swifty wrote:Does anyone have any suggestions for a (cheap) doorbell pusher that can be fitted outside? (in the British weather!)
My current doorbell (some Siemens junk) keeps failing, so I'd like to get a wireless button that is weather proof which I can integrate with Domoticz to trigger the Xiaomi gateways
At the risk of talking to myself - I have now found a solution for this
I took a spare Xiaomi door sensor, pulled it apart and wired a push button between GND and D0 pins, then fitted it all inside my old doorbell pusher casing.
Now I have a Xiaomi smart doorbell
- The gateway rings when the doorbell is pushed (using a bit of blocky in Domoticz).
However, I've noticed that once the tune has finished playing on the gateway, the state of the 'Xiaomi Smart Gateway Doorbell' (the one where you pick a sound) does not go back to 'Off' state in Domoticz - is this normal?
Hmmmm.....I stopped reading this topic a few weeks ago and I'm trying to get up-to-date again when I saw this.
I have a ZWave module behind my wall-push-switch and I'm trying to get rid of all ZWave devices (too expensive, not so reliable as I hoped, etc.). If I do the same with a door switch and put it behind my wall switch (which I don't want to alter), I should get the same results as with the ZWave module right? I'm using it as a kill-switch, so just a simpel ON or OFF signal is OK. Am I right? Someone who has the same setup / idea ?
Posted: Friday 07 July 2017 22:28
by Krosik
I get my xiaomi gateway 2 and i cant maked it with domoticz.
I adding everything by wiki but i stuck at
- Spoiler: show
2017-07-07 22:19:03.649 XiaomiGateway: will listen on 9898 for hardware id 35
2017-07-07 22:19:03.649 XiaomiGateway: Delaying worker startup...
2017-07-07 22:19:08.650 XiaomiGateway: Worker started...
2017-07-07 22:19:08.651 XiaomiGateway: Using 192.168.2.3 for local IP address.
2017-07-07 22:21:54.671 XiaomiGateway: stopped
2017-07-07 22:21:54.672 XiaomiGateway: will listen on 9898 for hardware id 35
2017-07-07 22:21:54.673 XiaomiGateway: Delaying worker startup...
2017-07-07 22:21:59.673 XiaomiGateway: Worker started...
2017-07-07 22:21:59.674 XiaomiGateway: Using 192.168.2.3 for local IP address.
2017-07-07 22:22:00.675 XiaomiGateway: stopped
2017-07-07 22:22:00.676 XiaomiGateway: will listen on 9898 for hardware id 35
2017-07-07 22:22:00.677 XiaomiGateway: Delaying worker startup...
2017-07-07 22:22:05.678 XiaomiGateway: Worker started...
2017-07-07 22:22:05.678 XiaomiGateway: Using 192.168.2.3 for local IP address.
I dont see any new devices
I did the Troubleshooting from wiki but not helped.
the gateway fw is 1.4.1_147.0143 the domoticz is laste beta on osmc raspberry pi.
the gateway ip is 192.168.2.5 and the domoticz server is 192.168.2.3
edit on the windows version on domoticz is working but i cant make it with raspberry pi with the udp????
Posted: Saturday 08 July 2017 4:11
by corbin
I would expect an error to be displayed between these two lines:
Perhaps the network configuration OSMC is causing an issue? I currently have the ability to test this but should be able to once my Raspberry Pi Zero arrives.
Posted: Saturday 08 July 2017 4:12
by corbin
Yevrashka wrote:Is it possible to turn on/off the Gateway's radio and switch it's channels from Domoticz?
No, sorry.
Posted: Saturday 08 July 2017 13:11
by Krosik
corbin wrote:I would expect an error to be displayed between these two lines:
I switch from ethernet cable to wifi dongle and its working....
Posted: Saturday 08 July 2017 14:28
by AlexC
Hi there,
Just trying to get Domoticz to switch on LED of Xiaomi Gateway when humidity level is higher than something - so that I can turn on my manual dehumidifier - it's middle of winter here in Auckland and humidity is getting quite high inside.
The problem is that current state of humidity in Events shows number 1, 2, 3, etc instead of actual humidity level. Dashboards and graphs use proper humidity level. Current state of Temp + Hum shows proper numbers but I can't have humidity only of there.
Do you guys have an idea how I could get proper humidity level to use in events? I saw that another guy had the same problem earlier but no one replied.
I'm on Domoticz v3.8034.
Thanks a lot!
Posted: Saturday 08 July 2017 20:13
by qwerk
Did you found out how to do that?
because my cube ( proud owner since 1 day) goes to alert all the time. looks like a resting stage.
I also have an issue with swing, didn't work for me.
also I cannot tap on it, I have to lift the cube and then tap twice on the table.
Qwerk
Posted: Monday 10 July 2017 12:19
by Andree
Hi to all,
sometimes all my xiaomi temperature sensors report a strange peak of 100°C and after some minutes turn back to normal.
There's a way for delete this peaks?
- Temp.jpg (51.42 KiB) Viewed 3187 times
Posted: Monday 10 July 2017 14:08
by n01knows
Hello.
I'm looking for advice.
I want to use different led colors on gateway for example:
dark yellow at night
blinking red when - fire, flood etc
blinking yellow when someone is using door bell etc.
Right now when I set yellow color on gateway it is not saving this value. Every time when I turn on gateway via domoticz I got green light.
Was any of you able to set custom lights and assign them to actions?
Posted: Monday 10 July 2017 14:20
by bertbigb
n01knows wrote:Hello.
Hi n01knows,
If everything went ok you have got a device Xiaomi RGB Gateway in your device list
By setting the necessary values in a script depending on the different states you must be able to accomplish what you want.
Please share you code then i hopefully can give some more clues how you can achieve your goals
Best regards
Bert
Posted: Monday 10 July 2017 23:39
by elvirisimo
Got latest stable Domoticz V3.5877 and I can't find Xiaomi on the list of the devices to add. It should be there? Right?
Posted: Tuesday 11 July 2017 3:31
by theo69
elvirisimo wrote:Got latest stable Domoticz V3.5877 and I can't find Xiaomi on the list of the devices to add. It should be there? Right?
only on beta
Posted: Tuesday 11 July 2017 9:58
by bbqkees
Andree wrote:Hi to all,
Press CTRL and click on the peak. Now you can delete it.
Posted: Tuesday 11 July 2017 15:15
by Andree
bbqkees wrote:Andree wrote:Hi to all,
Nothing happens with CTRL and click..Same with Firefox,Chrome and Edge..
Posted: Tuesday 11 July 2017 16:03
by bbqkees
Andree wrote:bbqkees wrote:Andree wrote:Hi to all,
yeah it is SHIFT + click.
Posted: Tuesday 11 July 2017 16:24
by Andree
Yesss now work!thx so much!
