Page 9 of 9
Re: Harmony support, new hardware?
Posted: Thursday 17 January 2019 18:58
by jursat
How did you do that?
Posted: Thursday 07 February 2019 7:29
by renerene
So, beginners question, how does this work?
New hardware only asks for address and port. No new devices were added. Now what? Where to login?
Posted: Thursday 07 February 2019 8:13
by DutchHans
Have you checked "accept new hardware devices" in settings?
Hans
Posted: Wednesday 25 December 2019 17:35
by packetloss
Today I noticed that my HABridge system was not able to use my Logitech Harmony hub anymore. Then I saw Domoticz also was not able to communicate. The syslog says:
Dec 25 02:39:14 server domoticz: Harmony Hub: Reattempt login.
Dec 25 02:42:14 server domoticz: Harmony Hub: Reattempt login.
Dec 25 02:46:14 server domoticz: Harmony Hub: Reattempt login.
Dec 25 02:51:14 server domoticz: Harmony Hub: Reattempt login.
etc...
At that time, I am very sure I was sleeping and not editing firewalls or anything
. Of course I switch off the Harmony hub and switched it back on. No luck.
Anyone else noticed this recently??
Posted: Wednesday 27 May 2020 20:20
by martinvandenhurk
Duan wrote: Thursday 29 December 2016 21:00
Hi All,
When I try to add my Harmony just like in the wiki, I don't see any fields to add a username and password.
I had this problem on the stable version 3.5837, but also on the latest beta version.
Does anyone else experience the same problem?
Kind regards,
Duan
Hi Duan, do you remember how you solved this issue years ago?
I'm having the same problem now
Posted: Thursday 28 May 2020 2:15
by melgi
UPDATE: father_mande compiled a new version 2020.2.1 of Domoticz and with this I could get my Harmony Hub finally working again! I did enable XMPP the other day, but with the old version it didn't work. With version 2020.2 it works.
martinvandenhurk wrote:Duan wrote: Thursday 29 December 2016 21:00
Hi All,
Kind regards,
Duan
Interested about the solution as well as I have exactly the same issue.
Regards,
melgi
Verstuurd vanaf mijn SM-G986B met Tapatalk
Posted: Saturday 03 October 2020 22:38
by OlivierFR
I had a Harmony Hub working for some time, but I had to change my Harmony.com password.
Since then the connection from Domoticz to the Hub fails.
I'm trying to find where I can enter the new password in Domoticz. However in the Domoticz Harmony hardware settings, I only have Address and Port. I have no Username and Password fields...
Am'I missing something?
Thanks,
Olivier
Posted: Wednesday 07 October 2020 10:18
by OlivierFR
Posting reply for others after getting confirmation that accessing the Harmony Hub does NOT require Username/Password anymore.
Ensure you have the latest firmware and XMPP is enabled (can be checked in the Harmony Remote Settings Menu).
Posted: Friday 30 October 2020 16:28
by geralddevrieze
Recently I've bought a Harmony Ultimate with Hub to use with Domoticz, but I can't establish any kind of connection. I've got XMPP enabled in the Harmony app, and added the Hub in Domoticz with it's IP address and port 5222. However, when I ping the hub all ports remain closed - and I suppose there should be at least one open port to establish a proper XMPP connection. Reboot of the hub didn't help at all.
The versions are:
- Domoticz 2020.2
- Harmony Hub 4.15.280
- Harmony App 5.7.6
Are there more people around that encountered this issue, and what could be a proper way to fix it?
Gerald
###UPDATE###
Problem solved: Domoticz used a cable connection to the modem, while the Harmony hub connected to the separate wireless router - they couldn't detect each other. I've moved the wireless router near my Raspberry Pi with Domoticz, and put the cable straight into the router instead of the modem; now both the hub and domoticz are sharing the exact same network.
Posted: Tuesday 27 April 2021 10:59
by martinvandenhurk
martinvandenhurk wrote: Wednesday 27 May 2020 20:20
Hi All,
Kind regards,
Duan
After a complete reinstall of Raspberry & Domoticz it works now.
(Domoticz is no longer asking to enter userid & password)
