Page 9 of 10
Re: Dashticz Dial - Features, Fixes & Updates
Posted: Monday 12 April 2021 19:41
by Vondee
Lokonli wrote: Monday 12 April 2021 16:14
Vondee wrote: Monday 12 April 2021 13:53 I have a custom dial with a 'CounterToday' value, but it does show now the 'Data' field of the variable with the 3.8.0 version. Version 3.6.7 do show 'CounterToday' correctly.
Can you post your block definition?
and the Domoticz json ouput of your device:
http://domotics-ip:port/json.htm?type=devices&rid=123
Replace 123 with your Domoticz device id.
Preferably add a screen shot of the problem as well.
Dashticz Block definition
blocks['Solar'] = {
        title: 'PV',
        type: 'dial',
        width: 6,
        showring: true,
        flash: false,
        shownumbers: true,
        showunit: true,
        last_update: false,
        min: 0,
        max: 30,
        values : [
                        value: 'CounterToday',
                        idx: 337,
                        unit: 'kWh'
                        value: 'Usage',
                        idx: 337,
                        icon: 'fas fa-solar-panel',
                        unit: 'W'
Json Output:
"ActTime" : 1618227367,
	"AstrTwilightEnd" : "22:42",
	"AstrTwilightStart" : "04:49",
	"CivTwilightEnd" : "21:11",
	"CivTwilightStart" : "06:20",
	"DayLength" : "13:41",
	"NautTwilightEnd" : "21:54",
	"NautTwilightStart" : "05:37",
	"ServerTime" : "2021-04-12 13:36:07",
	"SunAtSouth" : "13:45",
	"Sunrise" : "06:55",
	"Sunset" : "20:36",
	"app_version" : "2020.2",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"CounterToday" : "8.967 kWh",
			"CustomImage" : 0,
			"Data" : "15481.811 kWh",
			"Description" : "",
			"EnergyMeterMode" : "",
			"Favorite" : 1,
			"HardwareID" : 4,
			"HardwareName" : "Weerdata",
			"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
			"HardwareTypeVal" : 15,
			"HaveTimeout" : false,
			"ID" : "00082337",
			"LastUpdate" : "2021-04-12 13:36:00",
			"Name" : "Zonnecel Totaal",
			"Notifications" : "false",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Protected" : false,
			"ShowNotifications" : true,
			"SignalLevel" : "-",
			"SubType" : "kWh",
			"SwitchTypeVal" : 0,
			"Timers" : "false",
			"Type" : "General",
			"TypeImg" : "current",
			"Unit" : 1,
			"Usage" : "2025 Watt",
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "337"
	"status" : "OK",
	"title" : "Devices"
I removed the new Dasticz version, so I can not show the result. The the value in the center of the dial was the value of the 'Data' field, NOT 'CounterToday'. I tried to put in other datafields, but no change. When I reversed back to the older Dashticz version the Dial was OK.
Posted: Thursday 15 April 2021 18:17
by Lokonli
There was a change in the block parameters in version 3.7.x
By default, the data fields defined by the values parameter are now displayed below the 'main' data.
To hide the main data, and only show the 'fields' values, add the following parameter to the block definition:
   showvalue: false
Try the following block definition:
blocks['Solar'] = {
blocks['Solar'] = {
    title: 'PV',
    type: 'dial',
    width: 6,
    showring: true,
    flash: false,
    shownumbers: true,
    showunit: true,
    last_update: false,
    min: 0,
    max: 30,
    idx: 337,
    showvalue: false,
    values : [
                    unit: 'kWh',
                    addClass: 'primary',
                    isNeedle: true,
                    decimals: 1
                    value: 'Usage',
                    unit: 'W',
I've added
addClass: 'primary' to the first value, to make it bigger.
isNeedle: true, to bind the Needle to this value
decimals: 1, to make it a bit more accurate
Posted: Thursday 15 April 2021 19:33
by Multikoe
I have been playing with Dasticz only recently, having worked with Domoticz for about a year now. I created a dashboard which worked, until I updated to the last build (3.8 master). Now, one of my three dials no longer produces a pop-up when I click it. The other two do. I can not find anything different. To be clear: it worked before the update.
This is my block definition:
blocks['Anna temp'] = {
        type: 'dial', //Display as dial
        setpoint: 20.5,
        min: 10,
        max: 30,
        shownumbers: true,
        showring: false,
        showunit: true,
        idx: 11, //11 = Anna temp living
        title: 'Woonkamer', //The title of the block as shown in the dial.
        width: 4, //The width of the block relative to the column width
        last_update: false,
        //popup: 'popup_woonkamertemp',
Note the popup row: that's what I used before to filter out unwanted values. I commented it out now to test. When I hoover over the dial, it shrinks, like it should, but when I click, nothing happens.
Posted: Thursday 15 April 2021 20:03
by Lokonli
Multikoe wrote: Thursday 15 April 2021 19:33 I have been playing with Dasticz only recently, having worked with Domoticz for about a year now. I created a dashboard which worked, until I updated to the last build (3.8 master). Now, one of my three dials no longer produces a pop-up when I click it. The other two do. I can not find anything different. To be clear: it worked before the update.
        setpoint: 20.5,
        min: 10,
        max: 30,
        shownumbers: true,
        showring: false,
        showunit: true,
        last_update: false,
What was your previous Dashticz version?
Posted: Thursday 15 April 2021 20:05
by Lokonli
and how did you define the 'popup_woonkamertemp' block?
Posted: Thursday 15 April 2021 20:16
by Lokonli
        setpoint: 20.5,
        min: 10,
        max: 30,
        shownumbers: true,
        showring: false,
        showunit: true,
        last_update: false,
I see the space in the key is giving issues.
As workaround, use 'Annatemp' instead of 'Anna temp'.
I'll try to fix this as well.
Posted: Thursday 15 April 2021 23:01
by Lokonli
Lokonli wrote: Thursday 15 April 2021 20:16
        setpoint: 20.5,
        min: 10,
        max: 30,
        shownumbers: true,
        showring: false,
        showunit: true,
        last_update: false,
Space within block keys has been fixed for popup windows in latest beta. I'll create a new master within a week or so.
I still recommend not to use spaces in key values. It might give issues at other places as well.
Posted: Friday 16 April 2021 6:52
by Multikoe
Thats it! Thanks. Changed the key and the popup works.
Posted: Wednesday 19 May 2021 17:26
by stephanvdplas
I really love the Dials in Dashticz, they look rather fancy and are very functional.
There is one thing I'd like to see different: When clicking on the ring of a volume dial (which is a dimmer value in domoticz), the device is turning off. You only can change the volume by slinding the pointer in the ring. Is it possible to change this behaviour, so tipping the ring of the dial will change the level and not turn it off?
Regards,
Stephan van der Plas
Posted: Sunday 03 October 2021 15:16
by JuanUil
I have a dial for watering my garden. It origianaly is a selector switch in Domoticz.
I want to change the font, center the text. but I tried in customcss .dial .data and all other things.
nothing works.
what am I doing wrong?
jan
Posted: Tuesday 05 October 2021 17:22
by JuanUil
nobody?
Posted: Tuesday 12 October 2021 7:41
by gaber
is it possible to enlarge the font/title in the dial switches?
Posted: Tuesday 12 October 2021 15:55
by madpatrick
gaber wrote: Tuesday 12 October 2021 7:41 Hi all,
You can change color, fonts, etc.... in custom.css
for example add this to the file
[data-id='NAME_DIAL'] .value				{color: #373737 !important;font-size: 24px !important; text-align: center !important}
See also : https://dashticz.readthedocs.io/en/mast ... omcss.html
Posted: Tuesday 12 October 2021 21:08
by JuanUil
JuanUil wrote: Sunday 03 October 2021 15:16 Hi,
nothing works.
jan
and how about this one?
Posted: Wednesday 13 October 2021 13:00
by gaber
madpatrick wrote: Tuesday 12 October 2021 15:55
Using .value changes for example the temperature on dials.
But i didn't found anything to change the title.
Tried with .label, .title, etc.
Posted: Thursday 14 October 2021 13:18
by madpatrick
gaber wrote: Wednesday 13 October 2021 13:00
Try
.dt_title
Maybe this works
Or check this page for more info
https://dashticz.readthedocs.io/en/mast ... light=dial
Posted: Thursday 14 October 2021 13:48
by gaber
madpatrick wrote: Thursday 14 October 2021 13:18
Try
.dt_title
Maybe this works
I give up.
The only css changes working for me are these described in the "Dial" section here https://dashticz.readthedocs.io/en/mast ... om-styling
Posted: Thursday 14 October 2021 19:53
by Lokonli
JuanUil wrote: Tuesday 12 October 2021 21:08
nothing works.
jan
Add the following to custom.css:
/*to vertical center the dial menu*/
  .dial-menu .status {
      justify-content: center;
      display: flex;
      flex-direction: column;
  .dial-menu .status li {
      margin: unset
/*to change the font of the dial menu text*/
    font-size: 75%
Posted: Thursday 14 October 2021 19:58
by Lokonli
I can't see the image. Can you repost it?
Posted: Friday 15 October 2021 13:34
by gaber
Lokonli wrote: Thursday 14 October 2021 19:58
Sure i can.
