Page 9 of 15
Re: Multiple sources in one graph
Posted: Sunday 16 February 2020 14:18
by Sjonnie2017
clinkadink wrote: Sunday 16 February 2020 14:05 There was an update to the latest beta this morning. It included tooltip styling.
*snip*
It is obviously still a beta, so any feedback is appreciated ;)
I changed one file so how do I force this update (and forgot to make a backup :o )? I have copied the altered code to another file so I can fall back on that. I see no "force" option in the git command.
Posted: Sunday 16 February 2020 14:30
by clinkadink
How are you normally updating?
Posted: Sunday 16 February 2020 14:33
by Lokonli
git reset --hard HEAD
git pull
This will overwrite the changes you've made, but it will not remove new files you've created.
Posted: Sunday 16 February 2020 14:37
by clinkadink
The latest update contains the changes that you tested (plus the new toolTipStyle).
In other words, you shouldn't lose anything by updating.
Posted: Sunday 16 February 2020 14:59
by Sjonnie2017
clinkadink wrote: Sunday 16 February 2020 14:30 How are you normally updating?
I normally use "git pull" in the dashticz folder.
Lokonli wrote: Sunday 16 February 2020 14:33
git pull
That seemed to do the trick :)
clinkadink wrote: Sunday 16 February 2020 14:37 The latest update contains the changes that you tested (plus the new toolTipStyle).
Haven't lost anything indeed. Tried the toolTipStyle parameter and got this in the graph on the dashboard (über cool :mrgreen: ):
The tooltips do not work in the popup graphs though but I think you didn't expect it to ;)
Greetz,
Sjonnie
EDIT: The tooltips work on the multigraphs as well. Forgot to mention that ;)
Posted: Sunday 16 February 2020 15:03
by clinkadink
Great news, thanks! ;)
No, they won't work in popups ... at the moment.
Posted: Sunday 16 February 2020 15:08
by Sjonnie2017
clinkadink wrote: Sunday 16 February 2020 15:03 Great news, thanks! ;)
Looking at what you have achieved up til now I am sure you are going to fix that as well. :lol:
Greetz,
Sjonnie
Posted: Sunday 16 February 2020 17:46
by Sjonnie2017
While I was using Dashticz and checked some graphs I noticed a little odd behavior. It seems that the tooltips parameter shows a large amount of digits behind the decimal separator for last month. It works well for all other measurements like Today and Last Hours but the last day of this month however...
Last month - today:
Last month - *not* today:
Refreshing/re-selecting makes no difference.
Greetz,
Sjonnie
Posted: Sunday 16 February 2020 17:50
by clinkadink
That's is the standard tooltips, not the new tooltips. Can you check your block config?
Posted: Sunday 16 February 2020 18:01
by Sjonnie2017
Sorry! You're right of course. :oops: Added the new tooltip parameter to the blocks and all is working as expected now.
Greetz,
Sjonnie
Posted: Sunday 16 February 2020 22:02
by clinkadink
Sjonnie2017 wrote: Sunday 16 February 2020 13:44 if I click on Last month twice it shows me kWh (eg. 15kWh). If I then select last hours, on first click it shows me kWh (eg. 2000 kWh) and after the second click I get W (eg. 2000 W). Same applies for Today. If I select Last Hours it shows me W as unit of measurement. If I then select Last Month the first time it shows me W (eg. 20 W) and after the second click it shows me kWh (20 kWh). It looks like the unit of measurement is not immediately updated if I switch between different time measurements.
Finally found the issue. Am fixing it now.
P.S. toolTipStyle now working on Popups (on mine) ;)
Posted: Monday 17 February 2020 10:31
by clinkadink
There have been quite a few graph updates to the latest beta over the weekend.
Fixes:
  • Height can once again be set in the graph block, e.g. height: '300px'
  • drawOrderLast, drawOrderDay, drawOrderMonth now correctly allows sorting the order of datasets per button (last, today, month)
  • Users would often have to press the range button twice to show the correct ylabel - now fixed.
Updates:
  • The Legend order can now be changed by changing the order of the keys in the graph block config
  • User can now display HTML graph tooltips instead of the standard ones, e.g. toolTipStyle: true
  • The graph beta documentation has been updated to reflect the recent changes
  • Users can now debug their graph by setting their graph's block config, e.g. debugButton: true
  • HTML tooltips are now shown on Popups by default
To make use of these fixes and updates, please update to the latest beta.
https://github.com/Dashticz/dashticz/tree/beta
Tip 1: defined graph blocks do not require be named as "graph_idx" or "multigraph_idx" anymore. You can name them whatever you like.
Tip 2: all defined graph blocks must contain the devices parameter, e.g. devices: [123]
Tip 3: all undefined graphs (those without any block) should still be named as "graph_idx" (where idx is the idx of the device).
Posted: Monday 17 February 2020 10:33
by clinkadink
The latest update (this morning), includes the ability to add a debug button to your graph. To do this, add the following line to your graph's block config:
debugButton: true
The update adds a button to the top right of the graph. When pressed, a dialog box is displayed with key information about each device and the data that has been generated to show the graph. Each device has a link, this takes you to page showing all data about each device within the graph, using Domoticz api. Across the top shows the original keys and the new keys (appended with the device idx). I am hoping that this will help us resolve any issues we may experience with any troublesome graphs ;)
There are 3 buttons at the top of the debug window:
  • DevTools button - press F12 on the keyboard and then click this to show the graph properties in Dev Tools
  • Save button - click this to download your graph properties in JSON format. This will be helpful if you need support.
  • Close button - to exit the debug window. Although clicking outside of the window does the same thing.
Posted: Monday 17 February 2020 18:34
by Sjonnie2017
After all your hard work I just had to update and start testing. I added the debugButton = true parameter to the blocks. Everything else has been left 'as is'.
The code for electricity and gas:
blocks[grafiek_elektra] = {}
blocks[grafiek_elektra]['title'] = 'Elektriciteit';
blocks[grafiek_elektra]['devices'] = [199];
blocks[grafiek_elektra]['width'] = 12;
blocks[grafiek_elektra]['height'] = '400px';
blocks[grafiek_elektra]['interval'] = 2;
blocks[grafiek_elektra]['graphTypes'] = ['v', 'v2'];
blocks[grafiek_elektra]['graph'] = 'line';
blocks[grafiek_elektra]['sortDevices'] = true;
blocks[grafiek_elektra]['toolTipStyle'] = true;
blocks[grafiek_elektra]['debugButton'] = true;
blocks[grafiek_elektra]['legend'] = {'v2_199': 'Dag', 'v_199': 'Nacht'}
blocks[grafiek_gas] = {}
blocks[grafiek_gas]['title'] = 'Gas';
blocks[grafiek_gas]['devices'] = [200];
blocks[grafiek_gas]['width'] = 12;
blocks[grafiek_gas]['height'] = '400px';
blocks[grafiek_gas]['interval'] = 2;
blocks[grafiek_gas]['toolTipStyle'] = true;
blocks[grafiek_gas]['debugButton'] = true;
blocks[grafiek_gas]['legend'] = {'v_200': 'Per Uur', 'c_200': 'Totaal'}
You'll get used to my definition style (in time ;))
The pictures:
No tool tips on popup gas:
Dashboard graphs on first load:
Popup electricity on first load:
Popup electricity Last Month after first load:
Popup electricity Today after selecting Last Month:
Popup electricity Last Hours after selecting Today
I am almost certain it won't help a bit but I have added the debug code for the electricity graph just to be sure:
  "blockId": "block_33",
  "block": {
    "devices": [
      199
    "datasetColors": [
      "red",
      "yellow",
      "blue",
      "orange",
      "green",
      "purple"
    "barWidth": 0.9,
    "borderColors": [
      "red",
      "yellow",
      "blue",
      "orange",
      "green",
      "purple"
    "borderDash": [],
    "borderWidth": 2,
    "buttonsBorder": "white",
    "buttonsColor": "black",
    "buttonsFill": "white",
    "buttonsIcon": "#686868",
    "buttonsMarginX": 2,
    "buttonsMarginY": 0,
    "buttonsPadX": 6,
    "buttonsPadY": 2,
    "buttonsRadius": 4,
    "buttonsShadow": false,
    "buttonsSize": 14,
    "buttonsText": false,
    "cartesian": "linear",
    "custom": false,
    "debugButton": true,
    "displayFormats": false,
    "drawOrderDay": false,
    "drawOrderLast": false,
    "drawOrderMonth": false,
    "gradients": false,
    "graph": "line",
    "graphTypes": [
      "v",
      "v2"
    "height": "400px",
    "iconColour": "grey",
    "interval": 2,
    "legend": {
      "v2_199": "Dag",
      "v_199": "Nacht"
    "lineFill": false,
    "lineTension": 0.1,
    "maxTicksLimit": null,
    "method": 1,
    "pointBorderColor": [
      "grey"
    "pointBorderWidth": 0,
    "pointFillColor": [
      "red",
      "yellow",
      "blue",
      "orange",
      "green",
      "purple"
    "pointRadius": 0,
    "pointStyle": false,
    "reverseTime": false,
    "sortDevices": true,
    "spanGaps": false,
    "title": "Elektriciteit",
    "toolTipStyle": true,
    "width": 12
  "currentValue": "7.50 kWh",
  "currentValues": [
    "7.50 kWh"
  "customRange": false,
  "data": {
    "result": [
        "d": "2020-02-16 18:30",
        "v_199": "0",
        "v2_199": "0"
        "d": "2020-02-16 18:35",
        "v_199": "2552",
        "v2_199": "0"
        "d": "2020-02-16 18:40",
        "v_199": "2316",
        "v2_199": "0"
        "d": "2020-02-16 18:45",
        "v_199": "3264",
        "v2_199": "0"
        "d": "2020-02-16 18:50",
        "v_199": "2940",
        "v2_199": "0"
        "d": "2020-02-16 18:55",
        "v_199": "3025",
        "v2_199": "0"
        "d": "2020-02-16 19:00",
        "v_199": "2992",
        "v2_199": "0"
        "d": "2020-02-16 19:05",
        "v_199": "2808",
        "v2_199": "0"
        "d": "2020-02-16 19:10",
        "v_199": "1596",
        "v2_199": "0"
        "d": "2020-02-16 19:15",
        "v_199": "792",
        "v2_199": "0"
        "d": "2020-02-16 19:20",
        "v_199": "649",
        "v2_199": "0"
        "d": "2020-02-16 19:25",
        "v_199": "684",
        "v2_199": "0"
        "d": "2020-02-16 19:30",
        "v_199": "672",
        "v2_199": "0"
        "d": "2020-02-16 19:35",
        "v_199": "627",
        "v2_199": "0"
        "d": "2020-02-16 19:40",
        "v_199": "672",
        "v2_199": "0"
        "d": "2020-02-16 19:45",
        "v_199": "684",
        "v2_199": "0"
        "d": "2020-02-16 19:50",
        "v_199": "638",
        "v2_199": "0"
        "d": "2020-02-16 19:55",
        "v_199": "744",
        "v2_199": "0"
        "d": "2020-02-16 20:00",
        "v_199": "660",
        "v2_199": "0"
        "d": "2020-02-16 20:05",
        "v_199": "732",
        "v2_199": "0"
        "d": "2020-02-16 20:10",
        "v_199": "594",
        "v2_199": "0"
        "d": "2020-02-16 20:15",
        "v_199": "756",
        "v2_199": "0"
        "d": "2020-02-16 20:20",
        "v_199": "636",
        "v2_199": "0"
        "d": "2020-02-16 20:25",
        "v_199": "660",
        "v2_199": "0"
        "d": "2020-02-16 20:30",
        "v_199": "627",
        "v2_199": "0"
        "d": "2020-02-16 20:35",
        "v_199": "696",
        "v2_199": "0"
        "d": "2020-02-16 20:40",
        "v_199": "720",
        "v2_199": "0"
        "d": "2020-02-16 20:45",
        "v_199": "708",
        "v2_199": "0"
        "d": "2020-02-16 20:50",
        "v_199": "648",
        "v2_199": "0"
        "d": "2020-02-16 20:55",
        "v_199": "594",
        "v2_199": "0"
        "d": "2020-02-16 21:00",
        "v_199": "594",
        "v2_199": "0"
        "d": "2020-02-16 21:05",
        "v_199": "624",
        "v2_199": "0"
        "d": "2020-02-16 21:10",
        "v_199": "576",
        "v2_199": "0"
        "d": "2020-02-16 21:15",
        "v_199": "756",
        "v2_199": "0"
        "d": "2020-02-16 21:20",
        "v_199": "624",
        "v2_199": "0"
        "d": "2020-02-16 21:25",
        "v_199": "561",
        "v2_199": "0"
        "d": "2020-02-16 21:30",
        "v_199": "612",
        "v2_199": "0"
        "d": "2020-02-16 21:35",
        "v_199": "660",
        "v2_199": "0"
        "d": "2020-02-16 21:40",
        "v_199": "648",
        "v2_199": "0"
        "d": "2020-02-16 21:45",
        "v_199": "516",
        "v2_199": "0"
        "d": "2020-02-16 21:50",
        "v_199": "492",
        "v2_199": "0"
        "d": "2020-02-16 21:55",
        "v_199": "480",
        "v2_199": "0"
        "d": "2020-02-16 22:00",
        "v_199": "612",
        "v2_199": "0"
        "d": "2020-02-16 22:05",
        "v_199": "492",
        "v2_199": "0"
        "d": "2020-02-16 22:10",
        "v_199": "408",
        "v2_199": "0"
        "d": "2020-02-16 22:15",
        "v_199": "420",
        "v2_199": "0"
        "d": "2020-02-16 22:20",
        "v_199": "384",
        "v2_199": "0"
        "d": "2020-02-16 22:25",
        "v_199": "297",
        "v2_199": "0"
        "d": "2020-02-16 22:30",
        "v_199": "312",
        "v2_199": "0"
        "d": "2020-02-16 22:35",
        "v_199": "408",
        "v2_199": "0"
        "d": "2020-02-16 22:40",
        "v_199": "504",
        "v2_199": "0"
        "d": "2020-02-16 22:45",
        "v_199": "468",
        "v2_199": "0"
        "d": "2020-02-16 22:50",
        "v_199": "432",
        "v2_199": "0"
        "d": "2020-02-16 22:55",
        "v_199": "374",
        "v2_199": "0"
        "d": "2020-02-16 23:00",
        "v_199": "408",
        "v2_199": "0"
        "d": "2020-02-16 23:05",
        "v_199": "396",
        "v2_199": "0"
        "d": "2020-02-16 23:10",
        "v_199": "396",
        "v2_199": "0"
        "d": "2020-02-16 23:15",
        "v_199": "576",
        "v2_199": "0"
        "d": "2020-02-16 23:20",
        "v_199": "468",
        "v2_199": "0"
        "d": "2020-02-16 23:25",
        "v_199": "420",
        "v2_199": "0"
        "d": "2020-02-16 23:30",
        "v_199": "330",
        "v2_199": "0"
        "d": "2020-02-16 23:35",
        "v_199": "300",
        "v2_199": "0"
        "d": "2020-02-16 23:40",
        "v_199": "312",
        "v2_199": "0"
        "d": "2020-02-16 23:45",
        "v_199": "312",
        "v2_199": "0"
        "d": "2020-02-16 23:50",
        "v_199": "540",
        "v2_199": "0"
        "d": "2020-02-16 23:55",
        "v_199": "363",
        "v2_199": "0"
        "d": "2020-02-17 00:00",
        "v_199": "480",
        "v2_199": "0"
        "d": "2020-02-17 00:05",
        "v_199": "468",
        "v2_199": "0"
        "d": "2020-02-17 00:10",
        "v_199": "480",
        "v2_199": "0"
        "d": "2020-02-17 00:15",
        "v_199": "396",
        "v2_199": "0"
        "d": "2020-02-17 00:20",
        "v_199": "552",
        "v2_199": "0"
        "d": "2020-02-17 00:25",
        "v_199": "408",
        "v2_199": "0"
        "d": "2020-02-17 00:30",
        "v_199": "319",
        "v2_199": "0"
        "d": "2020-02-17 00:35",
        "v_199": "336",
        "v2_199": "0"
        "d": "2020-02-17 00:40",
        "v_199": "360",
        "v2_199": "0"
        "d": "2020-02-17 00:45",
        "v_199": "528",
        "v2_199": "0"
        "d": "2020-02-17 00:50",
        "v_199": "420",
        "v2_199": "0"
        "d": "2020-02-17 00:55",
        "v_199": "429",
        "v2_199": "0"
        "d": "2020-02-17 01:00",
        "v_199": "396",
        "v2_199": "0"
        "d": "2020-02-17 01:05",
        "v_199": "420",
        "v2_199": "0"
        "d": "2020-02-17 01:10",
        "v_199": "552",
        "v2_199": "0"
        "d": "2020-02-17 01:15",
        "v_199": "408",
        "v2_199": "0"
        "d": "2020-02-17 01:20",
        "v_199": "396",
        "v2_199": "0"
        "d": "2020-02-17 01:25",
        "v_199": "418",
        "v2_199": "0"
        "d": "2020-02-17 01:30",
        "v_199": "480",
        "v2_199": "0"
        "d": "2020-02-17 01:35",
        "v_199": "540",
        "v2_199": "0"
        "d": "2020-02-17 01:40",
        "v_199": "360",
        "v2_199": "0"
        "d": "2020-02-17 01:45",
        "v_199": "324",
        "v2_199": "0"
        "d": "2020-02-17 01:50",
        "v_199": "312",
        "v2_199": "0"
        "d": "2020-02-17 01:55",
        "v_199": "492",
        "v2_199": "0"
        "d": "2020-02-17 02:00",
        "v_199": "432",
        "v2_199": "0"
        "d": "2020-02-17 02:05",
        "v_199": "385",
        "v2_199": "0"
        "d": "2020-02-17 02:10",
        "v_199": "492",
        "v2_199": "0"
        "d": "2020-02-17 02:15",
        "v_199": "456",
        "v2_199": "0"
        "d": "2020-02-17 02:20",
        "v_199": "420",
        "v2_199": "0"
        "d": "2020-02-17 02:25",
        "v_199": "480",
        "v2_199": "0"
        "d": "2020-02-17 02:30",
        "v_199": "561",
        "v2_199": "0"
        "d": "2020-02-17 02:35",
        "v_199": "480",
        "v2_199": "0"
        "d": "2020-02-17 02:40",
        "v_199": "396",
        "v2_199": "0"
        "d": "2020-02-17 02:45",
        "v_199": "418",
        "v2_199": "0"
        "d": "2020-02-17 02:50",
        "v_199": "312",
        "v2_199": "0"
        "d": "2020-02-17 02:55",
        "v_199": "324",
        "v2_199": "0"
        "d": "2020-02-17 03:00",
        "v_199": "444",
        "v2_199": "0"
        "d": "2020-02-17 03:05",
        "v_199": "451",
        "v2_199": "0"
        "d": "2020-02-17 03:10",
        "v_199": "456",
        "v2_199": "0"
        "d": "2020-02-17 03:15",
        "v_199": "516",
        "v2_199": "0"
        "d": "2020-02-17 03:20",
        "v_199": "612",
        "v2_199": "0"
        "d": "2020-02-17 03:25",
        "v_199": "429",
        "v2_199": "0"
        "d": "2020-02-17 03:30",
        "v_199": "456",
        "v2_199": "0"
        "d": "2020-02-17 03:35",
        "v_199": "492",
        "v2_199": "0"
        "d": "2020-02-17 03:40",
        "v_199": "396",
        "v2_199": "0"
        "d": "2020-02-17 03:45",
        "v_199": "396",
        "v2_199": "0"
        "d": "2020-02-17 03:50",
        "v_199": "312",
        "v2_199": "0"
        "d": "2020-02-17 03:55",
        "v_199": "363",
        "v2_199": "0"
        "d": "2020-02-17 04:00",
        "v_199": "504",
        "v2_199": "0"
        "d": "2020-02-17 04:05",
        "v_199": "336",
        "v2_199": "0"
        "d": "2020-02-17 04:10",
        "v_199": "372",
        "v2_199": "0"
        "d": "2020-02-17 04:15",
        "v_199": "480",
        "v2_199": "0"
        "d": "2020-02-17 04:20",
        "v_199": "348",
        "v2_199": "0"
        "d": "2020-02-17 04:25",
        "v_199": "385",
        "v2_199": "0"
        "d": "2020-02-17 04:30",
        "v_199": "396",
        "v2_199": "0"
        "d": "2020-02-17 04:35",
        "v_199": "360",
        "v2_199": "0"
        "d": "2020-02-17 04:40",
        "v_199": "552",
        "v2_199": "0"
        "d": "2020-02-17 04:45",
        "v_199": "374",
        "v2_199": "0"
        "d": "2020-02-17 04:50",
        "v_199": "360",
        "v2_199": "0"
        "d": "2020-02-17 04:55",
        "v_199": "384",
        "v2_199": "0"
        "d": "2020-02-17 05:00",
        "v_199": "231",
        "v2_199": "0"
        "d": "2020-02-17 05:05",
        "v_199": "444",
        "v2_199": "0"
        "d": "2020-02-17 05:10",
        "v_199": "360",
        "v2_199": "0"
        "d": "2020-02-17 05:15",
        "v_199": "516",
        "v2_199": "0"
        "d": "2020-02-17 05:20",
        "v_199": "684",
        "v2_199": "0"
        "d": "2020-02-17 05:25",
        "v_199": "588",
        "v2_199": "0"
        "d": "2020-02-17 05:30",
        "v_199": "660",
        "v2_199": "0"
        "d": "2020-02-17 05:35",
        "v_199": "732",
        "v2_199": "0"
        "d": "2020-02-17 05:40",
        "v_199": "696",
        "v2_199": "0"
        "d": "2020-02-17 05:45",
        "v_199": "576",
        "v2_199": "0"
        "d": "2020-02-17 05:50",
        "v_199": "352",
        "v2_199": "0"
        "d": "2020-02-17 05:55",
        "v_199": "744",
        "v2_199": "0"
        "d": "2020-02-17 06:00",
        "v_199": "352",
        "v2_199": "0"
        "d": "2020-02-17 06:05",
        "v_199": "456",
        "v2_199": "0"
        "d": "2020-02-17 06:10",
        "v_199": "420",
        "v2_199": "0"
        "d": "2020-02-17 06:15",
        "v_199": "864",
        "v2_199": "0"
        "d": "2020-02-17 06:20",
        "v_199": "636",
        "v2_199": "0"
        "d": "2020-02-17 06:25",
        "v_199": "418",
        "v2_199": "0"
        "d": "2020-02-17 06:30",
        "v_199": "636",
        "v2_199": "0"
        "d": "2020-02-17 06:35",
        "v_199": "372",
        "v2_199": "0"
        "d": "2020-02-17 06:40",
        "v_199": "583",
        "v2_199": "0"
        "d": "2020-02-17 06:45",
        "v_199": "341",
        "v2_199": "0"
        "d": "2020-02-17 06:50",
        "v_199": "504",
        "v2_199": "0"
        "d": "2020-02-17 06:55",
        "v_199": "468",
        "v2_199": "0"
        "d": "2020-02-17 07:00",
        "v_199": "372",
        "v2_199": "0"
        "d": "2020-02-17 07:05",
        "v_199": "0",
        "v2_199": "516"
        "d": "2020-02-17 07:10",
        "v_199": "0",
        "v2_199": "275"
        "d": "2020-02-17 07:15",
        "v_199": "0",
        "v2_199": "360"
        "d": "2020-02-17 07:20",
        "v_199": "0",
        "v2_199": "216"
        "d": "2020-02-17 07:25",
        "v_199": "0",
        "v2_199": "360"
        "d": "2020-02-17 07:30",
        "v_199": "0",
        "v2_199": "198"
        "d": "2020-02-17 07:35",
        "v_199": "0",
        "v2_199": "360"
        "d": "2020-02-17 07:40",
        "v_199": "0",
        "v2_199": "372"
        "d": "2020-02-17 07:45",
        "v_199": "0",
        "v2_199": "407"
        "d": "2020-02-17 07:50",
        "v_199": "0",
        "v2_199": "444"
        "d": "2020-02-17 07:55",
        "v_199": "0",
        "v2_199": "324"
        "d": "2020-02-17 08:00",
        "v_199": "0",
        "v2_199": "408"
        "d": "2020-02-17 08:05",
        "v_199": "0",
        "v2_199": "276"
        "d": "2020-02-17 08:10",
        "v_199": "0",
        "v2_199": "396"
        "d": "2020-02-17 08:15",
        "v_199": "0",
        "v2_199": "324"
        "d": "2020-02-17 08:20",
        "v_199": "0",
        "v2_199": "480"
        "d": "2020-02-17 08:25",
        "v_199": "0",
        "v2_199": "308"
        "d": "2020-02-17 08:30",
        "v_199": "0",
        "v2_199": "408"
        "d": "2020-02-17 08:35",
        "v_199": "0",
        "v2_199": "240"
        "d": "2020-02-17 08:40",
        "v_199": "0",
        "v2_199": "308"
        "d": "2020-02-17 08:45",
        "v_199": "0",
        "v2_199": "192"
        "d": "2020-02-17 08:50",
        "v_199": "0",
        "v2_199": "336"
        "d": "2020-02-17 08:55",
        "v_199": "0",
        "v2_199": "276"
        "d": "2020-02-17 09:00",
        "v_199": "0",
        "v2_199": "396"
        "d": "2020-02-17 09:05",
        "v_199": "0",
        "v2_199": "276"
        "d": "2020-02-17 09:10",
        "v_199": "0",
        "v2_199": "384"
        "d": "2020-02-17 09:15",
        "v_199": "0",
        "v2_199": "286"
        "d": "2020-02-17 09:20",
        "v_199": "0",
        "v2_199": "312"
        "d": "2020-02-17 09:25",
        "v_199": "0",
        "v2_199": "418"
        "d": "2020-02-17 09:30",
        "v_199": "0",
        "v2_199": "336"
        "d": "2020-02-17 09:35",
        "v_199": "0",
        "v2_199": "492"
        "d": "2020-02-17 09:40",
        "v_199": "0",
        "v2_199": "308"
        "d": "2020-02-17 09:45",
        "v_199": "0",
        "v2_199": "336"
        "d": "2020-02-17 09:50",
        "v_199": "0",
        "v2_199": "180"
        "d": "2020-02-17 09:55",
        "v_199": "0",
        "v2_199": "264"
        "d": "2020-02-17 10:00",
        "v_199": "0",
        "v2_199": "264"
        "d": "2020-02-17 10:05",
        "v_199": "0",
        "v2_199": "204"
        "d": "2020-02-17 10:10",
        "v_199": "0",
        "v2_199": "456"
        "d": "2020-02-17 10:15",
        "v_199": "0",
        "v2_199": "341"
        "d": "2020-02-17 10:20",
        "v_199": "0",
        "v2_199": "456"
        "d": "2020-02-17 10:25",
        "v_199": "0",
        "v2_199": "384"
        "d": "2020-02-17 10:30",
        "v_199": "0",
        "v2_199": "264"
        "d": "2020-02-17 10:35",
        "v_199": "0",
        "v2_199": "396"
        "d": "2020-02-17 10:40",
        "v_199": "0",
        "v2_199": "288"
        "d": "2020-02-17 10:45",
        "v_199": "0",
        "v2_199": "324"
        "d": "2020-02-17 10:50",
        "v_199": "0",
        "v2_199": "363"
        "d": "2020-02-17 10:55",
        "v_199": "0",
        "v2_199": "348"
        "d": "2020-02-17 11:00",
        "v_199": "0",
        "v2_199": "396"
        "d": "2020-02-17 11:05",
        "v_199": "0",
        "v2_199": "330"
        "d": "2020-02-17 11:10",
        "v_199": "0",
        "v2_199": "228"
        "d": "2020-02-17 11:15",
        "v_199": "0",
        "v2_199": "264"
        "d": "2020-02-17 11:20",
        "v_199": "0",
        "v2_199": "264"
        "d": "2020-02-17 11:25",
        "v_199": "0",
        "v2_199": "204"
        "d": "2020-02-17 11:30",
        "v_199": "0",
        "v2_199": "253"
        "d": "2020-02-17 11:35",
        "v_199": "0",
        "v2_199": "420"
        "d": "2020-02-17 11:40",
        "v_199": "0",
        "v2_199": "348"
        "d": "2020-02-17 11:45",
        "v_199": "0",
        "v2_199": "348"
        "d": "2020-02-17 11:50",
        "v_199": "0",
        "v2_199": "440"
        "d": "2020-02-17 11:55",
        "v_199": "0",
        "v2_199": "312"
        "d": "2020-02-17 12:00",
        "v_199": "0",
        "v2_199": "276"
        "d": "2020-02-17 12:05",
        "v_199": "0",
        "v2_199": "374"
        "d": "2020-02-17 12:10",
        "v_199": "0",
        "v2_199": "276"
        "d": "2020-02-17 12:15",
        "v_199": "0",
        "v2_199": "253"
        "d": "2020-02-17 12:20",
        "v_199": "0",
        "v2_199": "300"
        "d": "2020-02-17 12:25",
        "v_199": "0",
        "v2_199": "360"
        "d": "2020-02-17 12:30",
        "v_199": "0",
        "v2_199": "242"
        "d": "2020-02-17 12:35",
        "v_199": "0",
        "v2_199": "240"
        "d": "2020-02-17 12:40",
        "v_199": "0",
        "v2_199": "324"
        "d": "2020-02-17 12:45",
        "v_199": "0",
        "v2_199": "192"
        "d": "2020-02-17 12:50",
        "v_199": "0",
        "v2_199": "228"
        "d": "2020-02-17 12:55",
        "v_199": "0",
        "v2_199": "420"
        "d": "2020-02-17 13:00",
        "v_199": "0",
        "v2_199": "276"
        "d": "2020-02-17 13:05",
        "v_199": "0",
        "v2_199": "264"
        "d": "2020-02-17 13:10",
        "v_199": "0",
        "v2_199": "492"
        "d": "2020-02-17 13:15",
        "v_199": "0",
        "v2_199": "348"
        "d": "2020-02-17 13:20",
        "v_199": "0",
        "v2_199": "308"
        "d": "2020-02-17 13:25",
        "v_199": "0",
        "v2_199": "408"
        "d": "2020-02-17 13:30",
        "v_199": "0",
        "v2_199": "288"
        "d": "2020-02-17 13:35",
        "v_199": "0",
        "v2_199": "276"
        "d": "2020-02-17 13:40",
        "v_199": "0",
        "v2_199": "264"
        "d": "2020-02-17 13:45",
        "v_199": "0",
        "v2_199": "396"
        "d": "2020-02-17 13:50",
        "v_199": "0",
        "v2_199": "192"
        "d": "2020-02-17 13:55",
        "v_199": "0",
        "v2_199": "242"
        "d": "2020-02-17 14:00",
        "v_199": "0",
        "v2_199": "396"
        "d": "2020-02-17 14:05",
        "v_199": "0",
        "v2_199": "252"
        "d": "2020-02-17 14:10",
        "v_199": "0",
        "v2_199": "204"
        "d": "2020-02-17 14:15",
        "v_199": "0",
        "v2_199": "240"
        "d": "2020-02-17 14:20",
        "v_199": "0",
        "v2_199": "420"
        "d": "2020-02-17 14:25",
        "v_199": "0",
        "v2_199": "264"
        "d": "2020-02-17 14:30",
        "v_199": "0",
        "v2_199": "276"
        "d": "2020-02-17 14:35",
        "v_199": "0",
        "v2_199": "300"
        "d": "2020-02-17 14:40",
        "v_199": "0",
        "v2_199": "456"
        "d": "2020-02-17 14:45",
        "v_199": "0",
        "v2_199": "348"
        "d": "2020-02-17 14:50",
        "v_199": "0",
        "v2_199": "319"
        "d": "2020-02-17 14:55",
        "v_199": "0",
        "v2_199": "276"
        "d": "2020-02-17 15:00",
        "v_199": "0",
        "v2_199": "396"
        "d": "2020-02-17 15:05",
        "v_199": "0",
        "v2_199": "253"
        "d": "2020-02-17 15:10",
        "v_199": "0",
        "v2_199": "264"
        "d": "2020-02-17 15:15",
        "v_199": "0",
        "v2_199": "192"
        "d": "2020-02-17 15:20",
        "v_199": "0",
        "v2_199": "297"
        "d": "2020-02-17 15:25",
        "v_199": "0",
        "v2_199": "264"
        "d": "2020-02-17 15:30",
        "v_199": "0",
        "v2_199": "252"
        "d": "2020-02-17 15:35",
        "v_199": "0",
        "v2_199": "264"
        "d": "2020-02-17 15:40",
        "v_199": "0",
        "v2_199": "360"
        "d": "2020-02-17 15:45",
        "v_199": "0",
        "v2_199": "276"
        "d": "2020-02-17 15:50",
        "v_199": "0",
        "v2_199": "276"
        "d": "2020-02-17 15:55",
        "v_199": "0",
        "v2_199": "253"
        "d": "2020-02-17 16:00",
        "v_199": "0",
        "v2_199": "396"
        "d": "2020-02-17 16:05",
        "v_199": "0",
        "v2_199": "276"
        "d": "2020-02-17 16:10",
        "v_199": "0",
        "v2_199": "276"
        "d": "2020-02-17 16:15",
        "v_199": "0",
        "v2_199": "341"
        "d": "2020-02-17 16:20",
        "v_199": "0",
        "v2_199": "300"
        "d": "2020-02-17 16:25",
        "v_199": "0",
        "v2_199": "276"
        "d": "2020-02-17 16:30",
        "v_199": "0",
        "v2_199": "348"
        "d": "2020-02-17 16:35",
        "v_199": "0",
        "v2_199": "600"
        "d": "2020-02-17 16:40",
        "v_199": "0",
        "v2_199": "480"
        "d": "2020-02-17 16:45",
        "v_199": "0",
        "v2_199": "432"
        "d": "2020-02-17 16:50",
        "v_199": "0",
        "v2_199": "363"
        "d": "2020-02-17 16:55",
        "v_199": "0",
        "v2_199": "492"
        "d": "2020-02-17 17:00",
        "v_199": "0",
        "v2_199": "336"
        "d": "2020-02-17 17:05",
        "v_199": "0",
        "v2_199": "240"
        "d": "2020-02-17 17:10",
        "v_199": "0",
        "v2_199": "420"
        "d": "2020-02-17 17:15",
        "v_199": "0",
        "v2_199": "336"
        "d": "2020-02-17 17:20",
        "v_199": "0",
        "v2_199": "319"
        "d": "2020-02-17 17:25",
        "v_199": "0",
        "v2_199": "444"
        "d": "2020-02-17 17:30",
        "v_199": "0",
        "v2_199": "492"
        "d": "2020-02-17 17:35",
        "v_199": "0",
        "v2_199": "1392"
        "d": "2020-02-17 17:40",
        "v_199": "0",
        "v2_199": "876"
        "d": "2020-02-17 17:45",
        "v_199": "0",
        "v2_199": "1342"
        "d": "2020-02-17 17:50",
        "v_199": "0",
        "v2_199": "576"
        "d": "2020-02-17 17:55",
        "v_199": "0",
        "v2_199": "1128"
        "d": "2020-02-17 18:00",
        "v_199": "0",
        "v2_199": "605"
        "d": "2020-02-17 18:05",
        "v_199": "0",
        "v2_199": "1176"
        "d": "2020-02-17 18:10",
        "v_199": "0",
        "v2_199": "572"
        "d": "2020-02-17 18:15",
        "v_199": "0",
        "v2_199": "1080"
        "d": "2020-02-17 18:20",
        "v_199": "0",
        "v2_199": "816"
        "d": "2020-02-17 18:25",
        "v_199": "0",
        "v2_199": "828"
    "status": "OK",
    "title": "Graph day"
  "dataFilterCount": 0,
  "dataFilterUnit": "",
  "decimals": 2,
  "forced": false,
  "graphConfig": null,
  "graphIdx": "block_33199",
  "hasBlock": true,
  "idx": 199,
  "lastRefreshTime": 1581960343,
  "mountPoint": "#block_33",
  "multigraph": false,
  "name": "Elektriciteit",
  "popup": false,
  "primary": true,
  "primaryIdx": "block_33199",
  "range": "month",
  "realrange": "month",
  "sensor": "counter",
  "subtype": "Energy",
  "txtUnit": "kWh",
  "type": "P1 Smart Meter",
  "keys": [
    "v",
    "v2"
  "ykeys": [
    "v_199",
    "v2_199"
  "ylabels": [
    "kWh",
    "kWh"
HTH
Greetz,
Sjonnie
Posted: Monday 17 February 2020 18:38
by clinkadink
Thanks for the feedback!
Can you try with interval commented out?
Edit: did you copy the debug log after pressing the 'month' button? As the range shows "month" but the data is for "days". Scroll to the bottom of the debug log.
"range": "month",
Posted: Monday 17 February 2020 18:44
by Sjonnie2017
But of course :)
No change in the graphs unfortunately :|
‘Eliminate all other factors, and the one which remains must be the truth.’
:lol:
EDIT: Debug log after first load (not selecting a time range):
  "block": {
    "devices": [
      199
    "datasetColors": [
      "red",
      "yellow",
      "blue",
      "orange",
      "green",
      "purple"
    "barWidth": 0.9,
    "borderColors": [
      "red",
      "yellow",
      "blue",
      "orange",
      "green",
      "purple"
    "borderDash": [],
    "borderWidth": 2,
    "buttonsPadX": 6,
    "buttonsPadY": 2,
    "buttonsRadius": 4,
    "buttonsSize": 14,
    "custom": false,
    "gradients": false,
    "graph": "line",
    "graphTypes": [
      "v",
      "v2"
    "height": "400px",
    "interval": 1,
    "legend": {
      "v2_199": "Dag",
      "v_199": "Nacht"
    "lineFill": false,
    "lineTension": 0.1,
    "method": 1,
      "grey"
    "pointFillColor": [
      "red",
      "yellow",
      "blue",
      "orange",
      "green",
      "purple"
    "pointRadius": 0,
    "spanGaps": false,
    "width": 12
  "currentValue": "7.93 kWh",
  "currentValues": [
    "7.93 kWh"
  "data": {
    "result": [
        "v_199": "0",
        "v2_199": "0"
        "v_199": "2992",
        "v2_199": "0"
        "v_199": "2808",
        "v2_199": "0"
        "v_199": "1596",
        "v2_199": "0"
        "v_199": "792",
        "v2_199": "0"
        "v_199": "649",
        "v2_199": "0"
        "v_199": "684",
        "v2_199": "0"
        "v_199": "672",
        "v2_199": "0"
        "v_199": "627",
        "v2_199": "0"
        "v_199": "672",
        "v2_199": "0"
        "v_199": "684",
        "v2_199": "0"
        "v_199": "638",
        "v2_199": "0"
        "v_199": "744",
        "v2_199": "0"
        "v_199": "660",
        "v2_199": "0"
        "v_199": "732",
        "v2_199": "0"
        "v_199": "594",
        "v2_199": "0"
        "v_199": "756",
        "v2_199": "0"
        "v_199": "636",
        "v2_199": "0"
        "v_199": "660",
        "v2_199": "0"
        "v_199": "627",
        "v2_199": "0"
        "v_199": "696",
        "v2_199": "0"
        "v_199": "720",
        "v2_199": "0"
        "v_199": "708",
        "v2_199": "0"
        "v_199": "648",
        "v2_199": "0"
        "v_199": "594",
        "v2_199": "0"
        "v_199": "594",
        "v2_199": "0"
        "v_199": "624",
        "v2_199": "0"
        "v_199": "576",
        "v2_199": "0"
        "v_199": "756",
        "v2_199": "0"
        "v_199": "624",
        "v2_199": "0"
        "v_199": "561",
        "v2_199": "0"
        "v_199": "612",
        "v2_199": "0"
        "v_199": "660",
        "v2_199": "0"
        "v_199": "648",
        "v2_199": "0"
        "v_199": "516",
        "v2_199": "0"
        "v_199": "492",
        "v2_199": "0"
        "v_199": "480",
        "v2_199": "0"
        "v_199": "612",
        "v2_199": "0"
        "v_199": "492",
        "v2_199": "0"
        "v_199": "408",
        "v2_199": "0"
        "v_199": "420",
        "v2_199": "0"
        "v_199": "384",
        "v2_199": "0"
        "v_199": "297",
        "v2_199": "0"
        "v_199": "312",
        "v2_199": "0"
        "v_199": "408",
        "v2_199": "0"
        "v_199": "504",
        "v2_199": "0"
        "v_199": "468",
        "v2_199": "0"
        "v_199": "432",
        "v2_199": "0"
        "v_199": "374",
        "v2_199": "0"
        "v_199": "408",
        "v2_199": "0"
        "v_199": "396",
        "v2_199": "0"
        "v_199": "396",
        "v2_199": "0"
        "v_199": "576",
        "v2_199": "0"
        "v_199": "468",
        "v2_199": "0"
        "v_199": "420",
        "v2_199": "0"
        "v_199": "330",
        "v2_199": "0"
        "v_199": "300",
        "v2_199": "0"
        "v_199": "312",
        "v2_199": "0"
        "v_199": "312",
        "v2_199": "0"
        "v_199": "540",
        "v2_199": "0"
        "v_199": "363",
        "v2_199": "0"
        "v_199": "480",
        "v2_199": "0"
        "v_199": "468",
        "v2_199": "0"
        "v_199": "480",
        "v2_199": "0"
        "v_199": "396",
        "v2_199": "0"
        "v_199": "552",
        "v2_199": "0"
        "v_199": "408",
        "v2_199": "0"
        "v_199": "319",
        "v2_199": "0"
        "v_199": "336",
        "v2_199": "0"
        "v_199": "360",
        "v2_199": "0"
        "v_199": "528",
        "v2_199": "0"
        "v_199": "420",
        "v2_199": "0"
        "v_199": "429",
        "v2_199": "0"
        "v_199": "396",
        "v2_199": "0"
        "v_199": "420",
        "v2_199": "0"
        "v_199": "552",
        "v2_199": "0"
        "v_199": "408",
        "v2_199": "0"
        "v_199": "396",
        "v2_199": "0"
        "v_199": "418",
        "v2_199": "0"
        "v_199": "480",
        "v2_199": "0"
        "v_199": "540",
        "v2_199": "0"
        "v_199": "360",
        "v2_199": "0"
        "v_199": "324",
        "v2_199": "0"
        "v_199": "312",
        "v2_199": "0"
        "v_199": "492",
        "v2_199": "0"
        "v_199": "432",
        "v2_199": "0"
        "v_199": "385",
        "v2_199": "0"
        "v_199": "492",
        "v2_199": "0"
        "v_199": "456",
        "v2_199": "0"
        "v_199": "420",
        "v2_199": "0"
        "v_199": "480",
        "v2_199": "0"
        "v_199": "561",
        "v2_199": "0"
        "v_199": "480",
        "v2_199": "0"
        "v_199": "396",
        "v2_199": "0"
        "v_199": "418",
        "v2_199": "0"
        "v_199": "312",
        "v2_199": "0"
        "v_199": "324",
        "v2_199": "0"
        "v_199": "444",
        "v2_199": "0"
        "v_199": "451",
        "v2_199": "0"
        "v_199": "456",
        "v2_199": "0"
        "v_199": "516",
        "v2_199": "0"
        "v_199": "612",
        "v2_199": "0"
        "v_199": "429",
        "v2_199": "0"
        "v_199": "456",
        "v2_199": "0"
        "v_199": "492",
        "v2_199": "0"
        "v_199": "396",
        "v2_199": "0"
        "v_199": "396",
        "v2_199": "0"
        "v_199": "312",
        "v2_199": "0"
        "v_199": "363",
        "v2_199": "0"
        "v_199": "504",
        "v2_199": "0"
        "v_199": "336",
        "v2_199": "0"
        "v_199": "372",
        "v2_199": "0"
        "v_199": "480",
        "v2_199": "0"
        "v_199": "348",
        "v2_199": "0"
        "v_199": "385",
        "v2_199": "0"
        "v_199": "396",
        "v2_199": "0"
        "v_199": "360",
        "v2_199": "0"
        "v_199": "552",
        "v2_199": "0"
        "v_199": "374",
        "v2_199": "0"
        "v_199": "360",
        "v2_199": "0"
        "v_199": "384",
        "v2_199": "0"
        "v_199": "231",
        "v2_199": "0"
        "v_199": "444",
        "v2_199": "0"
        "v_199": "360",
        "v2_199": "0"
        "v_199": "516",
        "v2_199": "0"
        "v_199": "684",
        "v2_199": "0"
        "v_199": "588",
        "v2_199": "0"
        "v_199": "660",
        "v2_199": "0"
        "v_199": "732",
        "v2_199": "0"
        "v_199": "696",
        "v2_199": "0"
        "v_199": "576",
        "v2_199": "0"
        "v_199": "352",
        "v2_199": "0"
        "v_199": "744",
        "v2_199": "0"
        "v_199": "352",
        "v2_199": "0"
        "v_199": "456",
        "v2_199": "0"
        "v_199": "420",
        "v2_199": "0"
        "v_199": "864",
        "v2_199": "0"
        "v_199": "636",
        "v2_199": "0"
        "v_199": "418",
        "v2_199": "0"
        "v_199": "636",
        "v2_199": "0"
        "v_199": "372",
        "v2_199": "0"
        "v_199": "583",
        "v2_199": "0"
        "v_199": "341",
        "v2_199": "0"
        "v_199": "504",
        "v2_199": "0"
        "v_199": "468",
        "v2_199": "0"
        "v_199": "372",
        "v2_199": "0"
        "v_199": "0",
        "v2_199": "516"
        "v_199": "0",
        "v2_199": "275"
        "v_199": "0",
        "v2_199": "360"
        "v_199": "0",
        "v2_199": "216"
        "v_199": "0",
        "v2_199": "360"
        "v_199": "0",
        "v2_199": "198"
        "v_199": "0",
        "v2_199": "360"
        "v_199": "0",
        "v2_199": "372"
        "v_199": "0",
        "v2_199": "407"
        "v_199": "0",
        "v2_199": "444"
        "v_199": "0",
        "v2_199": "324"
        "v_199": "0",
        "v2_199": "408"
        "v_199": "0",
        "v2_199": "276"
        "v_199": "0",
        "v2_199": "396"
        "v_199": "0",
        "v2_199": "324"
        "v_199": "0",
        "v2_199": "480"
        "v_199": "0",
        "v2_199": "308"
        "v_199": "0",
        "v2_199": "408"
        "v_199": "0",
        "v2_199": "240"
        "v_199": "0",
        "v2_199": "308"
        "v_199": "0",
        "v2_199": "192"
        "v_199": "0",
        "v2_199": "336"
        "v_199": "0",
        "v2_199": "276"
        "v_199": "0",
        "v2_199": "396"
        "v_199": "0",
        "v2_199": "276"
        "v_199": "0",
        "v2_199": "384"
        "v_199": "0",
        "v2_199": "286"
        "v_199": "0",
        "v2_199": "312"
        "v_199": "0",
        "v2_199": "418"
        "v_199": "0",
        "v2_199": "336"
        "v_199": "0",
        "v2_199": "492"
        "v_199": "0",
        "v2_199": "308"
        "v_199": "0",
        "v2_199": "336"
        "v_199": "0",
        "v2_199": "180"
        "v_199": "0",
        "v2_199": "264"
        "v_199": "0",
        "v2_199": "264"
        "v_199": "0",
        "v2_199": "204"
        "v_199": "0",
        "v2_199": "456"
        "v_199": "0",
        "v2_199": "341"
        "v_199": "0",
        "v2_199": "456"
        "v_199": "0",
        "v2_199": "384"
        "v_199": "0",
        "v2_199": "264"
        "v_199": "0",
        "v2_199": "396"
        "v_199": "0",
        "v2_199": "288"
        "v_199": "0",
        "v2_199": "324"
        "v_199": "0",
        "v2_199": "363"
        "v_199": "0",
        "v2_199": "348"
        "v_199": "0",
        "v2_199": "396"
        "v_199": "0",
        "v2_199": "330"
        "v_199": "0",
        "v2_199": "228"
        "v_199": "0",
        "v2_199": "264"
        "v_199": "0",
        "v2_199": "264"
        "v_199": "0",
        "v2_199": "204"
        "v_199": "0",
        "v2_199": "253"
        "v_199": "0",
        "v2_199": "420"
        "v_199": "0",
        "v2_199": "348"
        "v_199": "0",
        "v2_199": "348"
        "v_199": "0",
        "v2_199": "440"
        "v_199": "0",
        "v2_199": "312"
        "v_199": "0",
        "v2_199": "276"
        "v_199": "0",
        "v2_199": "374"
        "v_199": "0",
        "v2_199": "276"
        "v_199": "0",
        "v2_199": "253"
        "v_199": "0",
        "v2_199": "300"
        "v_199": "0",
        "v2_199": "360"
        "v_199": "0",
        "v2_199": "242"
        "v_199": "0",
        "v2_199": "240"
        "v_199": "0",
        "v2_199": "324"
        "v_199": "0",
        "v2_199": "192"
        "v_199": "0",
        "v2_199": "228"
        "v_199": "0",
        "v2_199": "420"
        "v_199": "0",
        "v2_199": "276"
        "v_199": "0",
        "v2_199": "264"
        "v_199": "0",
        "v2_199": "492"
        "v_199": "0",
        "v2_199": "348"
        "v_199": "0",
        "v2_199": "308"
        "v_199": "0",
        "v2_199": "408"
        "v_199": "0",
        "v2_199": "288"
        "v_199": "0",
        "v2_199": "276"
        "v_199": "0",
        "v2_199": "264"
        "v_199": "0",
        "v2_199": "396"
        "v_199": "0",
        "v2_199": "192"
        "v_199": "0",
        "v2_199": "242"
        "v_199": "0",
        "v2_199": "396"
        "v_199": "0",
        "v2_199": "252"
        "v_199": "0",
        "v2_199": "204"
        "v_199": "0",
        "v2_199": "240"
        "v_199": "0",
        "v2_199": "420"
        "v_199": "0",
        "v2_199": "264"
        "v_199": "0",
        "v2_199": "276"
        "v_199": "0",
        "v2_199": "300"
        "v_199": "0",
        "v2_199": "456"
        "v_199": "0",
        "v2_199": "348"
        "v_199": "0",
        "v2_199": "319"
        "v_199": "0",
        "v2_199": "276"
        "v_199": "0",
        "v2_199": "396"
        "v_199": "0",
        "v2_199": "253"
        "v_199": "0",
        "v2_199": "264"
        "v_199": "0",
        "v2_199": "192"
        "v_199": "0",
        "v2_199": "297"
        "v_199": "0",
        "v2_199": "264"
        "v_199": "0",
        "v2_199": "252"
        "v_199": "0",
        "v2_199": "264"
        "v_199": "0",
        "v2_199": "360"
        "v_199": "0",
        "v2_199": "276"
        "v_199": "0",
        "v2_199": "276"
        "v_199": "0",
        "v2_199": "253"
        "v_199": "0",
        "v2_199": "396"
        "v_199": "0",
        "v2_199": "276"
        "v_199": "0",
        "v2_199": "276"
        "v_199": "0",
        "v2_199": "341"
        "v_199": "0",
        "v2_199": "300"
        "v_199": "0",
        "v2_199": "276"
        "v_199": "0",
        "v2_199": "348"
        "v_199": "0",
        "v2_199": "600"
        "v_199": "0",
        "v2_199": "480"
        "v_199": "0",
        "v2_199": "432"
        "v_199": "0",
        "v2_199": "363"
        "v_199": "0",
        "v2_199": "492"
        "v_199": "0",
        "v2_199": "336"
        "v_199": "0",
        "v2_199": "240"
        "v_199": "0",
        "v2_199": "420"
        "v_199": "0",
        "v2_199": "336"
        "v_199": "0",
        "v2_199": "319"
        "v_199": "0",
        "v2_199": "444"
        "v_199": "0",
        "v2_199": "492"
        "v_199": "0",
        "v2_199": "1392"
        "v_199": "0",
        "v2_199": "876"
        "v_199": "0",
        "v2_199": "1342"
        "v_199": "0",
        "v2_199": "576"
        "v_199": "0",
        "v2_199": "1128"
        "v_199": "0",
        "v2_199": "605"
        "v_199": "0",
        "v2_199": "1176"
        "v_199": "0",
        "v2_199": "572"
        "v_199": "0",
        "v2_199": "1080"
        "v_199": "0",
        "v2_199": "816"
        "v_199": "0",
        "v2_199": "828"
        "d": "2020-02-17 18:30",
        "v_199": "0",
        "v2_199": "756"
        "d": "2020-02-17 18:35",
        "v_199": "0",
        "v2_199": "825"
        "d": "2020-02-17 18:40",
        "v_199": "0",
        "v2_199": "588"
        "d": "2020-02-17 18:45",
        "v_199": "0",
        "v2_199": "1144"
    "status": "OK",
  "decimals": 2,
  "forced": false,
  "hasBlock": true,
  "idx": 199,
  "lastRefreshTime": 1581961504,
  "popup": false,
  "primary": true,
  "range": "month",
  "txtUnit": "kWh",
  "keys": [
    "v",
    "v2"
  "ykeys": [
    "v_199",
    "v2_199"
  "ylabels": [
    "kWh",
    "kWh"
Posted: Monday 17 February 2020 18:51
by clinkadink
Sjonnie2017 wrote: Monday 17 February 2020 18:44 Debug log after first load (not selecting a time range):
   // truncated //
  "range": "month",       <---- should be "day"
  "realrange": "month",   <---- should be "day"
  "txtUnit": "kWh",
  "keys": [
    "v",
    "v2"
  "ykeys": [
    "v_199",
    "v2_199"
  "ylabels": [
    "kWh",
    "kWh"
That ^^^ is the reason. As suspected, your graph is initiating with range set to month. The default for month is kWh. Now to work out why.
It looks like the debug button is paying off already ;)
Posted: Monday 17 February 2020 18:55
by Sjonnie2017
I think we found the "why"
This is in my custom.js:
config['standard_graph'] = 'month';
Will rem it out and see what happens...
EDIT: Bingo!
However I would like to have last month as the standard time period for these graphs ;)
EDIT2: On the other hand: if it is a lot of work I will settle for 'day' :mrgreen:
Posted: Monday 17 February 2020 19:16
by clinkadink
Sjonnie2017 wrote: Monday 17 February 2020 18:55 However I would like to have last month as the standard time period for these graphs ;)
I should be able to fix it, now I know what the reason is. Thanks for the info. Leave it with me, I will get back to you ;)
Posted: Monday 17 February 2020 19:24
by Sjonnie2017
I am certain you will! Somehow I expect to have to update to the latest beta somewhere in the near future :lol:
