Page 9 of 14
Re: Python Plugin: GoodWe solar inverter via SEMS API
Posted: Sunday 02 January 2022 22:52
by JanJaap
Well you'd need to post some logging to see why it would cause the crash. There are multiple users without issues so maybe you missed some of the preconditions?
Posted: Sunday 16 January 2022 15:31
by whoami
I see that since the 4th of january I get the message:
"Failed to request data: Failed to call GoodWe API (return code = 100007)"
rebooting or restarting wont help.
Does anybody has this same message?
EDIT: selected europe and it works again
Posted: Sunday 16 January 2022 16:10
by JanJaap
I had the same issue, restarted the plugin and logged in with the Goodwe app and it worked again.....
Posted: Tuesday 18 January 2022 16:51
by jspeybro
I'm trying to get this plugin running, but get this in the logs:
2022-01-18 16:40:33.609 Error: GoodWe Solar Inverter: (GoodWeSEMS) failed to load 'plugin.py', Python Path used was '/config/plugins/domoticz-GoodWeSEMS-master/:/usr/lib/python38.zip:/usr/lib/python3.8:/usr/lib/python3.8/lib-dynload:/usr/local/lib/python3.8/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.8/dist-packages'.
2022-01-18 16:40:33.610 Error: GoodWe Solar Inverter: (GoodWe Solar Inverter) Module Import failed, exception: 'ModuleNotFoundError'
2022-01-18 16:40:33.610 Error: GoodWe Solar Inverter: (GoodWe Solar Inverter) Module Import failed: ' Name: requests'
2022-01-18 16:40:33.610 Error: GoodWe Solar Inverter: (GoodWe Solar Inverter) Error Line details not available.
2022-01-18 16:40:38.886 Error: Goodwe Solar Inverter: Error getting http user data!
I'm running domoticz in a docker container on libreElec.
Python is installed, but maybe I'm missing some additional packages?
any idea?
thanks
regards,
Johan
Posted: Tuesday 18 January 2022 17:01
by JanJaap
Yes, you are missing the 'request' package as indicated in the log. Please see installation instructions. Be aware that the installation path may depend on the user that makes the instalaltion. Your logfile mentions the path below as to look for the requests package.
Posted: Tuesday 18 January 2022 18:50
by jspeybro
ok, got it to work by copying manually the required modules to the Goodwe plugin directory
in case someone else needs it for libreelec 10:
I had to get these libraries from here:
https://github.com/psf/requests
https://github.com/urllib3/urllib3
https://github.com/chardet/chardet
https://github.com/kjd/idna
https://github.com/certifi/python-certifi
I unpacked them and copied the subdirectory with the library name to
/storage/.kodi/userdata/addon_data/docker.linuxserver.domoticz/config/plugins/domoticz-GoodWeSEMS-master/
after that, the devices show up and can be added to domoticz.
thanks for the plugin.
any way you can also get it to download all the historic data?
Posted: Tuesday 18 January 2022 19:06
by waltervl
Perhaps consider to use a docker container on LibreElec:
https://www.domoticz.com/wiki/Docker
Posted: Thursday 20 January 2022 12:37
by jspeybro
that's what I did, but then I didn't find how I should add the extra libraries that were required for python. just adding them manually to the plugin seemed to work for me but if there's a better way, I'm all ears.
Posted: Thursday 20 January 2022 21:49
by waltervl
Other way is to install them within the docker container with
docker exec -it domoticz
And then in that shell
pip3 install "module"
You have to install them every time you upgrade the docker container. There is already an discussion to have some kind of script in the container to have them installed after update.
Posted: Wednesday 26 January 2022 14:42
by waltervl
There seems to be a Python library that is reading the Goodwe inverter directly. See
https://domoticz.com/forum/viewtopic.ph ... 56#p285656
Is it possible to create a plugin for this? Should be better than scraping the cloud. Also when the cloud portal is gone (like Omnik) you can continue to monitor your inverter.
It seems that this libary is very usable for Domoticz:
https://github.com/marcelblijleven/goodwe
Posted: Thursday 07 April 2022 15:48
by tykasan
Hello Everyone,
I;'d like to ask you, about compatility issues on Domoticz Version: 2021.1
After update I dont have field for password and plugin wont connect.
I tried to clear browser cache/incognito mode/ domoticz reinstall/ plugin reinstall... nothing works...
Im thinking to revert back to versio 2020.03.
Can you please advise
M
Posted: Thursday 07 April 2022 21:19
by JanJaap
I'm running latest development with no issues.... Perhaps try a clean installation?
Posted: Thursday 07 April 2022 22:23
by tykasan
Thank for suggestion. I was hoping for not having to do so...
But yes, it worked....
fortunately I had a copy of working backup (not the latest one) but it will save me a lot of time to cofigure
Thank you for your input!
Posted: Tuesday 12 April 2022 8:56
by Darsh
Plugin version 1.1.1, author 'dylian94'
Domoticz version: 2022.1 (build 14231)
Starting from today 02:45 UTC, the plugin crashes, stopping Domoticz as well:
2022-04-12 03:45:14.510 GoodWe GW2500-NS: Station data received from GoodWe SEMS API (Station ID: cf85dc2c-8e0c-4aa9-8572-dd768e7e4a55)
2022-04-12 03:45:14.510 Error: GoodWe GW2500-NS: Call to function 'onMessage' failed, exception details:
2022-04-12 03:45:14.526 Error: Domoticz(pid:2724734, tid:2724767('GoodWe GW2500-N')) received fatal signal 11 (Segmentation fault)
2022-04-12 03:45:14.526 Error: siginfo address=0x770029937e, address=0x7f3a7b854fe1
2022-04-12 03:45:14.533 Error: Failed to start gdb, will use backtrace() for printing stack frame
2022-04-12 03:45:14.674 Error: #0 /home/domovoi/domoticz/domoticz : + 0x3f1c33 [0x55e20d807c33]
2022-04-12 03:45:14.674 Error: #1 /home/domovoi/domoticz/domoticz : signal_handler(int, siginfo_t*, void*) + 0x29d [0x55e20d80871d]
2022-04-12 03:45:14.674 Error: #2 /lib/x86_64-linux-gnu/libpthread.so.0 : + 0x14140 [0x7f3a7b855140]
2022-04-12 03:45:14.674 Error: #3 /lib/x86_64-linux-gnu/libpthread.so.0 : raise + 0x141 [0x7f3a7b854fe1]
2022-04-12 03:45:14.674 Error: #4 /lib/x86_64-linux-gnu/libpthread.so.0 : + 0x14140 [0x7f3a7b855140]
2022-04-12 03:45:14.674 Error: #5 /usr/lib/x86_64-linux-gnu/libpython3.9.so : + 0x1249d8 [0x7f3a7a68c9d8]
2022-04-12 03:45:14.674 Error: #6 /usr/lib/x86_64-linux-gnu/libpython3.9.so : _PyObject_MakeTpCall + 0x90 [0x7f3a7a62ea50]
2022-04-12 03:45:14.674 Error: #7 /usr/lib/x86_64-linux-gnu/libpython3.9.so : _PyEval_EvalFrameDefault + 0x7248 [0x7f3a7a5def08]
2022-04-12 03:45:14.674 Error: #8 /usr/lib/x86_64-linux-gnu/libpython3.9.so : + 0x1a4ddc [0x7f3a7a70cddc]
2022-04-12 03:45:14.674 Error: #9 /usr/lib/x86_64-linux-gnu/libpython3.9.so : _PyFunction_Vectorcall + 0x9d [0x7f3a7a629c7d]
2022-04-12 03:45:14.674 Error: #10 /usr/lib/x86_64-linux-gnu/libpython3.9.so : + 0xc8724 [0x7f3a7a630724]
2022-04-12 03:45:14.674 Error: #11 /usr/lib/x86_64-linux-gnu/libpython3.9.so : PyObject_CallFunctionObjArgs + 0x9f [0x7f3a7a630baf]
2022-04-12 03:45:14.674 Error: #12 /home/domovoi/domoticz/domoticz : Plugins::CPlugin::LogPythonException() + 0x1bc [0x55e20dca519c]
2022-04-12 03:45:14.674 Error: #13 /home/domovoi/domoticz/domoticz : Plugins::CPlugin::Callback(_object*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, _object*) + 0x1b6 [0x55e20dca7806]
2022-04-12 03:45:14.674 Error: #14 /home/domovoi/domoticz/domoticz : Plugins::onMessageCallback::ProcessLocked(Plugins::CPlugin*) + 0x1b3 [0x55e20dcc81b3]
2022-04-12 03:45:14.674 Error: #15 /home/domovoi/domoticz/domoticz : Plugins::CPluginMessageBase::Process(Plugins::CPlugin*) + 0x2b [0x55e20d78632b]
2022-04-12 03:45:14.674 Error: #16 /home/domovoi/domoticz/domoticz : Plugins::CPlugin::Do_Work() + 0x490 [0x55e20dcaf2f0]
2022-04-12 03:45:14.674 Error: #17 /home/domovoi/domoticz/domoticz : + 0xb546d0 [0x55e20df6a6d0]
2022-04-12 03:45:14.674 Error: #18 /lib/x86_64-linux-gnu/libpthread.so.0 : + 0x8ea7 [0x7f3a7b849ea7]
2022-04-12 03:45:14.674 Error: #19 /lib/x86_64-linux-gnu/libc.so.6 : clone + 0x3f [0x7f3a7b615def]
Restarting Domoticz doesn't help, after 5-6 successful SEMS portal polls the plugin fails again with the same message "Call to function 'onMessage' failed":
2022-04-12 04:17:05.244 GoodWe GW2500-NS: Worker thread started.
2022-04-12 04:17:05.244 Status: GoodWe GW2500-NS: Entering work loop.
2022-04-12 04:17:05.244 Status: GoodWe GW2500-NS: Started.
2022-04-12 04:17:05.348 Status: GoodWe GW2500-NS: Initialized version 1.1.1, author 'dylian94'
2022-04-12 04:17:06.771 GoodWe GW2500-NS: Station data received from GoodWe SEMS API (Station ID: cf85dc2c-8e0c-4aa9-8572-dd768e7e4a55)
2022-04-12 04:17:06.773 GoodWe GW2500-NS: Updated 18 device(s) for 1 station(s) with 1 inverter(s)
2022-04-12 04:18:05.409 GoodWe GW2500-NS: Station data received from GoodWe SEMS API (Station ID: cf85dc2c-8e0c-4aa9-8572-dd768e7e4a55)
2022-04-12 04:18:05.411 GoodWe GW2500-NS: Updated 18 device(s) for 1 station(s) with 1 inverter(s)
2022-04-12 04:19:05.714 GoodWe GW2500-NS: Station data received from GoodWe SEMS API (Station ID: cf85dc2c-8e0c-4aa9-8572-dd768e7e4a55)
2022-04-12 04:19:05.716 GoodWe GW2500-NS: Updated 18 device(s) for 1 station(s) with 1 inverter(s)
2022-04-12 04:20:06.370 GoodWe GW2500-NS: Station data received from GoodWe SEMS API (Station ID: cf85dc2c-8e0c-4aa9-8572-dd768e7e4a55)
2022-04-12 04:20:06.372 GoodWe GW2500-NS: Updated 18 device(s) for 1 station(s) with 1 inverter(s)
2022-04-12 04:21:06.325 GoodWe GW2500-NS: Station data received from GoodWe SEMS API (Station ID: cf85dc2c-8e0c-4aa9-8572-dd768e7e4a55)
2022-04-12 04:21:06.327 GoodWe GW2500-NS: Updated 18 device(s) for 1 station(s) with 1 inverter(s)
2022-04-12 04:22:05.231 GoodWe GW2500-NS: Station data received from GoodWe SEMS API (Station ID: cf85dc2c-8e0c-4aa9-8572-dd768e7e4a55)
2022-04-12 04:22:05.231 Error: GoodWe GW2500-NS: Call to function 'onMessage' failed, exception details:
2022-04-12 04:22:05.233 Error: Domoticz(pid:2844608, tid:2844629('GoodWe GW2500-N')) received fatal signal 11 (Segmentation fault)
Additionally, after restarting Domoticz and stopping the plugin, I've got another bunch of errors:
2022-04-12 08:06:06.305 Error: GoodWe GW2500-NS: Stop: Device 'GoodWe GW2500-NS - Solar inverter output current' Reference Count not correct, expected 1 found 2.
2022-04-12 08:06:06.305 Error: GoodWe GW2500-NS: Stop: Device 'GoodWe GW2500-NS - Solar inverter output voltage' Reference Count not correct, expected 1 found 2.
2022-04-12 08:06:06.305 Error: GoodWe GW2500-NS: Stop: Device 'Solar (kWh)' Reference Count not correct, expected 1 found 2.
It has been working fine up until today.
Has something changed on the SEMS portal that needs updating the plugin?
Additional question: is it possible to make Domoticz keep running if one of its plugins fails?
Darsh
Posted: Tuesday 12 April 2022 11:02
by JanJaap
You seem to be using the (very) old version by Dylian (which is no longer maintained). You need to pull from here:
https://github.com/JanJaapKo/domoticz-GoodWeSEMS
This one is running flawlessly on my end.
Posted: Tuesday 12 April 2022 11:34
by JanJaap
OK I need some more info to fully get it. Please run the plugin in debug mode and create an issue on GitHub with the logging included. Please also provide info like operating system etc.
Edit:
OK I see the previous comment is gone so assume the problem is also gone?
Posted: Tuesday 12 April 2022 11:59
by Darsh
Hi Jan-Jaap,
Thanks, your 2.0.7 is working fine. The issue was caused by the wrong portal password.
Darsh
Posted: Tuesday 12 April 2022 12:03
by JanJaap
OK, that is good to know. Wrong passwords should be handled a little bit more elegant than this
I'l look into that.
Posted: Friday 17 June 2022 11:39
by tonymer
Hi, Thanks for the plugin. Would there be any way to have in Domoticz the import/export of energy to the network? For me it is the most important data because it is what allows me to activate things automatically without spending energy. That data is in SEMS and also when you connect locally through PV Master. I have done some local connection test with the goodwe inverter and I have managed to request some test information (Model, serial number, etc). Thanks in advance
Posted: Friday 17 June 2022 17:03
by JanJaap
Hi Tony,
What do you exactly mean with 'import/export' to the network? The inverter can only see how much power it generates into the network of your house (which is the main counter in the plugin). It cannot know how much you (your house) had to take from the public network (a.k.a the grid). You need to read out your connection (I've got a smart meter with a so-called P1 plug which nicely lets me do that in Domoticz). I also do not see any such data in the SEMS portal.
Things get a bit more interesting when you have an inverter with not only solar panels but also a battery. I do not own such a thing so I'm depending on others to provide me with the data structures to make that happen. See
plugin issue 14. I do not have proper logging yet in that issue......
