Support for Somfy Connexoon and Tahoma
TheoL
- Domoticz version: 2024.7
Re: Support for Somfy Connexoon and Tahoma
Where can I find that one? And thanx for the quick response
- madpatrick
- Domoticz version: 2025.2
TheoL
That is the one I installed. And I followed those instructions. Although it's weird that the logs give a different version.
I think things went wrong, because I already had installed the old one first. I did find it strange that the config was messed up.
Now I'm getting these warnings:
2025-04-29 22:24:42.876 Error: Somfy: Call to function 'onStart' failed, exception details:
2025-04-29 22:24:42.878 Error: Somfy: Traceback (most recent call last):
2025-04-29 22:24:42.878 Error: Somfy: File "/home/domoticz_root/domoticz/plugins/somfy/plugin.py", line 576, in onStart
2025-04-29 22:24:42.878 Error: Somfy: _plugin.onStart()
2025-04-29 22:24:42.878 Error: Somfy: File "/home/domoticz_root/domoticz/plugins/somfy/plugin.py", line 165, in onStart
2025-04-29 22:24:42.878 Error: Somfy: self.tahoma.activate_token(pin,self.tahoma.token)
2025-04-29 22:24:42.878 Error: Somfy: File "/home/domoticz_root/domoticz/plugins/somfy/tahoma_local.py", line 119, in activate_token
2025-04-29 22:24:42.878 Error: Somfy: raise exceptions.LoginFailure("failed to activate token")
2025-04-29 22:24:42.878 Error: Somfy: exceptions.LoginFailure: failed to activate token
2025-04-29 22:25:06.115 Error: Somfy: Failed to request data: HTTPSConnectionPool(host='2033-9273-2678%20.local', port=8443): Max retries exceeded with url: /enduser-mobile-web/1/enduserAPI/setup/devices (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f9833f5e0>: Failed to establish a new connection: [Errno -2] Name or service not known'))
2025-04-29 22:25:30.116 Error: Somfy: Failed to request data: HTTPSConnectionPool(host='2033-9273-2678%20.local', port=8443): Max retries exceeded with url: /enduser-mobile-web/1/enduserAPI/setup/devices (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f9833f4f0>: Failed to establish a new connection: [Errno -2] Name or service not known'))
2025-04-29 22:25:54.110 Error: Somfy: Failed to request data: HTTPSConnectionPool(host='2033-9273-2678%20.local', port=8443): Max retries exceeded with url: /enduser-mobile-web/1/enduserAPI/setup/devices (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f9833f640>: Failed to establish a new connection: [Errno -2] Name or service not known'))
Okay I got it. I accidently added a space character behind the PIN. The plugin didn't like that. I see my devices now. Thanx for your time.
Rik60
I am running the beta version of the plugin, 4.2.22. It's working fine but causes an error in the Domoticz logging (Python, key error) when one of the devices was moving. I have solved this error by modifing the plugin.py file. I have added 2 lines around line 360, see attached pictures. To use the attached file, remove the.txt extension. I am controlling 2 roller shutters, 3 screens and 1 awning, Somfy IO system. Domoticz version 2025.1 build 16675. I am running this modified plugin now for an 1/2 year without problems/ errors
- Modified_plugin.py_4.2.22.jpg (67.97 KiB) Viewed 1400 times
- plugin.py_4.2.22.jpg (77.51 KiB) Viewed 1400 times
- plugin.py.txt
- (33.45 KiB) Downloaded 22 times
- madpatrick
thanks
Added to the beta 4.2.23
Tip.
Better to add text is a bracket field </> then by using a picture
You can thr easily copy the text
OLD
NEW
Tip.
OLD
if dataset["deviceURL"] not in Devices:
Domoticz.Error("device not found for URL: "+str(dataset["deviceURL"]))
logging.error("device not found for URL: "+str(dataset["deviceURL"])+" while updating states")
continue #no deviceURL found that matches to domoticz Devices, skip to next dataset
if (dataset["deviceURL"].startswith("io://")):
dev = dataset["deviceURL"]Code: Select all
if (dataset["name"] == "DeviceStateChangedEvent"):
continue #dataset does not contain correct event, skip to next dataset
dev = dataset["deviceURL"]-= HP server GEN11 =- ZwaveJS-=- Domoticz v2025.2 -=- Dashticz =-
Rik60
Please check line 8 of the new beta file. It is still 4.2.22
- madpatrick
I saw it also, Thanks
The master is now 4.2.23
Rik60
Please check in the Master version the Utils.py file. Now the master is updated with de beta plugin.py file, use in the new master version also the Utils.py file from the beta version.
Rik60
Tested the new master version 4.2.23 with the new plugin.py and utils.py files. Everyting working fine, updating without errors. Running the plugin with the new Domoticz stable 2025.1. No problems, errors.
Thanks for updating the plugin.
jcb2
Tested also with 4.2.23 and 25.1 and with Debian 13 -> OK !
Thanks.
Thanks.
- madpatrick
Just released version 4.5
Added a custum refresh interval for Day and Night
This will reduced unnecessary polling during night times.
Day time is 30 before sunrise and Night time 60 minutes after sunset (hardcoded)
Also cleaned up unnecessary files and lines
Made the error logging friendlier
The setup parameter order has been changed, so you need to correct this after a restart.
Some fields are no moved to a different location due to the limitation of fields.
Just re-enter the correct parameters
Have fun !
Have fun !
Rik60
Thanks for the update, some remarks:madpatrick wrote: Tuesday 29 April 2025 22:06 1. Search in this topic
2. Google
3, https://github.com/MadPatrick/somfy
I think the awing will not work correctly, did not test it yet,
The remarks in the files are in Dutch, not English?
- madpatrick
I have no awning so can not test
Please share more info so i’ll try to help
Translation will follow
Thanks for your remarks
Rik60
I have tested the new plugin, there are some probems:
First (i think this is a typo, an "," insteat of ";"):
has to be:
And insert back the removed lines, you can copy/replace the complete text into the plugin:
With these changes the plugin works for me without problems/errors, tested it with the awning and rolling shutters.
I can test the plugin if a new plugin is available
if not Parameters.get('Mode2') or ';' not in Parameters['Mode2']:
Domoticz.Log("Mode2 leeg of ongeldig, instellen op standaard 300,900")
Parameters['Mode2'] = "300,900"
Domoticz.Log("Mode2 leeg of ongeldig, instellen op standaard 300;900")
Parameters['Mode2'] = "300;900"
def update_devices_status(self, Updated_devices):
logging.debug("updating device status self.tahoma.startup = "+str(self.tahoma.startup)+" on num datasets: "+str(len(Updated_devices)))
logging.debug("updating device status on data: "+str(Updated_devices))
if self.local:
eventList = utils.filter_events(Updated_devices)
else:
eventList = Updated_devices
num_updates = 0
logging.debug("checking device updates for "+str(len(eventList))+" filtered events")
for dataset in eventList:
#logging.debug("checking dataset for URL: "+str(dataset['deviceURL']))
logging.debug("checking dataset: "+str(dataset))
deviceClassTrig = dataset["deviceClass"]
level = 0
status_num = 0
status = None
nValue = 0
sValue = "0"
states = dataset["deviceStates"]
if not (dataset["name"] == "DeviceStateChangedEvent" or dataset["name"] == "DeviceState"):
logging.debug("update_devices_status: dataset['name'] != DeviceStateChangedEvent: "+str(dataset["name"])+": breaking out")
for state in states:
status_num = 0
lumstatus_l = False
if ((state["name"] == "core:ClosureState") or (state["name"] == "core:DeploymentState")):
if (deviceClassTrig == "Awning"):
level = int(state["value"]) #Don't invert open/close percentage for an Awning
status_num = 1
else:
level = 100 - level #invert open/close percentage
status_num = 1
- madpatrick
i'd noticed them also.
Will be correct in the new version
I'm rewritting the plugin to enable more parameters
Can you try the bea branch for testing
Rik60
There is a problem in de master version, 1 line is missing
Please add the missing line:
I tried to switch to the beta, for some reason i can't. Have to figure out why not.
level = 0
level = 0
- madpatrick
Rik60
Master version is ok for me now. No errors, erverything is working, no problems.
Switched to the beta, plugin started without errors, problems. Seems to be working ok.
Just some questions, why put some setting into a config file, for me it should be better to leave the setting in the setting screen.
In winter, or when it's dark, you can close a rolling shutter, but there is not reading back cause of the delay's, polling. Is it possible, when you sent a command to the Somfy system, there is a polling for some time to see that it's moving. Specialy when you are not at home and want to close/open a rolling shutter and like to see the actual position. Also, when you open/close a device with a handheld remote, the system is out of sync when there is no polling.
I think there is something wrong with the logging, there is no file in /var/log. I can see some logging in the somfy log file in the domoticz folder.
Edit: Switched back to the master version, and looked a bit closer to the setting screen, the Somfy logging is in the domoticz folder. But i am missing some info, like which version is starting
And just for information, i am running domoticz version 2025.2 on Trixie on a rpi 3B+
- madpatrick
I've made some major adjustments since the update was not comming in anymore
Also the Awning feature caused the the plugin was blocking the polling when you don't have a Awning device
Restore the setting in Domoticz as parameter (for now)
Only the IP and port for domoticz are in de config.txt required since i ran out op free parameters
Also de Debug logging is nog working better
Implemented a feature that when a devices is activated the polling is 10 sec for 1 minute long
So even during night time it will update the devices fast and the goes back to the longer refresh time
Released it as 5.0.0
When this has no further issues i will push it to the main repository
please share your feedback
Rik60
Switched to the beta and updated it. Starts normal, without error, problems. Can control all devices, also the awning is working normal, but only the awning has no device update when it's moving. The polling is 10sec then, after 1 min it switch back to 20 sec. If a rolling shutter is moving the device is updating. If the awning is moving there is no updating. I did not change a setting.
