domoticz in synology as package! Available now.
pilgou60
- Domoticz version: 2.0.2362
Re: domoticz in synology as package! Available now.
Hello everybody.
I'm a new french and i would like to say thanks to everybody whose help us to setup our NAS. As you can see, i don't speak very well english but i would try to be clear.
I have a Synology ds214play with dsm 5.1.5022.
I installed on it domoticz v2258 and USB Serial Drivers v3.0.2 downloaded on your website http://jadahl.dscloud.me/sspks/?arch=evansport .
My usb receptor is SIGMA z-WAVE USB PLUS. (http://www.domotique-store.fr/domotique ... signs.html)
apparently, this dongle is not recognize. this is resutlt from dmesg command.
[323446.835258] usb 1-1: new full-speed USB device number 3 using ehci_hcd
[323447.380698] usbcore: registered new interface driver cdc_acm
Could you help me to setup my ds214play to work with this USB dongle or advise me to buy a new USB dongle that work with z-wave ZG8101.
Thanks a lot for your help.
Bruno
Bruno
jhsim
OK, Doume, now I'm out of my depth.Doume wrote:You can only do that if your telnet session is 'root' itself....
kaivalagi
Login to the command line with username "root" and password the same as your administrator account then try doing the chmodjhsim wrote:OK, Doume, now I'm out of my depth.Doume wrote:You can only do that if your telnet session is 'root' itself....
jhsim
That's it! RFXCOM and Z-wave both working now!kaivalagi wrote:Login to the command line with username "root" and password the same as your administrator account then try doing the chmodjhsim wrote:OK, Doume, now I'm out of my depth.Doume wrote:You can only do that if your telnet session is 'root' itself....
Thank you so much
- jumbotroll
pilgou60 wrote:Hello everybody.
Bruno
Try the new Domoticz v2.0.2362-6 version with support for Z-wave. Download here: http://jadahl.dscloud.me/sspks/?arch=evansport
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
pilgou60
hello everybody
I installed new version od domoticz (v2.2362)
when i want to set USB ZWave usb dongle i have a message driver failed.
Could you help me please.
2015-04-16 18:08:02.785 OpenZWave: Closed
2015-04-16 18:08:12.088 EventSystem stopped...
2015-04-16 18:08:12.113 OpenZWave: Starting...
2015-04-16 18:08:12.113 OpenZWave: using config in: /usr/local/domoticz/Config/
2015-04-16 18:08:30.614 Hardware Monitor: Fetching data (System sensors)
2015-04-16 18:08:32.142 Error: OpenZWave: Driver Failed!!
pilgou60
for jhsim :
I use z-wave usb plus dongle. It's not the same as z-wave usb dongle. The chipset is different.
Are you sure this device is included in the driver package 3.0.2 ?
pilgou60
Sorry.
thanks for you help.
raxor
Hi all
After a hard and funny work i have mi XPENology DSM 5.1 (HP 54NL) working with Domoticz. I'm sysadmin and have some skill in development.
Material i use: kankunit smartplugs wifi (x4 relay.cgi hacked), 3x FIBARO x2 1.5 relay and Controller Aeon Labs Z-Stick S2
Version: domoticz_bromolow-5.1_2.0.2276-6.spk (openzw and usb drivers included) from this post https://dl.dropboxusercontent.com/u/180 ... 2276-6.spk
Debian-Chroot from Synocommunity for sh scripting and cron tasks
I want to give back to the community the knowledge I have gained researching on the internet
Codes are not mine, i only repair and debug code to make it work on synologys
Install debian-chroot
- In DSM 5.1
- Add synocommunity source in packages center
- Setup --> Packages source, add
Synocommunity -- http://packages.synocommunity.com/
In General TAB enable "Any editor"
- Apply
- Go to community packages and install debian-chroot
- Enable Debian-chroot
SSHd synology NAS and enter in CHROOT session
Error code is normal.
(select en_US.UTF-8)
this repair error code
Install packages: I need in the next example
Enable crontab from debian-chroot- AND cron job to retrieve snmp info from QNAP NAS every 5 minutes (you can put any .sh you want, and install any package you can need with "aptitude install")
Exit CHROOT session. CTRL + D or exit
In synology, create shell script in /usr/local/rc.d (when synology starts always execute scripts in this dir with start parameter).
nano /usr/local/rc.d/crontabchroot.sh
Add
Check every 5 minutes
Enable qnap SNMP explained here: http://www.domoticz.com/wiki/NAS_Monitoring.
- And create dummy switch and sensors
My qnap have only one HD. If you want to monitoring any other HD or remaining HD size go to http://www.domoticz.com/wiki/NAS_Monitoring and view code
I Notice Remaining HD size code from wiki has bugged:
This part.....
Returns: "1.68 TB" in my case, space betwen "8" and "T" makes url returns 404 response. TRim variable after pull data to Domoticz server solve problem. (i dont know how to).
Above info is valid to any sh cron job you want to launch
Another objective achieved
Shutdown Windows computer (windows 7) from domoticz: chroot not needed
- SSHd Synology NAS
(-f parameter force shutdown)
To no disable windows UAC you can insert reg info to accept RPC commands
In windows create reg file. enablerpcshutdown.reg
- Execute to add to registry,
Enable remote registry service
- Execute CMD witch admin rights (search cmd in start button, right button in cmd.exe execute with admin rights)
- reboot windows
In Domoticz create virtual switch
Switch type: push off button
Assign to off action:
"script://volume1/@appstore/domoticz/scripts/shutdown_PC.sh"
Save
Profit
I hope this can be useful to others and for me to remembers the steps to reproduce
Im noob on Domoticz (4 days) but, i'm very satisffied with my advances: blockly events to auto off some lights after time, Floorplan with image, Scenes (to lights off). I use OpenVPN to manage Domoticz from outside
. hahaha My Wife hate's me, 4 days with no time for her. But now i sure my children do not left any light on when we leave our house.
Next target LUA scripting.
Thanks to community and developers
- In DSM 5.1
- Apply
/var/packages/debian-chroot/scripts/start-stop-status chrootCode: Select all
aptitude updateCode: Select all
aptitude upgradeCode: Select all
aptitude install localesCode: Select all
pkg-reconfigure localesCode: Select all
dpkg-reconfigure tzdataCode: Select all
locale-gen en_US.UTF-8Install packages: I need in the next example
aptitude install snmpdCode: Select all
aptitude install snmpCode: Select all
aptitude install curlEnable crontab from debian-chroot- AND cron job to retrieve snmp info from QNAP NAS every 5 minutes (you can put any .sh you want, and install any package you can need with "aptitude install")
#!/bin/sh
# starts the chroot cron service on startup and stops it
# on reboot/shutdown
case "$1" in
start)
chroot /volume1/@appstore/debian-chroot/var/chroottarget /etc/init.d/cron start
stop)
chroot /volume1/@appstore/debian-chroot/var/chroottarget /etc/init.d/cron stop
echo "Usage: $0 [start|stop]"
esacCode: Select all
chmod +x /usr/local/rc.d/crontabchroot.shCode: Select all
nano /volume1/@appstore/debian-chroot/var/chroottarget/etc/crontabCheck every 5 minutes
*/5 * * * * root /usr/bin/qnap.shCode: Select all
nano /volume1/@appstore/debian-chroot/var/chroottarget/usr/bin/qnap.shCode: Select all
#!/bin/bash
# Settings
NASIP="192.168.1.xxx" # NAS IP Address
PASSWORD="public" # SNMP Password
DOMO_IP="192.168.1.xxx" # Domoticz IP Address
DOMO_PORT="8084" # Domoticz Port
NAS_IDX="23" # Virtual switch NAS STATUS
CPU_TEMP_IDX="24" # Virtual temerature sensor IDX NAS CPU
HD1_TEMP_IDX="25" # Virtual temerature sensor IDX HD1
# Check if NAS in online
PINGTIME=`ping -c 1 -q $NASIP | awk -F"/" '{print $5}' | xargs`
echo $PINGTIME
if expr "$PINGTIME" '>' 0
then
curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "On" > /dev/null
if [ $? -eq 0 ] ; then
# NAS already ON
echo "NAS already ON"
# Temprature CPU
CPUtemp=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.24681.1.2.6.0 | cut -c 2-3`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$CPU_TEMP_IDX&nvalue=0&svalue=$CPUtemp"
# Temperature HD1
HDtemp1=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.24681.1.2.11.1.3.1 | cut -c 2-3`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$HD1_TEMP_IDX&nvalue=0&svalue=$HDtemp1"
# NAS ON
echo "NAS ON"
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=switchlight&idx=$NAS_IDX&switchcmd=On"
# Temprature CPU
# Send data
# Temperature HD1
# Send data
fi
curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "Off" > /dev/null
# NAS uitgeschakeld
echo "NAS already OFF"
exit
echo "NAS OFF"
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=switchlight&idx=$NAS_IDX&switchcmd=Off"
fi
fiCode: Select all
chmod +x /volume1/@appstore/debian-chroot/var/chroottarget/usr/bin/qnap.sh- And create dummy switch and sensors
This part.....
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$HD_REMAIN_IDX&nvalue=0&svalue=$size"Above info is valid to any sh cron job you want to launch
- SSHd Synology NAS
nano /volume1/@appstore/domoticz/scripts/shutdown_PC.shCode: Select all
#!/bin/sh
#Shutdown Computer
# IP of computer and admin user needed
net rpc -S 192.168.1.xx -U USER%PWD shutdown -t 1 -f
chmod +x /volume1/@appstore/domoticz/scripts/shutdown_PC.shIn windows create reg file. enablerpcshutdown.reg
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system]
"LocalAccountTokenFilterPolicy"=dword:00000001
sc config RemoteRegistry start= auto
sc start RemoteRegistry
Save
Profit
fwehrle
Thnak you vert much for sharing. I copy-paste it in a note reminder.
If you need help in lua scripting , tell me.
- jumbotroll
See later post.
Last edited by jumbotroll on Wednesday 24 June 2015 23:17, edited 1 time in total.
Jumbotroll
Jumbotroll
ab1976
Which version should I use on my DS211j? Thanks in advanced
ps I'm using RFXCOMe
Raspberry Pi B+
RFXCOMe
Kaku switches
x10 Security System
My system also act as XBMC
Raspberry Pi B+
RFXCOMe
Kaku switches
x10 Security System
- jumbotroll
What kind of CPU does my NAS have?ab1976 wrote:Which version should I use on my DS211j? Thanks in advanced
Check here:
http://forum.synology.com/wiki/index.ph ... y_NAS_have
DS211j have: Marvell Kirkwood mv6281 1.2Ghz ARM 16-bit@DDR2, 128MB of RAM.
http://jadahl.dscloud.me/sspks/?arch=88f6281
Jumbotroll
Jumbotroll
Jumbotroll
Nicogluck
Hi everyone,
My Domoticz (installed on my DS415play) gives frequently the following error message in the log :
Error: Error accessing automatic backup directories
I saw in different opened topics that Domoticz under Windows needs to be launched as administrator.
Is it the same here ?
Is there any solution ?
Thanks to all.
Thanks to all.
- G3rard
- Target OS: -
- Domoticz version: No
You have to give the right permissions to the backup folder and the subfolders with chmod and chown (add user Domoticz to group root).Nicogluck wrote:Hi everyone,
Thanks to all.
I use Midnight Commander (http://packages.synocommunity.com) to do this.
Not using Domoticz anymore
Pvhpsb
I try to work a lua script (script_time_ping.lua).
The message in the log file is LUA ping fail.
The message in the domoticz.log (ping: permission denied (are you root)?).
Can anyone help me out?
Regards,
Patrick
Regards,
Patrick
- G3rard
- Target OS: -
User domoticz has no rights to use ping. I think i used the following, but I am not sure anymore because I have tried several things.Pvhpsb wrote:Hello,
Regards,
Patrick
chmod u+s /bin/pingNot using Domoticz anymore
JesseKlaasse
Hi! First of all, thank you very much for this excellent package. It's working perfectly fine!jumbotroll wrote:Domoticz v2.0.2383-7 with openzwave and usbserial driver included.
DSM-5.1 5022.
I have a question. By default, Domoticz is installed on the Synology as a http web site. Would it be possible to include the option to run it as https? I don't like the idea of a password transported plain text over http.
Pvhpsb
It,s works for me, thanks.G3rard wrote:User domoticz has no rights to use ping. I think i used the following, but I am not sure anymore because I have tried several things.Pvhpsb wrote:Hello,
Regards,
PatrickLet us know if this fixed the problem.Code: Select all
chmod u+s /bin/ping
- mvveelen
Kudo's for jumbotroll and his effort to make regular updates for the packages so far. I've updated my Domoticz twice today without any problems. Thanks for your effort and (please) keep up the good work !
