dashticz: Important Request
Lokonli
Re: IMPORTANT REQUEST!!!
Post by Lokonli »
nosehook wrote: Thursday 06 December 2018 21:37
Lokonli wrote: Thursday 06 December 2018 20:25 Probably a permission issue indeed. I've a slightly different setup, and I'm not an expert, but probably you have to add read permission to all users for the dashticz related files, and execute permission for the folders .
chmod a+rx /var/www/html/dashticz_v2
If that's not sufficient then add
chmod a+rx /home/pi/domoticz/www/dashticz_v2
chmod -R a+rX /home/pi/domoticz/www/dashticz_v2/*
Hi Loki,
Thanks for the help!
on
I got:
chmod: cannot operate on dangling symlink '/var/www/html/dashticz_v2'
The second option I got no feedback, however,
Forbidden
You don't have permission to access /dashticz_v2/index.html on this server.
Apache/2.4.25 (Raspbian) Server at 192.168.0.115 Port 80
The 'dangling' errors message means that the dashticz_v2 symlink in /var/www/html points to the wrong (non existing) location.
cd /var/www/html/dashticz_v2 probably also doesn't work.
Check the symlink pointer with ls -l /var/www/html
Remove the symlink and recreate it again.
Then check whether it works with
and then you should be in the Dashticz root folder.
nosehook
Post by nosehook »
Lokonli wrote: Thursday 06 December 2018 21:52
Hi Loki,
on
I got:
Forbidden
I removed the symlink and made the new one, that worked, so http://192.168.0.115/dashticz_v2/index.html shows dashticz.
However, both the garbage collector and calendar show loading...
The attachment inspection.jpg is no longer available
Pi3 Domoticz | RFXcom 433E | KAKU/COCO |Harmony Hub | Samsung TV | HS100 | HS110| HUE | Tradfri | Tado| Xiaomi |sensors | scripts| Pi3 Node Red | Pi2 SDS_011 + MH-Z19B | PiAware (zero) | Pi2 breadboard with Node red and Domoticz
nosehook
Post by nosehook »
Lokonli
Post by Lokonli »
nosehook wrote: Friday 07 December 2018 11:44 inspection.jpg
In the error-log I see references to 192.168.0.115:82, which is not good.
Do you still have a setting for php_path in your CONFIG.js? You can remove it.
With the CORS errors I see the request comes from 192.168.0.115:8080. This is however your Domoticz server which is not correct.
Can you try again with opening Dashticz via the default port 80:
(http://192.168.0.115/dashticz_v2)
Can you report the errorlog after making the two changes?
The CORS error still is strange, and should have been fixed with beta 2.4.5 onwards. Which Dashticz version are you using? (Press the settings icon in the top bar and then the info tab)
nosehook
Post by nosehook »
Lokonli wrote: Friday 07 December 2018 15:10
Thank you so much for your time!!!
It works now on http://192.168.0.115/dashticz_v2 !!! Much appreciated!
My domoticz data:
Version: 4.10256
Build Hash: 1cae6678
Compile Date: 2018-12-05 13:14:32
dzVents Version: 2.4.9
Python Version: 3.5.3 (default, Sep 27 2018, 17:25:39) [GCC 6.3.0 20170516]
Thnaks again!
Lokonli
Post by Lokonli »
nosehook wrote: Friday 07 December 2018 18:25
My domoticz data:
Version: 4.10256
Thnaks again!
Good! Well done! and enjoy :)
leonhannink
Domoticz version: 4.9700
Post by leonhannink »
I'd tried everthing in the post, but i have a Synology nas 214play and domoticz +Dashticz running.
Domoticz runs on path: /volume1/@appstore/domoticz/ and Dashticz on: /volume1/@appstore/domoticz/www/dashticz/.
I'd tried also to replace Dashticz to my webserver to /web/Dashticz/ but nothings helps, no garbage, no tv guide. Please who now what to do ?
Apache is running, PHP also but i have no idea, some can help me?
leonhannink
Hi, Dashticz is working, but the symbolic link, in which Path do i place the link and which command?
Verzonden vanaf mijn iPad met Tapatalk
Lokonli
Post by Lokonli »
The web-root folder on Synology probably is /var/services/web. In that case create the symlink with:
ln -s /volume1/@appstore/domoticz/www/dashticz /var/services/web
Now open dashticz via:
http://synology-ip/dashticz
leonhannink
Domoticz folder is on /volume1/@appstore/domoticz/
Dasthicz folder is on /volume1/web/Dashticz
i can open Dashticz already via http://synology-ip/Dashticz/index.html
Then the link must be: ln -s /volume1/@appstore/domoticz/ /volume1/web/dashticz/? is that correct
does it matter where put the symlink in which folder?
and how can i see when the link is corrrect?
Lokonli
Post by Lokonli »
leonhannink wrote: Thursday 20 December 2018 19:50 Thanks
If you already can open dashticz then there is no need for a symlink anymore.
Some people prefer to have Dashticz installed in their home folder, but there is no need for that.
Open Dashticz in Chrome via http://synology-ip/Dashticz/index.html
Still no garbage and tvguide?
Do you see one or more Domoticz devices?
Three things to do:
* Click on the settings icon in the Dashticz top bar, tab 'info'. Which version is reported of Dashticz, Domoticz and PHP?
(you must have a recent beta of Dashticz, and it should report a PHP version)
* Post your CONFIG.js here.
(remove default_cors_url and dashticz_php_path from your CONFIG.js (if you have them defined)
* Press F12 in Chrome to open the developer window. Refresh the Dashticz page. Post the user messages and errors from the console tab in the developer window.
Pandabeer
Domoticz version: 10265
Post by Pandabeer »
I face also some problems - I have PHP 7.3 up and running, but still no garbage... still loading!
See attachment version and running PHP(for xx my personal info)
CONFIG.js
config['app_title'] = 'xx';
config['user_name'] = 'xx';
config['pass_word'] = 'xx';
config['loginEnabled'] = 0;
var garbage = {}
config['garbage_company'] = 'rova';
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = 'xx';
config['garbage_street'] = 'xx';
config['garbage_housenumber'] = 'xx';
config['garbage_maxitems'] = '4';
config['garbage_use_names'] = true;
config['garbage_use_colors'] = true;
config['garbage_icon_use_colors'] = true;
config['garbage_use_cors_prefix'] = true;
config['garbage'] = {
    gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
    pmd: {kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
    rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
    papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
    kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
    brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'},
    black: {kliko: 'black', code: '#000000', name: 'Zwart', icon: 'img/garbage/kliko_black.png'},
    milieu: {kliko: 'yellow', code: '#f9e231', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'},
    kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'},
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['garbage']
columns[1]['width'] = 4;
jquery.min.js:4 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
send @ jquery.min.js:4
/dashticz/vendor/dashticz/garbage/?service=rova&sub=undefined&zipcode=xx&nr=xx&t=:1 Failed to load resource: the server responded with a status of 500 (Internal Server Error)
50VM2574:483 Uncaught TypeError: Cannot read property 'split' of undefined
    at getStatusBlock (eval at globalEval (jquery.min.js:2), <anonymous>:483:50)
    at handleDevice (main.js?v=1545647766741:1373)
    at Object.success (main.js?v=1545647766741:1256)
    at i (jquery.min.js:2)
    at Object.fireWith [as resolveWith] (jquery.min.js:2)
    at z (jquery.min.js:4)
    at XMLHttpRequest.<anonymous> (jquery.min.js:4)
16VM2574:483 Uncaught TypeError: Cannot read property 'split' of undefined
getStatusBlock @ VM2574:483
handleDevice @ main.js?v=1545647766741:1373
success @ main.js?v=1545647766741:1256
i @ jquery.min.js:2
fireWith @ jquery.min.js:2
z @ jquery.min.js:4
(anonymous) @ jquery.min.js:4
load (async)
ajax @ jquery.min.js:4
n.(anonymous function) @ jquery.min.js:4
getDevices @ main.js?v=1545647766741:1076
getDevicesTmr @ main.js?v=1545647766741:1311
(anonymous) @ main.js?v=1545647766741:1319
Any Advise?
Little expert running Domoticz on a Raspberry Pi
Toon Thermostat | Mi-Light | Z-Wave Thermostat valves and CO2 / fire detection units | KiKa | Heat-IT Zwave thermostat |
Pandabeer
Post by Pandabeer »
After all Xmas diners and spending time with my family - I refreshed this morning... and it works! Thank you Santa
geertvercamer
Post by geertvercamer »
as a complete Linux noob this is quite difficult. Even more so, because I feel the wiki is quite often not up to date.
I started by downloading the zip and unpacking it in to /var/www/html/dashticz_v2
I've modified /etc/apace2/sites-enabled/000-default.conf and added:
<VirtualHost *:8092>
# Always set these headers.
Header set Access-Control-Allow-Origin "*"
DocumentRoot /var/www/html/dashticz_v2
<Directory "/var/www/html/dashticz_v2">
allow from all
Options Indexes FollowSymLinks
Require all granted
</Directory>
</VirtualHost>
added port 8092 to ports.conf
<ip_of_pi_running_dashticz>:8092 loads dasthicz with the desired buttons, weather, ... but the garbage block keeps loading, no calendars added so far.
Then I read, the files are included in the latest beta, so I upgraded. Still no luck. Added an info.php page, which shows PHP and cURL are up and running
<ip_of_pi_running_dashticz>:8092/vendor/dashticz/garbage/info.php reads PHP version 7.0.30-0+deb9u1 and cURL suppert enabled, version 7.52.1
Same info when I click the cog in dashticzs and select the info tab.
CONGIF.js:
config['garbage_company'] = 'ophaalkalender';
config['garbage_housenumber'] = '54';
config['garbage_icalurl'] = '';
config['garbage_icon_use_colors'] = true;		// true / false; shows colored or only white trashcan
config['garbage_maxitems'] = '2';
config['garbage_street'] = 'De Patine';
config['garbage_use_names'] = true;				// true / false; shows name from config
config['garbage_use_colors'] = true;			// true / false; shows coloring for complete line
config['garbage_zipcode'] = '8980';
	gft: {kliko: 'White', code: '#White', name: 'GFT'},
	pmd: {kliko: '#87CEFA', code: '#87CEFA', name: 'PMD', icon: 'img/garbage/kliko_blue.png'},
	rest: {kliko: 'White', code: 'White', name: 'Restafval'},
	papier: {kliko: 'gray', code: '#c7763f', name: 'Papier & karton'},
	kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval'},
	brown: {kliko: 'brown', code: '#c7763f', name: 'Bruin'},
	black: {kliko: 'black', code: '#000000', name: 'Zwart'},
I haven't done the symlink thing, I thought it isn't needed as dashticz is not running on the domoticz server (which is actually a W10 machine as I had way to many trouble with the PI). Of course, I may be wrong here.
Is there anyone who can shed a light in this darkness? ;)
leonhannink
Re: dashticz: Important Request
Here also it works! Thanks
geertvercamer
I installed Apache & PHP on a W10 machine.
Calendars are working fine, garbage (ophaalkalender, BE) not. :(
Settings as in previous post (2 up)
How can I debug? F12 and breakpoints do not work, for some reason the breakpoints are ignored.
:lol: BTW, looks like we're time travellers. Now, it's Wednesday, about 23:30, the post says Thursday 0:27
Derik
Post by Derik »
Dear All...
I do found some time to play with Dashticz...
I hope some can tell me with a new setup for my all the missing parts before Rob changed some masterthings..
When i read some topics.. There are a lot of different perimeters...
And unfortunately the WIKI :-(
I hope some can give a step by step guide..
For my calendar and garbage first
Thanks in advanced
infiltrator88
Post by infiltrator88 »
Question:
I created the LINK to /var/www/html/ and my calender and garbage are working again.
Now when i go to the old URL(With port number http://192.168.1.34:8080/dashticz_v2/index.html) I can see my News which gets the latest news of nu.nl.
When I go to the new URL(without port number http://192.168.1.34/dashticz_v2/index.html) the news items aren't showing up?
I tried F12 to see if I could find some errors but there are just no errors.
I haven't got a clue where or how to resolve this issue. Anybody got any ideas?
Thans in advance
Lokonli
Post by Lokonli »
infiltrator88 wrote: Tuesday 15 January 2019 11:07 Question:
Thans in advance
It's not completely clear what you tried to fix, and what the current problem is.
Apparently you are using calender, garbage and news.
Did you install the latest beta already?
What kind of system are you using? Raspberry PI?
You installed dashticz in /home/pi/domoticz/www/dashticz_v2?
You installed Apache and PHP?
If you open http://192.168.1.34/dashticz_v2/index.html then your calendar and garbage are working? Only news is not working?
Can you post here the lines from your CONFIG.js that define 'news', and, if they exist, the settings for
default_news_url
default_cors_url
dashticz_php_path
Next step in debugging:
Open Dashticz in Chrome, and press F12. The Chrome developers window opens. Refresh Dashticz. Then in the console-tab of the developer window:
* Is there any error reported?
* Which user messages are reported?
Lokonli
Post by Lokonli »
Derik wrote: Saturday 05 January 2019 20:42 Dear All...
Thanks in advanced
How far are you?
Did you follow the installation instructions in the Wiki?
https://www.domoticz.com/wiki/Dashticz_ ... stallation
Can you post your CONFIG.js, and summarize the problems you have?
