Page 9 of 19
Re: [REQUEST] Plugin for Tuya
Posted: Tuesday 26 February 2019 21:44
by sincze
Looks promissing ;-)
At least the data is updated :lol:
Due to "https://www.domoticz.com/wiki/Developin ... hon_plugin" in the first beta of the plugin I only have Mode1-Mode6 for variables.
With de debug option as shown in my earlier post I had 7 variables -> as a result the plugin did not work.
At the moment I solved by cheating a bit
Devices[key+10].Update(0,str(state['4']/1000))	# TypeName="Current (Single)
Posted: Tuesday 26 February 2019 22:14
by sincze
I added a separate Watt meter.
As I don't know yet how to deal with kwH ;-) or if I created the correct meter in Domoticz :lol:
i experiment with
Domoticz.Device(Name="Tuya SmartPlug #" + str(val+11), Unit=val+11, TypeName="kWh").Create()
Domoticz.Device(Name="Tuya SmartPlug #" + str(val+12), Unit=val+12, Type=243, Subtype=29, Switchtype=0, Image=0, Options="").Create()
Python is not my language at all.
Tuya Beta 1.01_Watt.jpeg (76.37 KiB) Viewed 3275 times
Posted: Wednesday 27 February 2019 8:48
by jslegers
Looks great. Thanks again for the effort. Domoticz man ;)
Posted: Wednesday 27 February 2019 9:22
by sincze
jslegers wrote: Wednesday 27 February 2019 8:48 Looks great. Thanks again for the effort. Domoticz man ;)
:lol: Maybe we can do a small test with your plugs?? Before public release ??
Posted: Wednesday 27 February 2019 10:51
by sincze
This is interesting. The plug is switched off, but sometimes it still uses different amounts of Watts somehow.
tuya plug off.JPG (43.45 KiB) Viewed 3262 times
Keep in mind the data represented comes from the plug itself.
Key 1: False Plug State
Key 2: 0 UNKNOWN
Key 4: 0.122 Ampere Key is:11
Key 5: 3.9 Watt Key is:12
Key 6:: 241.7 Voltage Key is:13
I guess the electronics are as cheap as the plug itself?
Posted: Wednesday 27 February 2019 16:06
by dorenberg
I can volunteer too!!!
Posted: Wednesday 27 February 2019 20:45
by sincze
dorenberg wrote: Wednesday 27 February 2019 16:06 I can volunteer too!!!
A 2 volonteers. Many thanks.
@dorenberg -> keep an eye on those dps-keys (you might need to adjust them in plugin.py -> see instructions).
I believe yours were a bit different from @jslegers and my powerplug.
I've added the plugin to https://www.domoticz.com/wiki/Plugins for future reference.
Please let me know your findings.
Posted: Wednesday 27 February 2019 22:03
by maczek
Hi guys,
I've installed your plugin sincze and I'm getting error:
2019-02-27 21:56:05.243 Status: (SmartPlug) Initialized version 1.0.0, author 'tixi_sincze'
2019-02-27 21:56:05.453 Error: (SmartPlug) 'onMessage' failed 'KeyError'.
2019-02-27 21:56:05.453 Error: (SmartPlug) ----> Line 530 in /home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/plugin.py, function onMessage
2019-02-27 21:56:05.453 Error: (SmartPlug) ----> Line 436 in /home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/plugin.py, function onMessage
Do you have idea what may be wrong?
I previously installed original tixi plugin and it worked fine.
The plugin does not work in Domoticz. However when I run get_dps.py I get correct response.
maczek
Posted: Wednesday 27 February 2019 22:10
by sincze
maczek wrote: Wednesday 27 February 2019 22:03 Hi guys,
maczek
Can you also share outcome of get_dps.py? Please
Posted: Wednesday 27 February 2019 22:17
by dorenberg
I had the same. This is my version of the script. Spot the differences in DPS values of 104 105 and 106. These parts I have changed.
Domoticz.Device(Name="Tuya SmartPlug (Switch)", Unit=val, TypeName="Switch").Create()
Domoticz.Log("Tuya SmartPlug Device (Switch) #" + str(val) +" created.")
Domoticz.Device(Name="Tuya SmartPlug (A)" , Unit=val*1+10, TypeName="Current (Single)").Create()
Domoticz.Log("Tuya SmartPlug Device (A) #" + str(val*1+10) +" created.")
Domoticz.Device(Name="Tuya SmartPlug (kWh)", Unit=val*1+11, TypeName="kWh").Create()
Domoticz.Log("Tuya SmartPlug Device kWh #" + str(val*1+11) +" created.")
Domoticz.Device(Name="Tuya SmartPlug (V)", Unit=val*1+12, TypeName="Voltage").Create()
Domoticz.Log("Tuya SmartPlug Device (V) #" + str(val*1+12) +" created.")
Domoticz.Device(Name="Tuya SmartPlug (W)", Unit=val*1+13, TypeName="Usage").Create()
Domoticz.Log("Tuya SmartPlug Device (W) #" + str(val*1+14) +" created.")
Devices[key*1+10].Update(0,str(state[str(self.__ampere)]/1000)) # TypeName="Current (Single)
Devices[key*1+11].Update(0,str(state[str(self.__watt)]/10) + ";0") # kWh / Calculated
Devices[key*1+12].Update(0,str(state[str(self.__voltage)]/10)) # TypeName="Voltage"
Devices[key*1+13].Update(0,str(state[str(self.__watt)]/10)) # TypeName="Usage"
Domoticz.Debug("created. Key 101: " + str(state['1']) + " Plug State")
Domoticz.Debug("created. Key 104: " + str(state[str(self.__ampere)]/1000) + " Ampere Key is:" + str(key+10))
Domoticz.Debug("created. Key 105: " + str(state[str(self.__watt)]/10) + " Watt Key is:" + str(key+11))
Domoticz.Debug("created. Key 106:: " + str(state[str(self.__voltage)]/10) + " Voltage Key is:" + str(key+12))
# 	Domoticz Tuya Smart Plug Python Plugin                                       	   #
# 	MIT License        #
#	Copyright (c) 2018 tixi                                                            #
#	Permission is hereby granted, free of charge, to any person obtaining a copy       #
#	of this software and associated documentation files (the "Software"), to deal      #
#	in the Software without restriction, including without limitation the rights       #
#	to use, copy, modify, merge, publish, distribute, sublicense, and/or sell          #
#	copies of the Software, and to permit persons to whom the Software is              #
#	furnished to do so, subject to the following conditions:                           #
#	The above copyright notice and this permission notice shall be included in all     #
#	copies or substantial portions of the Software.                                    #
#	THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR         #
#	IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,           #
#	FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE        #
#	AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER             #
#	LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,      #
#	OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE      #
#	SOFTWARE.        #
<plugin key="sincze_tuya_smartplug_plugin" name="Tuya SmartPlug" author="tixi_sincze" version="1.0.0" externallink=" https://github.com/sincze/Domoticz-Tuya-SmartPlug-Plugin">
	<params>
		<param field="Address" label="IP address" width="200px" required="true"/>
		<param field="Mode1" label="DevID" width="200px" required="true"/>
		<param field="Mode2" label="Local Key" width="200px" required="true"/>
		<param field="Mode3" label="DPS" width="200px" required="true" default="1"/>
		<param field="Mode4" label="DPS group" width="200px" required="true" default="None"/>
		<param field="Mode5" label="DPS always ON" width="200px" required="true" default="None"/>
		<param field="Mode6" label="Debug" width="75px">
			<options>
				<option label="0"   value="0" default="true"/>
				<option label="1"   value="1"/>
				<option label="2"   value="2"/>
				<option label="4"   value="4"/>
				<option label="8"   value="8"/>
				<option label="16"  value="16"/>
				<option label="32"  value="32"/>
				<option label="64"  value="64"/>
				<option label="128" value="128"/>
			</options>
		</param>
	</params>
</plugin>
# https://wiki.domoticz.com/wiki/Developing_a_Python_plugin
# Debugging
# Value 	Meaning
# 0 		None. All Python and framework debugging is disabled.
# 1 		All. Very verbose log from plugin framework and plugin debug messages.
# 2 		Mask value. Shows messages from Plugin Domoticz.Debug() calls only.
# 4 		Mask Value. Shows high level framework messages only about major the plugin.
# 8 		Mask Value. Shows plugin framework debug messages related to Devices objects.
# 16 		Mask Value. Shows plugin framework debug messages related to Connections objects.
# 32 		Mask Value. Shows plugin framework debug messages related to Images objects.
# 64 		Mask Value. Dumps contents of inbound and outbound data from Connection objects.
# 128 		Mask Value. Shows plugin framework debug messages related to the message queue.
import Domoticz
import pytuya
import json
# plug object (represents a socket of the Tuya device)
class Plug:
	# constructor
	def __init__(self,unit):
		self.__dps_id   = unit		# dps id
		self.__command  = None		# command ('On'/'Off'/None)
		self.__alwaysON = False		# True if the socket should be always ON, False otherwise
		return
	# update_state function
	#		update the domoticz device
	#		and checks if the last command is equal to the current state
	# parameters:
	#		state: True <=> On ; False <=> Off
	# returns:
	#		True in case of an error (the state does not correspond to the command)
	#		False otherwise
	def update_state(self,state): #state: True <=> On ; False <=> Off
		if(state):
			UpdateDevice(self.__dps_id, 1, "On")
			if(self.__command == 'Off'):
				return True
			else:
		elif(self.__alwaysON): #if not state: need to change the state for always_on devices
			self.__command = 'On'
			return True
		else:
			UpdateDevice(self.__dps_id, 0, "Off")
			if(self.__command == 'On'):
				return True
			else:
		return False
	# set_command function
	# 		set the command for the next request
	def set_command(self,cmd):
		else:
			self.__command = cmd
	# set_alwaysON function
	# 		set __alwaysON to True
	def set_alwaysON(self):
		self.__alwaysON = True
	# put_payload function
	#		add to dict_payload the command to be sent to the device
	def put_payload(self,dict_payload):
		if(self.__command == None):
			return
		if(self.__command =="On"):
			dict_payload[str(self.__dps_id)] = True
		else:
			dict_payload[str(self.__dps_id)] = False
# plugin object
class BasePlugin:
	# constant definition
	__HB_BASE_FREQ = 2			  #heartbeat frequency (val x 10 seconds)
	__VALID_CMD    = ('On','Off') #list of valid command
	# private functions definition
	#	__extract_status
	#	__is_encoded
	#	__command_to_execute
	# __extract_status
	# Parameter
	#	Data: a received payload from the tuya smart plug
	# Returns a tuple (bool,dict)
	#	first:  set to True if an error occur and False otherwise
	#	second: dict of the dps (irrelevant if first is True )
	def __extract_status(self, Data):
		start=Data.find(b'{"devId')
		if(start==-1):
			return (True,"")
		result = Data[start:] #in 2 steps to deal with the case where '}}' is present before {"devId'
		end=result.find(b'}}')
		if(end==-1):
			return (True,"")
		end=end+2
		result = result[:end]
		if not isinstance(result, str):
			result = result.decode()
		try:
			result = json.loads(result)
			return (False,result['dps'])
		except (JSONError, KeyError) as e:
			return (True,"")
	# __is_encoded
	# Parameter
	# Returns
	#	True if Data is encoded
	#	False otherwise
	# Remark: for debugging purpose
	#~ def __is_encoded(self, Data):
		#~ tmp = Data[20:-8]  # hard coded offsets
		#~ if(tmp.startswith(b'3.1')):#PROTOCOL_VERSION_BYTES
			#~ return True
		#~ else:
			#~ return False
	#	send a command (set or status) to the tuya device
	def __command_to_execute(self):
		self.__runAgain = self.__HB_BASE_FREQ
		if(self.__connection.Connected()):
			dict_payload = {}
			for key in self.__plugs:
				self.__plugs[key].put_payload(dict_payload)
			if(len(dict_payload) != 0):
				self.__state_machine = 1
				payload = self.__device.generate_payload('set', dict_payload)
				self.__connection.Send(payload)
			else:
				self.__state_machine = 2
				payload=self.__device.generate_payload('status')
		else:
			if(not self.__connection.Connecting()):
				self.__connection.Connect()
	# constructor
	def __init__(self):
		self.__address          = None          		#IP address of the smartplug
		self.__devID            = None          		#devID of the smartplug
		self.__localKey         = None          		#localKey of the smartplug
		self.__device           = None          		#pytuya object of the smartplug
		self.__ampere	        = 104						#key for Ampere
		self.__watt             = 105						#key for Watt
		self.__voltage          = 106						#key for Voltage
		self.__runAgain         = self.__HB_BASE_FREQ	#heartbeat frequency
		self.__connection       = None					#connection to the tuya plug
		self.__unit2dps_id_list = None					#mapping between Unit and list of dps id
		self.__plugs	        = None					#mapping between dps id and a plug object
		self.__state_machine    = 0						#state_machine: 0 -> no waiting msg ; 1 -> set command sent ; 2 -> status command sent
		return
	# onStart Domoticz function
	def onStart(self):
		# Debug mode
		Domoticz.Debugging(int(Parameters["Mode6"]))
		Domoticz.Debug("onStart called")
		#get parameters
		self.__address  = Parameters["Address"]
		self.__devID    = Parameters["Mode1"]
		self.__localKey = Parameters["Mode2"]
		#set the next heartbeat
		#build internal maps (__unit2dps_id_list and __plugs)
		self.__unit2dps_id_list = {}
		self.__plugs            = {}
		max_unit                = 0
		max_dps					= 0
		for val in sorted(Parameters["Mode3"].split(";")):
			self.__unit2dps_id_list[int(val)]=[int(val),]
			self.__plugs[int(val)]=Plug(int(val))
			if(int(val)>max_unit):
				max_unit=int(val)
		max_dps = max_unit
		#groups management: #syntax: 1;2 : 3;4
		max_unit = max_unit + 1
		if(Parameters["Mode4"]!="None"):
			groups = Parameters["Mode4"].split(":")
			for group in groups:
				self.__unit2dps_id_list[max_unit]=[]
				for val in sorted(group.split(";")):
					self.__unit2dps_id_list[max_unit].append(int(val))
		#create domoticz devices
		if(len(Devices) == 0):
			for val in self.__unit2dps_id_list:
				if(val <= max_dps): #single socket dps
				else: #group: selector switch
					Options = {"LevelActions": "|",
						"LevelNames": "Off|On",
						"LevelOffHidden": "false",
						"SelectorStyle": "0"}
					Domoticz.Device(Name="Tuya SmartPlug #" + str(val), Unit=val, TypeName="Selector Switch", Options=Options).Create()
					Domoticz.Log("Tuya SmartPlug Device #" + str(val) +" created.")
		#manage always on
		if(Parameters["Mode5"]!="None"):
			for val in sorted(Parameters["Mode5"].split(";")):
				self.__plugs[int(val)].set_alwaysON()
		#create the pytuya object
		self.__device = pytuya.OutletDevice(self.__devID, self.__address, self.__localKey)
		#state machine
		#start the connection
		self.__connection = Domoticz.Connection(Name="Tuya", Transport="TCP/IP", Address=self.__address, Port="6668")
	# onConnect Domoticz function
	def onConnect(self, Connection, Status, Description):
		if (Connection == self.__connection):
			if (Status == 0):
				Domoticz.Debug("Connected successfully to: "+Connection.Address+":"+Connection.Port)
				self.__command_to_execute()
			else:
				Domoticz.Debug("OnConnect Error Status: " + str(Status))
				if(Status==113):#no route to host error (skip to avoid intempestive connect call)
					return
					self.__connection.Disconnect()
	# onMessage Domoticz function
	def onMessage(self, Connection, Data):
		Domoticz.Debug("onMessage called: " + Connection.Address + ":" + Connection.Port +" "+ str(Data))
			if(self.__state_machine == 0):#skip nothing was waiting
				return
			if(self.__state_machine == 1):#after a set command: need to ask the status
				self.__connection.Send(payload)#TODO active connection check (it should be because we just get a message)
				return
			#now self.__state_machine == 2
			(error,state) = self.__extract_status(Data)
			if(error):
				return
			error = False
				error = error or self.__plugs[key].update_state(state[str(key)])
			if(error):
	# onCommand Domoticz function
	def onCommand(self, Unit, Command, Level, Hue):
		Domoticz.Debug("onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + " Level: " + str(Level))
		if(Command=="Set Level"): #group (selector switch): convert level to command (0 <=> 'Off' ; 10 <=> 'On')
			if(Level==0):
				Command = 'Off'
			elif(Level==10):
				Command = 'On'
			else:
				Domoticz.Error("Undefined Level: " + str(Level))
				return
		if(Command not in self.__VALID_CMD):
			Domoticz.Error("Undefined command: " + Command)
			return
		for val in self.__unit2dps_id_list[Unit]:
			self.__plugs[val].set_command(Command)
	# onDisconnect Domoticz function
	def onDisconnect(self, Connection):
		Domoticz.Debug("Disconnected from: "+Connection.Address+":"+Connection.Port)
	# onHeartbeat Domoticz function
	def onHeartbeat(self):
		self.__runAgain -= 1
		if(self.__runAgain == 0):
	# onStop Domoticz function
	def onStop(self):
		self.__plugs	        = None
		if(self.__connection.Connected() or self.__connection.Connecting()):
# Domoticz plugin management
global _plugin
_plugin = BasePlugin()
def onStart():
	global _plugin
	_plugin.onStart()
def onStop():
	global _plugin
	_plugin.onStop()
def onConnect(Connection, Status, Description):
	global _plugin
	_plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data):
	global _plugin
	_plugin.onMessage(Connection, Data)
def onCommand(Unit, Command, Level, Hue):
	global _plugin
	_plugin.onCommand(Unit, Command, Level, Hue)
def onDisconnect(Connection):
	global _plugin
	_plugin.onDisconnect(Connection)
def onHeartbeat():
	global _plugin
	_plugin.onHeartbeat()
# Generic helper functions
def UpdateDevice(Unit, nValue, sValue, TimedOut=0, AlwaysUpdate=False):
	# Make sure that the Domoticz device still exists (they can be deleted) before updating it
	if Unit in Devices:
		if Devices[Unit].nValue != nValue or Devices[Unit].sValue != sValue or Devices[Unit].TimedOut != TimedOut or AlwaysUpdate:
			Devices[Unit].Update(nValue=nValue, sValue=str(sValue), TimedOut=TimedOut)
			Domoticz.Debug("Update " + Devices[Unit].Name + ": " + str(nValue) + " - '" + str(sValue) + "'")
Posted: Wednesday 27 February 2019 22:23
by maczek
The output of get_dps.py:
Plug State Information:
{'dps': {'23': 30147, '25': 1205, '21': 1, '1': True, '22': 623, '19': 891, '18': 432, '20': 2346, '24': 17293, '9': 0}, 'devId': '46268374840d8e953b36'}
Plug DPS List:
1
Posted: Thursday 28 February 2019 6:34
by dorenberg
You have to check in the smart life app which values corresponding to the parameters in the list.
Posted: Thursday 28 February 2019 9:23
by sincze
dorenberg wrote: Thursday 28 February 2019 6:34 You have to check in the smart life app which values corresponding to the parameters in the list.
@dorenberg. Tnx for helping me test the plugin with different types of plugs. Interesting to see what is going wrong with variables "val & key" in the plugin. We could agree upon making the plug single socket only. :lol: and use the spare parameter in the hardware tab to fill in your device id's instead of hacking them into the plugin.py
Just for the fun In meantime
Your:
Could as well be:
Domoticz.Device(Name="Tuya SmartPlug (A)" , Unit=val+10, TypeName="Current (Single)").Create()
Domoticz.Log("Tuya SmartPlug Device (A) #" + str(val+10) +" created."
As the multiplier was chosen (and because I don't have such a multi plug... guessed by me) to avoid overlapping device-ids. :shock:
Posted: Thursday 28 February 2019 11:13
by maczek
Hi guys,
I found solution to my problem:
{'devId': '46268374840d8e953b36', 'dps': {'1': True, '23': 30147, '18': 175, '25': 1205, '9': 0, '22': 623, '19': 260, '24': 17293, '20': 2334, '21': 1}}
Plug DPS List:
1
Then I had to adjust values in constructor:
        self.__ampere = 18  # key for Ampere
        self.__watt = 19  # key for Watt
        self.__voltage = 20  # key for Voltage
My unit IDs in Domoticz start from 14 so I edited this:
                Devices[key * 1 + 13].Update(0, str(state[str(self.__ampere)] / 1000))  # TypeName="Current (Single)
                Devices[key * 1 + 14].Update(0, str(state[str(self.__watt)] / 10) + ";0")  # kWh / Calculated
                Devices[key * 1 + 15].Update(0, str(state[str(self.__voltage)] / 10))  # TypeName="Voltage"
                Devices[key * 1 + 16].Update(0, str(state[str(self.__watt)] / 10))  # TypeName="Usage"
I thought it would work if I set the DPS to 4 in device settings but it didn't work so I had to change 10,11,12,13 to 13,14,15,16.
Works fine, no error :) I wonder how the total KWh usage is collected - is it calculated by the device or by the plugin? Is it the average of all reads?
Cheers,
maczek
Posted: Thursday 28 February 2019 11:35
by sincze
maczek wrote: Thursday 28 February 2019 11:13 Hi guys,
Plug DPS List:
1
Tnx for your feedback.
That is 2 happy testers.
This gives me some python programming skill confidence. :lol:
That is a tricky one indeed.
I had to modify (edit the created device) and put in on 'calculated'.
As by default it is set to a 'device' thing.
But that data is not retrieved from the plug as far as I know so the plugin will send '0' all the time. Just do a ctrl-f for ';0'
I could not find a different plugin that showed me how to do it straight out of the box.
Posted: Thursday 28 February 2019 12:02
by maczek
Reading and debugging this code gave me also some (a little) python skills confidence - I have 12+ years of commercial background in PHP but started learning Python recently ;)
Funny thing is that I bought this plug yesterday and then started googling to find a way to setup it in Domoticz. I wasn't aware that this plugin was so young :D
Posted: Thursday 28 February 2019 12:08
by sincze
maczek wrote: Thursday 28 February 2019 12:02 Reading and debugging this code gave me also some (a little) python skills confidence - I have 12+ years of commercial background in PHP but started learning Python recently ;)
offtopic: If PHP is your thing.. Why not speed up your Domoticz with Pass2PHP
https://www.domoticz.com/forum/viewtopic.php?t=12343
I modified the plugin to help somebody else, as I use Pass2PHP for my setup. :lol:
Even had to borrow a plug.
Fun part with the plugins is that they create the devices for you ;-) With pass2php I had to create virtual devices all the time.
Posted: Thursday 28 February 2019 12:41
by dorenberg
The counting seems not to work over here. Keeps 0.000 kwh. So maybe I did something wrong.
all info is available in the plug. Just in another json block.....
0.02 is in kWh of today. 0.43 is total.
"result": {
"thisDay": "0.02",
"sum": "0.43",
"years": {
"2019": {
"02": "0.43"
"t": 1549792047291,
"success": true,
"status": "ok"
Posted: Thursday 28 February 2019 16:51
by sincze
dorenberg wrote: Thursday 28 February 2019 12:41 The counting seems not to work over here. Keeps 0.000 kwh. So maybe I did something wrong.
"result": {
"thisDay": "0.02",
"sum": "0.43",
"years": {
"2019": {
"02": "0.43"
"t": 1549792047291,
"success": true,
"status": "ok"
Ok you have a more expensive plug that is for sure :lol:
I have it solved like this:
Posted: Thursday 28 February 2019 17:46
by sincze
I modified my local plugin so now you can add the DPS values of Amp;Watt;Volt in the hardware config screen.
And it does work.. ;-)
