- Spoiler: show
Sharing : Afval kalendar in text sensor
- jvdz
- Domoticz version: 4.107
Re: Sharing : Afval kalendar in text sensor
Strange. could you zip both your time script and your version of the JSON.lua into one zipfile and email it to me so I can have a look if there is anything strange in them?
- jvdz
Uploaded a update for script_time_afvalwijzer.lua to GitHub with the following changes:
The second change was a fix needed for the reported error by @silver323 .
Jos
- Changed the logic to always run the update process when debug=true, so don't forget to change it back to
"debug = false" for normal operations to avoid updating each minute and generating a lot of log records!
- Added some logic to strip a part of the JSON response before decoding it into a JSON table,
because the data sometimes contains base64 encoded images for some gemeentes,
which caused an error in the JSON lexing.Jos
silver323
Jos,jvdz wrote: Thursday 07 February 2019 11:35 Uploaded a update for script_time_afvalwijzer.lua to GitHub with the following changes:The second change was a fix needed for the reported error by @silver323 .Code: Select all
- Changed the logic to always run the update process when debug=true, so don't forget to change it back to "debug = false" for normal operations to avoid updating each minute and generating a lot of log records! - Added some logic to strip a part of the JSON response before decoding it into a JSON table, because the data sometimes contains base64 encoded images for some gemeentes, which caused an error in the JSON lexing.
Jos
Thanks for your help. I'm glad it works now.
hoeby
- Domoticz version: V2022.1
Nice script you guys made here.
Unfortunally for me, but my city isn't using "mijn afvalwijzer", but "de afval app"
It gives way different information than "mijn afvalwijzer". Would it be possible to add "de afval app" to this nice script?
This is the code to use "de afval app"
zip=6101ea
housnr =21
The result when running
zip=6101ea
housnr =21
http://dataservice.deafvalapp.nl/dataservice/DataServiceServlet?service=OPHAALSCHEMA&land=NL&postcode=6101EA&straatId=0&huisnr=21Code: Select all
GFT;12-01-2018;26-01-2018;09-02-2018;23-02-2018;09-03-2018;23-03-2018;06-04-2018;20-04-2018;04-05-2018;18-05-2018;01-06-2018;15-06-2018;29-06-2018;13-07-2018;27-07-2018;10-08-2018;24-08-2018;07-09-2018;21-09-2018;05-10-2018;19-10-2018;02-11-2018;16-11-2018;30-11-2018;14-12-2018;28-12-2018;11-01-2019;25-01-2019;08-02-2019;22-02-2019;08-03-2019;22-03-2019;05-04-2019;19-04-2019;03-05-2019;17-05-2019;31-05-2019;14-06-2019;28-06-2019;06-07-2019;12-07-2019;09-08-2019;23-08-2019;07-09-2019;20-09-2019;04-10-2019;18-10-2019;01-11-2019;15-11-2019;29-11-2019;13-12-2019;27-12-2019;
KERSTBOOM;12-01-2018;11-01-2019;
PLASTIC;22-01-2018;19-02-2018;19-03-2018;16-04-2018;14-05-2018;11-06-2018;09-07-2018;06-08-2018;03-09-2018;01-10-2018;29-10-2018;26-11-2018;24-12-2018;21-01-2019;18-02-2019;18-03-2019;15-04-2019;13-05-2019;08-06-2019;08-07-2019;05-08-2019;02-09-2019;30-09-2019;28-10-2019;25-11-2019;23-12-2019;
REST;05-01-2018;19-01-2018;02-02-2018;16-02-2018;02-03-2018;16-03-2018;30-03-2018;13-04-2018;28-04-2018;11-05-2018;25-05-2018;08-06-2018;22-06-2018;06-07-2018;20-07-2018;03-08-2018;17-08-2018;31-08-2018;14-09-2018;28-09-2018;12-10-2018;26-10-2018;09-11-2018;23-11-2018;07-12-2018;21-12-2018;04-01-2019;18-01-2019;01-02-2019;15-02-2019;01-03-2019;15-03-2019;29-03-2019;12-04-2019;26-04-2019;10-05-2019;24-05-2019;07-06-2019;21-06-2019;05-07-2019;19-07-2019;02-08-2019;16-08-2019;30-08-2019;13-09-2019;27-09-2019;11-10-2019;25-10-2019;08-11-2019;22-11-2019;06-12-2019;20-12-2019;
SNOEIAFVAL;12-03-2018;26-03-2018;09-04-2018;01-10-2018;15-10-2018;29-10-2018;11-03-2019;25-03-2019;08-04-2019;30-09-2019;14-10-2019;28-10-2019;Thin-client --> Docker Domoticz main environment
- jvdz
Returned data for that site looks pretty straightforward.
Will have a look to create a separate script for this and publish it.
PM me your email address please so we do some testing before it gets published.
Jos
Jos
- jvdz
The script script_time_huisvuil-echt.lua is added to my GitHub for the gemeentes Echt-Susteren.
Jos
Jos
hoeby
i testes it and works beautifull. thanks Jos.jvdz wrote: Sunday 10 February 2019 10:25 The script script_time_huisvuil-echt.lua is added to my GitHub for the gemeentes Echt-Susteren.
Jos
it is made for "de afval app"
when searching on the website of de afval app, more gemeentes could be working. could be possible minor changed need to be made.
these gemeentes i found on there website:
Bergeijk
Bladel
Boekel
Boxmeer
Buren
Cuijk
Culemborg
Echt-Susteren
Eersel
Geldermalsen
Grave
Helmond
Lingewaal
Maasdriel
Mill en Sint Hubert
Neder-BetuweNeerijnen
Oirschot
Reusel-De Mierden
Sint Anthonis
Someren
Son en Breugel
Terneuzen
Tiel
West Maas en Waal
Zaltbommel
- jvdz
Good to know... so I made these changes to the GitHub version:
Jos
- Renamed huisvuil-echt to huisvuil-deafvalapp because this site supports a long list of gemeentes.
- Also made a change to the script to properly list the missing afvaltypes in the table.-
hoeby
there is a letter forgotten in text GFT.
the script says "tuinfval"
should be "tuinAfval"
but the script works, including the forgotten letter
dnacid
Thanks for the great script!
Working without a problem in gemeente "De wolden".
Little tip for "Domoticz-on-windows" users:
Change the line in which trhe script searches for the JSON.lua file to
JSON = (loadfile "C:\\Program Files (x86)\\Domoticz\\scripts\\lua\\JSON.lua")() -- Use default Domoticz JSON.lua - jvdz
Thanks for letting me know.... I see I did a great Cut&Paste job as it was wrong at multiple places.hoeby wrote: Tuesday 12 February 2019 19:23 there is a letter forgotten in text GFT.
Fixed in GitHub.
Good to hear!
Jos
freijn
- Domoticz version: Stable
Hey Jos,
My notifications are not working anymore
THis is from the logfile
2019-03-04 21:46:00.617 Error: EventSystem: in AfvalAlarm: [string "---------------------------------------------..."]:113: attempt to index global 'notificationtitle' (a nil value)
this is line 113
notificationtitle = notificationtitle:gsub('@DAG@',dag)
this is my config
myAfvalDevice = 'Afval Kalender' -- The Text devicename in Domoticz
hostname = "afvalkalender.purmerend.nl" -- Specify the hostname of your afvalwebsite. eg: "afvalkalender.purmerend.nl", "afvalkalender.sudwestfryslan.nl", "mijnblink.nl" ..etc
ShowNextEvents = 3 -- indicate the next x events to show in the TEXT Sensor in Domoticz
Postcode = '1448xx' -- Postcode
Housenr = 'xx' -- Huisnummer zonder toevoeging
Housenrtoev='' -- Huisnummer toevoeging
NotificationEmailAdress = '[email protected]' -- Specify your Email Address for the notifications. Leave empty to skip email notification
Notificationsystem = 'telegram' -- Specify notification system eg "telegram/pushover/.." leave empty to skip
The ''xx" are dummies
from the log so website works...
2019-03-04 21:50:00.493 Status: EventSystem: Script event triggered: script_time_humidity
2019-03-04 21:50:00.518 Status: LUA: @AFOpzet::afvaltype_cfg :Dummy2;2;2
2019-03-04 21:50:00.518 Status: LUA: @AFOpzet::afvaltype_cfg :Dummy1;2;2
2019-03-04 21:50:00.518 Status: LUA: @AFOpzet::afvaltype_cfg :Plastic, Metaal en Drankkartons;19;2
2019-03-04 21:50:00.518 Status: LUA: @AFOpzet::afvaltype_cfg :Kerstbomen;19;22
2019-03-04 21:50:00.518 Status: LUA: @AFOpzet::afvaltype_cfg :Restafval;21;46
2019-03-04 21:50:00.518 Status: LUA: @AFOpzet::afvaltype_cfg :GFT;19;2
2019-03-04 21:50:00.518 Status: LUA: @AFOpzet::afvaltype_cfg :Papier en karton;19;2
2019-03-04 21:50:00.518 Status: LUA: @AFOpzet::Scheduled time(s) not reached yet, so nothing to do!
Any Clue ??
THanks Frank
this is line 113
this is my config
Any Clue ??
THanks Frank
- jvdz
Did you remove/comment these lines under the Table?:
.. else just PM or Email me your script and I will have a look.
Jos
notificationtitle = '@AFW: @DAG@ de @AFVALTEXT@ aan de weg zetten!'
notificationtext = '@DAG@ wordt de @AFVALTEXT@ opgehaald!'
Jos
freijn
Hi Jos,
Sorry for the slow response.. Busy with work
I am using the script script_time_opzet.lua
and do not see the lines : (from the latest Github)
in the script : script_time_afvalwijzer.lua
I do see them.
Can you please check and confirm its missing in the Github and should be added ?
Cheers,
Frank
I do see them.
Cheers,
Frank
- jvdz
Shoot, those are indeed missing in the latest commit and only show when sending a notifications.freijn wrote: Thursday 07 March 2019 18:08 and do not see the lines : (from the latest Github)
Sorry about that and thanks for reporting.... the github version should be fixed now.
Jos
freijn
Thank !! YOU !!! sir for making these scripts and fast support!!!!
Cheers,
Frank
Cheers,
Frank
- jvdz
You're welcome and glad things are working.
Jos
Jos
Heelderpeel
- Domoticz version: V2020.2
Very nice script, works perfectly, tomorrow I know if I have set the notification on the phone correctly, we will see.
But I would like to add the weekday to the script so that it becomes visible in Domoticz. I have no knowledge about lua,
but had looked a bit in other scripst and earlier versions, but I still can't get it done.
Can anyone help me?
(I use the: script_time_afvalwijzer.lua script)
Greetings,
Maurice
Can anyone help me?
Greetings,
Maurice
freijn
What weekday ??
All is in already ?
All is in already ?
- Capture.JPG (19.89 KiB) Viewed 2268 times
- jvdz
How would like to see the text change?
Could you post the current content of the TEXT device and how you like to have it changed?
Jos
That depends on the information available for that particular Gemeente.
Jos
