Page 9 of 23
Re: Dashticz - Module - Calendar
Posted: Sunday 21 May 2017 20:01
by Trigun
EdKo66 wrote:Wrong topic, but about once a week, Rob commits a new stable version.
Great! thanks Edko66!!
Posted: Sunday 21 May 2017 20:11
by robgeerts
Available now :)
Posted: Sunday 21 May 2017 20:13
by Trigun
robgeerts wrote:Available now :)
Hahah great service rob!
Thnx!!
Posted: Monday 22 May 2017 21:50
by Trigun
does anyone know why the popup(that shows the agenda when ou click on the agenda list) works on a laptop but does not work on a Ipad?
this is the code I Use
// iCalendar Plugin, supports all .ics calendar types like Google Calendar, Apple Calendar
var calendars = {}
calendars.f1 = { maxitems: 14, url: 'https://calendar.google.com/calendar/XXX&ctz=Europe/Amsterdam', icalurl: 'https://calendar.google.com/calendar/ical/XXX/private-XXX/basic.ics' }
BTW, the rest is working now with the new master version.
Posted: Monday 22 May 2017 21:53
by EdwinK
Isn't working at all for me, neither on laptop or tablet.
Posted: Monday 22 May 2017 21:55
by Trigun
EdKo66 wrote:Isn't working at all for me, neither on laptop or tablet.
It's because the URL is not within the new setup(few posts back) I put it in again(check the code) :)
Sent from my iPad using Tapatalk
Posted: Monday 22 May 2017 22:30
by Trigun
Trigun wrote:does anyone know why the popup(that shows the agenda when ou click on the agenda list) works on a laptop but does not work on a Ipad?
var calendars = {}
I figured out that it also isn't working in internet Explorer, also the calendar isn't working.
seems like it uses some sort of browser cache
Posted: Wednesday 31 May 2017 11:28
by Girbie
I managed to install the .ics calendar. However, I noticed that it doesn't show my whole day activity of today. Is this a known issue?
Furthermore, a reccuring full day event (an anniversary) is showing 3 times and all with the same date (for next year) with starting time 11:00 am. I believe this ís a known issue?
I also got the popup window to work. Does anyone know if it is possible to show a day or week view in stead of month view?
FYI, I just installed the latest bèta version of Dashticz.
Thanks in advance for your help/advice!
Posted: Wednesday 31 May 2017 13:58
by Trigun
Girbie wrote:Hi all,
Hi can you please share Your config? I am Still looking at getting the pop-up to work, its killing me so far :)
Thnx in advance!
Posted: Wednesday 31 May 2017 16:24
by EdwinK
I can't get the popup working either. Not from the calendar or from the webcam.
Posted: Thursday 01 June 2017 22:52
by Trigun
Hi Girbi,
Any chance you are able to help Edko66 and myself out here?
Would Be much appreciated.
Thnx and Cheers!
Verzonden vanaf mijn iPad met Tapatalk
Posted: Monday 05 June 2017 14:20
by jake
I have a google account and use the google calendar as well. How do I get the right hyperlink for my var definition in config.js? I have no experiende with .ical and the wiki doesn't explain this part.
Posted: Monday 05 June 2017 14:51
by Swifty
Login to your google account and view calendars - hover the mouse over the calendar name in the section 'My Calendars' you should see a drop down button appear.
Click that, and choose 'Calendar Settings' from there, you will find the iCal url if you scroll down.
Posted: Monday 05 June 2017 16:52
by poudenes
is the problem already solved in calendar when you have repeated items ? it show 1 hour difference. one time items are shown correct
Posted: Monday 05 June 2017 21:13
by jake
Swifty wrote:Login to your google account and view calendars - hover the mouse over the calendar name in the section 'My Calendars' you should see a drop down button appear.
Thanks, that did the trick! However, I have all together 3 google accounts, so I added them all in the style like calendars.business and calendars.private (using our first names instead). The weirdest thing is that only 1 of 3 agenda's is shown, the other ones just show an empty black background (I therefore can see that there is some space reserved for them). I used the private ical link for all 3, I can't imagine that I should or have changed a setting within Google agenda that forbids showing these agenda's.
I also tried by pasting the ical hyperlink into the one working/showing agenda line of config.js, but that agenda disappeared right away on the dashboard, until I rolled back to the original ical for that agenda. I therefore can't have made a mistake in the config.js, but it has to do with the Google agenda (setting) itself.
Posted: Tuesday 06 June 2017 8:42
by Drikus
Trigun wrote: I figured out that it also isn't working in internet Explorer, also the calendar isn't working.
Had a look at the code and noticed that Internet explorer global variables are used (event and item), if you change those to for example: event1 and item1, the calendar should work in Internet explorer as well.
Posted: Wednesday 07 June 2017 11:44
by Girbie
Hi Girbi,
Thnx and Cheers!
This is in my config.js file:
var calendars = {}
calendars.prive = {width:12, maxitems: 5, icon:'fa-calendar', title: 'Kalender', url: 'https://calendar.google.com/calendar/embed?src=xxxxxxxxxxxx&ctz=Europe/Amsterdam', icalurl: 'https://calendar.google.com/calendar/ical/xxxxxxxxx/public/basic.ics'}
var _ICALENDAR_DATEFORMAT     = 'DD/MM/YYYY HH:mm';
var _ICALENDAR_LOCALE         = 'nl_NL'; //en,hu, etc.
Where xxxxxxxxx should be replace by your details of course.
Posted: Wednesday 07 June 2017 20:15
by Derik
Dear All
Is there perhaps a 0ffice365 plugin???
Or a way to use a 365 Calendar?
Posted: Thursday 08 June 2017 0:22
by Derik
real nice stuff.!!
Some questions:
Can i adjust the size and color of the title, i use:
 = {width:12, maxitems: 10, icon:'fa-calendar', title: 'Different color and size', icalurl: 'https://calendar.go
And that give:
Try to change that.....
Is there perhaps a option to change colors for this day events and the actual event.
Like actual green
the day blue
etc
And is it possible to load directly ical into the script?
So i can use the combined calendar out of the box with ical
Now i need to make for the formule a new calendar.
Kids holidays
Kids footbal etc
to get different colors
edit:
Do i mis the daily and week events in my screen?
Is that correct or do i have wrong settings?
I see only events / hour
Posted: Thursday 08 June 2017 12:15
by gielie
Did someone get the IOs birthday calender working? Id like see the birthdays of my contacts in my Dashticz.
