Python Plugin: Broadlink RM2
zak45
Domoticz version: V2024.4
Re: Python Plugin: Broadlink RM2
Post by zak45 »
oslalo wrote:Thank you kingoifsnake74 for you answerd.
It mean that nobody can use the Broadlink with Domoticz in this moment ???
the V3 is here.
oslalo
Domoticz version: latest
Post by oslalo »
Hello zak45,
I have problems with the configuration of the Broadlink to Domoticz.
Could you send you my log file and json files ??
Thank you in advanced
zak45
Post by zak45 »
oslalo wrote:Hello zak45,
yep
goblin
Domoticz version: 2023.1
Post by goblin »
It seems that i am too simple to get broadlink working on my RP. with Domoticz and also the lack of knowledge does not help .
I even bought a new Sdcard and installed domoticz from scratc
New (Latest raspbian jessie lite img.) and domoticz version 3.8114. etc.
Then i typed below (to the letter. i Think/hope)
sudo apt-get install python3-pip libglib2.0-dev
sudo pip3 install Crypto
sudo pip3 install broadlink
sudo cp -r /usr/local/lib/python3.4/dist-packages/Crypto/ /usr/lib/python3.4/
sudo cp -r /usr/local/lib/python3.4/dist-packages/broadlink /usr/lib/python3.4/
sudo service domoticz restart
i hoped to see the broadlink in the hardware setup list. But nothing.
this is what i found in the Log. ( with other stuff in between)
2017-07-23 16:02:35.471 PluginSystem: Started, Python version '3.4.2
2017-07-23 16:02:37.945 PluginSystem: Entering work loop.
2017-07-23 16:02:38.004 Python EventSystem: Module not found - Trying to initialize.
2017-07-23 16:02:38.009 Python EventSystem: Initalizing event module.
2017-07-23 16:02:38.010 EventSystem: Started
If it is not to much to ask has plaaggeest or Zak45 has any idea or point me in a direction of "Broadlink installation in Domoticz for dummies"
thanks a lot
domoticz on two pies and HA bridge for Alexa
zak45
Post by zak45 »
@goblin
do you have downloaded plugin.py and put it under plugins/BroadlinkRM2 ??
goblin
Post by goblin »
Thank zak45, for your reply:
i have only done what written in my last post.
i can not find the dir. plugins/broadlinkRM with WinSCP
the closest i could find is /usr/local/lib/python3.4/dist-packages/broadlink
Also no broadlinkRM.
BR
zak45
Post by zak45 »
goblin wrote:Thank zak45, for your reply:
BR
you will find all information in Domoticz Wiki and/or Forum.
you need to create the directory by yourself and put the plugin.py under it.
see http://www.domoticz.com/wiki/Using_Python_plugins
goblin
Post by goblin »
i just did :
# Obtain plugin from github
mkdir -p domoticz/plugins/denon/
curl -L https://raw.githubusercontent.com/domot ... non4306.py > domoticz/plugins/denon/plugin.py
# set execute permissions (default was 644 pi:pi)
chmod 755 domoticz/plugins/denon/plugin.py
# restart domoticz service
sudo systemctl restart domoticz.service
and got this in the log:
2017-07-25 17:46:42.649 Error: PluginList: Parsing '/home/pi/domoticz/plugins/denon/', 'Error document empty.' at line 0 column 0 in XML ''.
and found the plugin.py at ./proc/self/task/13041/cwd/domoticz/plugins/denon/ (and in /AwoxSMP/)
the plugin.py was empty so i replaced them with the downloaded one from you (2017 3.0.0)
One step closer: got the broadlink in the hardware setup but nothing happens when i push setup.
it differs also a lot with the screen on https://www.domoticz.com/wiki/Plugins/BroadlinkRM2.html
(i wish i understood a little bit more of linux)
regards
zak45
Post by zak45 »
goblin wrote:i just did :
regards
do not follow wiki explicitly, sometimes this show only example, this is the case for Denon, need to be adapted to what you want to implement.
goblin
Post by goblin »
thanks zak45,
that's what happens if your not familiar with linux
any hints to incorporate broadlink in Domoticz ?
BR
Moulders
Post by Moulders »
I thought I had set everything up correctly but I get the following error in the logs when I try to turn it on:
2017-08-06 21:24:57.096 User: Admin initiated a switch command (8/Broadcom - Remote/On)
2017-08-06 21:24:57.116 (Broadcom) Calling message handler 'onCommand'.
2017-08-06 21:24:57.116 (Broadcom) onCommand called for Unit 254: Parameter 'On', Level: 0 , Connected : False
2017-08-06 21:24:57.116 (Broadcom) Generate on Command for learned code stored on unit/ini :254
2017-08-06 21:24:57.117 Error: (Broadcom) 'onCommand' failed 'NoSectionError'.
2017-08-06 21:24:57.117 Error: (Broadcom) ----> Line 217 in /home/moulders/domoticz/plugins/BroadlinkRM2/plugin.py, function onCommand
2017-08-06 21:24:57.117 Error: (Broadcom) ----> Line 314 in /home/moulders/domoticz/plugins/BroadlinkRM2/plugin.py, function genCommand
2017-08-06 21:24:57.117 Error: (Broadcom) ----> Line 781 in /usr/lib/python3.5/configparser.py, function get
2017-08-06 21:24:57.117 Error: (Broadcom) ----> Line 1138 in /usr/lib/python3.5/configparser.py, function _unify_values
2017-08-06 21:25:12.803 (Broadcom) Calling message handler 'onHeartbeat'.
2017-08-06 21:25:42.819 (Broadcom) Calling message handler 'onHeartbeat'.
any ideas what I might of done wrong?
Thanks.
zak45
Post by zak45 »
Moulders wrote:I thought I had set everything up correctly but I get the following error in the logs when I try to turn it on:
2017-08-06 21:24:57.116 (Broadcom) onCommand called for Unit [b]254[/b]: Parameter 'On', Level: 0 , Connected : False
2017-08-06 21:24:57.116 (Broadcom) Generate on Command for learned code stored on unit/ini :[b]254[/b]
Thanks.
you have generated wrong ID value into the ini file for remote control. please see wiki.
Moulders
Post by Moulders »
ah!
thanks for the input, I had assumed the ini file was automatically generated! I'll give it a try when I get home to night :)
Moulders
Post by Moulders »
I'm still struggling with the ini files.. can anyone provide an example of theirs so I can compare?
zak45
Post by zak45 »
Moulders wrote:I'm still struggling with the ini files.. can anyone provide an example of theirs so I can compare?
here is mine:
this is an example of ini need to be created for remote customization
Others ini files are created automatically during learn/import process.
heureekma
Post by heureekma »
Hello, I am trying to install my Broadlink RM pro on my Domoticz which runs on a Synology. I am on:
Synology DSM: DSM 6.1.3-15152 Update 1
Domoticz: 3.0.8153-7
Python: 3.5.1-0105 (installed package, if I check the version with ‘python –version’ I get Python 2.7.12 as result)
During installation, I have tried to run the ‘pip3 install broadlink’ command under ssh, but this failed (response: ‘pip3: command not found’).
I have copied the plugin files in /usr/local/domoticz/var/plugins/Domoticz-Broadlink.
After adding the hardware for the Broadlink using IP 127.0.0.1 and mac ‘000..00’, an entry is added to the hardware list.
Then my Domoticz freezes. In my package list on my Synology I see that Domoticz has been stopped. After starting it again, I find the following error messages in my log:
2017-08-13 15:11:06.731 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/usr/local/domoticz/var/plugins/Domoticz-Broadlink/
:/volume2/@appstore/py3k/usr/local/lib/python35.zip:/volume2/@appstore/py3k/usr/local/lib/python3.5/
:/volume2/@appstore/py3k/usr/local/lib/python3.5/plat-linux :/volume2/@appstore/py3k/usr/local/lib/python3.5/lib-dynload'.
2017-08-13 15:11:06.731 Error: (Broadlink RM Pro) Module Import failed, exception: 'ImportError'
2017-08-13 15:11:06.731 Error: (Broadlink RM Pro) Module Import failed: ' Name: broadlink'
I still see the Broadlink in the hardware list, but no new device in the device list or under the switches tab (device My br – Discover has not been created). I have set the Broadlink to inactive to prevent Domoticz from freezing.
My guess is that the Broadlink plugin has not been installed properly as the pip3 command failed, but I am not sure. The discrepancy between the installed and reprted Python version is also strange.
Can anyone please help with a solution or ideas what to check. I am not a linux expert, so please spell it out for me.
Thanks in advance!!
zak45
Post by zak45 »
@heureekma
"if I check the version with ‘python –version’ I get Python 2.7.12 as result"
for me this should be the main problem. Others users with synology have been able to install it so should work.
I'm sorry but not able to help, I'm on Windows. Just do some search on the forum, maybe you could found the solution.
heureekma
Post by heureekma »
@zak45, thx
I have searched if could find info on how to install a pytho service in synology. I found this: https://primalcortex.wordpress.com/2016 ... nstaller/
It was clear that the installs had not run properply because PIP was not installed. After installing PIP, and adding te ip/mac manually, 4 devices appeared in domoticz: import, temp, remote, command.
This looked like progress, but the 'Command' device does not work. Pressing the 'Learn' button in the 'Command' device gives no result (status should change to 'On', I would expect a led on the receiver to blink or light up).
In the log, every 30s the following error appears:
Error: Broadlink Pro hardware (15) thread seems to have ended unexpectedly
I don't know what to check next. I would be gratefull for suggestions.
zak45
Post by zak45 »
For those on synology, take a look there:
https://zhougy0717.github.io/2017/07/31 ... on%20Echo/
macben44
Post by macben44 »
Hello
I am desperate. I have been trying for 3 days to run my Broadlink with Domoticz.
I have :
Raspberry 1 4.4.50+ armv61
Domoticz V3.8153
pi@raspberrypi ~ $python3.5 --version
Python 3.5.2
pi@raspberrypi ~ $ pip --version
pip 9.0.1 from /usr/local/lib/python3.5/site-packages (pyth
n 3.5)
pi@raspberrypi ~ $ ls /usr/local/lib/
libpython3.5m.so      libwiringPiDev.so.2.44  pkgconfig
libpython3.5m.so.1.0  libwiringPi.so          python3.5
libpython3.so         libwiringPi.so.2.44
libwiringPiDev.so     perl
pi@raspberrypi ~ $ ls /usr/local/lib/python3.5/
abc.py               hmac.py            sched.py
aifc.py              html               selectors.py
antigravity.py       http               shelve.py
argparse.py          idlelib            shlex.py
ast.py               imaplib.py         shutil.py
asynchat.py          imghdr.py          signal.py
asyncio              importlib          _sitebuiltins.py
asyncore.py          imp.py             site-packages
base64.py            inspect.py         site.py
bdb.py               io.py              smtpd.py
binhex.py            ipaddress.py       smtplib.py
bisect.py            json               sndhdr.py
_bootlocale.py       keyword.py         socket.py
bz2.py               lib2to3            socketserver.py
calendar.py          lib-dynload        sqlite3
cgi.py               LICENSE.txt        sre_compile.py
cgitb.py             linecache.py       sre_constants.py
chunk.py             locale.py          sre_parse.py
cmd.py               logging            ssl.py
codecs.py            lzma.py            statistics.py
codeop.py            macpath.py         stat.py
code.py              macurl2path.py     stringprep.py
collections          mailbox.py         string.py
_collections_abc.py  mailcap.py         _strptime.py
colorsys.py          _markupbase.py     struct.py
_compat_pickle.py    mimetypes.py       subprocess.py
compileall.py        modulefinder.py    sunau.py
_compression.py      multiprocessing    symbol.py
concurrent           netrc.py           symtable.py
config-3.5m          nntplib.py         _sysconfigdata.py
configparser.py      ntpath.py          sysconfig.py
contextlib.py        nturl2path.py      tabnanny.py
copy.py              numbers.py         tarfile.py
copyreg.py           opcode.py          telnetlib.py
cProfile.py          operator.py        tempfile.py
crypt.py             optparse.py        test
csv.py               os.py              textwrap.py
ctypes               _osx_support.py    this.py
curses               pathlib.py         _threading_local.py
datetime.py          pdb.py             threading.py
dbm                  __phello__.foo.py  timeit.py
decimal.py           pickle.py          tkinter
difflib.py           pickletools.py     tokenize.py
dis.py               pipes.py           token.py
distutils            pkgutil.py         traceback.py
doctest.py           platform.py        tracemalloc.py
dummy_threading.py   plat-linux         trace.py
_dummy_thread.py     plistlib.py        tty.py
email                poplib.py          turtledemo
encodings            posixpath.py       turtle.py
ensurepip            pprint.py          types.py
enum.py              profile.py         typing.py
filecmp.py           pstats.py          unittest
fileinput.py         pty.py             urllib
fnmatch.py           __pycache__        uuid.py
formatter.py         pyclbr.py          uu.py
fractions.py         py_compile.py      venv
ftplib.py            _pydecimal.py      warnings.py
functools.py         pydoc_data         wave.py
__future__.py        pydoc.py           weakref.py
genericpath.py       _pyio.py           _weakrefset.py
getopt.py            queue.py           webbrowser.py
getpass.py           quopri.py          wsgiref
gettext.py           random.py          xdrlib.py
glob.py              reprlib.py         xml
gzip.py              re.py              xmlrpc
hashlib.py           rlcompleter.py     zipapp.py
heapq.py             runpy.py           zipfile.py
pi@raspberrypi ~/BroadlinkRM2 $ sudo pip3 install broadlink0.5/
Processing ./broadlink-0.5
  Requirement already satisfied (use --upgrade to upgrade):
broadlink==0.5 from file:///home/pi/BroadlinkRM2/broadlink-
.5 in /usr/local/lib/python3.5/site-packages
Requirement already satisfied: pycrypto==2.6.1 in /usr/loca
/lib/python3.5/site-packages (from broadlink==0.5)
Building wheels for collected packages: broadlink
  Running setup.py bdist_wheel for broadlink ... done
  Stored in directory: /root/.cache/pip/wheels/38/cc/a8/f73
d73c924b3fadd44f5a21f42b7fbeb1c37ec63be7a885d5
Successfully built broadlink
pi@raspberrypi ~ $ ls -lrt domoticz/plugins/broadlink/
total 52
-rwxrwxrwx 1 pi   pi   11469 Oct 25 12:32 plugin_http.py
-rwxrwxrwx 1 pi   pi      72 Oct 25 12:32 plugin_http.sh
-rwxrwxrwx 1 pi   pi    1501 Oct 25 12:32 plugin_send.py
-rwxrwxrwx 1 pi   pi   26034 Oct 25 13:55 plugin.py
drwxr-x--- 2 root root  4096 Oct 25 13:55 __pycache__
And I have always the error after a
sudo service domoticz.sh restart
2017-10-25 12:35:20.104 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/broadlink/:/usr/local/lib/python35.zip:/usr/local/lib/python3.5/:/usr/local/lib/python3.5/plat-linux:/usr/local/lib/python3.5/lib-dynload'.
2017-10-25 12:35:20.104 Error: (BroadlinkRM2) Module Import failed, exception: 'ImportError'
2017-10-25 12:35:20.104 Error: (BroadlinkRM2) Module Import failed: ' Name: broadlink'
I read all the posts, including those on Chinese domoticz.
Can you help me ?
Thx
