Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
Madgeni
Re: Controlicz - Domoticz to Google Home/Assistant integration
Post by Madgeni »
brain wrote: Saturday 28 July 2018 8:26
Madgeni wrote: Friday 27 July 2018 21:17 I'll take a look for you. Do the other colours work ok?
yes other colours work ok
thanx
ok, that's something. Can you mail me from your controlicz profile? then i I can take a look in the logs and see what hex code it's passing (I have to translate the colour to a hex, it's possible milights want a different one..)
NiklasO
Post by NiklasO »
I'm a subscriber.
Could you add the things under scenario too?
Present to Google Home as an ordinary light switch. On and off. Like I have one for window light on that I would like to be able to control by voice.
NiklasO
Post by NiklasO »
Like this
Madgeni
Post by Madgeni »
Hi - Scenes (Scenarios) can be added - just make sure the 'Scene' (Scenario?) Active Menu is enabled for your User in Domoticz.
NiklasO
Post by NiklasO »
Madgeni wrote: Sunday 29 July 2018 8:53 Hi - Scenes (Scenarios) can be added - just make sure the 'Scene' (Scenario?) Active Menu is enabled for your User in Domoticz.
I can't see them.
Also, they are not in the list where I could select devices for the user in Domoticz.
English
Edit: oh! They have to be in a room plan. I don't think my other devices is but they show up anyway. So, reading the thread made it a little more clear. Created a new room and added the scene/group and now I see it. Thanks! Going to read the faq now.
Brutus
Post by Brutus »
Hi there,
I am testing Controlicz now there is a Dutch Google Assistant. But when I want to add controlicz as a service in the Google assistant this is all I see:
With other services you see a button where you can alter the settings.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
maxtrash
Post by maxtrash »
some days ago controlling my lights via controlicz stopped working. Didn't pay much attention but later on tried to figure out what the problem was. Unfortunately my rpi didn't boot anymore and I decided to reinstall it. After some work and putting back the domoticz database, everything worked again except Controlicz.
I now found out that you changed from a donation to a subscription model. Too bad for me, but will pay. I have made a donation in the past, but I can imagine that the amount of donations are not very significant compared to a monthly fee. I can understand some money being charged for professional software and hosting like this!
My controlicz account is now changed to a free subscription model. I have not paid yet, but is anything supposed to work with the free subscription? After pressing the test-button on the Controlicz site it says everything is fine. I cannot however add the Controlicz account in the google home app. After approving the full access the app just says it couldn't update the setting. Do you know what the problem is, I have seen this before and I think it started working again without a specific reason?
Madgeni
Post by Madgeni »
hi - if you subscribe, then you'll be able to access Controlicz in your Home app
maxtrash
Post by maxtrash »
yes, it works again. Thx
Lemme
Domoticz version: Dev
Controlicz and support for other languages
Post by Lemme »
Soon Google will provide support for the danish language (besides a lot of other languages). When they go live officially, will danish be supported automatically in Controlicz - will it work out of the box?
Or will there be some programming taking place from your side, before Controlicz will work with danish (and the other languages)? And if so, do you have any idea of how long it will take?
Br
Flemming
Brutus
Post by Brutus »
Madgeni wrote: Sunday 05 August 2018 9:11 hi - if you subscribe, then you'll be able to access Controlicz in your Home app
Is that my problem to? I can't couple Controlicz in the google assistant as mentioned a couple posts before. I would like to test it first.
Greetings
28x Fibaro Modules
SMA Solar System
mauko
Post by mauko »
Ok,
I have google home mini, public IP address and domoticz at my local network. How do I go about and setup Controlicz? Do I need some special instructions via PM from Madgeni?
Madgeni
Post by Madgeni »
Hi -
Domoticz needs to be accessible via https over the internet;
setup a user in Domoticz;
assign devices to a room plan (and assign them devices to the user)
Update your Controlicz profile with:
Hostname; Port; Domoticz username; password
Test your connection + see if your devices are in your Controlicz profile.
Then if you're happy, subscribe, enjoy :)
ronschaeffer
Post by ronschaeffer »
Hello-
Apologies if this has been asked before. I couldn't find it in the thread. Is it possible to query status of a device, e.g.:
- "Is the bedroom light on?"
- "Is the front door closed?"
Thanks,
Ron
Madgeni
Post by Madgeni »
Yes it is - you can also do it by Google Room ("What lights are on in the bedroom") etc.
alanlsmith
Domoticz version: Latest β
Post by alanlsmith »
Just a quick one. Just tried checking the back door (having seen the post above) and 'Is the back door closed?' is not understood but 'Is the back door off?' gets the reply 'The back door is off'
Which is correct but not right, if you see what I mean.
Not important but thought I should mention it.
I am using LightwaveRF door contacts which report open and closed to Domoticz.
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
Madgeni
Post by Madgeni »
alanlsmith wrote: Thursday 09 August 2018 10:40 Just a quick one. Just tried checking the back door (having seen the post above) and 'Is the back door closed?' is not understood but 'Is the back door off?' gets the reply 'The back door is off'
Nope, that's a fair comment - open/close are *still* not available yet with GH (they're coming, and Controlicz is ready).
alanlsmith
No problem, just thought I'd mention it.
Furiousz23
Domoticz version: 4.10199
Post by Furiousz23 »
Anyone else expierincing problems with Google Assistent? I cant open the assistent settings, the "compass"button is visible, but nog clickable. Tried it on 4 android devices. Also switching the language from Dutch tot English didn't help.
Update:
I just uninstalled the Google and Assistant app and reinstalled them. After that's i was able tot open the assistant settings, but there is no way to setup Controlicz... :roll:
sstolk
Post by sstolk »
I would like to protect my Domoticz from the outside world and opening the HTTPS port sounds good but not for me.
Can you provide me from where Controlicz is coming eg. IP's?
