Page 80 of 123
Posted: Wednesday 21 June 2017 0:47
by deennoo
chatainsim wrote:langoo wrote:deennoo wrote:
They will never ship them even if they are on sale...
I bought mine from them...
Same for me have the new door sensor.
Button in on it's way too.
Ok your the best guys ! And are you sure they will works ?
Posted: Wednesday 21 June 2017 11:07
by Revers59
New Design Xiaomi AQara Smart Body Sensor ZigBee Wireless Connection Built In Light Intensity Sensors Work On Phone APP
upgrade with light support.
Posted: Wednesday 21 June 2017 11:36
by deennoo
Revers59 wrote:New Design Xiaomi AQara Smart Body Sensor ZigBee Wireless Connection Built In Light Intensity Sensors Work On Phone APP
Thx as usual wait to be sure that the gateway broadcast data from this device before spending money.
Those new device looks to be the same as another HA solution who will arrive at the end of year
Posted: Wednesday 21 June 2017 19:30
by quack3d
What do you use the pressure measurement in the new temperature sensors for?
Posted: Wednesday 21 June 2017 23:19
by deennoo
Pressure : baromètre need to be convert on mbar ... Glad to know that you have it on Domoticz
Posted: Thursday 22 June 2017 7:48
by mikeoo
Bought them with a per-sales and they deliver just fine. Took about 3 weeks.
Posted: Thursday 22 June 2017 8:03
by deennoo
mikeoo wrote:]
Was talking about actual sales...
Posted: Thursday 22 June 2017 8:31
by mikeoo
deennoo wrote:mikeoo wrote:]
It was also a actual sale but 3 weeks ago
Posted: Thursday 22 June 2017 14:34
by langoo
mikeoo wrote:deennoo wrote:mikeoo wrote:]
Same as me..
Posted: Friday 23 June 2017 14:04
by Diab
Hi.
Since three days I'm not able to perform a new installation of the Xiaomy Gateway running on a Raspberry Pi.
It was running previously (before the two last updates) but since I downloaded V3.8003 and 8005, no way to reinstall the gateway.
The browser has been cleaned but I definitly don't have access to the gateway parameters (name, IP @, port...), only what is below.
- Capture du 2017-06-22 10-54-09.png (187.67 KiB) Viewed 3334 times
Did anyone already face this situation?
Thanks for support
Posted: Friday 23 June 2017 15:07
by corbin
I've just updated my dev copy, had issues at first after trying to clear the browser cache. Clearing it again resulted in this:
- gateway_setup.JPG (69.44 KiB) Viewed 3322 times
So it could be your cache hasn't fully cleared
Posted: Friday 23 June 2017 15:20
by Diab
Hi Corbin.
Thanks for your support.
Sometime I really do not understand how it works
I cleaned again by the same way the browser cache and performed Ctrl+F5 to be sure.
Now it works perfectly, gateway added.
Have a nice WE.
Posted: Saturday 24 June 2017 5:14
by Onkytonk
So I went ahead and ordered one of these. It was only $10au more than the old body sensor so I thought I'd give it a go. Hopefully it works with the xiaomi plugin, at least the movement sensor for now, until the light sensor is implemented.
Has anyone got one of these and tested it yet?
Posted: Saturday 24 June 2017 9:41
by theo69
Hi I bought this Single Button Zero Line Aqara Switch
http://www.gearbest.com/access-control/ ... d=10893221 however it gives me this error while using with Domoticz:
2017-06-24 07:36:26.142 XiaomiGateway: unhandled model: ctrl_ln1
2017-06-24 07:36:27.088 XiaomiGateway: unhandled model: ctrl_ln1
2017-06-24 07:36:28.197 XiaomiGateway: unhandled model: ctrl_ln1
2017-06-24 07:36:31.957 XiaomiGateway: unhandled model: ctrl_ln1
2017-06-24 07:36:34.857 XiaomiGateway: unhandled model: ctrl_ln1
Any update if it will be added soon, anything else I can do to help adding it?
Posted: Saturday 24 June 2017 9:44
by warmaniac
theo69 wrote:Hi I bought this Single Button Zero Line Aqara Switch
As we wrote before, we need to wait and pray if xiaomi fix it on gateway because this is problem of Aqara series sensors/switches.
Posted: Saturday 24 June 2017 9:51
by theo69
I think its because its not integrated in Domotics, because the Switches without Zero Line are fine. The Zero Line Switch is working with homebridge plugin
https://github.com/YinHangCode/homebridge-mi-aqara
Posted: Saturday 24 June 2017 9:53
by theo69
Also I am always getting loads of Error are these normal?:
2017-06-24 07:39:00.168 Error: EventSystem: in Wohnzimmer Tischlampe: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:39:00.172 Error: EventSystem: in Wohnzimmer Stehlampe: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:39:00.176 Error: EventSystem: in Veranda Links: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:39:00.181 Error: EventSystem: in Veranda Rechts: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:39:00.185 Error: EventSystem: in Veranda Alle: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:39:00.190 Error: EventSystem: in Wohnzimmer Stehlampen alle: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:40:00.207 Error: EventSystem: in Wohnzimmer Tischlampe: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:40:00.211 Error: EventSystem: in Wohnzimmer Stehlampe: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:40:00.215 Error: EventSystem: in Veranda Links: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:40:00.220 Error: EventSystem: in Veranda Rechts: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:40:00.224 Error: EventSystem: in Veranda Alle: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:40:00.229 Error: EventSystem: in Wohnzimmer Stehlampen alle: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:41:00.245 Error: EventSystem: in Wohnzimmer Tischlampe: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:41:00.249 Error: EventSystem: in Wohnzimmer Stehlampe: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:41:00.254 Error: EventSystem: in Veranda Links: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:41:00.258 Error: EventSystem: in Veranda Rechts: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:41:00.263 Error: EventSystem: in Veranda Alle: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:41:00.267 Error: EventSystem: in Wohnzimmer Stehlampen alle: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:42:00.284 Error: EventSystem: in Wohnzimmer Tischlampe: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:42:00.289 Error: EventSystem: in Wohnzimmer Stehlampe: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:42:00.293 Error: EventSystem: in Veranda Links: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:42:00.300 Error: EventSystem: in Veranda Rechts: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
2017-06-24 07:42:00.304 Error: EventSystem: in Veranda Alle: [string "commandArray = {}..."]:2: attempt to index global 'devicechanged' (a nil value)
Posted: Saturday 24 June 2017 13:33
by xxLeoxx93
What is the easiest way to tell domoticz that when i doubleclick my switch it should turn of my xiaomi wallplug? I can only see to run a script when interacting with my switch?
Posted: Saturday 24 June 2017 15:07
by theo69
xxLeoxx93 wrote:What is the easiest way to tell domoticz that when i doubleclick my switch it should turn of my xiaomi wallplug? I can only see to run a script when interacting with my switch?
Try Lua or Blocky
this is example with Lua, really powerfull!
if devicechanged['buttonswitch'] == 'Double Click' then
if otherdevices['wallplug'] == 'Off' then
commandArray['wallplug'] = 'On'
commandArray['wallplug'] = 'Off'
Posted: Saturday 24 June 2017 15:16
by Swifty
Anyone compiled corbins github version of domoticz recently? - I tried to update last night and after compiling I get 'Segmentation Fault' when trying to run domoticz.
I've re-cloned to a fresh folder and re-compiled, but same issue.. (rPi 2)
