Page 79 of 123
Posted: Monday 19 June 2017 14:05
by TigroEHOT
2017-06-19 22:04:46.533 XiaomiGateway: unhandled model: ctrl_ln1
2017-06-19 22:04:46.533 {"cmd":"report","model":"ctrl_ln1","sid":"158d00012a35e7","short_id":24692,"data":"{\"channel_0\":\"off\"}"}
Posted: Monday 19 June 2017 14:25
by warmaniac
corbin wrote:@langoo and @TigroEHOT
When it reports 'unhandled model', it should say what the name is, ie
XiaomiGateway: unhandled model: tempsensor
I need to know what the name is (tempsensor in the above example) and what device it is. Also will need an example of the raw message output - enable raw gateway messages - see
https://www.domoticz.com/wiki/Xiaomi_Ga ... leshooting
nothing new for me , have 2 pcs new Aqara magnet door/window plus 2pcs Aqara Temperature/Humidity/Pressure sensors
2017-06-19 14:22:49.464 2017-06-19 14:22:49.464 XiaomiGateway: unhandled model:
2017-06-19 14:22:49.465 2017-06-19 14:22:49.465 {"cmd":"read_ack","model":"","sid":"158d00017200ff","short_id":26405,"data":"{\"voltage\":3015}"}
2017-06-19 14:22:49.466 2017-06-19 14:22:49.466 XiaomiGateway: unhandled model:
2017-06-19 14:22:49.466 2017-06-19 14:22:49.466 {"cmd":"read_ack","model":"","sid":"158d0001a4c79e","short_id":44567,"data":"{\"voltage\":3005}"}
2017-06-19 14:22:49.467 2017-06-19 14:22:49.467 XiaomiGateway: unhandled model:
2017-06-19 14:22:49.467 2017-06-19 14:22:49.467 {"cmd":"read_ack","model":"","sid":"158d00016c3e55","short_id":55642,"data":"{\"voltage\":3045}"}
2017-06-19 14:22:49.468 2017-06-19 14:22:49.468 {"cmd":"read_ack","model":"","sid":"158d00016c402b","short_id":30460,"data":"{\"voltage\":3035}"}
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Posted: Monday 19 June 2017 19:44
by SwordFish
deennoo wrote:SwordFish wrote:deennoo wrote:
Sory for asking but is it on your blog already?
Cant find it.
A simple how to is online for yeelight bedside lamp & Domoticz :
http://domo-attitude.fr/tuto-lampe-de-c ... -domoticz/
That in simple french word, google translate do a good job, i'll provied a how to on domoticz wiki next week.
If some one can help by provieding a Python Plugin this can be perfect
I try to install this but get a error when trying to install enum
Is it also possible to control 2 bedlights?
pi@raspberrypi:~ $ sudo pip3 install enum
Downloading/unpacking enum
Downloading enum-0.4.6.tar.gz
Running setup.py (path:/tmp/pip-build-2iowbxb_/enum/setup.py) egg_info for package enum
File "<string>", line 3, in <module>
File "/usr/lib/python3/dist-packages/setuptools/__init__.py", line 12, in <module>
from setuptools.extension import Extension
File "/usr/lib/python3/dist-packages/setuptools/extension.py", line 7, in <module>
from setuptools.dist import _get_unpatched
File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 16, in <module>
from setuptools.depends import Require
File "/usr/lib/python3/dist-packages/setuptools/depends.py", line 6, in <module>
from setuptools import compat
File "/usr/lib/python3/dist-packages/setuptools/compat.py", line 45, in <module>
import http.client as httplib
File "/usr/lib/python3.4/http/client.py", line 69, in <module>
import email.parser
File "/usr/lib/python3.4/email/parser.py", line 12, in <module>
from email.feedparser import FeedParser, BytesFeedParser
File "/usr/lib/python3.4/email/feedparser.py", line 27, in <module>
from email import message
File "/usr/lib/python3.4/email/message.py", line 16, in <module>
from email import utils
File "/usr/lib/python3.4/email/utils.py", line 29, in <module>
import socket
File "/usr/lib/python3.4/socket.py", line 51, in <module>
from enum import IntEnum
ImportError: cannot import name 'IntEnum'
Complete output from command python setup.py egg_info:
import email.parser
import socket
Posted: Monday 19 June 2017 22:21
by deennoo
Cant find it.
import email.parser
import socket
import email.parser
import socket
please contact me on my blog...this topic is for xiaomi zigbee device ok ?
Posted: Monday 19 June 2017 22:32
by deennoo
TigroEHOT wrote:2017-06-19 22:04:46.533 XiaomiGateway: unhandled model: ctrl_ln1
Your switch is the wall mounted one ?this one who need Line and neutral ? with a single button ?
I just recieve a dual switch from this serie, but didn't open it already, will try to help Corbin
@corbin this device is the same as ctrl1 device, and surely the On with 2 button is call ctrl_ln2 with the same fonction as ctrl2 device.
Posted: Monday 19 June 2017 22:34
by deennoo
I have a temp sensor to, and Domoticz log only says : 2017-06-19 22:17:26.345 XiaomiGateway: unhandled model: using 3.7995
looks like API doesn't boardcast this sensors information for the moment
The square wireless switch isn't on the app for the moment
Posted: Monday 19 June 2017 22:36
by deennoo
TigroEHOT wrote:Hi all!
I bought a couple of single button switches with neutral line and power usage report. But in Domoticz log I see unhandled model: ctrl_ln1
Just should wait for the update or I can help in anyway? Is there any data I can collect and provide?
this switch doesn't provied any power usage, he just show how is your voltage
Posted: Monday 19 June 2017 23:44
by langoo
Will this helpension? This is one off the new Aqara Temp/Hum sensors. I see in the app that the gateway updates the values from the sensors if I for example blows on them.
2017-06-19 23:34:51.639 XiaomiGateway: unhandled model:
2017-06-19 23:34:51.639 {"cmd":"read_ack","model":"","sid":"158d0001a1fa0e","short_id":24884,"data":"{\"voltage\":2965}"}
Posted: Monday 19 June 2017 23:51
by deennoo
langoo wrote:corbin wrote:@langoo and @TigroEHOT
As you Can see the only data forcasted is the battery voltage...
Posted: Tuesday 20 June 2017 0:11
by warmaniac
deennoo wrote:langoo wrote:corbin wrote:@langoo and @TigroEHOT
We need to wait for fw update of gateway
, maybe sometimes it will be done.
Posted: Tuesday 20 June 2017 2:25
by TigroEHOT
Yes, right.
Posted: Tuesday 20 June 2017 16:34
by langoo
Yes that seems as the only solution right now.
Posted: Tuesday 20 June 2017 16:53
by deennoo
Arrive on the app today the water sensor
Don't know where to get it.
About square device (wireless square switch, square door sensor, square temp and the new pir (with led) : gearbest can't have them anymore.
Posted: Tuesday 20 June 2017 17:02
by langoo
deennoo wrote:Arrive on the app today the water sensor
What do you mean with gearbest can't have them?
http://www.gearbest.com/access-control/pp_626702.html
Posted: Tuesday 20 June 2017 19:50
by benbammens
OK, the new temperature sensors show up in the android app.
I still can't see them in Domoticz though...
Posted: Tuesday 20 June 2017 20:50
by deennoo
They will never ship them even if they are on sale...
by deennoo
benbammens wrote:OK, the new temperature sensors show up in the android app.
As explain previously
Posted: Tuesday 20 June 2017 21:54
by langoo
I bought mine from them...
Posted: Wednesday 21 June 2017 0:19
by deennoo
I add ones to but they will not get them anymore
Posted: Wednesday 21 June 2017 0:29
by chatainsim
Same for me have the new door sensor.
Button in on it's way too.
