Locked
SwordFish
Domoticz version: V4.11375
Re: Dashticz v2.0, custom positioning and multiple screens
Post by SwordFish »
Is it save to use the moon script again? ;)
mAiden88
Domoticz version: 3.7286
Post by mAiden88 »
htilburgs wrote:Like to share?
Ofc. Will post it later to Day.
Anyone can build a fast processor. The trick is to build a fast system.
wizjos
Post by wizjos »
bierlaagh wrote: partly conformed
Only
n='00'
should be
n='50'
Although my moon.50.png is New Moon and moon.00.png is a full moon
You're completely right! Will fix it. Thanks! Still some minor issues. I'm checking it...
SwordFish
Post by SwordFish »
Only
n='00'
should be
n='50'
Great
Than i wait till its fix before i turn the script on again
Edit;
couldn't wait some i copied the last version of the script a few page back, turned the script on a get this error;
2017-04-27 09:57:40.874 Error: EventSystem: in Moon: [string "-- Variables to customize -------------------..."]:122: attempt to call field 'round' (a nil value)
wizjos
Post by wizjos »
OK I think I've got the moonphase lua script working again. I made the mistake to assume lua has a function 'round' when porting it from js to lua.
But now I think I've 'floored' the problem :lol:
New Moonphase LUA script:
-- Variables to customize ------------------------------------------------
local moonpicture = "MoonPicture"           -- name of the uservar to write the name of the moonphase picture to
local checkvar = "MoonphaseCheck"           -- name of the uservar to check if update is allowed
local checktime = 3600                      -- check allowed every x seconds 3600 = 60 min. Check the wundergroud API limitation before changing this
local city = "<your town>"                        -- Your city for Wunderground API
local countryCode = "<YOUR COUNTRY CODE>"                    -- Your country code for Wunderground API
local idxmoonpercentage ='125'              -- Your virtual moon percentage illuminated Device ID
local idxmoonage ='131'                     -- Your virtual moon age Device ID
local idxmoonphase ='132'                   -- Your virtual moon phase Device ID
local idxmoonrise='124'                     -- Your virtual moon rise variable ID
local idxmoonset='127'                      -- Your virtual moon set variable ID
local wuAPIkey = "<your key>"         -- Your Weather Underground API Key
local DOMO_IP = "<your domo ip>"            -- Domoticz ip address
local DOMO_PORT = "<your domo port>"                    -- Domoticz port
local tempfilename = '/var/tmp/phase.tmp'   -- can be anywhere writeable
local debug=false                            -- false, true for domoticz log
function file_exists(path)
    -- function to check if a file exists
    local file = io.open(path, "rb")
    if file then file:close() end
    return file ~= nil
function timedifference(s)
    -- function to determine the difference in seconds between the current time and a given one
    year = string.sub(s, 1, 4)
    month = string.sub(s, 6, 7)
    day = string.sub(s, 9, 10)
    hour = string.sub(s, 12, 13)
    t1 = os.time()
    return difference
function may_update(device, timeelapsed)
    -- function to check whether an update is allowed
    return uservariables_lastupdate[device] == nil or timedifference(uservariables_lastupdate[device]) >= timeelapsed
    time = os.date("*t")
    url='http://api.wunderground.com/api/'..wuAPIkey..'/astronomy/q/'..countryCode..'/'..city..'.json'
    if (may_update(checkvar,checktime)==true) or (file_exists(tempfilename)==false) then
       -- read API Wunderground
        if debug then print("Moonphase - Collecting data from: "..url) end
        os.execute('curl -s '..url..' > '..tempfilename)
        -- NOTE: if the command above doens't work in your situation try
        -- read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
        -- instead! Thanks to EdKo66
        file = io.open(tempfilename, "r")
        s= file:read("*a")
        s = (string.gsub(s, "%c+", ""))
        file:close()
        -- moonrise
        moonriseHour, moonriseMinute = string.match(s, [["moonrise": {"hour":"(%d+)","minute":"(%d+)"]])
        if debug then print("Moonrise:\t"..moonriseHour..":"..moonriseMinute) end
        -- moonset
        moonsetHour, moonsetMinute = string.match(s, [["moonset": {"hour":"(%d+)","minute":"(%d+)"]])
        if debug then print("Moonset:\t"..moonsetHour..":"..moonsetMinute) end
        -- percentage of moon illuminated
        percentIlluminated = string.match(s, [["percentIlluminated":"(%d+)"]])
        if debug then print("Percent:\t"..percentIlluminated.."%") end
        -- age of moon since last new moon
        age = string.match(s, [["ageOfMoon":"(%d+)"]])
        if debug then print("Age:\t\t"..age) end
        -- Phase of the moon
        -- set the moonPhaseIcon to your appropriate icon number (8 x)
        moonPhase = string.match(s, [["phaseofMoon":"(.-)"]])
        if moonPhase=="New Moon" then
            moonPhase = "Nieuwe maan"
            is_waxing = true
        if moonPhase=="Waxing Crescent" then
            moonPhase = "Wassende halve maan"
            is_waxing = true
        if moonPhase=="First Quarter" then
            moonPhase = "Eerste kwartier"
            is_waxing = true
        if moonPhase=="Waxing Gibbous" then
            moonPhase = "Wassende maan"
            is_waxing = true
        if moonPhase=="Full" then
            moonPhase = "Volle maan"
            is_waxing = false
        if moonPhase=="Waning Gibbous" then
            moonPhase = "Afnemende maan"
            is_waxing = false
        if moonPhase=="Last Quarter" then
            moonPhase = "Laatste kwartier"
            is_waxing = false
        if moonPhase=="Waning Crescent" then
            moonPhase = "Afnemende halve maan"
            is_waxing = false
        -- calculate moonphase picture
        if percentIlluminated == '0' then
            n='50'
            if waardecheck==false then
                picnumber=math.floor(math.abs(percentIlluminated-100)/2)
                n=tostring(picnumber)
                if n.length==1 then
                    n='0'+n
                picnumber=math.floor(50+(percentIlluminated/2))
                if picnumber == 100 then
                  picnumber=99
        picture='moon.'..n..'.png'
        if debug then print('Picture number: '..n..' '..'Picture name: '..picture) end
        commandArray['Variable:'..checkvar]=moonPhase
        commandArray['Variable:'..moonpicture]=picture
        commandArray[1] = {['UpdateDevice'] = idxmoonphase.."|0|"..moonPhase}
        commandArray[2] = {['UpdateDevice'] = idxmoonrise.."|0|"..moonriseHour..":"..moonriseMinute}
        commandArray[3] = {['UpdateDevice'] = idxmoonset.."|0|"..moonsetHour..":"..moonsetMinute}
        commandArray[4] = {['UpdateDevice'] = idxmoonage.."|0|"..age}
        commandArray[5] = {['UpdateDevice'] = idxmoonpercentage.."|0|"..percentIlluminated}
        if debug then print("MoonPhase - Update not allowed: Difference is "..timedifference(uservariables_lastupdate[checkvar]).." seconds") end
Please confirm...
Wizjos
SwordFish
Post by SwordFish »
wizjos wrote:OK I think I've got the moonphase lua script working again. I made the mistake to assume lua has a function 'round' when porting it from js to lua.
    return file ~= nil
    t1 = os.time()
    return difference
        s= file:read("*a")
        file:close()
        -- moonrise
        -- moonset
            is_waxing = true
            is_waxing = true
            is_waxing = true
            is_waxing = true
            is_waxing = false
            is_waxing = false
            is_waxing = false
            is_waxing = false
            n='50'
                if n.length==1 then
                    n='0'+n
                  picnumber=99
Please confirm...
Wizjos
No errors so far :)
wizjos
Post by wizjos »
SwordFish wrote: couldn't wait some i copied the last version of the script a few page back, turned the script on a get this error;
Should be gone now... LUA doesn't know of a function 'round'. Used 'floor' instead.
Wizjos
wizjos
Post by wizjos »
SwordFish wrote:No errors so far :)
8-) Thanks for testing! Revised original post as well
EdwinK
Post by EdwinK »
htilburgs wrote:
When u use the following command, you can still install in the map 'dashboard' if you like:
git clone https://github.com/robgeerts/dashticz_v2.git dashboard
And what if you want to put it in the root of the server?
mvveelen
Post by mvveelen »
mvveelen wrote:I was wondering: Is it possible to get the "var _SHOW_LASTUPDATE" per device?
For instance: I couldn't care less when the last time it was when I switch off a light, but it would be nice to see when a door sensor has been opened/closed.
And another question: I'd like to display the CV pressure (general, pressure), but all I see is: "Nefit - CV druk : AAN", where it should read 1.6 BAR. Is it possible to change that too ?
EdwinK
Post by EdwinK »
Please confirm...
Wizjos
No errors so far :)
No images of the moon anymore :( Still looks for http://192.168.0.10/dashboard/img/moon/moon.0.png
edit: now it works.
DvD
Post by DvD »
No error messages anymore but the moon is showing a full moon ...
EdwinK
Post by EdwinK »
DvD wrote:No error messages anymore but the moon is showing a full moon ...
This is 'my' moon atm
Moon50
Moon50
Screen Shot 2017-04-27 at 11.34.37.png (43.35 KiB) Viewed 2385 times
DvD
Post by DvD »
Here the variable is also moon50 but its showing a full moon....strange
UPDATE: never mind ! working
htilburgs
Post by htilburgs »
When you perform the git clone command from the root of the server, then it wil create a directory in the root.
Hardware:
EdwinK
Post by EdwinK »
I know, but I don't want/need a directory in the root. I just wanted to have all the files in the root, so calling my server with only the ip-address instead of adding a directory behind it.
mkscity
Domoticz version: 3.5877
Post by mkscity »
mkscity wrote:is it somehow possible to show more infos for moon phase?
Actually i have the following visible:
And this code in custom.js:
function getExtendedBlockTypes(blocktypes){
	blocktypes.Name['Download'] = { icon: 'fa fa-download', title: '<Name>', value: '<Data>' }
	blocktypes.Name['Mondphase'] = { icon: 'fa fa-moon-o', title: '<Name>', value: '<Data>' }
	blocktypes.Name['Mondaufgang'] = { icon: 'fa fa-moon-o', title: '<Data>', value: '<Name>' }
	return blocktypes;
But whatever i try to add for showing correct values for "Mondaufgang" and "Monduntergang" i see only switches.
Same Problem is actually that order is not changed, it shows always first <Data> then <Name>
Switch is set to true in config.js.
//Mondphase
blocks[192] = {}
blocks[192]['width'] = 6;
blocks[192]['switch'] = true;
i tried now the following changes in custom.js
I had same problem with Dutch texts. Can you try these settings? Don't forget to change the idx to yours.
blocks[idx] = {} //Mondaufgang
blocks[idx]['switch'] = true;
blocks[idx]['icon'] = 'fa-moon-o';
blocks[idx] = {} //Monduntergang
blocktypes.Name['Mondaufgang'] = { icon: 'fa-moon-o', title: '<Name>', value: '<Data>' }
blocktypes.Name['Monduntergang'] = { icon: 'fa-moon-o', title: '<Name>', value: '<Data>' }
	return blocktypes;
But so far still the same, Mondaufgang and Monduntergang still showing as a switch.
Problem with order is also still existing, it shows first Data then title.
Is there anything what i can try to get the correct view?
madrian
Post by madrian »
If you have time, please add more info to the Wiki about:
buttons.calendar = {icon: 'fa-calendar', title: 'Kalender', url: 'PASTE_URL_HERE'}
It is for Google Calendar? Other ical calendars are not supported?
@Rob: on Github, CONFIG.js/DEFAULT_CONFIG.js files are missing.
Blueone
Post by Blueone »
I have the following block:
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_Verbruik','281_1','281_2','282']
columns[2]['width'] = 6;
Device 281 is the powerusage and 282 the gas usage.
When I click the gas block the graph is showing in a popup. When I click the power blocks the graph isn't showing, probably because of the _1 and _2, is it possible to show the graph also at these kind of blocks?
Ierlandfan
Post by Ierlandfan »
If you want to use Google Calendar it's quit easy
Goto you Google Calendar press the arrow at the left next to your calendar.
It takes you to the "Calendar details"
You can change the height, color and other details like default week, agenda, or month under the part
"Change colour, size etc. (Click on it)
After changing (or not)
Copy the code found in the block "at the top of the page
Looks like this:
<iframe src="https://calendar.google.com/calendar/embed?mode=AGENDA&height=600&wkst=1&bgcolor=%23ffffff&src=your_email_address&color=%23125A12&ctz=Europe%2FAmsterdam" style="border-width:0" width="250" height="600" frameborder="0" scrolling="no"></iframe>
Delete the
 <iframe src=
and
part.
Create a Iframe var in CONFIG.js
frames.calendar = {height:250,frameurl:"https://calendar.google.com/calendar/embed?mode=AGENDA&height=600&wkst=1&bgcolor=%23ffffff&src=your_email_address&color=%23125A12&ctz=Europe%2FAmsterdam"
add frames.calendar to some column.
Edit: For some reason when dashboard reloads the page the calendar isn't filled anymore. Need to look into that.
Enjoy
Locked
