Page 75 of 123
Posted: Tuesday 06 June 2017 11:03
by corbin
StefanoA wrote:
Ok, done
perfect!
Posted: Tuesday 06 June 2017 11:04
by corbin
warmaniac wrote:
My other sensors works well, like human body , door, but this new not appearing in new devices , i can't see it at log file when added , already restarted xiaomi gateway try to compile new beta version of domoticz , nothing works , has anybody idea ? Thanks
I think it is need of a firmware update, probably not much longer to wait
Posted: Tuesday 06 June 2017 11:18
by benbammens
warmaniac wrote:Hi there , i want to ask if somebody use the new temperature and humidity sensor link :
http://m.gearbest.com/access-control/pp_626702.html
I have the same problem. The app says there are 2 sub devices (I have 2 temp sensors) but they do not show up in the list... Not in the app, not in Domoticz.
I have ordered 1 older sensor too see if that will work.
I read somewhere that the ios app does work OK with the new sensor. I'm not an Apple guy so can't test...
Posted: Tuesday 06 June 2017 11:30
by warmaniac
In ios app it is ok, showing both new temperature sensors correctly
benbammens wrote:warmaniac wrote:Hi there , i want to ask if somebody use the new temperature and humidity sensor link :
Posted: Tuesday 06 June 2017 12:21
by Swifty
@StefanoA - My suggestion was just a shot in the dark based on the trouble you described, so I'm glad it's working for you now
Does anyone have any suggestions for a (cheap) doorbell pusher that can be fitted outside? (in the British weather!)
My current doorbell (some Siemens junk) keeps failing, so I'd like to get a wireless button that is weather proof which I can integrate with Domoticz to trigger the Xiaomi gateways
Posted: Tuesday 06 June 2017 12:32
by benbammens
warmaniac wrote:In ios app it is ok, showing both new temperature sensors correctly
Lucky you. Hope they update the android app soon...
Posted: Tuesday 06 June 2017 12:49
by warmaniac
Im looking at wireshark output by UDP packets xiaomi gateway sending report only for gateway, motion and magnet sensors , that it must by failure of xiaomi gateway not domoticz .
Posted: Tuesday 06 June 2017 13:17
by deennoo
Confirming m'y observation.
Xiaomi didn't update Gateway already for n'es design devices. App pictures doesn't show the Real one.
We have to wait from Xiaomi Update
Posted: Tuesday 06 June 2017 19:49
by doxikus
Yep, I have the same problem, waiting for APP update
. There is a few video reviews and they said that new sensor type (aqara, cubed shape) works on iOS. Se we need to wait for update on Android.
Posted: Tuesday 06 June 2017 21:58
by theo69
Hi i have the Dual Button Wireless Switch
http://www.gearbest.com/alarm-systems/pp_610095.html in my domoticz it shows like:
- screenshot_36.png (72.42 KiB) Viewed 2728 times
however it shows not supported in homekit ;-(, need some help
Posted: Tuesday 06 June 2017 22:26
by theo69
I also have the single wireless wall switch
http://www.gearbest.com/access-control/pp_626696.html I can switch it on but not off (both homekit and domotics Dashboard, it shows like this:
- screenshot_37.png (52.96 KiB) Viewed 2727 times
I tried Selector and on/off, however its not working
Posted: Tuesday 06 June 2017 22:47
by marcotrumpet
Try to set an off delay in switch settings to 1 sec
Inviato dal mio SM-G950F utilizzando Tapatalk
Posted: Tuesday 06 June 2017 23:09
by theo69
Thanks, however if i do that i only can switch off
and in homekit the switch goes on and 1 second later off
Posted: Wednesday 07 June 2017 0:18
by warmaniac
Android app update did not solve problem with domoticz visibility of device, hopeit solves gateway update
Odoslané z môjho iPhone cez Tapatalk
Posted: Wednesday 07 June 2017 9:47
by theo69
Hi there I have a aqara
http://www.gearbest.com/access-control/pp_626696.htmlpush button. I am trying to configure it to use on/off. However it shows on but I can not switch it off if i press the button again, tried delay on button off button on/off button nothing is working
Posted: Wednesday 07 June 2017 22:36
by langoo
Hello
I got the new type of temperature/humidity sensor today from Gearbest. No problem getting the Gateway to show up in Domoticz. I can mate the sensors to the Gateway in the iOS-app but they never show up in Domoticz, anyone know why?
Posted: Wednesday 07 June 2017 22:39
by warmaniac
Hi , I wrote it before, it is because xiaomi gateway didn't updating status of sensor throught wifi , we must wait for update of gateway
langoo wrote:Hello
I got the new type of temperature/humidity sensor today from Gearbest. I can mate the sensors to the gateway but they never show up in Domoticz, anyone know why?
Posted: Wednesday 07 June 2017 23:01
by theo69
theo69 wrote:Hi there I have a aqara
Is nobody using one of these wireless wall switches?
Posted: Wednesday 07 June 2017 23:16
by NuNca
Hi, first of all thank you corbin for all the work you've done. i've been using this some time now and it works perfectly.
today i received a new aqara doorsensor (wanted to test it)
http://www.gearbest.com/access-control/pp_626703.html
it can be connected to the gateway using the Mi-app (iOS) and it shows up as a normal doorsensor with log and everything.
But it isn't shown in the Domoticz log.
When you use it (removing the magnet from the base and putting it back) there isn't a message in the Domoticz log, but when it's connected to the gateway and you press pair button on the doorsensor you will get a message in the Domoticz log:
2017-06-07 22:33:38.235 XiaomiGateway: unhandled model:
2017-06-07 22:33:38.235 {"cmd":"heartbeat","model":"","sid":"158d0001a3e8f3","short_id":35014,"data":"{\"voltage\":3155}"}
when i look at the developers mode i can see the device as:
{ Model: lumi.sensor_magnet.aq2,did: lumi.158d0001a3e8f3,name: Test }
i don't know if it's possible to get this new doorsensor also added to Domoticz. Hopefully you can show your magic once again.
If you need anything else please let me know.
Posted: Wednesday 07 June 2017 23:59
by warmaniac
There is a problem with aqara ones devices because it not updating status via UDP from gateway, so it must be done from xiaomi , maybe after some firmware update, it can work correctly ,btw I try to watch it via wireshark but nothing shows at output from xiaomi gateway ,(have too door and temperature aqara devices) .
