Page 73 of 123
Posted: Saturday 27 May 2017 10:08
by Mooseknuckle
Has anybody succesfully added the following wireless switch to the gateway?
http://www.gearbest.com/access-control/pp_626695.html
I tried to add it as a round wireless switch but It doesn't work. Maybe I just have to wait for a gateway update but I was curious if others did succeed in adding the switch.
Posted: Sunday 28 May 2017 16:52
by levynger
Mooseknuckle wrote:Hi,
xiaomi released a new wireless switch ?
if this is the case, it may use a different ID.
can you paste logs after clicking it, it should show "unknown device" with the ID..
Posted: Sunday 28 May 2017 19:04
by quack3d
I think he actually means he's unable to add it to the gateway through the app. I wonder why they made this revision of buttons and temperature sensors. As a light switch I think I prefer the old switch style as you can hit the entire switch, not just the middle.
Posted: Monday 29 May 2017 8:47
by Mooseknuckle
It is what quack3d said, adding it to the gateway does not work. The strange thing is that when I add it, the mihome app counts it as a device but I cannot see it under the devices. Also in Domoticz I see the new switch but nothing changes when I press the button. I can add other devices to the gateway so I think I have to wait for a firmware update from Xiaomi.
Posted: Monday 29 May 2017 9:06
by levynger
So you are able to add it to mi home apl?
In this case, you won't see it in domoticz devices if it uses new ID.
After paring it in mi home app, click on it, and in domoticz logs you should see the unknown line with the new device id.
Paste it here, and corbin would be able to do his magics..
Sent from my SM-N920G using Tapatalk
Posted: Monday 29 May 2017 10:07
by Mooseknuckle
levynger wrote:Mooseknuckle wrote:Hi,
That does not work. As I said, after adding it with the mihome app the switch is not visible in the app, while it does count as a device. I see the switch in Domoticz but it doesn't change and nothing appears in the log when I push the switch. The last update time remains on the time I added the switch.
The problem starts with adding it to the gateway, this has to work before making it work in Domoticz. But anywayz, I was just wondering if ppl with this switch have similar problems or that maybe my switch is broken. All other switches work perfectly.
Posted: Monday 29 May 2017 14:56
by quack3d
Anyone tested the new temperature monitor version? The one shaped like a square.
Posted: Tuesday 30 May 2017 20:25
by Coldman
corbin wrote:Was the error when smoke was detected?
You can enable the raw gateway messages to appear in the Domoticz log by creating a user variable 'XiaomiMessage' of type Integer and value 1. (Setup -> More Options -> User Variables). Then restart the Gateway hardware in Domoticz. from
http://www.domoticz.com/wiki/Xiaomi_Gat ... leshooting
Hello Corbin,
Thanks alot for your great job!
Could you please add Gas Sensor to Domoticz, logs:
XiaomiGateway: unhandled model: natgas
{"cmd":"report","model":"natgas","sid":"158d0001112b11","short_id":14003,"data":"{\"alarm\":\"0\"}"}
{"cmd":"report","model":"natgas","sid":"158d0001112b11","short_id":14003,"data":"{\"density\":\"0\"}"}
{"cmd":"heartbeat","model":"natgas","sid":"158d0001112b11","short_id":14003,"data":"{\"voltage\":3600}"}
Posted: Wednesday 31 May 2017 6:30
by StefanoA
PROBLEM OF COMMUNICATION AFTER REBOOT
I don't know if this is normal/happening to everyone, but for me it's a problem
After restart/reboot of Raspberry Pi3 & domoticz, if I look at LOG I always find communication problems like below
I figured out that if I go to HARDWARE page, select xiaomi gateway line and just push UPDATE button, the communication thread is restarted and communication is fixed and everything's working properly like shown below
so again, is this normal/happening to everyone else ?
is there any way to prevent this problem automatically in case of reboot/power loss ?
thanks
Posted: Wednesday 31 May 2017 10:07
by lamouette
Same "problem" on my side since ... the beginning
Posted: Wednesday 31 May 2017 17:50
by chatainsim
Maybe Domoticz start to quickly after startup of the Pi?
Posted: Thursday 01 June 2017 13:36
by Swifty
StefanoA wrote:PROBLEM OF COMMUNICATION AFTER REBOOT
thanks
Not sure if it helps, as I don't seem to have this problem, but if you run 'raspiconfig' I think there is an option in there to 'Wait for network on boot' (or something along those lines).
Maybe try to turn that on so that the network stack is fully up and address allocated etc. before Domoticz starts?
Posted: Thursday 01 June 2017 21:20
by Mat2Vence
is there anyway to know easily in Domoticz which voltage device correspond to which sensor?
I saw reference of the hex code in another post, but there is nothing matching on my device list... anything I am doind wrong?
Posted: Thursday 01 June 2017 21:55
by corbin
Thanks, have added to
https://github.com/corbinmunce/domoticz
Setting it as a smoke detector, type same as the actual smoke detector. Anyone know if there is a more suitable device type for Gas?
Posted: Thursday 01 June 2017 21:58
by Coldman
Thanks a lot!
UPD: additional information, what's inside:
Posted: Thursday 01 June 2017 22:00
by corbin
Mat2Vence wrote:is there anyway to know easily in Domoticz which voltage device correspond to which sensor?
If you don't have many devices, try matching them by battery level on the devices page
Posted: Thursday 01 June 2017 22:03
by corbin
I've added a 5 second delay at startup, hope that helps.
Posted: Thursday 01 June 2017 22:04
by Mat2Vence
corbin wrote:If you don't have many devices, try matching them by battery level on the devices page
I have 11 of them... not that easy... anyway I can identify at least some of them.
Posted: Friday 02 June 2017 0:14
by Mat2Vence
One more question... is there any easyway to make the alarm ringtone keep ringing for a while? By default, if switch on, it only remains active for a short period of time which is not that practical for using as an alarm siren.
I guess there is no way to do in blocky script and I should go though lua, isn't it?
Posted: Friday 02 June 2017 3:21
by ben53252642
My smoke detector has arrived, this is appearing in the Domoticz status logs:
2017-06-02 11:02:44.854 2017-06-02 11:02:44.854 XiaomiGateway: unhandled model: smoke
I can't see the smoke detector in the devices list, I've rebooted the Domoticz server twice.
Build 3.7602
Any ideas?
