Page 71 of 123
Posted: Monday 15 May 2017 19:15
by quack3d
How do I know which voltage reading is for which temperature sensor? I have 5 of them now.
Posted: Monday 15 May 2017 19:19
by bing69
quack3d wrote:How do I know which voltage reading is for which temperature sensor? I have 5 of them now.
Look to the hex code by id in the device list
Posted: Monday 15 May 2017 19:26
by quack3d
bing69 wrote:quack3d wrote:How do I know which voltage reading is for which temperature sensor? I have 5 of them now.
But the code doesn't match any of the other devices. Example: 3FBBDA6D on voltage and DF25 on humidity, temp, humidity/temp.
EDIT: Ahh... now I get it. The new voltages showing up was for my 4 switches and 1 motion sensor, not the 5 temperature sensors. Now I could identify the hex codes.
Posted: Monday 15 May 2017 20:21
by elgiampo
Hello to everyone!
in my dreams
I would like to use my Xiaomi Smart Wireless Switch to turn on my hue light.. what's the best way to do this?
Posted: Monday 15 May 2017 21:06
by quack3d
Perhaps a bit OT, but what's the deal with the tape that comes with the buttons, temp and motion sensors? Are they just extras if original wears out? If so, shouldnt the tape be double sided? Or are you supposed to use the sticker in the package together with the sticker attached to the device?
Also, my motion sensor has no preattached double sided tape but a small circular patch comes with in the package. But this one is not double sided, so what's the intention here? :S
Posted: Tuesday 16 May 2017 8:14
by deennoo
quack3d wrote:Perhaps a bit OT, but what's the deal with the tape that comes with the buttons, temp and motion sensors? Are they just extras if original wears out? If so, shouldnt the tape be double sided? Or are you supposed to use the sticker in the package together with the sticker attached to the device?
They are all double side tape, they come as a second part if you need to change them.
Posted: Tuesday 16 May 2017 9:03
by StefanoA
I'm having a problem on Domoticz Beta (latest version V3.7450 but also previous last was the same)
Until yesterday everything was ok, but today after restarting the raspberry3 on which domoticz is running, I cannot connect anymore to xiaomy gateway
and if I go to hardware page, I can't see all parameters of gateway,
IP address, port and password fields aren't visible anymore !
In another instance I'm running, again on a rasp3, I don't have same problem
connection is fine and I can see all parameters under hardware page !!
what's the matter ? the two systems are almost identical
pls help
Posted: Tuesday 16 May 2017 9:12
by quack3d
deennoo wrote:quack3d wrote:Perhaps a bit OT, but what's the deal with the tape that comes with the buttons, temp and motion sensors? Are they just extras if original wears out? If so, shouldnt the tape be double sided? Or are you supposed to use the sticker in the package together with the sticker attached to the device?
No, there's only adhesive on one side. Have you checked?
And did your motion sensor come with double sided tape? This is how mine looks:
Posted: Tuesday 16 May 2017 11:23
by superelch
farhanito wrote:superelch wrote:simple hack:
put the door sensor very close to the Electromagnetic coil of your doorbell. works for me. easy hack without any soldering.
sorry for my ignorance, but what does this hack do?
the door sensor works with magnetism.
you get an alarm/massage when someone ring your doorbell.....
Posted: Tuesday 16 May 2017 20:56
by chatainsim
Regarding smoke sensor here what I got in Domoticz logs:
2017-05-16 20:51:43.558 XiaomiGateway: unhandled model: smoke
2017-05-16 20:51:43.559 {"cmd":"report","model":"smoke","sid":"158d0001538a9e","short_id":31763,"data":"{\"density\":\"0\"}"}
2017-05-16 20:51:43.583 XiaomiGateway: unhandled model: smoke
2017-05-16 20:51:43.583 {"cmd":"heartbeat","model":"smoke","sid":"158d0001538a9e","short_id":31763,"data":"{\"voltage\":3265}"}
If it can help to integrate into Domoticz.
Posted: Wednesday 17 May 2017 9:23
by corbin
I've added the smoke detector to
https://github.com/corbinmunce/domoticz, are you able to compile and test?
Posted: Wednesday 17 May 2017 16:38
by Mat2Vence
Just to know.. Are the sound elements supposed to work back with the actual beta version? Thanks for your help
Posted: Wednesday 17 May 2017 16:58
by farhanito
noticed a new firmware update for the gateway, anybody knows what's changed?
Posted: Wednesday 17 May 2017 17:09
by blacksn0w
Here too, 1.4.1_146.0141
Hope they've fixed the false positives in the APIl
Posted: Wednesday 17 May 2017 23:01
by chatainsim
I will try as soon as possible.
Which branche ? Because master was updated 13 days ago.
Posted: Thursday 18 May 2017 0:47
by Mat2Vence
Sorry for annoying you again on that point, but could anyone let me know whether the MP3, Alarm Clock, Alarm Ringtone, Door ringtone, RGB and gateway volume are wrking with beta 3.7450?
I have try to remove them and set them back, but there is still no communication from Domoticz to these fonctions on the gateway. But, in another hand, if I am setting the RGB with the Xiaomi apps, I have the status back on Domoticz (only the case with RGB).
Any idea where it can come from in case it is supposed to work?
Posted: Thursday 18 May 2017 10:33
by corbin
All gateway sounds are working through Domoticz on my setup.
Check that your gateway IP has not changed, and also double check the password - I think it did once reset on me accidentally.
Posted: Thursday 18 May 2017 10:36
by corbin
Sorry, forgot to sync. It is updated now -
Posted: Thursday 18 May 2017 15:50
by Caribou
Sorry I don't know if it's Xiaomi related or a more general question about domoticz:
why do I get that message "no temperature sensors founded or added in the system…" quickly displayed in the footer of this webpage:
https://i.imgur.com/nebpvLz.png ?
Posted: Friday 19 May 2017 10:29
by Mat2Vence
corbin wrote:All gateway sounds are working through Domoticz on my setup.
I have other sensor (door sensor and PIR) that are working perfectly. So I guess the communication is correct... I am gonna make some other checks.
