How to install Domoticz on a Synology NAS
Sneezydevil
Re: How to install Domoticz on a Synology NAS
Post by Sneezydevil »
gertjanwo wrote:1 year ago was the last post.
i have a NAS and stil intrested in using the Domoticz
Is any one out here who can help me out?
I have a synology nas 216play
I am a bit confused, last post was like 1 week ago right?
For a 216play you prolly need (depending on your dsm version):
http://www.jadahl.com/domoticz_beta_6/?arch=monaco
Do you know which version of DMS you have?
//Edit
I typed to slow :D
Goldwing1973
Domoticz version: Stable
Post by Goldwing1973 »
Could someone please tell me what config to edit to change the port Domoticz uses?
I updated Domoticz on my Synology NAS from my iPad, then closed the tab forgetting it always returns a question box and the end asking what ports it should use.
Now Domoticz is trying to start at port 8080 and 443, and obviously they are already in use.
I've been looking in the /volume1/@appstore/domoticz folder, but can't find the right config file.
Over 50 Z-Wave Devices (Fibaro and Neo), 4xLogitech Hub, 2xPhilips Hue Bridge+55 Lights, 1x Nest Thermostat, 2xNetatmo Weather Station, 1xSkybell v1 Doorbell, 3 Kwikset KEVO Doorlocks and Domoticz running on a Intel NUC
jumbotroll
Post by jumbotroll »
Goldwing1973 wrote:Could someone please tell me what config to edit to change the port Domoticz uses?
Default http port on domoticz for synology is 8084
Default https port on domoticz for synology is 8443
On my packages, you can change port settings in the install wizard.
https://paypal.me/Jumbotroll
Jumbotroll
Goldwing1973
jumbotroll wrote: Default http port on domoticz for synology is 8084
So you can't change them afterwards?
And if i remove and reinstall the package, will this also remove the database? i.e. do i need to start all over again????
jumbotroll
If you update, you keep the database, but if you reinstall the database will be deleted but you always have backed up your database file :-)
Remember not all ports are avalible on the Synology NAS.
Jumbotroll
putte
Domoticz version: 2.0.2112
Post by putte »
I'm trying to install Domoticz on my NAS Synology DS413J
I can add:
http://packages.synocommunity.com
But I have problem to add:
Name "Domoticz Updates" and URL "http://jadahl.dscloud.me/sspks/" and OK
I have set "General" and select "install packages from all publishers"
But I get Invalid location :(
I can install Domoticz, no port available when i search for my RFXtrx433E
jumbotroll
putte wrote:Hi,
I can add:
The package from http://packages.synocommunity.com does not include USB drivers! Uninstall this package and use my packages that include OpenZwave and all USB drivers.
For DSM6.x use this URL:
For DSM5.2 use this URL:
http://www.jadahl.com/domoticz_beta/
Jumbotroll
comas38
Post by comas38 »
Good evening,
I have uninstalled Domoticz and now I try to install it again but I am trying to reach the package for the DSM 4.2 but no chance.
I tried :
- syno community channel -> no more visible
- http://www.jadahl.com/domoticz_beta/ channel -> no more valid
- beta page on jadahl.com -> no version visible
I can only reach packages compatible with DSM 5.0
Any link for this package or other idea ?
Thank you for your help
jumbotroll
comas38 wrote:Good evening,
I tried :
I did stop update domoticz for DSM 4.2 last year, but maybe I can compile a version for you?
What Synology NAS do you have?
Jumbotroll
comas38
Post by comas38 »
Good morning,
I have a 209 one.
If you could compile this package, it would be very helpful.
Thank you
jumbotroll
comas38 wrote:Good morning,
I have a 209 one.
Thank you
Here you go :-)
Domoticz v3.0.6333-7
http://www.jadahl.com/domoticz_old/?arch=88f6281
Jumbotroll
comas38
Post by comas38 »
So cool !
Thank you very much for your help !
checkdiz
Post by checkdiz »
hello, I have a new rflink gateway linked with usb to my synology ds214. with dsm 6). installed newest domoticz version for ds214 (Jadahl), but when adding the rflink as hardware, it's not recognized (usb port "0") . Domoticz log says "serial worker stopped". what am i doing wrong??
jumbotroll
checkdiz wrote:hello, I have a new rflink gateway linked with usb to my synology ds214. with dsm 6). installed newest domoticz version for ds214 (Jadahl), but when adding the rflink as hardware, it's not recognized (usb port "0") . Domoticz log says "serial worker stopped". what am i doing wrong??
http://www.nemcon.nl/blog2/wiring
Frequent Reset issues:
In case you experience frequent reset issues you might want to try the following:
connect a 10 uF capacitor between reset and ground on the Arduino.
Simply stick the pins of the capacitor in the power connector socket.
Connect the minus pole to ground. The plus pole to reset.
This will fix any reset problems when connecting a regular Arduino Mega to a Synology NAS.
It also solve reset issues in some other cases.
The voltage of the 10uf capacitor is not really important as long as it is 5 volts or higher (12/25/50/63/240/etc. volts all are fine)
Note: When you want to update the firmware of the Arduino, remove the capacitor and reconnect it when done with the upgrade.
Alternatively you can use an Arduino Mega that has a CH340 USB chip.
Edit: Sometimes you have to reboot your NAS after the first installation.
Last edited by jumbotroll on Saturday 14 January 2017 14:58, edited 1 time in total.
Jumbotroll
checkdiz
Post by checkdiz »
im actually using the arduino mega with ch340 chip. bought at nodo-shop.nl, specifically for use with synology.. could it be something else?
jumbotroll
checkdiz wrote:im actually using the arduino mega with ch340 chip. bought at nodo-shop.nl, specifically for use with synology.. could it be something else?
Did you reboot the NAS?
Jumbotroll
checkdiz
Post by checkdiz »
yes, multiple times
jumbotroll
checkdiz wrote:yes, multiple times
Try to log in with Telnet/ssh and type: dmesg
Look for:
usbcore: registered new interface driver ch341
usbserial: USB Serial support registered for ch341-uart
ch341 6-2:1.0: ch341-uart converter detected
usb 6-2: ch341-uart converter now attached to ttyUSB0
or check if there is some errors and paste them here.
Jumbotroll
checkdiz
Post by checkdiz »
will do. thanks for support so far. when I type dmesg it closes down putty, so first I have to figure that out
checkdiz
Post by checkdiz »
i got this:
USB Serial support registered for TI USB 3410 1 port adapter
USB Serial support registered for TI USB 5052 2 port adapter
usbcore: registered new interface driver ti_usb_3410_5052
ti_usb_3410_5052: v0.10:TI USB 3410/5052 Serial Driver
i saw one error, but don't know if related:
EXT3-fs (md0): error: couldn't mount because of unsupported optional features (240)
