checkdiz wrote:hello, I have a new rflink gateway linked with usb to my synology ds214. with dsm 6). installed newest domoticz version for ds214 (Jadahl), but when adding the rflink as hardware, it's not recognized (usb port "0") . Domoticz log says "serial worker stopped". what am i doing wrong??
http://www.nemcon.nl/blog2/wiring
Frequent Reset issues:
In case you experience frequent reset issues you might want to try the following:
connect a 10 uF capacitor between reset and ground on the Arduino.
Simply stick the pins of the capacitor in the power connector socket.
Connect the minus pole to ground. The plus pole to reset.
This will fix any reset problems when connecting a regular Arduino Mega to a Synology NAS.
It also solve reset issues in some other cases.
The voltage of the 10uf capacitor is not really important as long as it is 5 volts or higher (12/25/50/63/240/etc. volts all are fine)
Note: When you want to update the firmware of the Arduino, remove the capacitor and reconnect it when done with the upgrade.
Alternatively you can use an Arduino Mega that has a CH340 USB chip.
Edit: Sometimes you have to reboot your NAS after the first installation.
