Page 8 of 16
Re: Is it gonna rain within the next X minutes?
Posted: Saturday 03 December 2016 15:21
by happyman
I add an line so the log is more compleet.
print('Regen verwacht: '..regen..' mm binnen '..minuten..' minuten.')
..regen.. is the function from your script.
The last time the script gives an strange result:
2016-12-03 15:15:00.854 LUA: Regen verwacht: nan mm binnen 20 minuten.
And the switch in continuos ON.
I cannot found where the
nan is generated. Any ideas?
Posted: Saturday 03 December 2016 15:59
by jvdz
What is the content of the file downloaded by the script? (rain.txt)
Jos
Posted: Sunday 04 December 2016 7:22
by mikeoo
happyman wrote:Hi,
I think the nan is because the value is 0 when there is no rain predicts.
https://en.wikipedia.org/wiki/NaN
Posted: Saturday 10 December 2016 17:33
by happyman
Here is the complete code
-- IsItGonnaRain( int minutesinfuture)
-- returns: int avarage rainfall for the next minutesinfuture
-- Function to get rain prediction from Buienradar.nl (dutch)
-- http://gratisweerdata.buienradar.nl/#Buienradar You may use their free service for non-commercial purposes.
-- Written in LUA by Hans van der Heijden (h4nsie @ gmail.com)
-- Spring 2015
-- 28-03-2015 v0.3 bug: quotes around url added.
-- 27-03-2015 v0.2 return value is now average for next time
-- 26-03-2015 v0.1 Initial release
-- todo: some error checking on http and file handling (tmp file)
function IsItGonnaRain( minutesinfuture )
-- config ---------------------------------------------------------
lat='52.65160' -- example lat/lon for Den Haag
lon='5.10954'
debug=false
tempfilename = '/var/tmp/rain.tmp' -- can be anywhere writeable
url='http://gadgets.buienradar.nl/data/raintext?lat='..lat..'&lon='..lon
if debug then print(url) end
read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
file = io.open(tempfilename, "r")
totalrain=0
rainlines=0
-- now analyse the received lines, format is like 000|15:30 per line.
while true do
line = file:read("*line")
if not line then break end
if debug then print('Line:'..line) end
linetime=string.sub(tostring(line), 5, 9)
if debug then print('Linetime: '..linetime) end
-- Linetime2 holds the full date calculated from the time on a line
linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')}
difference = os.difftime (linetime2,os.time())
-- When a line entry has a time in the future AND is in the given range, then totalize the rainfall
if ((difference > 0) and (difference<=minutesinfuture*60)) then
if debug then print('Line in time range found') end
rain=tonumber(string.sub(tostring(line), 0, 3))
totalrain = totalrain+rain
rainlines=rainlines+1
if debug then print('Rain in timerange: '..rain) end
if debug then print('Total rain now: '..totalrain) end
file:close()
-- Returned value is average rain fall for next time
-- 0 is no rain, 255 is very heavy rain
-- When needed, mm/h is calculated by 10^((value -109)/32) (example: 77 = 0.1 mm/hour)
averagerain=totalrain/rainlines
return(averagerain)
time = os.date("*t")
if ((time.min % 15)==0) then
----- REGEN ------
minuten=15
regen = IsItGonnaRain(minuten)
if regen > 70 and otherdevices['Rain expected']=='Off' then
commandArray['SendNotification']='Regenscript#Regen verwacht'
commandArray['Rain expected']='On'
if regen == 0 and otherdevices['Rain expected']=='On' then
commandArray['SendNotification']='Regenscript#Geen regen meer verwacht'
commandArray['Rain expected']='Off'
I'm not at home right now so I cannot view the rain.txt file. Will follow.
When I enter the url in explorer there is data.
http://gadgets.buienradar.nl/data/raintext?lat=52.65160&lon=5.10954
000|17:35
000|17:40
000|17:45
000|17:50
035|17:55
057|18:00
057|18:05
070|18:10
057|18:15
057|18:20
080|18:25
070|18:30
057|18:35
035|18:40
035|18:45
035|18:50
035|18:55
000|19:00
000|19:05
000|19:10
000|19:15
000|19:20
000|19:25
000|19:30
Posted: Sunday 11 December 2016 22:50
by MaffeMuis
Put debug on to TRUE
Also I think your URL need to be:
http://gadgets.buienradar.nl/data/raint ... 5&lon=5.11
Set your
lat to 52.65
and
lon to 5.11
I think they changed something, you get an MOVE PAGE is you used the more advaned lat en lon.
Posted: Tuesday 03 January 2017 0:49
by Domoticzfun
I tried this script today and got it working after a change. Thanks for the nice work!
As already been said the URL needed has been changed,
It is changed to this one:
url='
http://gpsgadget.buienradar.nl/data/rai ... 5&lon=5.11'
(tried it in the webbrowser and checked the file, this is working now as I see values for one hour for every 5 minutes in /var/tmp/rain.tmp)
lat and lon are auto rounded in 2 decimals so more decimals in the variables are useless.
Rob
Posted: Wednesday 22 February 2017 23:27
by Brutus
sander815 wrote:i am not getting this to work anymore.
Url is working, but my virtaul switch Rain expected remains 0mm
/var/tmp/rain.txt is looking ok
112|13:30
117|13:35
106|13:40
106|13:45
087|13:50
087|13:55
087|14:00
057|14:05
057|14:10
057|14:15
057|14:20
057|14:25
070|14:30
035|14:35
000|14:40
035|14:45
000|14:50
000|14:55
000|15:00
and in teh log i see this:
2017-02-22 13:30:01.531 LUA: Regen verwacht: 109.66666666667 mm binnen 15 minuten.
what am i doing wrong?
Maybe you can post your script?
Posted: Thursday 23 February 2017 17:52
by Brutus
sander815 wrote:Code: Select all
-- Spring 2015
lat='51.70' -- example lat/lon for Den Haag
lon='5.98'
debug=false
totalrain=0
rainlines=0
while true do
file:close()
return(averagerain)
----- REGEN ------
minuten=15
You say that you "Rain Expected" Virtual Switch remains 0mm. Its a Switch so you can only set it "On" or "Off". As the script does at the bottom.
When was the last time this switch has changed in the log?
Posted: Friday 10 March 2017 12:35
by EldigoR
FYI
I saw errors like these in the logging from time to time..
Error: EventSystem: Warning!, lua script Lua Rain Expected has been running for more than 10 seconds
So I added a 5 seconds timeout to the curl command.
read = os.execute('curl --connect-timeout 5 -s -o '..tempfilename..' "'..url..'"')
Posted: Thursday 13 April 2017 8:46
by zicht
I noticed that you use a temp file to write data to.
Just to make you aware that this is not needed at all i post my sollution around that ...
( I hate writing temp files for obvious reasons)
function to read directly any page into a string
function os.capture(cmd, raw) -- os.command uitvoeren en resultaat daarvan lezen in string
local f = assert(io.popen(cmd, 'r'))
local s = assert(f:read('*a'))
f:close()
if raw then return s end
s = string.gsub(s, '^%s+', '')
s = string.gsub(s, '%s+$', '')
s = string.gsub(s, '[\n\r]+', ' ')
return s
And then in you following code you can do (just an example) :
-- construct the request URL
local url = 'http://gadgets.buienradar.nl/data/raintext/ -F lat=51.0 -F lon=5.51'
content = os.capture("Curl "..url)
Content will contain all data that you will need to split into a table to manipulate.
In the table rain {} you will find rain, In the table rtime{} you will find corresponding times.
sep = "%s"
local rain={}
local rtime={}
i=1
for str in string.gmatch(content, "([^"..sep.."]+)") do
rain[i]=string.sub(str, 1, 3)
rtime[i]=string.sub(str, 5, 10)
if (tonumber(rain[i]) > 0) then
if (eersteregen == "" ) then eersteregen = rtime[i] end
totalrain=totalrain + tonumber(rain[i])
rainlines=rainlines + 1
alletijden=alletijden .. " " .. rtime[i]
i = i + 1
averagerain = round(totalrain /rainlines,2)
averagerain = round(10^((averagerain-109)/32),1)
Hope it helps you all to avoid writing unneeded files
Posted: Friday 14 April 2017 9:51
by gielie
Can someone explain how to create a text switch with rain expected, i can't get it to work. I use the latest script but i only have an on/off switch and a print in the log but i want this in a text switch.
Posted: Monday 17 April 2017 16:34
by BarryT
local RainTextIDX = 19 -- your domoticz text device
debug = false -- enable or disable debug output
tempfilename = '/home/pi/domoticz/scripts/barry/rain.tmp' -- be sure this is in the correct map, and give it chmod 0666
totalrain = 0
rainlines = 0
url='http://gadgets.buienradar.nl/data/raintext/?lat=1.1&lon=1.1' -- this is important!! change the lat and lon to your needs!!
while true do
file:close()
return(averagerain)
function round(num, idp)
local mult = 10^(idp or 0)
return math.floor(num * mult + 0.5) / mult
minuten=30
RainPrediction = IsItGonnaRain(minuten)
RainmmHour=10^((RainPrediction-109)/32)
if (RainPrediction > 20 ) then
verw = 3
RainPredictionText=('('..round(RainmmHour, 1)..' mm) regen verwacht!')
verw = 2
RainPredictionText=('Voorlopig blijft het droog!')
commandArray[2] = {['UpdateDevice'] = RainTextIDX .. '|0|' .. tostring(RainPredictionText)}
I have included this script in events system @lua and works perfect
- r3.png (21.46 KiB) Viewed 3264 times
Posted: Monday 17 April 2017 17:32
by SwordFish
BarryT wrote:Code: Select all
totalrain = 0
rainlines = 0
while true do
file:close()
return(averagerain)
minuten=30
verw = 3
verw = 2
But how do we use this?
Is this instead of script_time_rain?
Posted: Monday 17 April 2017 17:43
by SwordFish
SwordFish wrote:BarryT wrote:Code: Select all
totalrain = 0
rainlines = 0
while true do
file:close()
return(averagerain)
minuten=30
verw = 3
verw = 2
Edit;
Get it working
Posted: Monday 17 April 2017 22:49
by Siewert308SW
Thx for the script.
In addition to the previous posted i added 2 extra virtual rain expectation widgets.
-> 30 minutes -> 60 minutes -> 120 minutes
And set the script to update every 30minutes.
-- Get System Time
local m = os.date('%M')
-- Buienradar
local RainTextIDX = 192 --your domoticz text device
local Rain60TextIDX = 193 --your domoticz text device
local Rain120TextIDX = 194 --your domoticz text device
tempfilename = '/mnt/storage/domoticz_scripts/logging/buienradar/rain.tmp' -- be sure this is in the correct map, and give it chmod 0666
totalrain = 0
rainlines = 0
while true do
file:close()
return(averagerain)
if (m % 30 == 0) then -- run once in 30 min
minuten=30
minuten60=60
minuten120=100
-- Buienradar - Update virtual text device
if (RainPrediction > 5 ) then
verw = 3
RainPredictionText=('Komende 30min wordt er een buitje verwacht!')
RainPredictionText60=('Komende uur wordt er een buitje verwacht!')
RainPredictionText120=('Na het komende uur word er een buitje verwacht!')
elseif (RainPrediction > 12 ) then
verw = 2
RainPredictionText=('Komende 30min ('..round(RainmmHour, 1)..' mm) regen verwacht!')
RainPredictionText60=('Komende uur ('..round(RainmmHour, 1)..' mm) regen verwacht!')
RainPredictionText120=('Na het komende uur word er ('..round(RainmmHour, 1)..' mm) regen verwacht!')
verw = 1
RainPredictionText=('Komende 30min blijft het voorlopig droog!')
RainPredictionText60=('Komende uur blijft het voorlopig droog!')
RainPredictionText120=('Na het komende uur blijft het voorlopig droog!')
commandArray[1] = {['UpdateDevice'] = RainTextIDX .. '|0|' .. tostring(RainPredictionText)}
commandArray[2] = {['UpdateDevice'] = Rain60TextIDX .. '|0|' .. tostring(RainPredictionText60)}
commandArray[3] = {['UpdateDevice'] = Rain120TextIDX .. '|0|' .. tostring(RainPredictionText120)}
- domo_rain.png (33.82 KiB) Viewed 3231 times
edited:
optimised script
Posted: Tuesday 18 April 2017 21:09
by gielie
I have a problem with my rain script, especially with the text switch which never changes.
this is my code.
-- Original script here: https://www.domoticz.com/wiki/Is_it_gonna_rain
-- Spring 2015
-- Marco van Wijngaarden
-- 30-08-2016 v1.0 Adopted and updated the above scripts
-- 30-08-2016 v1.1 Updated the request URL, apparently buienrader is redirecting to different url
-- 30-08-2016 v1.2 Updated CURL to follow redirect and reverted (back to documented) request URL
-- Buienradar.nl --
-- Gratis Weerdata --
-- Buienradar stelt gratis weerdata beschikbaar voor particulieren en bedrijven (website/intranet).
-- Het gebruik van onderstaande weerdata is alleen toegestaan voor niet-commerciële doeleinden.
-- Het gebruik voor mobiele toepassingen of commerciële doeleinden vereist toestemming van Buienradar, zie ook de Disclaimer.
-- Vraag hier toestemming aan voor het gebruik van de weerdata: http://www.buienradar.nl/overbuienradar/contact
-- Vragen, suggesties of een leuk idee? Neem contact met ons op en bouw mee aan Buienradar!
-- Buienradar widget - Neerslagdata op basis van coördinaten
-- Op basis van de door u gewenste coördinaten (latitude en longitude) kunt u de neerslag tot twee uur vooruit ophalen in tekstvorm.
-- De data wordt iedere 5 minuten geüpdatet.
-- Op deze pagina kunt u de neerslag in tekst vinden: http://gps.buienradar.nl/getrr.php?lat=51&lon=3
-- De waarde 0 geeft geen neerslag aan (droog), de waarde 255 geeft zware neerslag aan.
-- Gebruik de volgende formule voor het omrekenen naar de neerslagintensiteit in de eenheid millimeter per uur (mm/u):
-- Neerslagintensiteit = 10^((waarde-109)/32)
-- Ter controle: een waarde van 77 is gelijk aan een neerslagintensiteit van 0,1 mm/u.
-- config ------------------------------------------------------------------------------------------------------
-- Set your local position (latitude and longitude)
local latitude = '52.65' -- your home latitude, set as a user variable
local longitude = '4.77' -- your home longtitude, set as a user variable
-- timewindow for prediction
local minutesinfuture = 30 -- (int) minutes in future to calculate rain
-- threshold for switch (when do we actually call it rain and want to act accordingly)
local switchthreshold = 70 -- (int) value to toggle virtual switch
-- Rain switch (ON when rain above threshold, else OFF)
local rainswitchname = "Regen verwacht" -- (str) name for switch to toggle
-- Virtual device (txt) displays textual result
local idxRegenmmUur = 370 -- IDX for virtual (text) sensor
-- Show results in log
local debug = 1 -- 1 = ON or 0 = OFF
-- NMA notifications (only during the day)
local notify = false -- (bool) set 'false' or 'true'
-- URL for data rewquest
local requesturl = "http://gadgets.buienradar.nl/data/raintext?lat='..lat..'&lon='..lon"
-- redirects to "http://gadgets.buienradar.nl/data/raintext"
-- Where do we store the data (tmp) file
local tempfilename = "/home/pi/domoticz/scripts/tmp/rain.tmp"
-- default to activate script (set 'false' to run once every 5 minutes or 'true' to run every minute)
local active = false -- (bool) set 'false' or 'true'
-- No edit required below this line
-- execute (activate) every 5 minutes
local time = os.date("*t")
if ((time.min % 5)==0) then
-- set to active
active = true
-- Functions ---------------------------------------------------------------------------------------------------
-- function to split a string --
function splitString(str, delim, maxNb)
-- Eliminate bad cases...
if string.find(str, delim) == nil then
return { str }
if maxNb == nil or maxNb < 1 then
maxNb = 0 -- No limit
local result = {}
local pat = "(.-)" .. delim .. "()"
local nb = 0
local lastPos
for part, pos in string.gmatch(str, pat) do
nb = nb + 1
result[nb] = part
lastPos = pos
if nb == maxNb then break end
-- Handle the last field
if nb ~= maxNb then
result[nb + 1] = string.sub(str, lastPos)
return result
-- function to request rain data
function IsItGonnaRain(requesturl,latitude,longitude,tempfilename,minutesinfuture,debug)
local averagerain = 0
local totalrain = 0
local rainlines = 0
local url = requesturl..'?lat='..latitude..'&lon='..longitude
-- print to log
if (debug == 1) then print("| Request URL .............. : " .. url) end
-- now get the data
local trigger_action = 'curl -Lo '..tempfilename..' "'..url..'"'
-- CURL options: -s for Silent (no error messages)
-- -o for Write output to file instead of stdout.
-- -L Follow redirects if the server reports that the requested page has moved (indicated with a Location: header and a 3XX response code)
handle = os.execute(trigger_action)
-- print request result to log
if handle then
print("| CURL Data request ........ : Success")
print("! CURL Data request ........ : Failed")
-- open file and process data
-- count datalines
local linenbr = 0
while true do
-- count received lines
linenbr = linenbr+1
-- line/data format is like 000|15:30 per line, we need to split the string
raindata = splitString(line,"|")
rain = tonumber(raindata[1])
linetime = raindata[2]
-- Linetime2 holds the full date calculated from the time on each line
-- calculate the time difference between data/line and os time
-- When a line entry has a time in the future AND is within the given range, then add/totalize the rainfall
if ((difference >= 0) and (difference <= minutesinfuture*60)) then
-- print (relevant) data to log
if (debug == 1) then print("| Rain data (line) ......... : " .. line) end
-- calculate totals
rainlines = rainlines+1
-- close the file
file:close()
-- Returned value is average rain fall for next (int) minutes
averagerain = totalrain/rainlines
-- print summary to log
print("| Rain data received # lines : " .. linenbr)
print("| In timerange # lines ..... : " .. rainlines)
print("| Total rain ............... : " .. totalrain)
print("| Average rain calculated .. : " .. averagerain)
return(averagerain)
-- Functions to round a number to the given number of decimal places
-- returns result as string (text)
return string.format("%." .. (idp or 0) .. "f", num)
-- returns result as a number
function round2number(num, idp)
return tonumber(string.format("%." .. (idp or 0) .. "f", num))
-- Note: If the number is rounded in order to be printed (as text) use function "round" (removed the tonumber function)
-- Converting to number then back to string would reintroduce rounding errors, so for numbers use "round2number" function
-- Process -----------------------------------------------------------------------------------------------------
-- start numbering at 1
indexArray=1
-- executes when active (every 5 minutes)
if (active) then
-- when debugging set to 1, writing to log starts here
print("+--------------------------------------------------+")
print("| =============== IS IT GONNA RAIN =============== |")
-- rain variables
local regen = 0
local regenmmUur = 0
local rainstr = ""
-- execute function (for given future minutes)
regen = IsItGonnaRain(requesturl,latitude,longitude,tempfilename,minutesinfuture,debug)
-- round result
if (regen > 0) then
regen = round2number(regen, 0)
-- convert rain to mm/uur
if (regen > 0) then
regenmmUur = 10^((regen-109)/32)
regenmmUur = round(regenmmUur, 3)
-- textual result
if (regen > 0) then
rainstr = tostring("Regen verwacht: "..regen.." (".. regenmmUur.." mm/uur) binnen "..minutesinfuture.." minuten")
rainstr = tostring("Geen regen verwacht binnen komende "..minutesinfuture.." minuten")
-- write value to virtual (text) sensor
if ((idxRegenmmUur) and (regenmmUur)) then
commandArray[indexArray] = {['UpdateDevice'] = tostring(idxRegenmmUur)..'|0|'..rainstr}
indexArray=indexArray+1
-- when debugging set to 1, write to log
print("| Rain text ................ : " .. rainstr)
-- toggle switch ON
if regen > switchthreshold and otherdevices[rainswitchname]=='Off' then
-- send notification during the day
if (timeofday['Daytime']) and (notify) then
commandArray[indexArray] = {['SendNotification']=rainstr}
-- change switch to ON
commandArray[indexArray] = {[rainswitchname]='On'}
-- toggle switch OFF
if regen == 0 and otherdevices[rainswitchname] =='On' then
-- change switch to OFF
commandArray[indexArray] = {[rainswitchname]='Off'}
-- logging end
print("| --------------------- END ---------------------- |")
this is my error
2017-04-18 21:05:00.479 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_rain.lua: /home/pi/domoticz/scripts/lua/script_time_rain.lua:165: bad argument #1 to 'sub' (string expected, got nil)
Does someone have any idea how to solve this?
Posted: Tuesday 18 April 2017 21:31
by BarryT
gielie wrote:I have a problem with my rain script, especially with the text switch which never changes.
this is my code.
-- Spring 2015
-- Buienradar.nl --
-- set to active
active = true
return { str }
local result = {}
local nb = 0
local lastPos
nb = nb + 1
result[nb] = part
lastPos = pos
if nb ~= maxNb then
return result
local totalrain = 0
local rainlines = 0
-- print to log
-- now get the data
if handle then
-- count datalines
local linenbr = 0
while true do
linenbr = linenbr+1
-- calculate totals
-- close the file
file:close()
return(averagerain)
indexArray=1
if (active) then
-- rain variables
local regen = 0
local rainstr = ""
-- round result
if (regen > 0) then
if (regen > 0) then
-- textual result
if (regen > 0) then
-- toggle switch ON
-- logging end
this is my error
Did you changed the buienradar url as mentioned earlier?
Posted: Saturday 22 April 2017 9:02
by poudenes
Maybe stupid question, But whats script filename ending? .ph .pl other?
Siewert308SW wrote:Thx for the script.
-- Get System Time
-- Buienradar
totalrain = 0
rainlines = 0
while true do
file:close()
return(averagerain)
minuten=30
minuten60=60
minuten120=100
verw = 3
verw = 2
verw = 1
edited:
optimised script
Posted: Saturday 22 April 2017 10:36
by jvdz
poudenes wrote:Maybe stupid question, But whats script filename ending? .ph .pl other?
None of those but it is a LUA script.
Jos
Posted: Saturday 22 April 2017 10:39
by Siewert308SW
@poudenes
It's a Lua script.
But forget about the script i amended.
After a closer look it aint working as i intended.
The 60 and 120min forecast are printed but are presenting the 30min prediction.
Need a closer look.
