SolarEdge production throttling from Domoticz
jvdz
Domoticz version: 4.107
Re: SolarEdge production throttling from Domoticz
Post by jvdz »
Just had a look, and we could add a test in that code section to avoid the hard error in the log, and only generate a log message for "Verbose" stating the device is missing in the table, but it will simply skip processing the device for this heartbeat.
I can't test the change since I don't have Meters/Batteries, so please PM/email me when you like to test the change for me before I commit it in github.
jvdz
Post by jvdz »
The additional tests to avoid the reported errors is committed to the MetersDev branch.
jannl
Domoticz version: 2026.1.x
Post by jannl »
Testing with the meters dev branch, what does: status: Solaredge: Skip Sync as P1 not updated last (56603893) seconds and restore default update interval mean?
No updates now, switching back to Addies branch
Edit: I suppose P1 refers to smart meter data? In what format does it need to be? I use a youless for my smart meter, the data looks like this: 3406118;975140;496075;1460471;31;0
jvdz
Post by jvdz »
Guess you defined a p1 idx which the plugin tries to use to sync its updates to solaredge with? This message simply states that the supplied idx did update for that number of seconds so it will use the default defined update timer seconds. All should still work fine.
The only thing used of the p1 device is the lastupdatetime.
jannl
Post by jannl »
A ok, clear.
Hm, switched to my test docker, same image as production. This seems to work
Edit: there is no check (on ID) whether a device is already present? I have a lot of duplicate devices now
Edit2: I obviously have to do more tests/checks
Edit3: Not all device occur twice, I guess the check is only done for the first device. The double deviceID's could be a problem I suppose
imautohuttraeger
Domoticz version: latest
Post by imautohuttraeger »
More than half a year ago, I did a fresh install with new OS due to the need of Domoticz Version 2025.2. I got several errors so I had to deactivated this solaredge plugin. Now I run 2026.1 and I thought to give Solaredge Modbus a new trial.
As a basis, I use the instructions from this wiki page
https://wiki.domoticz.com/SolarEdge#Usi ... e_inverter
adopted to MastersDev of course
git clone -b MetersDev https://github.com/jvanderzande/domoticz-solaredge-modbustcp-plugin.git
But when I execute
sudo pip3 install -r requirements.txt
I get this error message
pi@Raspberry:~/domoticz/plugins/domoticz-solaredge-modbustcp-plugin $ pi@Raspber                                                  ry:~/domoticz/plugins/domoticz-solaredge-modbustcp-plugin $ sudo pip3 install -r                                                   requirements.txt
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
    python3-xyz, where xyz is the package you are trying to
    install.
    If you wish to install a non-Debian-packaged Python package,
    create a virtual environment using python3 -m venv path/to/venv.
    Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
    sure you have python3-full installed.
    For more information visit http://rptl.io/venv
note: If you believe this is a mistake, please contact your Python installation                                                   or OS distribution provider. You can override this, at the risk of breaking your                                                   Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
If anyone could help me with a working step-by-step instruction for a dummy like me, I would highly appreciate that.
Stop, look and listen.
Rik60
Post by Rik60 »
You have to setup a Python Vitual environment, follow these steps:
https://wiki.domoticz.com/Using_Python_ ... %20distros
madpatrick
Post by madpatrick »
Or the quick way
pip3 install -r requirements.txt --break-system-packages
gizmocuz
Post by gizmocuz »
madpatrick wrote: Sunday 10 May 2026 21:15 Or the quick way
don't do that! that could break system packages! The best way is to setup an environment (not needed when using Domoticz in a docker container as this is already done)
