Page 8 of 8
Re: Is it possible to add Shelly 2PM GEN 3 to Domoticz?
Posted: Saturday 28 June 2025 18:37
by Daro1003
1. I just need to turn on the flows and dashticz stops working properly.
2. I start a scene in domoticz and then the lighting from the sensors stops working, i.e. communication between Domoticz and sonoff 4ch.
Posted: Sunday 29 June 2025 12:28
by FireWizard
Hello @Daro1003,
I do not understand, why all this trouble with Dashticz and the Switches occurs.
But I went back to a very basic flow.
Can you test this one.
Disable all flows, which receive and control Shellies and try this complete new flow.
Instead of a configuration, all idx's are hard coded in the flow (1060 and 1061)
As always, configure your own MQTT settings,
Test and let me know.
        "id": "ffc4efc1cd6ece12",
        "type": "function",
        "z": "10c090a82727bafe",
        "name": "Control Domoticz Switch",
        "func": "let msg1 = {};\nlet msg2 = {};\nmsg1.topic = \"shellies/switches\";\nmsg2.topic = \"shellies/temperature\";\n\n//Open (for Reversed Position)\nif (msg.payload.current_pos === 100) {\n    msg1.payload = { \"command\": \"udevice\", \"idx\": 1060, \"nvalue\": 1, \"svalue\": \"100\" }\n}\n\n//Closed (for Reversed Position)\nif (msg.payload.current_pos === 0) {\n    msg1.payload = { \"command\": \"udevice\", \"idx\": 1060, \"nvalue\": 0, \"svalue\": \"0\" }\n}\n\n//Percentage (for Reversed Position)\nif ((msg.payload.current_pos > 0) && (msg.payload.current_pos < 100)) {\n    msg1.payload = { \"command\": \"udevice\", \"idx\": 1060, \"nvalue\": 2, \"svalue\": msg.payload.current_pos.toString() }\n}\n\n//Temperature\nmsg2.payload = { \"command\": \"udevice\", \"idx\": 1061, \"nvalue\": 0, \"svalue\": msg.payload.temperature.tC.toString() }\n\nreturn [[msg1,msg2]];",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 530,
        "y": 380,
        "wires": [
                "17f76470f66893c6"
        "id": "63466c41eeccdb21",
        "type": "mqtt out",
        "name": "Domoticz In",
        "topic": "domoticz/in",
        "qos": "0",
        "retain": "false",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "broker": "38b35487299a036d",
        "x": 1050,
        "y": 380,
        "wires": []
        "id": "f5114a0ea7413f87",
        "type": "mqtt in",
        "name": "Shelly Cover Status Out",
        "topic": "shelly2pmg3-34cdb0774d4c/status/cover:0",
        "qos": "0",
        "datatype": "auto-detect",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 260,
        "y": 380,
        "wires": [
                "ffc4efc1cd6ece12"
        "id": "c3669ae0eab4b29d",
        "type": "comment",
        "name": "Shelly  ====> Domoticz Switch",
        "info": "",
        "x": 540,
        "y": 320,
        "wires": []
        "id": "51882f2b44c43e5c",
        "type": "mqtt in",
        "name": "Domoticz Out",
        "topic": "domoticz/out",
        "qos": "0",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 290,
        "y": 200,
        "wires": [
                "ab0176dcde2164b2"
        "id": "dbc4d9f998e839fd",
        "type": "function",
        "name": "Blinds + Percentage ",
        "func": "// Function Blinds and Percentage\n\nmsg.topic = \"shelly2pmg3-34cdb0774d4c/command/cover:0\";\n\n//Closed\nif (msg.payload.nvalue === 0) { msg.payload = \"close\" };\n\n//Open\nif (msg.payload.nvalue === 1) { msg.payload = \"open\" };\n\n//Percentage\nif (msg.payload.nvalue === 2) { msg.payload = \"pos,\" + msg.payload.Level.toString() };\n\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 820,
        "y": 200,
        "wires": [
                "91622adcb065ef12",
                "adb3dcf604b852df"
        "id": "91622adcb065ef12",
        "type": "debug",
        "name": "debug 76",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 1040,
        "y": 260,
        "wires": []
        "id": "adb3dcf604b852df",
        "type": "mqtt out",
        "name": "Shelly Cover Command Out",
        "topic": "",
        "qos": "0",
        "retain": "false",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1100,
        "y": 200,
        "wires": []
        "id": "67acc7281fe20577",
        "type": "comment",
        "name": " Domoticz Switch ====> Shelly",
        "info": "",
        "x": 540,
        "y": 140,
        "wires": []
        "id": "ab0176dcde2164b2",
        "type": "switch",
        "name": "Filter Domoticz Switch Index",
        "property": "payload.idx",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "1060",
                "vt": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 540,
        "y": 200,
        "wires": [
                "dbc4d9f998e839fd"
        "id": "17f76470f66893c6",
        "type": "rbe",
        "name": "Prevent Loop",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "property": "payload",
        "topi": "topic",
        "x": 790,
        "y": 380,
        "wires": [
                "63466c41eeccdb21",
                "1917bf35635d0f9e"
        "id": "1917bf35635d0f9e",
        "type": "debug",
        "name": "debug 77",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1040,
        "y": 440,
        "wires": []
        "id": "38b35487299a036d",
        "type": "mqtt-broker",
        "name": "Raspberry Pi 1",
        "broker": "192.168.10.51",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "autoUnsubscribe": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
Posted: Monday 30 June 2025 18:45
by Daro1003
I'm testing this new flow for the second day and everything works fine.
Where do I provide the switch IDX and temperature IDX?
Posted: Tuesday 01 July 2025 20:48
by FireWizard
Hello @Daro1003,
I suggest, that we leave it, as it is now.
In case of another Shelly you can simply copying this flow and adjust some parameters.
You have 2 streams, one from Domoticz to the Shelly.
This one needs only the Domoticz IDX number of the Domoticz Switch.
See the picture below and the "red arrow" in the "Switch" node, called "Filter Domoticz Switch Index"
The other stream is from the Shelly to Domoticz This one needs the Domoticz IDX's in the "Function" node.
See the picture below and the "red arrows" in the "Function" node, called "Control Domoticz Switch" for the Domoticz switch
and the "blue arrow" for the Domoticz Temperature Sensor.
Best regards
Posted: Thursday 03 July 2025 18:28
by Daro1003
ok so I select the whole flow and give copy.
Then new FLOW and ctrl+V
Question:
Where do I put the shelly ID?
You showed me where to put the IDX switch and temp - thank you
Posted: Thursday 03 July 2025 21:56
by FireWizard
Hi Daro1003,
You asked.
Yes, or Select the nodes, you want to copy and then CTRL-C and CTRL-V
Question:
We have a limited number of nodes in the flow and if you would have double-clicked om each of them, you would have seen them yourself.
But okay,
In the upper stream from Domoticz to the Shelly, click on the Function node, called "Blinds + Percentage" and see below:
In the lower stream from Shelly to Domoticz, click on the MQTT Input node, called "Shelly Cover Status Out" and see below:
For the future development of flows, I recommend watching this playlist: Node-RED Essentials. (https://www.youtube.com/playlist?list=P ... qFcXBkHy-6). The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
Best regards
Posted: Wednesday 30 July 2025 15:14
by Derik
My way is not to use some plugins.
Try nodered, with Chatgpt. Put your data from mqtt explorer into chat... And make a good prompt. amazing
Posted: Wednesday 30 July 2025 17:15
by waltervl
Derik wrote: Wednesday 30 July 2025 15:14 And make a good prompt
And that is where most are going wrong. What is a good prompt?
