Page 8 of 33
Re: Python Plugin : Broadlink RM2 V4
Posted: Saturday 14 April 2018 17:21
by zak45
ian13010 wrote: Tuesday 10 April 2018 17:56
Found a palliative with the suppression of special character (é, à, ',...) in json files.
Works great !
this should be corrected on 4.1.0
Posted: Saturday 14 April 2018 17:23
by zak45
starjuice wrote: Thursday 12 April 2018 14:30
I use raspian jessie on RPI3, Domoticz 3.9208 (beta), python 3.4.2 and a RM pro+.
I'm not able to connect to th RM. Only the discover function is ok.
What i'm doing wrong please?
try the 4.1.0
Posted: Saturday 14 April 2018 17:25
by zak45
maximus wrote: Monday 02 April 2018 0:43
Hi, i tried many Things, but i cant run the plugin on rasbian stretch with stable domoticz. How can i Install the Beta? How can i Install it in stable. After i create the Broadlink as new Hardware, there is no Switch. Please help meine.
Thx
you need Domoticz 90xx and Broadlink 4.1.0
Posted: Saturday 14 April 2018 17:29
by zak45
RueDesButtes wrote: Monday 02 April 2018 19:19
I am a "Domoticz" Newbi,
I am struggling with Broadlink for 1 week,
I am able to enter the details of the RM, but nothing happened: no error, no switch, no device...
Can you help me ?
Hardware:
- Raspberry PI 2 B
- Broadlink RMP PRO+ (V3?)
I have installed:
- Raspbian Jessy Lite Stretch
- Domoticz V3.8153
- Python 3.5
you need Domoticz v 90xx or greater
Posted: Sunday 15 April 2018 1:11
by starjuice
Many thanks zak45 the 4.1.0 version solve the issue !!!!
Posted: Sunday 15 April 2018 1:47
by starjuice
I was able to learn the first IR signal but not the others. I use the 4.1.0 python 4.4.2 domoticz 3.9224
It is better than nothing but only one signal is not enough .
as you can see in the log the other signal are null.
(RMpro2) b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
2018-04-15 10:00:57.173 (RMpro2) 000000000000000000000000
2018-04-15 10:00:57.173 (RMpro2) Code stored in memory
2018-04-15 10:00:57.173 (RMpro2 - Command) Updating device from 0:'Off' to have values 1:'20'.
2018-04-15 10:00:57.182 (RMpro2) Update 1:'20' (RMpro2 - Command)
2018-04-15 01:44:00.994 (Rmpro) onCommand called for Unit 1: Parameter 'Set Level', Level: 10 , Connected : True
2018-04-15 01:44:00.994 (Rmpro) All plugin system is on pause for 5s...
2018-04-15 01:44:00.994 (Rmpro) When Broadlink led is lit press the button on your remote within 5 seconds
2018-04-15 01:44:02.326 User: Admin initiated a switch command (6/Rmpro - Command/Set Level)
2018-04-15 01:44:02.327 (Rmpro) Pushing 'onCommandCallback' on to queue
2018-04-15 01:44:03.986 User: Admin initiated a switch command (6/Rmpro - Command/Set Level)
2018-04-15 01:44:03.987 (Rmpro) Pushing 'onCommandCallback' on to queue
2018-04-15 01:44:06.959 (Rmpro) b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
2018-04-15 01:44:06.959 (Rmpro) 000000000000000000000000
2018-04-15 01:44:06.959 (Rmpro) Code stored in memory
2018-04-15 01:44:07.009 (Rmpro) Processing 'onCommandCallback' message
2018-04-15 01:44:07.009 (Rmpro) Calling message handler 'onCommand'.
2018-04-15 01:44:07.009 (Rmpro) onCommand called for Unit 1: Parameter 'Set Level', Level: 10 , Connected : True
2018-04-15 01:44:07.009 (Rmpro) All plugin system is on pause for 5s...
2018-04-15 01:44:07.010 (Rmpro) When Broadlink led is lit press the button on your remote within 5 seconds
2018-04-15 01:44:10.415 User: Admin initiated a switch command (6/Rmpro - Command/Set Level)
2018-04-15 01:44:10.416 (Rmpro) Pushing 'onCommandCallback' on to queue
2018-04-15 01:44:12.572 (Rmpro) b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
2018-04-15 01:44:12.572 (Rmpro) 000000000000000000000000
2018-04-15 01:44:12.572 (Rmpro) Code stored in memory
2018-04-15 01:44:12.572 (Rmpro) Processing 'onCommandCallback' message
2018-04-15 01:44:12.572 (Rmpro) Calling message handler 'onCommand'.
2018-04-15 01:44:12.573 (Rmpro) onCommand called for Unit 1: Parameter 'Set Level', Level: 10 , Connected : True
2018-04-15 01:44:12.573 (Rmpro) All plugin system is on pause for 5s...
2018-04-15 01:44:12.573 (Rmpro) When Broadlink led is lit press the button on your remote within 5 seconds
2018-04-15 01:44:13.250 (Rmpro) Pushing 'onHeartbeatCallback' on to queue
2018-04-15 01:44:17.794 (Rmpro) b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
2018-04-15 01:44:17.794 (Rmpro) 000000000000000000000000
2018-04-15 01:44:17.794 (Rmpro) Code stored in memory
2018-04-15 01:44:17.845 (Rmpro) Processing 'onCommandCallback' message
2018-04-15 01:44:17.845 (Rmpro) Calling message handler 'onCommand'.
2018-04-15 01:44:17.845 (Rmpro) onCommand called for Unit 1: Parameter 'Set Level', Level: 10 , Connected : True
2018-04-15 01:44:17.845 (Rmpro) All plugin system is on pause for 5s...
2018-04-15 01:44:17.845 (Rmpro) When Broadlink led is lit press the button on your remote within 5 seconds
2018-04-15 01:44:18.765 User: Admin initiated a switch command (6/Rmpro - Command/Set Level)
2018-04-15 01:44:18.766 (Rmpro) Pushing 'onCommandCallback' on to queue
2018-04-15 01:44:21.970 User: Admin initiated a switch command (6/Rmpro - Command/Set Level)
2018-04-15 01:44:21.971 (Rmpro) Pushing 'onCommandCallback' on to queue
2018-04-15 01:44:23.249 (Rmpro) b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
2018-04-15 01:44:23.249 (Rmpro) 000000000000000000000000
2018-04-15 01:44:23.249 (Rmpro) Code stored in memory
2018-04-15 01:44:23.249 (Rmpro) Processing 'onHeartbeatCallback' message
2018-04-15 01:44:23.249 (Rmpro) Calling message handler 'onHeartbeat'.
2018-04-15 01:44:23.300 (Rmpro) Processing 'onCommandCallback' message
2018-04-15 01:44:23.300 (Rmpro) Calling message handler 'onCommand'.
2018-04-15 01:44:23.300 (Rmpro) onCommand called for Unit 1: Parameter 'Set Level', Level: 20 , Connected : True
2018-04-15 01:44:23.300 (Rmpro) b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
2018-04-15 01:44:23.489 (Rmpro) Code Sent....
2018-04-15 01:44:23.489 (Rmpro) Processing 'onCommandCallback' message
2018-04-15 01:44:23.489 (Rmpro) Calling message handler 'onCommand'.
2018-04-15 01:44:23.489 (Rmpro) onCommand called for Unit 1: Parameter 'Set Level', Level: 20 , Connected : True
2018-04-15 01:44:23.490 (Rmpro) b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
2018-04-15 01:44:23.524 (Rmpro) Code Sent....
2018-04-15 01:44:30.941 User: Admin initiated a switch command (6/Rmpro - Command/Set Level)
2018-04-15 01:44:30.941 (Rmpro) Pushing 'onCommandCallback' on to queue
2018-04-15 01:44:30.990 (Rmpro) Processing 'onCommandCallback' message
2018-04-15 01:44:30.990 (Rmpro) Calling message handler 'onCommand'.
2018-04-15 01:44:30.990 (Rmpro) onCommand called for Unit 1: Parameter 'Set Level', Level: 40 , Connected : True
2018-04-15 01:44:30.990 (Rmpro - Command) Updating device from 1:'20' to have values 0:'Off'.
2018-04-15 01:44:30.998 (Rmpro) Update 0:'Off' (Rmpro - Command)
2018-04-15 01:44:30.999 (Rmpro) Reset learned command
2018-04-15 01:44:33.745 User: Admin initiated a switch command (6/Rmpro - Command/Set Level)
2018-04-15 01:44:33.746 (Rmpro) Pushing 'onCommandCallback' on to queue
2018-04-15 01:44:33.754 (Rmpro) Processing 'onCommandCallback' message
2018-04-15 01:44:33.754 (Rmpro) Calling message handler 'onCommand'.
2018-04-15 01:44:33.754 (Rmpro) onCommand called for Unit 1: Parameter 'Set Level', Level: 10 , Connected : True
2018-04-15 01:44:33.754 (Rmpro) All plugin system is on pause for 5s...
2018-04-15 01:44:33.754 (Rmpro) When Broadlink led is lit press the button on your remote within 5 seconds
2018-04-15 01:44:38.583 User: Admin initiated a switch command (6/Rmpro - Command/Set Level)
2018-04-15 01:44:38.584 (Rmpro) Pushing 'onCommandCallback' on to queue
2018-04-15 01:44:38.762 (Rmpro) b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
2018-04-15 01:44:38.763 (Rmpro) 000000000000000000000000
2018-04-15 01:44:38.763 (Rmpro) Code stored in memory
2018-04-15 01:44:38.763 (Rmpro - Command) Updating device from 0:'Off' to have values 1:'20'.
2018-04-15 01:44:38.772 (Rmpro) Update 1:'20' (Rmpro - Command)
2018-04-15 01:44:38.822 (Rmpro) Processing 'onCommandCallback' message
2018-04-15 01:44:38.822 (Rmpro) Calling message handler 'onCommand'.
2018-04-15 01:44:38.822 (Rmpro) onCommand called for Unit 1: Parameter 'Set Level', Level: 20 , Connected : True
2018-04-15 01:44:38.822 (Rmpro) b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
2018-04-15 01:44:39.376 (Rmpro) Code Sent....
2018-04-15 01:44:41.449 User: Admin initiated a switch command (6/Rmpro - Command/Set Level)
2018-04-15 01:44:41.449 (Rmpro) Pushing 'onCommandCallback' on to queue
2018-04-15 01:44:41.480 (Rmpro) Processing 'onCommandCallback' message
2018-04-15 01:44:41.480 (Rmpro) Calling message handler 'onCommand'.
2018-04-15 01:44:41.480 (Rmpro) onCommand called for Unit 1: Parameter 'Set Level', Level: 20 , Connected : True
2018-04-15 01:44:41.480 (Rmpro) b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
2018-04-15 01:44:41.482 (Rmpro) Code Sent....
2018-04-15 01:44:43.255 (Rmpro) Pushing 'onHeartbeatCallback' on to queue
2018-04-15 01:44:43.286 (Rmpro) Processing 'onHeartbeatCallback' message
2018-04-15 01:44:43.286 (Rmpro) Calling message handler 'onHeartbeat'.
2018-04-15 01:44:47.189 User: Admin initiated a switch command (6/Rmpro - Command/Set Level)
2018-04-15 01:44:47.189 (Rmpro) Pushing 'onCommandCallback' on to queue
2018-04-15 01:44:47.194 (Rmpro) Processing 'onCommandCallback' message
2018-04-15 01:44:47.194 (Rmpro) Calling message handler 'onCommand'.
2018-04-15 01:44:47.195 (Rmpro) onCommand called for Unit 1: Parameter 'Set Level', Level: 30 , Connected : True
2018-04-15 01:44:47.200 (Rmpro) ini file creation..../home/pi/domoticz/plugins/BroadlinkRM2/BroadlinkRM2-4-10.ini
2018-04-15 01:44:47.200 (Rmpro) Creating device '4-10 '.
2018-04-15 01:44:47.203 (Rmpro) Command line : "/home/pi/domoticz/plugins/BroadlinkRM2/plugin_send.py" /home/pi/domoticz/plugins/BroadlinkRM2/BroadlinkRM2-4-10.ini
2018-04-15 01:44:47.203 (Rmpro - Command) Updating device from 1:'20' to have values 1:'10'.
2018-04-15 01:44:47.211 (Rmpro) Update 1:'10' (Rmpro - Command)
2018-04-15 01:45:13.260 (Rmpro) Pushing 'onHeartbeatCallback' on to queue
2018-04-15 01:45:13.264 (Rmpro) Processing 'onHeartbeatCallback' message
2018-04-15 01:45:13.264 (Rmpro) Calling message handler 'onHeartbeat'.
2018-04-15 01:45:43.266 (Rmpro) Pushing 'onHeartbeatCallback' on to queue
2018-04-15 01:45:43.277 (Rmpro) Processing 'onHeartbeatCallback' message
2018-04-15 01:45:43.277 (Rmpro) Calling message handler 'onHeartbeat'.
Posted: Sunday 15 April 2018 12:54
by zak45
starjuice wrote: Sunday 15 April 2018 1:47
Plugin is not able to manage more than one signal at same time.. do you have saved the first one and tried after to read another one ?
Posted: Sunday 15 April 2018 15:51
by starjuice
yes I save first then after I try to learn another.
But the signal catched is always 000000
2018-04-15 15:48:00.288 User: Admin initiated a switch command (6/RMpro2 - Command/Set Level)
2018-04-15 15:48:00.288 (RMpro2) Pushing 'onCommandCallback' on to queue
2018-04-15 15:48:00.307 (RMpro2) Processing 'onCommandCallback' message
2018-04-15 15:48:00.307 (RMpro2) Calling message handler 'onCommand'.
2018-04-15 15:48:00.307 (RMpro2) onCommand called for Unit 1: Parameter 'Set Level', Level: 40 , Connected : True
2018-04-15 15:48:00.307 (RMpro2 - Command) Updating device from 1:'20' to have values 0:'Off'.
2018-04-15 15:48:00.312 (RMpro2) Update 0:'Off' (RMpro2 - Command)
2018-04-15 15:48:00.312 (RMpro2) Reset learned command
2018-04-15 15:48:02.787 User: Admin initiated a switch command (6/RMpro2 - Command/Set Level)
2018-04-15 15:48:02.788 (RMpro2) Pushing 'onCommandCallback' on to queue
2018-04-15 15:48:02.818 (RMpro2) Processing 'onCommandCallback' message
2018-04-15 15:48:02.818 (RMpro2) Calling message handler 'onCommand'.
2018-04-15 15:48:02.818 (RMpro2) onCommand called for Unit 1: Parameter 'Set Level', Level: 10 , Connected : True
2018-04-15 15:48:02.818 (RMpro2) All plugin system is on pause for 5s...
2018-04-15 15:48:02.818 (RMpro2) When Broadlink led is lit press the button on your remote within 5 seconds
2018-04-15 15:48:07.825 (RMpro2) b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
2018-04-15 15:48:07.825 (RMpro2) 000000000000000000000000
2018-04-15 15:48:07.825 (RMpro2) Code stored in memory
2018-04-15 15:48:07.825 (RMpro2 - Command) Updating device from 0:'Off' to have values 1:'20'.
2018-04-15 15:48:07.832 (RMpro2) Update 1:'20' (RMpro2 - Command)
2018-04-15 15:48:08.547 User: Admin initiated a switch command (6/RMpro2 - Command/Set Level)
2018-04-15 15:48:08.548 (RMpro2) Pushing 'onCommandCallback' on to queue
2018-04-15 15:48:08.584 (RMpro2) Processing 'onCommandCallback' message
2018-04-15 15:48:08.584 (RMpro2) Calling message handler 'onCommand'.
2018-04-15 15:48:08.584 (RMpro2) onCommand called for Unit 1: Parameter 'Set Level', Level: 20 , Connected : True
2018-04-15 15:48:08.584 (RMpro2) b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
2018-04-15 15:48:08.586 (RMpro2) Code Sent....
2018-04-15 15:48:13.095 User: Admin initiated a switch command (6/RMpro2 - Command/Set Level)
2018-04-15 15:48:13.096 (RMpro2) Pushing 'onCommandCallback' on to queue
2018-04-15 15:48:13.145 (RMpro2) Processing 'onCommandCallback' message
2018-04-15 15:48:13.146 (RMpro2) Calling message handler 'onCommand'.
2018-04-15 15:48:13.146 (RMpro2) onCommand called for Unit 1: Parameter 'Set Level', Level: 20 , Connected : True
2018-04-15 15:48:13.146 (RMpro2) b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
2018-04-15 15:48:13.147 (RMpro2) Code Sent....
2018-04-15 15:48:21.333 (RMpro2) Pushing 'onHeartbeatCallback' on to queue
2018-04-15 15:48:21.365 (RMpro2) Processing 'onHeartbeatCallback' message
2018-04-15 15:48:21.365 (RMpro2) Calling message handler 'onHeartbeat'.
2018-04-15 15:48:32.380 User: Admin initiated a switch command (6/RMpro2 - Command/Set Level)
2018-04-15 15:48:32.380 (RMpro2) Pushing 'onCommandCallback' on to queue
2018-04-15 15:48:32.405 (RMpro2) Processing 'onCommandCallback' message
2018-04-15 15:48:32.405 (RMpro2) Calling message handler 'onCommand'.
2018-04-15 15:48:32.405 (RMpro2) onCommand called for Unit 1: Parameter 'Set Level', Level: 30 , Connected : True
2018-04-15 15:48:32.408 (RMpro2) ini file creation..../home/pi/domoticz/plugins/BroadlinkRM2/BroadlinkRM2-4-5.ini
2018-04-15 15:48:32.408 (RMpro2) Creating device '4-5 '.
2018-04-15 15:48:32.996 (RMpro2) Command line : "/home/pi/domoticz/plugins/BroadlinkRM2/plugin_send.py" /home/pi/domoticz/plugins/BroadlinkRM2/BroadlinkRM2-4-5.ini
2018-04-15 15:48:32.996 (RMpro2 - Command) Updating device from 1:'20' to have values 1:'10'.
2018-04-15 15:48:33.005 (RMpro2) Update 1:'10' (RMpro2 - Command)
2018-04-15 15:48:41.547 User: Admin initiated a switch command (6/RMpro2 - Command/Set Level)
2018-04-15 15:48:41.547 (RMpro2) Pushing 'onCommandCallback' on to queue
2018-04-15 15:48:41.573 (RMpro2) Processing 'onCommandCallback' message
2018-04-15 15:48:41.573 (RMpro2) Calling message handler 'onCommand'.
2018-04-15 15:48:41.573 (RMpro2) onCommand called for Unit 1: Parameter 'Set Level', Level: 40 , Connected : True
2018-04-15 15:48:41.573 (RMpro2) Nothing to reset
2018-04-15 15:48:44.880 User: Admin initiated a switch command (6/RMpro2 - Command/Set Level)
2018-04-15 15:48:44.880 (RMpro2) Pushing 'onCommandCallback' on to queue
2018-04-15 15:48:44.880 (RMpro2) Processing 'onCommandCallback' message
2018-04-15 15:48:44.881 (RMpro2) Calling message handler 'onCommand'.
2018-04-15 15:48:44.881 (RMpro2) onCommand called for Unit 1: Parameter 'Set Level', Level: 10 , Connected : True
2018-04-15 15:48:44.881 (RMpro2) All plugin system is on pause for 5s...
2018-04-15 15:48:44.881 (RMpro2) When Broadlink led is lit press the button on your remote within 5 seconds
2018-04-15 15:48:49.887 (RMpro2) b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
2018-04-15 15:48:49.887 (RMpro2) 000000000000000000000000
2018-04-15 15:48:49.888 (RMpro2) Code stored in memory
2018-04-15 15:48:49.888 (RMpro2 - Command) Updating device from 1:'10' to have values 1:'20'.
2018-04-15 15:48:49.892 (RMpro2) Update 1:'20' (RMpro2 - Command)
2018-04-15 15:48:49.931 User: Admin initiated a switch command (6/RMpro2 - Command/Set Level)
2018-04-15 15:48:49.931 (RMpro2) Pushing 'onCommandCallback' on to queue
2018-04-15 15:48:49.942 (RMpro2) Processing 'onCommandCallback' message
2018-04-15 15:48:49.943 (RMpro2) Calling message handler 'onCommand'.
2018-04-15 15:48:49.943 (RMpro2) onCommand called for Unit 1: Parameter 'Set Level', Level: 20 , Connected : True
2018-04-15 15:48:49.943 (RMpro2) b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
2018-04-15 15:48:50.497 (RMpro2) Code Sent....
2018-04-15 15:48:51.339 (RMpro2) Pushing 'onHeartbeatCallback' on to queue
2018-04-15 15:48:51.349 (RMpro2) Processing 'onHeartbeatCallback' message
2018-04-15 15:48:51.349 (RMpro2) Calling message handler 'onHeartbeat'.
2018-04-15 15:48:53.652 User: Admin initiated a switch command (6/RMpro2 - Command/Set Level)
2018-04-15 15:48:53.652 (RMpro2) Pushing 'onCommandCallback' on to queue
2018-04-15 15:48:53.654 (RMpro2) Processing 'onCommandCallback' message
2018-04-15 15:48:53.654 (RMpro2) Calling message handler 'onCommand'.
2018-04-15 15:48:53.654 (RMpro2) onCommand called for Unit 1: Parameter 'Set Level', Level: 30 , Connected : True
2018-04-15 15:48:53.657 (RMpro2) ini file creation..../home/pi/domoticz/plugins/BroadlinkRM2/BroadlinkRM2-4-6.ini
2018-04-15 15:48:53.657 (RMpro2) Creating device '4-6 '.
2018-04-15 15:48:53.659 (RMpro2) Command line : "/home/pi/domoticz/plugins/BroadlinkRM2/plugin_send.py" /home/pi/domoticz/plugins/BroadlinkRM2/BroadlinkRM2-4-6.ini
2018-04-15 15:48:53.659 (RMpro2 - Command) Updating device from 1:'20' to have values 1:'10'.
2018-04-15 15:48:53.663 (RMpro2) Update 1:'10' (RMpro2 - Command)
2018-04-15 15:49:21.345 (RMpro2) Pushing 'onHeartbeatCallback' on to queue
2018-04-15 15:49:21.375 (RMpro2) Processing 'onHeartbeatCallback' message
2018-04-15 15:49:21.375 (RMpro2) Calling message handler 'onHeartbeat'.
Posted: Sunday 15 April 2018 15:54
by starjuice
zak45 wrote: Sunday 15 April 2018 12:54
Yes I save the first and after I try to learn another signal but the result is alway 00000.
The only way is to create a new "broadlinkRM2 via kodi" material.
Top
Posted: Sunday 15 April 2018 20:11
by Lars65
I get this when I try to run the plugin:
Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/BroadlinkRM2/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
Running raspbian stretch.
Any suggestions what to do?
Posted: Sunday 15 April 2018 21:25
by jumping
zak45 wrote: Saturday 14 April 2018 17:23
try the 4.1.0
I have 4.0 version, how can I update to 4.1? thanks
Posted: Sunday 15 April 2018 23:28
by zak45
jumping wrote: Sunday 15 April 2018 21:25
[I have 4.0 version, how can I update to 4.1? thanks
see
viewtopic.php?f=65&t=21645
Posted: Sunday 15 April 2018 23:29
by zak45
Lars65 wrote: Sunday 15 April 2018 20:11
show the output of this command :
sudo pip3 show broadlink
Posted: Tuesday 17 April 2018 17:00
by Lars65
output is:
Version: 0.8
Summary: Python API for controlling Broadlink IR controllers
Home-page:
http://github.com/mjg59/python-broadlink
Author: Matthew Garrett
Author-email:
[email protected]
License: UNKNOWN
Requires: pycryptodome, PyCRC
Required-by:
Posted: Tuesday 17 April 2018 17:44
by zak45
Lars65 wrote: Tuesday 17 April 2018 17:00
output is:
Version: 0.8
Home-page:
Author-email:
[email protected]
License: UNKNOWN
Required-by:
try this :
cp -r /usr/local/lib/python3.5/dist-packages/broadlink /usr/lib/python3.5
something like that...
Posted: Thursday 19 April 2018 1:58
by starjuice
My RPI become unstable... I have to create a new hardward for each signal learned... I cannot use a hardware for more than 1 signal.
Everybody have to do this?
(RMpro3) Pushing 'onHeartbeatCallback' on to queue
2018-04-19 01:47:49.671 (RMpro3) Processing 'onHeartbeatCallback' message
2018-04-19 01:47:49.671 (RMpro3) Calling message handler 'onHeartbeat'.
2018-04-19 01:47:50.161 (RMpro4) Pushing 'onHeartbeatCallback' on to queue
2018-04-19 01:47:50.172 (RMpro4) Processing 'onHeartbeatCallback' message
2018-04-19 01:47:50.172 (RMpro4) Calling message handler 'onHeartbeat'.
2018-04-19 01:47:50.263 (RMpro2) Pushing 'onHeartbeatCallback' on to queue
2018-04-19 01:47:50.273 (RMpro2) Processing 'onHeartbeatCallback' message
2018-04-19 01:47:50.273 (RMpro2) Calling message handler 'onHeartbeat'.
2018-04-19 01:47:50.623 (RMpro6) Pushing 'onHeartbeatCallback' on to queue
2018-04-19 01:47:50.624 (RMpro6) Processing 'onHeartbeatCallback' message
2018-04-19 01:47:50.624 (RMpro6) Calling message handler 'onHeartbeat'.
2018-04-19 01:47:50.661 (RMpro5) Pushing 'onHeartbeatCallback' on to queue
2018-04-19 01:47:50.674 (RMpro5) Processing 'onHeartbeatCallback' message
2018-04-19 01:47:50.674 (RMpro5) Calling message handler 'onHeartbeat'.
2018-04-19 01:47:51.161 (RMprotestrf) Pushing 'onHeartbeatCallback' on to queue
2018-04-19 01:47:51.175 (RMprotestrf) Processing 'onHeartbeatCallback' message
2018-04-19 01:47:51.175 (RMprotestrf) Calling message handler 'onHeartbeat'.
2018-04-19 01:47:51.191 (RMprotest) Pushing 'onHeartbeatCallback' on to queue
2018-04-19 01:47:51.225 (RMprotest) Processing 'onHeartbeatCallback' message
2018-04-19 01:47:51.226 (RMprotest) Calling message handler 'onHeartbeat'.
2018-04-19 01:47:51.623 (RMchacon) Pushing 'onHeartbeatCallback' on to queue
2018-04-19 01:47:51.626 (RMchacon) Processing 'onHeartbeatCallback' message
2018-04-19 01:47:51.626 (RMchacon) Calling message handler 'onHeartbeat'.
2018-04-19 01:47:51.690 (RMchacon2) Pushing 'onHeartbeatCallback' on to queue
2018-04-19 01:47:51.727 (RMchacon2) Processing 'onHeartbeatCallback' message
2018-04-19 01:47:51.727 (RMchacon2) Calling message handler 'onHeartbeat'.
2018-04-19 01:47:51.995 (RMmachinelvaisselleON) Pushing 'onHeartbeatCallback' on to queue
2018-04-19 01:47:52.028 (RMmachinelvaisselleON) Processing 'onHeartbeatCallback' message
2018-04-19 01:47:52.028 (RMmachinelvaisselleON) Calling message handler 'onHeartbeat'.
2018-04-19 01:47:52.128 (RMmachinelingeOFF) Pushing 'onHeartbeatCallback' on to queue
2018-04-19 01:47:52.178 (RMmachinelingeOFF) Processing 'onHeartbeatCallback' message
2018-04-19 01:47:52.178 (RMmachinelingeOFF) Calling message handler 'onHeartbeat'.
2018-04-19 01:47:55.336 (RMTVvolmoins) Pushing 'onHeartbeatCallback' on to queue
2018-04-19 01:47:55.385 (RMTVvolmoins) Processing 'onHeartbeatCallback' message
2018-04-19 01:47:55.385 (RMTVvolmoins) Calling message handler 'onHeartbeat'.
2018-04-19 01:47:55.541 (Meteo ) Temp + Humidity + Baro (Temp Hum Bar)
2018-04-19 01:47:55.550 (Meteo ) Wind (Température ressentie)
2018-04-19 01:47:55.559 (Meteo ) UV (UV)
2018-04-19 01:47:55.568 (Meteo ) Rain (Pluie)
2018-04-19 01:47:55.577 (Meteo ) General/Solar Radiation (Radiation solaire)
2018-04-19 01:47:59.265 (RMTVvolplus) Pushing 'onHeartbeatCallback' on to queue
2018-04-19 01:47:59.291 (RMTVvolplus) Processing 'onHeartbeatCallback' message
2018-04-19 01:47:59.291 (RMTVvolplus) Calling message handler 'onHeartbeat'.
Posted: Thursday 19 April 2018 12:41
by zak45
starjuice wrote: Thursday 19 April 2018 1:58
Nope.. One hardware by physical device...
And as you have already the ini files, you can use the import feature to merge learned code into only one Domoticz hardware.
Posted: Thursday 19 April 2018 17:15
by starjuice
zak45 wrote: Thursday 19 April 2018 12:41
You would be nice to explain me how to use the import feature.
When I press to the import button in Domoticz a popup appear "import switching" but nothing happen.
If you have a little tutorial for noobs.
Thanks in advance for your help
Posted: Thursday 19 April 2018 17:43
by zak45
starjuice wrote: Thursday 19 April 2018 17:15
The wiki should give you all information :
https://www.domoticz.com/wiki/Plugins/B ... RM2_Device
Posted: Thursday 19 April 2018 22:00
by madrian
I installed plugin and I added as a new hardware and I am getting this error:
2018-04-19 21:55:22.946 Error: (Broadlink RM3 mini) Plugin did not stop after 5 seconds, flushing event queue...
2018-04-19 21:55:22.946 (Broadlink RM3 mini) requeuing 'onHeartbeatCallback' message for 'Xiaomi Mi Flower Mate'
2018-04-19 21:55:22.946 Error: (Broadlink RM3 mini) Callback event 'onHeartbeatCallback' (Python call 'onHeartbeat') discarded.
2018-04-19 21:55:22.947 Error: (Broadlink RM3 mini) Callback event 'onHeartbeatCallback' (Python call 'onHeartbeat') discarded.
2018-04-19 21:55:22.947 (Broadlink RM3 mini) requeuing 'onHeartbeatCallback' message for 'Xiaomi Mi Flower Mate'
2018-04-19 21:55:22.947 Error: (Broadlink RM3 mini) Callback event 'onStopCallback' (Python call 'onStop') discarded.
2018-04-19 21:55:22.947 (Broadlink RM3 mini) Stopping threads.
2018-04-19 21:55:22.947 (Broadlink RM3 mini) Stopped.
2018-04-19 21:55:22.947 (Broadlink RM3 mini) Started.
2018-04-19 21:56:30.277 Error: Broadlink RM3 mini hardware (13) thread seems to have ended unexpectedly
...and no device in Devices are created.
I have another plugin installed
Xiaomi Mi Flower Mate, if it is related.
