Page 8 of 16
Re: Python Plugin: Broadlink RM2 V3
Posted: Sunday 17 September 2017 0:33
by aleph0
Wow !
I'm amazed by this work
Fantastic ! Thanks you so much for delivering such a nice plugin !
Thanks to you, for 10€ (the price for a RM mini 3) I'll be able to drive smartly my old aircon' from 2004
Posted: Sunday 17 September 2017 1:03
by zak45
aleph0 wrote: Sunday 17 September 2017 0:33
Wow !
Merci
Posted: Monday 18 September 2017 20:01
by reza
zak45 wrote: Sunday 17 September 2017 1:03
Wow !
Merci
can i use rmpro and rmpro2 and rmpro mini with this plugin ? or this is just for rmpro2?
what is mean "merci" ?
where are you from zak ?
Posted: Tuesday 19 September 2017 18:12
by zak45
reza wrote: Monday 18 September 2017 20:01
Yes, should work.
Merci, danke, gracias, thanks... France
Posted: Wednesday 20 September 2017 11:40
by reza
zak45 wrote: Tuesday 19 September 2017 18:12
Yes, should work.
thank you for answer dear friend
Posted: Thursday 21 September 2017 11:24
by reza
i can not "on" remote. and i dont have ini file in C:BroadlinkRM2.
also i can not understand what say in wiki.... please help me
i have this problem when i want open folder C:
- dkdkdkdk.jpg (44.28 KiB) Viewed 2789 times
Posted: Thursday 21 September 2017 12:25
by Sjonnie2017
reza wrote:i can not "on" remote. and i dont have ini file in C:BroadlinkRM2.
You are trying to create an impossible path. Try this:
/home/pi/domoticz/broadlink_ini
That should work
Verstuurd vanaf mijn YOGA Tablet 2-1050F met Tapatalk
A little tip
Posted: Thursday 21 September 2017 12:35
by Sjonnie2017
I found out that you get the "can not connect to broadlink" messages in the log when you have a wrong annotation for the MAC address.
Normally you would write a MAC address like this:
The plugin however wants it to be written like this:
So no colon between the pairs.
HTH
Greetz,
Sjonnie
Posted: Thursday 21 September 2017 14:50
by reza
[/quote]You are trying to create an impossible path. Try this:
That should work
[/quote]
i test it but again i have problem.
- Untitledssdsd.jpg (52.43 KiB) Viewed 2778 times
- 1111.jpg (206.14 KiB) Viewed 2778 times
Posted: Thursday 21 September 2017 15:03
by Sjonnie2017
Hi Reza,
Weird! I had that too!
I thought I had made a mistake myself and corrected it. Seems more people are affected by this.
How to solve?
Open a terminal and change directory (cd) to the broadlink_ini folder. So enter this:
cd /home/pi/domoticz/broadlink_ini
After that you need to change the ownership of the two folders inside the broadlink_ini folder. So enter this:
That will make pi owner of all files and folders in the broadlink_ini folder.
Don't know if it is necessary but it works for me
HTH
Greetz,
Sjonnie
Posted: Thursday 21 September 2017 15:19
by reza
Sjonnie2017 wrote: Thursday 21 September 2017 15:03
Hi Reza,
How to solve?
HTH
Greetz,
Sjonnie
dont work for me and i have same error:
2017-09-21 17:48:13.099 Error: (Rayan) ini file not found: /home/pi/domoticz/broadlink_ini/BroadlinkRM2-4-254.ini
Posted: Thursday 21 September 2017 15:35
by Sjonnie2017
Hi Reza,
"Don't work" is somewhat vague.
Can you explain what does not work? Do the folders have new ownership or not?
I had a similar issue and got it working so there is hope
Here is what I did:
1 - I removed the Broadlink device from Domoticz
2 - Emptied the broadlink_ini folder
3 - Remove __pychache__ folder from /home/pi/domoticz/plugins/BroadlinkRM2
4 - Restarted Domoticz by opening a terminal to the pi and entering
sudo service domoticz restart
5 - Created a new Broadlink device
6 - Made sure the ownership of the folders import and remote were correct (see previous post)
7 - Used the switch "Broadlink - command" to learn a new command from one of my remotes
8 - Saved the command (creates a new device)
9 - Presto
HTH
Greetz,
Sjonnie
Posted: Thursday 21 September 2017 16:19
by reza
Sjonnie2017 wrote: Thursday 21 September 2017 15:35
Hi Reza,
Here is what I did:
9 - Presto
HTH
Greetz,
Sjonnie
3 - "Remove __pychache__ folder from /home/pi/domoticz/plugins/BroadlinkRM2" how remove this ? thank you
Posted: Friday 22 September 2017 13:17
by megus
Please help!
I know this happened to other people before but I did't see solution or it doesn't work for me.
I have tried to make this plugin work on freshly Pi3 running Raspbian Jessie following your WIKI
pi@domoticz:~ $ cat /proc/version
Linux version 4.9.35-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1014 SMP Fri Jun 30 14:47:43 BST 2017
But always end up with the same errors:
Domoticz V3.8153
Dashboard
Switches
Scenes
Temperature
Weather
Utility
Setup
All
Status
Error
Filter:
X
2017-09-22 18:22:59.358 Domoticz V3.8153 (c)2012-2017 GizMoCuz
2017-09-22 18:22:59.358 Build Hash: 494fff7, Date: 2017-07-30 20:19:41
2017-09-22 18:22:59.358 Startup Path: /home/pi/domoticz/
2017-09-22 18:22:59.557 PluginSystem: Started, Python version '3.4.2'.
2017-09-22 18:22:59.569 Active notification Subsystems: gcm, http (2/12)
2017-09-22 18:22:59.571 WebServer(HTTP) started on address: :: with port 8080
2017-09-22 18:22:59.581 WebServer(SSL) started on address: :: with port 443
2017-09-22 18:22:59.583 Proxymanager started.
2017-09-22 18:22:59.585 Starting shared server on: :::6144
2017-09-22 18:22:59.586 TCPServer: shared server started...
2017-09-22 18:22:59.586 RxQueue: queue worker started...
2017-09-22 18:23:00.737 Incoming connection from: 10.0.0.25
2017-09-22 18:23:01.587 EventSystem: reset all events...
2017-09-22 18:23:01.588 EventSystem: reset all device statuses...
2017-09-22 18:23:01.722 Python EventSystem: Module not found - Trying to initialize.
2017-09-22 18:23:01.725 Python EventSystem: Initalizing event module.
2017-09-22 18:23:01.726 EventSystem: Started
2017-09-22 18:23:01.900 PluginSystem: Entering work loop.
2017-09-22 18:23:02.306 (test) Initialized version 3.0.0, author 'zak45'
2017-09-22 18:23:02.360 (test) Debug log level set to: 'true'.
2017-09-22 18:23:02.360 (test) 'HardwareID':'2'
2017-09-22 18:23:02.360 (test) 'Author':'zak45'
2017-09-22 18:23:02.360 (test) 'Mode2':'/home/pi/domoticz/plugins/BroadlinkRM2/ini'
2017-09-22 18:23:02.360 (test) 'Key':'BroadlinkRM2'
2017-09-22 18:23:02.360 (test) 'Name':'test'
2017-09-22 18:23:02.360 (test) 'Mode3':'no'
2017-09-22 18:23:02.360 (test) 'HomeFolder':'/home/pi/domoticz/plugins/BroadlinkRM2/'
2017-09-22 18:23:02.361 (test) 'Version':'3.0.0'
2017-09-22 18:23:02.361 (test) 'Mode1':'000000000000'
2017-09-22 18:23:02.361 (test) 'Mode5':'9000'
2017-09-22 18:23:02.361 (test) 'Mode6':'Debug'
2017-09-22 18:23:02.361 (test) 'Port':'0'
2017-09-22 18:23:02.361 (test) 'Address':'127.0.0.1'
2017-09-22 18:23:02.361 (test) 'Mode4':'no'
2017-09-22 18:23:02.361 (test) Device count: 2
2017-09-22 18:23:02.361 (test) Device: 1 - ID: 1, Name: 't8 - Discover', nValue: 0, sValue: 'Off'
2017-09-22 18:23:02.361 (test) Device ID: '1'
2017-09-22 18:23:02.361 (test) Device Name: 't8 - Discover'
2017-09-22 18:23:02.361 (test) Device nValue: 0
2017-09-22 18:23:02.361 (test) Device sValue: 'Off'
2017-09-22 18:23:02.361 (test) Device LastLevel: 0
2017-09-22 18:23:02.361 (test) Device: 254 - ID: 2, Name: 't8 - Remote', nValue: 0, sValue: ''
2017-09-22 18:23:02.362 (test) Device ID: '2'
2017-09-22 18:23:02.362 (test) Device Name: 't8 - Remote'
2017-09-22 18:23:02.362 (test) Device nValue: 0
2017-09-22 18:23:02.362 (test) Device sValue: ''
2017-09-22 18:23:02.362 (test) Device LastLevel: 0
2017-09-22 18:23:02.362 (test) Connecting to: 127.0.0.1:000000000000
2017-09-22 18:23:02.427 Error: (test) Error Connecting to Broadlink device....
2017-09-22 18:23:02.428 (test) Device Number begin to : 1
2017-09-22 18:23:02.450 (test) No ini file :/home/pi/domoticz/plugins/BroadlinkRM2/ini/remote/plugin_remote_2.ini
2017-09-22 18:23:02.450 (test) Custom Commands for Remote not managed
2017-09-22 18:23:02.451 (test) Heartbeat interval set to: 30.
2017-09-22 18:23:11.817 (test) Calling message handler 'onHeartbeat'.
2017-09-22 18:23:20.392 User: Admin initiated a switch command (1/t8 - Discover/On)
2017-09-22 18:23:20.433 (test) Calling message handler 'onCommand'.
2017-09-22 18:23:20.433 (test) onCommand called for Unit 1: Parameter 'On', Level: 0 , Connected : False
2017-09-22 18:23:20.433 (test) All plugin system is on pause for 5s...
2017-09-22 18:23:25.440 (test) Found 1 broadlink devices
2017-09-22 18:23:25.452 Error: (test) 'onCommand' failed 'TypeError':'sequence item 0: expected str instance, bytes found'.
2017-09-22 18:23:25.452 Error: (test) ----> Line 210 in /home/pi/domoticz/plugins/BroadlinkRM2/plugin.py, function onCommand
2017-09-22 18:23:25.452 Error: (test) ----> Line 397 in /home/pi/domoticz/plugins/BroadlinkRM2/plugin.py, function Discover
2017-09-22 18:23:25.452 Error: (test) ----> Line 203 in /usr/lib/python3.4/broadlink/__init__.py, function auth
2017-09-22 18:23:25.452 Error: (test) ----> Line 258 in /usr/lib/python3.4/broadlink/__init__.py, function send_packet
2017-09-22 18:23:25.452 Error: (test) ----> Line 162 in /usr/lib/python3.4/broadlink/__init__.py, function encrypt_pyaes
2017-09-22 18:23:41.831 (test) Calling message handler 'onHeartbeat'.
I've tried to run it on Python 3.4 and assembled 3.5 jut to test
pi@domoticz:~ $ python3
Python 3.5.2 (default, Sep 21 2017, 19:47:52)
[GCC 4.9.2] on linux
Type "help", "copyright", "credits" or "license" for more information.
but still the same
BTW I can not follow the wiki recommendation on how to run it on python 3.4
It says :
developer info
this code : learnedCommand=str(ir_packet.hex()) is pecific to python 3.5 or >, not work on 3.4
replaced by : learnedCommand=str(codecs.encode(ir_packet, 'hex_codec')) ( & import codecs ) to have it running in 3.x
but it does not mach the file plugin.py content, which is:
learnedCommand=(codecs.encode(ir_packet, 'hex_codec')).decode('utf-8')
If I add
the plugin can not run at all:
2017-09-22 20:58:47.080 TCPServer: shared server started...
2017-09-22 20:58:47.081 RxQueue: queue worker started...
2017-09-22 20:58:49.081 EventSystem: reset all events...
2017-09-22 20:58:49.082 EventSystem: reset all device statuses...
2017-09-22 20:58:49.217 Python EventSystem: Module not found - Trying to initialize.
2017-09-22 20:58:49.220 Python EventSystem: Initalizing event module.
2017-09-22 20:58:49.221 EventSystem: Started
2017-09-22 20:58:49.412 PluginSystem: Entering work loop.
2017-09-22 20:58:49.572 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/BroadlinkRM2/:/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
2017-09-22 20:58:49.572 Error: (test) Module Import failed, exception: 'SyntaxError'
2017-09-22 20:58:49.572 Error: (test) Import detail: File: /home/pi/domoticz/plugins/BroadlinkRM2/plugin.py, Line: 1872208736, offset: 431
2017-09-22 20:58:49.572 Error: (test) Error Line ' learnedCommand=str(codecs.encode(ir_packet, 'hex_codec'))(& import codecs)
Posted: Sunday 24 September 2017 17:33
by Sjonnie2017
reza wrote: Thursday 21 September 2017 16:19
Open a terminal and enter the following:
cd /home/pi/domoticz/plugins/BroadlinkRM2
sudo rm -rf __py*
Presto
PS. I am under the impression that you are a Windows user and this is your first attempt at Linux. Before diving into the wonderfull world of Domoticz on your Pi
this might be a good place to start. It's been a great help to me
Greetz,
Sjonnie
Posted: Sunday 24 September 2017 17:42
by Sjonnie2017
megus wrote: Friday 22 September 2017 13:17
Please help!
Hi, I know there is a command that will let you "find¨ your Broadlink and connect to it but I found it was easier to just enter the correct ip and MAC address in the hardware section of Domoticz.
In your log it shows
So you haven't changed the IP and MAC when creating the device. Try to enter the correct IP (your router should be able to tell you that - one of your wireless clients should start with RM****) and find out the MAC (again in most cases your router is your friend). Make sure you enter the MAC address without the colons (see one of my previous posts). If you've done that your connection should be up and running.
HTH
Greetz,
Sjonnie
Posted: Sunday 24 September 2017 22:22
by megus
Hi Sjonnie2017
I've tried that as wel but same errors so I started as per wiki from discovering broadlink itself
applied IP and MAC now
same thing:
2017-09-25 06:17:55.511 Domoticz V3.8153 (c)2012-2017 GizMoCuz
2017-09-25 06:17:55.512 Build Hash: 494fff7, Date: 2017-07-30 20:19:41
2017-09-25 06:17:55.514 Startup Path: /home/pi/domoticz/
2017-09-25 06:17:55.685 PluginSystem: Started, Python version '3.4.2'.
2017-09-25 06:17:55.698 Active notification Subsystems: gcm, http (2/12)
2017-09-25 06:17:55.700 WebServer(HTTP) started on address: :: with port 8080
2017-09-25 06:17:55.710 WebServer(SSL) started on address: :: with port 443
2017-09-25 06:17:55.712 Proxymanager started.
2017-09-25 06:17:55.713 Starting shared server on: :::6144
2017-09-25 06:17:55.714 TCPServer: shared server started...
2017-09-25 06:17:55.714 RxQueue: queue worker started...
2017-09-25 06:17:57.715 EventSystem: reset all events...
2017-09-25 06:17:57.716 EventSystem: reset all device statuses...
2017-09-25 06:17:57.781 Incoming connection from: 10.0.0.25
2017-09-25 06:17:57.851 Python EventSystem: Module not found - Trying to initialize.
2017-09-25 06:17:57.854 Python EventSystem: Initalizing event module.
2017-09-25 06:17:57.855 EventSystem: Started
2017-09-25 06:17:58.043 PluginSystem: Entering work loop.
2017-09-25 06:17:58.450 (test) Initialized version 3.0.0, author 'zak45'
2017-09-25 06:17:58.454 (test) Debug log level set to: 'true'.
2017-09-25 06:17:58.454 (test) 'HardwareID':'2'
2017-09-25 06:17:58.454 (test) 'Mode5':'9000'
2017-09-25 06:17:58.454 (test) 'Mode6':'Debug'
2017-09-25 06:17:58.454 (test) 'Author':'zak45'
2017-09-25 06:17:58.454 (test) 'Mode1':'34ea34b50a16'
2017-09-25 06:17:58.454 (test) 'Name':'test'
2017-09-25 06:17:58.454 (test) 'Mode4':'no'
2017-09-25 06:17:58.454 (test) 'Version':'3.0.0'
2017-09-25 06:17:58.455 (test) 'Address':'10.0.0.97'
2017-09-25 06:17:58.455 (test) 'HomeFolder':'/home/pi/domoticz/plugins/BroadlinkRM2/'
2017-09-25 06:17:58.455 (test) 'Mode3':'no'
2017-09-25 06:17:58.455 (test) 'Port':'0'
2017-09-25 06:17:58.455 (test) 'Mode2':'/home/pi/domoticz/plugins/BroadlinkRM2/ini'
2017-09-25 06:17:58.455 (test) 'Key':'BroadlinkRM2'
2017-09-25 06:17:58.455 (test) Device count: 2
2017-09-25 06:17:58.455 (test) Device: 1 - ID: 1, Name: 't8 - Discover', nValue: 0, sValue: 'Off'
2017-09-25 06:17:58.455 (test) Device ID: '1'
2017-09-25 06:17:58.455 (test) Device Name: 't8 - Discover'
2017-09-25 06:17:58.455 (test) Device nValue: 0
2017-09-25 06:17:58.455 (test) Device sValue: 'Off'
2017-09-25 06:17:58.455 (test) Device LastLevel: 0
2017-09-25 06:17:58.455 (test) Device: 254 - ID: 2, Name: 't8 - Remote', nValue: 0, sValue: ''
2017-09-25 06:17:58.455 (test) Device ID: '2'
2017-09-25 06:17:58.456 (test) Device Name: 't8 - Remote'
2017-09-25 06:17:58.456 (test) Device nValue: 0
2017-09-25 06:17:58.456 (test) Device sValue: ''
2017-09-25 06:17:58.456 (test) Device LastLevel: 0
2017-09-25 06:17:58.456 (test) Connecting to: 10.0.0.97:34ea34b50a16
2017-09-25 06:17:58.538 Error: (test) Error Connecting to Broadlink device....
2017-09-25 06:17:58.538 (test) Device Number begin to : 1
2017-09-25 06:17:58.561 (test) No ini file :/home/pi/domoticz/plugins/BroadlinkRM2/ini/remote/plugin_remote_2.ini
2017-09-25 06:17:58.561 (test) Custom Commands for Remote not managed
2017-09-25 06:17:58.562 (test) Heartbeat interval set to: 30.
2017-09-25 06:18:00.331 User: Admin initiated a switch command (1/t8 - Discover/On)
2017-09-25 06:18:00.365 (test) Calling message handler 'onCommand'.
2017-09-25 06:18:00.365 (test) onCommand called for Unit 1: Parameter 'On', Level: 0 , Connected : False
2017-09-25 06:18:00.365 (test) All plugin system is on pause for 5s...
2017-09-25 06:18:05.372 (test) Found 1 broadlink devices
2017-09-25 06:18:05.384 Error: (test) 'onCommand' failed 'TypeError':'sequence item 0: expected str instance, bytes found'.
2017-09-25 06:18:05.384 Error: (test) ----> Line 210 in /home/pi/domoticz/plugins/BroadlinkRM2/plugin.py, function onCommand
2017-09-25 06:18:05.384 Error: (test) ----> Line 397 in /home/pi/domoticz/plugins/BroadlinkRM2/plugin.py, function Discover
2017-09-25 06:18:05.384 Error: (test) ----> Line 203 in /usr/lib/python3.4/broadlink/__init__.py, function auth
2017-09-25 06:18:05.384 Error: (test) ----> Line 258 in /usr/lib/python3.4/broadlink/__init__.py, function send_packet
2017-09-25 06:18:05.385 Error: (test) ----> Line 162 in /usr/lib/python3.4/broadlink/__init__.py, function encrypt_pyaes
2017-09-25 06:18:07.989 (test) Calling message handler 'onHeartbeat'.
2017-09-25 06:18:37.995 (test) Calling message handler 'onHeartbeat'.
Posted: Sunday 24 September 2017 23:52
by zak45
@megus
make a try by installing pycrypto...
Posted: Monday 25 September 2017 12:40
by megus
@zak45
pi@domoticz:~ $ pip3 install pycrypto
Requirement already satisfied: pycrypto in /usr/local/lib/python3.5/site-packages
Posted: Monday 25 September 2017 12:54
by zak45
megus wrote: Monday 25 September 2017 12:40
@zak45
Requirement already satisfied: pycrypto in [b]/usr/local/lib/python3.5/[/b]site-packages
Looks like you have several 3.x installation. Python framework search for 3.4 apparently.Maybe should be better to have only one, except this is really necessary.
