Re: Dashticz - Feature Requests
Posted: Wednesday 07 June 2017 21:42
option to change the standby screen....
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
Id like to bump this idea up.gielie wrote:Is it possible to create buttons instead a dropdown menu.
So you want to turn on the screen when there is motion in front of the tablet?jjnj wrote:I would like to ask for the following feature:
Turn back to the main screen when Dashticz is in the standby screen when a switch is turned on.
This means I can do the following:
With the app motion sensor and tasker you can use the frontcamera of the tablet displaying Dashticz to switch on a certain switch when motion is detected.
So when you approach Dashticz the screen will switch to the normal mode. A similar approach like the Nest for example.
I want to turn the screen on, but from the standby screen of dashticz to the main screen. So the screen of the tablet itself will stay on, it just switching between screen states in dashticz.blacksn0w wrote:So you want to turn on the screen when there is motion in front of the tablet?jjnj wrote:I would like to ask for the following feature:
I've got another solution for this problem, i'm using http://www.ozerov.de/fully-kiosk-browser/ which got the feature motion detection.
The screen is off in standard, but the camera is still looking for motion.
If detected, the screen gets on, and will stay there until the motion is gone and 20s are over.
This might fit your needs better than doing this with 3 apps, sending data to domoticz, get info back and turn the screen on
So for me that is exactly what blacksnow is saying. Only his screen comes on from being off and not stand-by as you are requesting. For me the method of blacksnow is easier so it seems!jjnj wrote:I want to turn the screen on, but from the standby screen of dashticz to the main screen. So the screen of the tablet itself will stay on, it just switching between screen states in dashticz.blacksn0w wrote:So you want to turn on the screen when there is motion in front of the tablet?jjnj wrote:I would like to ask for the following feature:
That method is endeed easier but doesn't allow you to use the standby screen of Dashticz and just completely turns of the screen.krizzz wrote:So for me that is exactly what blacksnow is saying. Only his screen comes on from being off and not stand-by as you are requesting. For me the method of blacksnow is easier so it seems!jjnj wrote:I want to turn the screen on, but from the standby screen of dashticz to the main screen. So the screen of the tablet itself will stay on, it just switching between screen states in dashticz.blacksn0w wrote: So you want to turn on the screen when there is motion in front of the tablet?
True! But when you want to activate the normal Dashticz dashboard when coming closer to the tablet. You will never see the stand-by screen itself because it will always switch to regular one coming closerjjnj wrote:That method is endeed easier but doesn't allow you to use the standby screen of Dashticz and just completely turns of the screen.krizzz wrote:So for me that is exactly what blacksnow is saying. Only his screen comes on from being off and not stand-by as you are requesting. For me the method of blacksnow is easier so it seems!jjnj wrote: I want to turn the screen on, but from the standby screen of dashticz to the main screen. So the screen of the tablet itself will stay on, it just switching between screen states in dashticz.
http://192.168.1.146:8080/json.htm?type=graph&sensor=counter&idx=27&range=day&method=1&jsoncallback=?
var data={
"ValueQuantity" : "",
"ValueUnits" : "",
"method" : 1,
"result" : [
"d" : "2017-06-09 10:10",
"v" : "273.000"
"d" : "2017-06-09 10:15",
"v" : "275.000"
"d" : "2017-06-09 10:20",
"v" : "266.000"
"d" : "2017-06-09 10:25",
"v" : "294.000"
"d" : "2017-06-09 10:30",
"v" : "259.000"
"d" : "2017-06-09 10:35",
"v" : "264.000"
"d" : "2017-06-09 10:40",
"v" : "271.000"
"d" : "2017-06-09 10:45",
"v" : "264.000"
"d" : "2017-06-09 10:50",
"v" : "241.000"
"d" : "2017-06-09 10:55",
"v" : "273.000"
"d" : "2017-06-09 10:00",
"eu" : "21.000"
"d" : "2017-06-09 11:00",
"v" : "282.000"
"d" : "2017-06-09 11:05",
"v" : "271.000"
"d" : "2017-06-09 11:10",
"v" : "248.000"
"d" : "2017-06-09 11:15",
"v" : "271.000"
"d" : "2017-06-09 11:20",
"v" : "271.000"
"d" : "2017-06-09 11:25",
"v" : "259.000"
"d" : "2017-06-09 11:30",
"v" : "262.000"
"d" : "2017-06-09 11:35",
"v" : "289.000"
"d" : "2017-06-09 11:40",
"v" : "271.000"
"d" : "2017-06-09 11:45",
"v" : "269.000"
"d" : "2017-06-09 11:50",
"v" : "273.000"
"d" : "2017-06-09 11:55",
"v" : "271.000"
"eu" : "0.000"
"d" : "2017-06-09 12:00",
"v" : "248.000"
"d" : "2017-06-09 12:05",
"v" : "269.000"
"d" : "2017-06-09 12:10",
"v" : "266.000"
"d" : "2017-06-09 12:15",
"v" : "269.000"
"d" : "2017-06-09 12:20",
"v" : "250.000"
"d" : "2017-06-09 12:25",
"v" : "243.000"
"d" : "2017-06-09 12:30",
"v" : "259.000"
"d" : "2017-06-09 12:35",
"v" : "262.000"
"d" : "2017-06-09 12:40",
"v" : "259.000"
"d" : "2017-06-09 12:45",
"v" : "294.000"
"d" : "2017-06-09 12:50",
"v" : "269.000"
"d" : "2017-06-09 12:55",
"v" : "271.000"
"eu" : "0.000"
"d" : "2017-06-09 13:00",
"v" : "266.000"
"d" : "2017-06-09 13:05",
"v" : "266.000"
"d" : "2017-06-09 13:10",
"v" : "246.000"
"d" : "2017-06-09 13:15",
"v" : "266.000"
"d" : "2017-06-09 13:20",
"v" : "271.000"
"d" : "2017-06-09 13:25",
"v" : "269.000"
"d" : "2017-06-09 13:30",
"v" : "271.000"
"d" : "2017-06-09 13:35",
"v" : "285.000"
"d" : "2017-06-09 13:40",
"v" : "257.000"
"d" : "2017-06-09 13:45",
"v" : "252.000"
"d" : "2017-06-09 13:50",
"v" : "255.000"
"d" : "2017-06-09 13:55",
"v" : "241.000"
"eu" : "0.000"
"d" : "2017-06-09 14:00",
"v" : "271.000"
"d" : "2017-06-09 14:05",
"v" : "269.000"
"d" : "2017-06-09 14:10",
"v" : "269.000"
"d" : "2017-06-09 14:15",
"v" : "271.000"
"d" : "2017-06-09 14:20",
"v" : "239.000"
"d" : "2017-06-09 14:25",
"v" : "271.000"
"d" : "2017-06-09 14:30",
"v" : "271.000"
"d" : "2017-06-09 14:35",
"v" : "271.000"
"d" : "2017-06-09 14:40",
"v" : "294.000"
"d" : "2017-06-09 14:45",
"v" : "292.000"
"d" : "2017-06-09 14:50",
"v" : "259.000"
"d" : "2017-06-09 14:55",
"v" : "257.000"
"eu" : "0.000"
"d" : "2017-06-09 15:00",
"v" : "271.000"
"d" : "2017-06-09 15:05",
"v" : "252.000"
"d" : "2017-06-09 15:10",
"v" : "271.000"
"d" : "2017-06-09 15:15",
"v" : "271.000"
"d" : "2017-06-09 15:20",
"v" : "271.000"
"d" : "2017-06-09 15:25",
"v" : "255.000"
"d" : "2017-06-09 15:30",
"v" : "241.000"
"d" : "2017-06-09 15:35",
"v" : "271.000"
"d" : "2017-06-09 15:40",
"v" : "271.000"
"d" : "2017-06-09 15:45",
"v" : "259.000"
"d" : "2017-06-09 15:50",
"v" : "289.000"
"d" : "2017-06-09 15:55",
"v" : "259.000"
"eu" : "0.000"
"d" : "2017-06-09 16:00",
"v" : "257.000"
"d" : "2017-06-09 16:05",
"v" : "269.000"
"d" : "2017-06-09 16:10",
"v" : "243.000"
"d" : "2017-06-09 16:15",
"v" : "241.000"
"d" : "2017-06-09 16:20",
"v" : "271.000"
"d" : "2017-06-09 16:25",
"v" : "273.000"
"d" : "2017-06-09 16:30",
"v" : "275.000"
"d" : "2017-06-09 16:35",
"v" : "246.000"
"d" : "2017-06-09 16:40",
"v" : "271.000"
"d" : "2017-06-09 16:45",
"v" : "273.000"
"d" : "2017-06-09 16:50",
"v" : "269.000"
"d" : "2017-06-09 16:55",
"v" : "289.000"
"eu" : "0.000"
"d" : "2017-06-09 17:00",
"v" : "257.000"
"d" : "2017-06-09 17:05",
"v" : "379.000"
"d" : "2017-06-09 17:10",
"v" : "374.000"
"d" : "2017-06-09 17:15",
"v" : "372.000"
"d" : "2017-06-09 17:20",
"v" : "241.000"
"d" : "2017-06-09 17:25",
"v" : "269.000"
"d" : "2017-06-09 17:30",
"v" : "264.000"
"d" : "2017-06-09 17:35",
"v" : "269.000"
"d" : "2017-06-09 17:40",
"v" : "239.000"
"d" : "2017-06-09 17:45",
"v" : "266.000"
"d" : "2017-06-09 17:50",
"v" : "257.000"
"d" : "2017-06-09 17:55",
"v" : "285.000"
"eu" : "85.000"
"d" : "2017-06-09 18:00",
"v" : "303.000"
"d" : "2017-06-09 18:05",
"v" : "282.000"
"d" : "2017-06-09 18:10",
"v" : "597.000"
"d" : "2017-06-09 18:15",
"v" : "607.000"
"d" : "2017-06-09 18:20",
"v" : "625.000"
"d" : "2017-06-09 18:25",
"v" : "471.000"
"d" : "2017-06-09 18:30",
"v" : "588.000"
"d" : "2017-06-09 18:35",
"v" : "561.000"
"d" : "2017-06-09 18:40",
"v" : "616.000"
"d" : "2017-06-09 18:45",
"v" : "505.000"
"d" : "2017-06-09 18:50",
"v" : "289.000"
"d" : "2017-06-09 18:55",
"v" : "423.000"
"eu" : "246.000"
"d" : "2017-06-09 19:00",
"v" : "427.000"
"d" : "2017-06-09 19:05",
"v" : "411.000"
"d" : "2017-06-09 19:10",
"v" : "345.000"
"d" : "2017-06-09 19:15",
"v" : "411.000"
"d" : "2017-06-09 19:20",
"v" : "409.000"
"d" : "2017-06-09 19:25",
"v" : "407.000"
"d" : "2017-06-09 19:30",
"v" : "416.000"
"d" : "2017-06-09 19:35",
"v" : "418.000"
"d" : "2017-06-09 19:40",
"v" : "386.000"
"d" : "2017-06-09 19:45",
"v" : "423.000"
"d" : "2017-06-09 19:50",
"v" : "370.000"
"d" : "2017-06-09 19:55",
"v" : "388.000"
"eu" : "0.000"
"d" : "2017-06-09 20:00",
"v" : "420.000"
"d" : "2017-06-09 20:05",
"v" : "423.000"
"d" : "2017-06-09 20:10",
"v" : "407.000"
"d" : "2017-06-09 20:15",
"v" : "358.000"
"d" : "2017-06-09 20:20",
"v" : "407.000"
"d" : "2017-06-09 20:25",
"v" : "409.000"
"d" : "2017-06-09 20:30",
"v" : "381.000"
"d" : "2017-06-09 20:35",
"v" : "471.000"
"d" : "2017-06-09 20:40",
"v" : "489.000"
"d" : "2017-06-09 20:45",
"v" : "460.000"
"d" : "2017-06-09 20:50",
"v" : "494.000"
"d" : "2017-06-09 20:55",
"v" : "492.000"
"eu" : "0.000"
"d" : "2017-06-09 21:00",
"v" : "478.000"
"d" : "2017-06-09 21:05",
"v" : "473.000"
"d" : "2017-06-09 21:10",
"v" : "294.000"
"d" : "2017-06-09 21:15",
"v" : "294.000"
"d" : "2017-06-09 21:20",
"v" : "292.000"
"d" : "2017-06-09 21:25",
"v" : "278.000"
"d" : "2017-06-09 21:30",
"v" : "282.000"
"d" : "2017-06-09 21:35",
"v" : "289.000"
"d" : "2017-06-09 21:40",
"v" : "262.000"
"d" : "2017-06-09 21:45",
"v" : "294.000"
"d" : "2017-06-09 21:50",
"v" : "292.000"
"d" : "2017-06-09 21:55",
"v" : "294.000"
"eu" : "0.000"
"d" : "2017-06-09 22:00",
"v" : "273.000"
"d" : "2017-06-09 22:05",
"v" : "262.000"
"d" : "2017-06-09 22:10",
"v" : "292.000"
"d" : "2017-06-09 22:15",
"v" : "292.000"
"d" : "2017-06-09 22:20",
"v" : "285.000"
"d" : "2017-06-09 22:25",
"v" : "292.000"
"d" : "2017-06-09 22:30",
"v" : "271.000"
"d" : "2017-06-09 22:35",
"v" : "278.000"
"d" : "2017-06-09 22:40",
"v" : "289.000"
"d" : "2017-06-09 22:45",
"v" : "264.000"
"d" : "2017-06-09 22:50",
"v" : "287.000"
"d" : "2017-06-09 22:55",
"v" : "289.000"
"eu" : "0.000"
"d" : "2017-06-09 23:00",
"v" : "287.000"
"d" : "2017-06-09 23:05",
"v" : "278.000"
"d" : "2017-06-09 23:10",
"v" : "259.000"
"d" : "2017-06-09 23:15",
"v" : "287.000"
"d" : "2017-06-09 23:20",
"v" : "292.000"
"d" : "2017-06-09 23:25",
"v" : "278.000"
"d" : "2017-06-09 23:30",
"v" : "296.000"
"d" : "2017-06-09 23:35",
"v" : "273.000"
"d" : "2017-06-09 23:40",
"v" : "269.000"
"d" : "2017-06-09 23:45",
"v" : "292.000"
"d" : "2017-06-09 23:50",
"v" : "271.000"
"eu" : "0.000"
"d" : "2017-06-10 00:00",
"v" : "294.000"
"d" : "2017-06-10 00:05",
"v" : "292.000"
"d" : "2017-06-10 00:10",
"v" : "478.000"
"d" : "2017-06-10 00:15",
"v" : "372.000"
"d" : "2017-06-10 00:20",
"v" : "331.000"
"d" : "2017-06-10 00:25",
"v" : "321.000"
"d" : "2017-06-10 00:30",
"v" : "315.000"
"d" : "2017-06-10 00:35",
"v" : "335.000"
"d" : "2017-06-10 00:40",
"v" : "289.000"
"d" : "2017-06-10 00:45",
"v" : "292.000"
"d" : "2017-06-10 00:50",
"v" : "289.000"
"d" : "2017-06-10 00:55",
"v" : "292.000"
"eu" : "0.000"
"d" : "2017-06-10 01:00",
"v" : "266.000"
"d" : "2017-06-10 01:05",
"v" : "292.000"
"d" : "2017-06-10 01:10",
"v" : "294.000"
"d" : "2017-06-10 01:15",
"v" : "292.000"
"d" : "2017-06-10 01:20",
"v" : "275.000"
"d" : "2017-06-10 01:25",
"v" : "262.000"
"d" : "2017-06-10 01:30",
"v" : "275.000"
"d" : "2017-06-10 01:35",
"v" : "278.000"
"d" : "2017-06-10 01:40",
"v" : "278.000"
"d" : "2017-06-10 01:45",
"v" : "303.000"
"d" : "2017-06-10 01:50",
"v" : "294.000"
"d" : "2017-06-10 01:55",
"v" : "294.000"
"eu" : "0.000"
"d" : "2017-06-10 02:00",
"v" : "292.000"
"d" : "2017-06-10 02:05",
"v" : "282.000"
"d" : "2017-06-10 02:10",
"v" : "262.000"
"d" : "2017-06-10 02:15",
"v" : "292.000"
"d" : "2017-06-10 02:20",
"v" : "292.000"
"d" : "2017-06-10 02:25",
"v" : "289.000"
"d" : "2017-06-10 02:30",
"v" : "266.000"
"d" : "2017-06-10 02:35",
"v" : "273.000"
"d" : "2017-06-10 02:40",
"v" : "278.000"
"d" : "2017-06-10 02:45",
"v" : "280.000"
"d" : "2017-06-10 02:50",
"v" : "273.000"
"d" : "2017-06-10 02:55",
"v" : "264.000"
"eu" : "0.000"
"d" : "2017-06-10 03:00",
"v" : "296.000"
"d" : "2017-06-10 03:05",
"v" : "294.000"
"d" : "2017-06-10 03:10",
"v" : "292.000"
"d" : "2017-06-10 03:15",
"v" : "264.000"
"d" : "2017-06-10 03:20",
"v" : "296.000"
"d" : "2017-06-10 03:25",
"v" : "298.000"
"d" : "2017-06-10 03:30",
"v" : "296.000"
"d" : "2017-06-10 03:35",
"v" : "296.000"
"d" : "2017-06-10 03:40",
"v" : "296.000"
"d" : "2017-06-10 03:45",
"v" : "278.000"
"d" : "2017-06-10 03:50",
"v" : "280.000"
"d" : "2017-06-10 03:55",
"v" : "275.000"
"eu" : "0.000"
"d" : "2017-06-10 04:00",
"v" : "273.000"
"d" : "2017-06-10 04:05",
"v" : "294.000"
"d" : "2017-06-10 04:10",
"v" : "296.000"
"d" : "2017-06-10 04:15",
"v" : "298.000"
"d" : "2017-06-10 04:20",
"v" : "294.000"
"d" : "2017-06-10 04:25",
"v" : "262.000"
"d" : "2017-06-10 04:30",
"v" : "296.000"
"d" : "2017-06-10 04:35",
"v" : "296.000"
"d" : "2017-06-10 04:40",
"v" : "294.000"
"d" : "2017-06-10 04:45",
"v" : "278.000"
"d" : "2017-06-10 04:50",
"v" : "296.000"
"d" : "2017-06-10 04:55",
"v" : "275.000"
"eu" : "0.000"
"d" : "2017-06-10 05:00",
"v" : "271.000"
"d" : "2017-06-10 05:05",
"v" : "292.000"
"d" : "2017-06-10 05:10",
"v" : "266.000"
"d" : "2017-06-10 05:15",
"v" : "294.000"
"d" : "2017-06-10 05:20",
"v" : "294.000"
"d" : "2017-06-10 05:25",
"v" : "294.000"
"d" : "2017-06-10 05:30",
"v" : "294.000"
"d" : "2017-06-10 05:35",
"v" : "262.000"
"d" : "2017-06-10 05:40",
"v" : "296.000"
"d" : "2017-06-10 05:45",
"v" : "292.000"
"d" : "2017-06-10 05:50",
"v" : "273.000"
"d" : "2017-06-10 05:55",
"v" : "273.000"
"eu" : "0.000"
"d" : "2017-06-10 06:00",
"v" : "289.000"
"d" : "2017-06-10 06:05",
"v" : "278.000"
"d" : "2017-06-10 06:10",
"v" : "296.000"
"d" : "2017-06-10 06:15",
"v" : "296.000"
"d" : "2017-06-10 06:20",
"v" : "266.000"
"d" : "2017-06-10 06:25",
"v" : "294.000"
"d" : "2017-06-10 06:30",
"v" : "292.000"
"d" : "2017-06-10 06:35",
"v" : "328.000"
"d" : "2017-06-10 06:40",
"v" : "331.000"
"d" : "2017-06-10 06:45",
"v" : "340.000"
"d" : "2017-06-10 06:50",
"v" : "377.000"
"d" : "2017-06-10 06:55",
"v" : "349.000"
"eu" : "0.000"
"d" : "2017-06-10 07:00",
"v" : "354.000"
"d" : "2017-06-10 07:05",
"v" : "358.000"
"d" : "2017-06-10 07:10",
"v" : "361.000"
"d" : "2017-06-10 07:15",
"v" : "370.000"
"d" : "2017-06-10 07:20",
"v" : "370.000"
"d" : "2017-06-10 07:25",
"v" : "400.000"
"d" : "2017-06-10 07:30",
"v" : "2176.000"
"d" : "2017-06-10 07:35",
"v" : "2786.000"
"d" : "2017-06-10 07:40",
"v" : "2773.000"
"d" : "2017-06-10 07:45",
"v" : "2732.000"
"d" : "2017-06-10 07:50",
"v" : "809.000"
"d" : "2017-06-10 07:55",
"v" : "972.000"
"eu" : "2161.000"
"d" : "2017-06-10 08:00",
"v" : "450.000"
"d" : "2017-06-10 08:05",
"v" : "441.000"
"d" : "2017-06-10 08:10",
"v" : "471.000"
"d" : "2017-06-10 08:15",
"v" : "625.000"
"d" : "2017-06-10 08:20",
"v" : "492.000"
"d" : "2017-06-10 08:25",
"v" : "510.000"
"d" : "2017-06-10 08:30",
"v" : "487.000"
"d" : "2017-06-10 08:35",
"v" : "489.000"
"d" : "2017-06-10 08:40",
"v" : "494.000"
"d" : "2017-06-10 08:45",
"v" : "462.000"
"d" : "2017-06-10 08:50",
"v" : "1282.000"
"d" : "2017-06-10 08:55",
"v" : "480.000"
"eu" : "0.000"
"d" : "2017-06-10 09:00",
"v" : "480.000"
"d" : "2017-06-10 09:05",
"v" : "563.000"
"d" : "2017-06-10 09:10",
"v" : "478.000"
"d" : "2017-06-10 09:15",
"v" : "604.000"
"d" : "2017-06-10 09:20",
"v" : "494.000"
"d" : "2017-06-10 09:25",
"v" : "503.000"
"d" : "2017-06-10 09:30",
"v" : "473.000"
"d" : "2017-06-10 09:35",
"v" : "469.000"
"d" : "2017-06-10 09:40",
"v" : "499.000"
"d" : "2017-06-10 09:45",
"v" : "499.000"
"d" : "2017-06-10 09:50",
"v" : "768.000"
"d" : "2017-06-10 09:55",
"v" : "565.000"
"eu" : "0.000"
"d" : "2017-06-10 10:00",
"v" : "531.000"
"d" : "2017-06-10 10:05",
"v" : "533.000"
"eu" : "0.000"
"d" : "2017-06-10 10:10",
"v" : "508.000"
"status" : "OK",
"title" : "Graph counter day"
?(data);
http://192.168.1.146:8080/json.htm?type=graph&sensor=counter&idx=27&range=day&method=0&jsoncallback=?Code: Select all
var data={
"ValueUnits" : "",
"method" : 0,
"result" : [
"v" : "48.000"
"v" : "0.000"
"v" : "90.000"
"v" : "246.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"v" : "2161.000"
"v" : "0.000"
"v" : "0.000"
"v" : "0.000"
"d" : "2017-06-10 11:00",
"v" : "122.000"
"d" : "2017-06-10 12:00",
"v" : "0.000"
"d" : "2017-06-10 13:00",
"v" : "230.000"
"d" : "2017-06-10 14:00",
"v" : "0.000"
"status" : "OK",
?(data);
blocks['graph_27'] = {}
blocks['graph_27']['width'] = 5;
url: _HOST_DOMOTICZ+'/json.htm?type=graph&sensor='+sensor+'&idx='+idx+'&range='+realrange+'&time='+new Date().getTime()+'&jsoncallback=?',
url: _HOST_DOMOTICZ+'/json.htm?type=graph&sensor='+sensor+'&idx='+idx+'&range='+realrange+'&method=1&time='+new Date().getTime()+'&jsoncallback=?',
I would love this also. It would however probably make more sense to have the Spotify control integrated in Domoticz itself first. I have done some forum searches but cannot find this has been done so far. But I'm not the pro hereSundown89 wrote:Hi!
I would like Spotify integration. I have multiroom audio using RPi's as Spotify Connect devices. See github here.
Currently I am using my android phone as the remote to control them. Would be nice to control the devices from the tablet on the wall through Dashticz.
Fixed in latest beta, add a image to the img-folder and use:htilburgs wrote:I meant like in the rss feed, etc..
But I like the feature as in the buttons, just the option icon: or image: in the variable.
example:
calendars.f1 = { maxitems: 5, title: 'F1 Calendar', icon: 'fa-calendar ',icalurl: 'https://calendar.google.com/calendar/ical/xx/basic.ics' }
or
calendars.f1 = { maxitems: 5, title: 'F1 Calendar', image: 'img/calendar.png',icalurl: 'https://calendar.google.com/calendar/ical/xx/basic.ics' }
calendars.f1 = { maxitems: 5, title: 'F1 Calendar', [b]image: 'calendar.png'[/b],icalurl: 'https://calendar.google.com/calendar/ical/xx/basic.ics' }
I've added this class in BETA: calendar_iconhtilburgs wrote:Rob, one question. Is it possible to change the class of the calendar image?
Now is has class ICON and is it not quite possible to change format of location of the image.
