Page 69 of 123
Posted: Wednesday 03 May 2017 14:37
by jjnj
Besides the smoke detectors, new revisions of the switch, door/windows sensor and temp/hum sensor are coming:
Temp/hum sensor (very cheap)
http://www.gearbest.com/access-control/pp_626702.html
Door/window sensor:
http://www.gearbest.com/access-control/pp_626703.html
Switch:
http://www.gearbest.com/access-control/pp_626695.html
It all looks pretty nice.
Edit:
A curtain motor:
http://www.gearbest.com/access-control/pp_626697.html
Posted: Wednesday 03 May 2017 14:47
by mikeoo
Only with the switch is says ZigBee Connection?
I look nice but not sure iff it will work with the Gateway off Xiaomi. There is not mention off it.
Posted: Wednesday 03 May 2017 19:09
by deennoo
Looks to be the same as the futur Thomson Home automation system.
If you made some search on FCC website you will find a vibration sensor to put on a door.
All of them looks to be zigbee compatible, now wait and see.
Posted: Wednesday 03 May 2017 22:19
by pikapt
Hi guys
I'm having some serious issues regarding the range between the hub and the motion detector. In my current setup they are about 6m away from each other and it's working perfectly. I've tried to move the sensor 5 meter above (total 10m +-) and the it works every now and then. Since it's not stable, it's not an option for me.
So I'm trying to understand how far away are the xiaomi devices on your setups, afaik the switch and the door sensor work a little bit better but still won't be enough for one hub to cover an entire apartment.
I'm not having good experiences when it comes to use the xiaomi plug as repeater as well..
Posted: Wednesday 03 May 2017 23:44
by mrefex
After the latest upate v3.7412 my MP3 gateway doesn't respond anymore. I can trigger a doorbell or alarm bell but the mid value script to trigger your own mp3's don't work anymore. Does anybody have the same issues after updating?
Posted: Thursday 04 May 2017 16:34
by bar1
Hi everyone, i am new to Domoticz and to the forum, sorry if the questions has been answered.
recently i discovered domoticz and i was very excited to add it to my Xiaomi smart home set up , but it looks like my gateway isn't compatible (first gen)?
so i hoped on to gearbest to got a new gateway + some more sensors....
i see some of the new sensors come with Aqara interface, so i am a little confused.
what is the difference between the 2?
I am assuming that will be the gateway i will have to buy
http://www.gearbest.com/living-applianc ... 16094.html for aqera?
and most importantly which one is supported by Domoticz?
Thanks,
Bar1
Posted: Thursday 04 May 2017 17:16
by chrispazz
corbin wrote:What are the Xiaomi lamps? Yeelights?
Yes, the Yeelights
Posted: Thursday 04 May 2017 17:17
by chrispazz
I am waiting for this to operate my air conditioning system.
Will it be compatible in Domoticz?
http://it.gearbest.com/smart-home/pp_229556.html
Posted: Thursday 04 May 2017 19:41
by jjnj
The IR isn't compatible yet. Not sure if it's zigbee? This thread is only for the gateway and its zigbee compatible accessories
Posted: Friday 05 May 2017 8:24
by mrefex
mrefex wrote:After the latest upate v3.7412 my MP3 gateway doesn't respond anymore. I can trigger a doorbell or alarm bell but the mid value script to trigger your own mp3's don't work anymore. Does anybody have the same issues after updating?
Today updated to v3.7416
deleted all audio gateways and reinstalled them.
works again!
Posted: Friday 05 May 2017 10:13
by ilpier
I know this is a stupid question but i do not understand how this work!
For the Wirless Switch there is 4 combination,Click,Double Click,long click an long click release.
For the first two ok,easy,but the other two?!Physically how they should be activated??
Posted: Friday 05 May 2017 11:39
by allmehandidesigns
it's not perform well, in latest version. there are many bugs i m facing after updating latest version
Posted: Friday 05 May 2017 18:32
by xxLeoxx93
bar1 wrote:Hi everyone, i am new to Domoticz and to the forum, sorry if the questions has been answered.
Thanks,
Bar1
As fr as I know, there is only one version of the smart home hub and that works totaly fine with domoticz. So you probably did something wrong.
ilpier wrote:I know this is a stupid question but i do not understand how this work!
When you long klick it toggles beween both states like a switch.
Posted: Friday 05 May 2017 23:18
by deennoo
xxLeoxx93 wrote:bar1 wrote:Hi everyone, i am new to Domoticz and to the forum, sorry if the questions has been answered.
Thanks,
Bar1
Your bad there is 2 version :
1st who doesn't play chinese web radio, the older one who doesn't allow développer mode not domoticz compatible
2nd the last who play web chinese radio, who allow développer mode and domoticz compatible
Posted: Saturday 06 May 2017 18:23
by uwanttodance
Hi all. New to Domoticz and xiaomi smart home products. I own the gateway set and the socket with USB port. I'm exploring if this socket or the gateway unit can be programmed to monitor my internet connection such that I can work out a sequence to reset my modem whenever the socket or any components of this system detects that the internet connection is down. I'm referencing this to a product called the ResetPlug / Konke plug which is available in the US. Appreciate the advice to get this working.
Sent from my XT1575 using Tapatalk
Posted: Sunday 07 May 2017 10:06
by Mat2Vence
I did lost all the sound capability with the last udpdate I made (rev 3.7421). It was working well until then.
Cannot play the sound of the ring door or the alarm. Is it a known issue?
Edit : It seems that the RGB light does nto respond anymore too.
However no issue on sensor.
Posted: Sunday 07 May 2017 13:51
by maciejwr
Hi. Any chance controll radio in gateway ?
Play, Stop , next station ?
Posted: Sunday 07 May 2017 22:03
by apazga
Mat2Vence wrote:Hi,
Same here. I cannot turn light on/off using latest beta version.
Posted: Monday 08 May 2017 9:28
by ben53252642
Yay, I'm getting battery level readings for my sensors. Thanks Corbin!
- Screen Shot 2017-05-08 at 5.27.45 pm.png (190.97 KiB) Viewed 3858 times
Posted: Monday 08 May 2017 23:24
by Mat2Vence
Just move to the new version 3.7449 but it did not solve the issue of RGB and sound.
