brugje
Domoticz version: 2024.4
Post by brugje »
That should not be related. I think you also updated Domoticz to a new version and new Domoticz version have gone through some API changes. See the warning in the wiki https://www.domoticz.com/wiki/Domoticz_ ... d_newer.29
Yes I'm on version 2024-4. So there are some changes. I changed the frontpage json to the new getdevices call.
function RefreshData()
	clearInterval($.refreshTimer);
	var jurl=$.domoticzurl+"/json.htm?type=command&param=getdevices&plan="+$.roomplan+"&lastupdate="+$.LastUpdateTime;
	$.getJSON(jurl,
		format: "json"
	function(data) {
		if (typeof data.result != 'undefined') {
			$.each(data.result, function(i,item){
				for( var ii = 0, len = $.PageArray.length; ii < len; ii++ ) {
					if( $.PageArray[ii][0] === item.idx ) {		// Domoticz idx number
						var vtype=	$.PageArray[ii][1]; 		// Domotitcz type (like Temp, Humidity)
						var vlabel=	$.PageArray[ii][2];			// vak number from HTML layout
						var vdesc=	$.PageArray[ii][3];			// description
						var vattr=	$.PageArray[ii][4];			// extra css attributes
						var valarm=	$.PageArray[ii][5]; 		// alarm value to turn text to red
						var vdata=	item[vtype];				// current value
						if (typeof vdata == 'undefined') {
							vdata="???";
						} else {
							// remove too much text
							vdata=new String(vdata).split("Watt",1)[0];
							vdata=new String(vdata).split("kWh",1)[0];
							vdata=new String(vdata).split("km/h",1)[0];
							vdata=new String(vdata).split("W/m2",1)[0];
							vdata=new String(vdata).split("graden C",1)[0];
							vdata=new String(vdata).split("mm",1)[0];
							vdata=new String(vdata).split("/555",1)[0];
							vdata=new String(vdata).split("C",1)[0];
							vdata=new String(vdata).split("m3",1)[0];
							vdata=new String(vdata).split(" ",1)[0];
But now I need the solution to my problem
Groet Jan
praet mar frysk
You probably made an error somewhere else when changing the script.
