Page 66 of 123
Posted: Tuesday 18 April 2017 22:29
by pikapt
Not a big help but I have one and is showing ok. Have you tried to delete and re-add the device?
Posted: Tuesday 18 April 2017 22:37
by murtadin
quack3d wrote:Any ideas why humidity is not the same in the standalone device as in the temp + humidity device?
i have 7 sensors. three of them have difference.
@Corbin - lux sensors in gateway in dark shows 330 lux - a bit high i think?
Posted: Tuesday 18 April 2017 22:41
by bing69
267 lux in the night
Posted: Wednesday 19 April 2017 0:03
by murtadin
bing69 wrote:267 lux in the night
Are you sure?
https://en.wikipedia.org/wiki/Lux
Posted: Wednesday 19 April 2017 1:47
by deennoo
Are you sure?
That not à Real Lux Meter just à value from 300 to 1200
300: night
1300 : day
Posted: Wednesday 19 April 2017 9:09
by bing69
Are you sure?
Thats what Domoticz says, sorry...
Now on this moment he says 1233
Posted: Wednesday 19 April 2017 9:39
by bertbigb
How can I get this Lux sensor active? I see my Xiaomi Gateway but no Lux sensor
Posted: Wednesday 19 April 2017 10:03
by marcotrumpet
Check utility tab or refresch xiaomi hardware
Inviato dal mio SM-G950F utilizzando Tapatalk
Posted: Wednesday 19 April 2017 12:39
by claudioita
Is it possible to use TWO Xiaomi Gateway in Domoticz?
Posted: Wednesday 19 April 2017 13:34
by bertbigb
Thanks for Your answer. I checked the utility tab but there it wasn't. What do you mean with refreshing the Xiaomi hardware? Delete and reinstall? Or?
Posted: Wednesday 19 April 2017 13:54
by marcotrumpet
In hardware tab, click thr xiaomi gateway and then the blue button "refresh"
Posted: Wednesday 19 April 2017 14:10
by bertbigb
Hi Marcotrumpet,
Thanks for your answer.
I first set in settings accept new hardware and the I updated the Xiamomi hardware but unfortunately for me that didn't help. No Lux sensor occurs. All the others are there as far as I can see, but no Lux sensors.
Below a picture of all my Xiaomi hardware (but no Lux sensor :roll: )
Posted: Wednesday 19 April 2017 14:37
by marcotrumpet
Mmm.. maybe someone else has suggestion..
Posted: Wednesday 19 April 2017 15:44
by pikapt
bertbigb what version of domoticz is installed on your system? you need to be on the last dev version from corbin
https://github.com/corbinmunce/domoticz
you need to compile it from source..
Posted: Wednesday 19 April 2017 15:50
by bertbigb
mea culpa, mea culpa.
I understood that this development was in the beta already, since I also saw the Doorbell, MP3 and Ringtone I thought that corbins development was integrated in the beta. But if that is not the truth I have to put some more pressure on my own project to install a domoticz environment to test development versions. I will compile corbins version on my newly rapberry 3 and see if I then have a lux sensor also.
Sorry for bothering the community and thanks for everyone wanting to help me.
Posted: Wednesday 19 April 2017 16:02
by pikapt
Now that you say that I think I had the MP3 functionalities at the same time I had Lux... I mean, that was based on the latest firmware update from Xiaomi.. anyway give corbin dev a go maybe it will work (it works for me!)
Posted: Wednesday 19 April 2017 16:06
by G3rard
@bertbigb, the Xiaomi lux sensor is available in the latest beta, so no need to install corbins dev version.
Make sure you have new hardware enabled in the Domoticz settings (think it took some time before it was available) and consider a restart of Domoticz.
Posted: Thursday 20 April 2017 2:16
by jjnj
Hi all, today I saw that there is also the option to add a smoke alarm. Turns out the Xiaomi system now includes a smoke and gas alarm which is produced in collaboration with Honeywell.
http://m.gearbest.com/alarm-systems/pp_615081.html?
Is there by any chance a possibility to integrate this into Domoticz or has this already been done so? Image
Posted: Thursday 20 April 2017 7:30
by bertbigb
G3rard wrote:@bertbigb, the Xiaomi lux sensor is available in the latest beta, so no need to install corbins dev version.
I did a restart and have had enabled new hardware all the evening and night over. Still no result.
I also checked for the firmware, at this moment it is on 1.4.1_145.0141
Does anyone has another suggestion / solution?
Posted: Thursday 20 April 2017 16:14
by ToneStrife
Hello everyone,
I'm having problems with my cube. It says every certain time that status is Free Fall, in adition, clockwise is sending a blank status. I don't know how to fix it.
OK. I edit myself, after an update everything is working fine again!
So another question, I'm trying to make clockwise and anticlokwise change de light level. A used a script found here but it send me an error. Anyone has this script or somethign similar working properly?
