domoticz in synology as package! Available now.
jumbotroll
Re: domoticz in synology as package! Available now.
Post by jumbotroll »
moonface wrote: Sunday 18 February 2018 23:25 Hello Jumbotroll,
I have a synology DS 918 + and i couldn’t find any working drivers in your website for my aeotec z stick s2 .
Is it possible for you to build appropriate drivers ?
Many thanks
Best regards
Moonface
DS 918+ use arch-apollolake. All drivers are included in the domoticz packages.
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
moonface
Post by moonface »
Thanks for your answer and I tried to install apollolake drivers.
The problem is the log shows :
[ 113.034899] usbserial: version magic '4.4.15 SMP preempt mod_unload ' should be '4.4.15+ SMP preempt mod_unload '
[ 113.068743] ftdi_sio: Unknown symbol usb_serial_handle_sysrq_char (err 0)
[ 113.077302] ftdi_sio: Unknown symbol usb_serial_generic_open (err 0)
[ 113.099729] ftdi_sio: Unknown symbol usb_serial_handle_dcd_change (err 0)
[ 113.118669] ftdi_sio: Unknown symbol usb_serial_deregister_drivers (err 0)
[ 113.143888] ftdi_sio: Unknown symbol usb_serial_generic_unthrottle (err 0)
[ 113.186683] ftdi_sio: Unknown symbol usb_serial_handle_break (err 0)
[ 113.227666] ftdi_sio: Unknown symbol usb_serial_generic_get_icount (err 0)
[ 113.267654] ftdi_sio: Unknown symbol usb_serial_generic_tiocmiwait (err 0)
[ 113.308653] ftdi_sio: Unknown symbol usb_serial_generic_throttle (err 0)
[ 113.349664] ftdi_sio: Unknown symbol usb_serial_register_drivers (err 0)
[ 113.421865] cp210x: Unknown symbol usb_serial_generic_open (err 0)
[ 113.461653] cp210x: Unknown symbol usb_serial_generic_close (err 0)
[ 113.502715] cp210x: Unknown symbol usb_serial_deregister_drivers (err 0)
[ 113.538687] cp210x: Unknown symbol usb_serial_register_drivers (err 0)
Do you have any idea ?
Thanks for your help.
Moonface
jumbotroll
moonface wrote: Monday 19 February 2018 8:53 Thanks for your answer and I tried to install apollolake drivers.
Moonface
What DSM version do you use? DSM 6.1 or DSM 6.2 beta?
Jumbotroll
moonface
Post by moonface »
DSM 6.1
jumbotroll
Try to uninstall domoticz and if you have installed older drivers and reinstall domoticz.
This problem with the drivers should be fixed in newest beta.
viewtopic.php?f=17&t=20479
Jumbotroll
moonface
Post by moonface »
Thank you but in fact I use jeedom so just need the drivers.
Will it be possible to download them directly from your website ?
jumbotroll
moonface wrote: Monday 19 February 2018 9:09 Thank you but in fact I use jeedom so just need the drivers.
Did you test my UsbSerialDrivers_apollolake-6.1_6-11.spk driver ?
Download from here: http://www.jadahl.com/drivers/DSM_6.1/
Jumbotroll
moonface
Post by moonface »
Thank you.
Tried the last version you provided with the following approach :
Copy your drivers into /usr/lib/modules using a cp -f command (cp -f * from the downloaded directory to /usr/lib/modules)
Restarting the nas
Unfortunately the result is the same :(
Any idea ?
Thank you.
Moonface
jumbotroll
@moonface
Why is not working for you, but working for another users I don't know.
http://www.domoticz.com/forum/viewtopic ... start=1180
Maybe you have some older .ko files in your system.
It's working for domoticz users.
Jumbotroll
moonface
Post by moonface »
Indeed, it's disappointing ....
Usbserial.ko is only in the following path :
/volume1/@appstore/UsbSerialDrivers/modules/usbserial.ko -> Extracted from your pkg
/usr/lib/modules/usbserial.ko -> Copy of file above
Moonface
moonface
Post by moonface »
Jumbotroll,
I have tried to remove cp210x.ko and usbserial.ko from my system.
I have rebooted by NAS and install Domoticz package ....
Even with it, I have the following errors and the USB key is not recognized by Domoticz either :
[ 113.173539] cp210x: Unknown symbol usb_serial_generic_open (err 0)
[ 113.180477] cp210x: Unknown symbol usb_serial_generic_close (err 0)
[ 113.187697] cp210x: Unknown symbol usb_serial_deregister_drivers (err 0)
[ 113.195247] cp210x: Unknown symbol usb_serial_register_drivers (err 0)
[ 113.250909] pl2303: Unknown symbol usb_serial_handle_sysrq_char (err 0)
[ 113.258434] pl2303: Unknown symbol usb_serial_generic_open (err 0)
[ 113.265429] pl2303: Unknown symbol usb_serial_generic_close (err 0)
[ 113.272537] pl2303: Unknown symbol usb_serial_handle_dcd_change (err 0)
[ 113.279958] pl2303: Unknown symbol usb_serial_deregister_drivers (err 0)
[ 113.287475] pl2303: Unknown symbol usb_serial_handle_break (err 0)
[ 113.294504] pl2303: Unknown symbol usb_serial_generic_tiocmiwait (err 0)
[ 113.302052] pl2303: Unknown symbol usb_serial_register_drivers (err 0)
[ 113.369558] ch341: Unknown symbol usb_serial_generic_open (err 0)
[ 113.376445] ch341: Unknown symbol usb_serial_generic_close (err 0)
[ 113.383429] ch341: Unknown symbol usb_serial_handle_dcd_change (err 0)
[ 113.390834] ch341: Unknown symbol usb_serial_deregister_drivers (err 0)
[ 113.398273] ch341: Unknown symbol usb_serial_generic_tiocmiwait (err 0)
[ 113.405717] ch341: Unknown symbol usb_serial_register_drivers (err 0)
[ 113.466790] ti_usb_3410_5052: Unknown symbol usb_serial_deregister_drivers (err 0)
[ 113.476539] ti_usb_3410_5052: Unknown symbol usb_serial_generic_get_icount (err 0)
[ 113.496853] ti_usb_3410_5052: Unknown symbol usb_serial_generic_tiocmiwait (err 0)
[ 113.531618] ti_usb_3410_5052: Unknown symbol usb_serial_register_drivers (err 0)
Moonface
michaelb
Post by michaelb »
I've installed the latest beta for DMS6.1 with Python (domoticz_cedarview-6.1_3.0.8924-7) and it's running like clockwork!
However the time in Domoticz is 1 hour behind the time set on the NAS. I cannot find a setting for this but it puts my schedule off with one hour. Any fix for this?
Thanks for your excellent work Jumbotroll!
jumbotroll
michaelb wrote: Tuesday 20 February 2018 21:47 Hi,
Try to set your location in Setup -> latitude and longitude.
Jumbotroll
michaelb
Post by michaelb »
Strangely the location was set correctly but changing it twice did the trick. Thanks for the quick response!
Verstuurd vanaf mijn SM-J510FN met Tapatalk
teo1966
Domoticz version: 2025.1
Post by teo1966 »
Hello Jumbotroll
cant you for me make a domoticz package for this synology DS508 whit this soft/hardware DSM 4.0-2265 Freescale PowerQUICC III MPC8543 PPC
thanks
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
jumbotroll
teo1966 wrote: Saturday 24 February 2018 10:46 Hello Jumbotroll
thanks
Sorry, it is not possible to compile on that DSM version.
I did test to compile for DSM 4.0-2265 ppc854x, but it's to many errors and the toolchain/kernel is to old for that DSM version to build domoticz.
Jumbotroll
teo1966
Post by teo1966 »
jumbotroll wrote: Saturday 24 February 2018 12:08
thanks
thanks i donate 10 euro for all the work for now and in the future ;)
Release: 11
Codename: bullseye
jumbotroll
teo1966 wrote: Saturday 24 February 2018 12:42
Thanks! :)
Jumbotroll
jnoel68
Post by jnoel68 »
Hi Jumbotroll
Just upgraded to beta version (domoticz_x86-6.1_3.0.8975-7.spk), but it's clearly not working. I'm no more able to get any page (only a combobox at the top left corner of the page) .... so trying back to revert to stable version, but the synology package center doesn't allow me to rollback to this older version.
Any idea why ? How can I rollback to a stable version which is working fine ?
Thx for your help
jumbotroll
jnoel68 wrote: Wednesday 07 March 2018 9:52 Hi Jumbotroll
Thx for your help
Very strange! I use domoticz_x86-6.1_3.0.8975-7.spk on DS712+ here without any problem.
Try to clear your browser.
You can't roll back domoticz packages on synology, but you can take backup of database/script and reinstall to the stable package..
Jumbotroll
