domoticz in synology as package! Available now.
Ady92100
- Domoticz version: >V3.6796
Re: domoticz in synology as package! Available now.
Hello to everyone
Domoticz by Jadahl is running well on a syno DS212.
Every morning at 3:00 AM, domoticz do some kind of maintenance or something like that...
I can see that some threads (mainly with Darsky) are ended unexpectedly.
In most of the cases, Domoticz continue runnning well.
But it has happened that Domoticz stopped ===> So no more heating...... not good for the WAF.
So I was wondering if there is a command (or a bash program that I can automatically start after 3:00 AM) to
a) check that Domoticz is not running
b) if so, to start it
Many thanks for your help
Synology DS212 + RFXTrx433 + AEon Stick S2
Oregon - Thgr122Nx / Chacon - module 1000w - détecteur de fumée 34131 / OWL -CM180 / Greenwave Multiprise
- jumbotroll
1. What DSM version do you have on your NAS?Ady92100 wrote: Tuesday 06 February 2018 19:41 Hello to everyone
2. What domoticz version have you installed?
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
Ady92100
hello
version DSM = 6.1.5-15254
Stable version = V3.8143
- jumbotroll
Ok, I don't know if this will solve your problem, but you can always try the latest beta version.Ady92100 wrote: Tuesday 06 February 2018 21:12 hello
Take backup of your database and scripts if you have any and uninstall the stable version.
Manually download and Install the beta version and restore your database.
Latest beta I have compiled for DSM6.1x can be downloaded here: http://www.jadahl.com/domoticz_beta_6.1/
DS-212 use arch-88f6281
Jumbotroll
Jumbotroll
Ady92100
Ok Thanks
I will test and let you know
Ady92100
Hello again
I was also thinking to a bash script that will use the start-stop-status command after testing 'ps -ef | grep domoticz'
Do you know what is the syntax to run this command from a bash script ?
Feanor
Hi!
Python seems all right, no errors, but BatteryLevel is not shown in the hardware list. Any suggestions?
I am having exactly the same issues as John. In my case, I installed (rather copied, since missing apt-get on my Diskstation) Logread's BatteryLevel Plugin into a subfolder of /volume1/@appstore/domoticz/plugins and chmoded to 755. My log looks like this:johnnie wrote: Sunday 04 February 2018 20:06 Hi folks,
I’m facing a challange and hopefully somebody can point me in the right direction:
Installed the python spk and domoticz package with python on the NAS.
I want to install/use the SVT python plugin! Installed this with the help of the wiki.
But it doesn’t show up in the list!?
I see in the logging:
2018-01-31 20:36:28.601 Python EventSystem: Module not found - Trying to initialize.
2018-01-31 20:36:28.603 Python EventSystem: Initalizing event module.
Is there still something wrong?
At this moment I'm stuck (running circles), I've copied the plugin.py (manually, not with git command because I don't know how this works on synology), put it in the SVT directory under plugins (changed with chmod), restarted Domoticz. But still not able to see/select the plugin in the hardware list.....
Can somebody please help me in the right direction?
Tia, and best regards, John
2018-02-07 11:31:32.266 Domoticz V3.8153 (c)2012-2017 GizMoCuz
2018-02-07 11:31:32.267 Build Hash: 494fff7-modified, Date: 2017-07-30 12:19:41
2018-02-07 11:31:32.267 Startup Path: /usr/local/domoticz/
2018-02-07 11:31:32.504 EventSystem: reset all events...
2018-02-07 11:31:33.805 PluginSystem: Started, Python version '3.5.1'.
2018-02-07 11:31:34.075 WebServer(SSL) started on address: :: with port 8444
2018-02-07 11:31:34.078 Proxymanager started.
2018-02-07 11:31:34.111 TCPServer: shared server started...
2018-02-07 11:31:34.121 RxQueue: queue worker started...
2018-02-07 11:31:36.161 EventSystem: reset all events...
2018-02-07 11:31:36.163 EventSystem: reset all device statuses...
2018-02-07 11:31:36.170 DarkSky: Started...
2018-02-07 11:31:36.170 PluginSystem: Entering work loop.
2018-02-07 11:31:36.681 OpenZWave: using config in: /usr/local/domoticz/Config/
2018-02-07 11:31:36.719 OpenZWave: Starting...
2018-02-07 11:31:36.719 OpenZWave: Version: 1.4-2692-g3fc6967-dirty
2018-02-07 11:31:36.761 Python EventSystem: Module not found - Trying to initialize.
2018-02-07 11:31:36.764 Python EventSystem: Initalizing event module.
2018-02-07 11:31:36.765 EventSystem: Started
2018-02-07 11:31:37.247 OpenZWave: Driver Ready
2018-02-07 11:31:37.459 OpenZWave: Value_Added: Unhandled Label: Seismic Intensity, Unit: Thanks!
Gorefest
Any change there will be a beta version for my Synology 215+ to be able to handle my Xiaomi devices better?
I have added a Xiaomi gateway to my domoticz, its working except that I get "XiaomiGateway: unhandled model: sensor_motion.aq2" from my motion sensor. Or is there a possibility to manual add this device to domoticz?
- jumbotroll
You can download and manually install beta version from my website.Gorefest wrote: Friday 09 February 2018 11:30 Any change there will be a beta version for my Synology 215+ to be able to handle my Xiaomi devices better?
Your nas use arch-alpine4k
Jumbotroll
Jumbotroll
AllesVanZelf
- Domoticz version: 12467
Hi Jumbotroll,
Can you tell me what the difference is between:
http://www.jadahl.com/domoticz_beta_6.1_python/
and:
http://www.jadahl.com/domoticz_beta_6.1 ... 125.patch/
Bart
and:
Bart
- jumbotroll
It's a OpenZwave patch for Remotec ZRC-90 Scene Master.AllesVanZelf wrote: Friday 09 February 2018 21:49 Hi Jumbotroll,
and:
Bart
Read this: viewtopic.php?f=31&t=12539&start=20#p135154
Edit: All beta packages is now build with openzwave_1125.patch
Last edited by jumbotroll on Wednesday 14 February 2018 20:32, edited 1 time in total.
Jumbotroll
Jumbotroll
AllesVanZelf
Okay, thank you.
jeroenkl
Dear JumBotroll,
I'm missing the 6.1 armadaXP package, is has been removed. Which version should I use?
best regards,
Jeroen
best regards,
Jeroen
- jumbotroll
armadaxp for DSM 6.1 was lost in space, but now it's back againjeroenkl wrote: Sunday 11 February 2018 9:15 Dear JumBotroll,
best regards,
Jeroen
Jumbotroll
Jumbotroll
jeroenkl
you are great!jumbotroll wrote: Sunday 11 February 2018 11:58armadaxp for DSM 6.1 was lost in space, but now it's back againjeroenkl wrote: Sunday 11 February 2018 9:15 Dear JumBotroll,
best regards,
Jeroen![]()
hq007
- Domoticz version: 3.8153
@jumbotroll
I'm also having the same error with my Human body sensor 2 in the log, XiaomiGateway: unhandled model: sensor_motion.aq2
I'm running on a DS1512+
Version: 3.8153
Compile Date: 2017-07-30 12:19:41
Is there a beta version i can try to see if that would improve? btw great work so far!
Version: 3.8153
- jumbotroll
If you take a look on my website, you will find beta versions.hq007 wrote: Wednesday 14 February 2018 20:16 @jumbotroll
Version: 3.8153
Beta versions for DSM 6.1 you can download and install manually: http://www.jadahl.com/domoticz_beta_6.1/
BTW DS1512+ use arc-cedarview
Jumbotroll
Jumbotroll
hq007
super! that was what i was looking for, i already found the beta's but didnt know which package!jumbotroll wrote: Wednesday 14 February 2018 20:26If you take a look on my website, you will find beta versions.hq007 wrote: Wednesday 14 February 2018 20:16 @jumbotroll
Version: 3.8153
hq007
works like a charm now, super thanks!
moonface
Hello Jumbotroll,
I have a synology DS 918 + and i couldn’t find any working drivers in your website for my aeotec z stick s2 .
Is it possible for you to build appropriate drivers ?
Many thanks
Best regards
Moonface
Many thanks
Best regards
Moonface
