Posted: Friday 14 April 2017 7:07
After updating to latest beta V3.7320 I can detect all devices correctly
temperatures are read correctly,
but when I try to switch ON/OFF a Xiaomi Smart Plug nothing happens (no error, no switching on the plug)
I tried to follow troubleshooting guide by corbin and issue iptable commands but got following errors
[/url]
can the problem be related to some kernel/system version or configuration ?
I tried already several times to remove and add again the gateway after changing its LAN password and checking IP address
I'm running domoticz on raspberry pi 3 b updated to latest version of system
[/url]can the problem be related to some kernel/system version or configuration ?
2017-04-14 06:35:16.594 PROXY: Authenticate result: success.
2017-04-14 06:35:24.188 PROXY: Incoming connection from: 27.102.101.11
2017-04-14 06:39:35.803 User: Admin initiated a switch command (55/fancoil zona ufficio/On)
2017-04-14 06:39:35.954 (Gateway_negozio) Light/Switch (fancoil zona ufficio)
2017-04-14 06:40:30.249 User: Admin initiated a switch command (55/fancoil zona ufficio/Off)
2017-04-14 06:40:30.400 (Gateway_negozio) Light/Switch (fancoil zona ufficio)
2017-04-14 06:41:01.127 XiaomiGateway: stopped
2017-04-14 06:42:37.157 XiaomiGateway: will listen on 9898 for hardware id 11
2017-04-14 06:42:37.157 XiaomiGateway: Worker started...
2017-04-14 06:42:37.158 XiaomiGateway: Using 192.168.1.5 for local IP address.
2017-04-14 06:42:37.163 XiaomiGateway: RGB Gateway Detected
2017-04-14 06:42:37.163 XiaomiGateway: New Gateway Found (29b426a4/Xiaomi RGB Gateway)
2017-04-14 06:42:37.164 (Gwy_negozio) Lighting Limitless/Applamp (Unknown)
2017-04-14 06:42:37.167 XiaomiGateway: New Switch Device Found (29b426a4)
2017-04-14 06:42:37.167 (Gwy_negozio) Light/Switch (Unknown)
2017-04-14 06:42:37.171 XiaomiGateway: New Switch Device Found (29b426a4)
2017-04-14 06:42:37.171 (Gwy_negozio) Light/Switch (Unknown)
2017-04-14 06:42:37.175 XiaomiGateway: New Switch Device Found (29b426a4)
2017-04-14 06:42:37.175 (Gwy_negozio) Light/Switch (Unknown)
2017-04-14 06:42:37.179 XiaomiGateway: New Switch Device Found (29b426a4)
2017-04-14 06:42:37.180 (Gwy_negozio) Light/Switch (Unknown)
2017-04-14 06:42:37.183 XiaomiGateway: New Switch Device Found (29b426a4)
2017-04-14 06:42:37.183 (Gwy_negozio) Light/Switch (Unknown)
2017-04-14 06:42:37.593 {"cmd":"read_ack","model":"sensor_ht","sid":"158d00010f2abd","short_id":212,"data":"{\"voltage\":3035,\"temperature\":\"2064\",\"humidity\":\"4843\"}"}
2017-04-14 06:42:37.593 (Gwy_negozio) Temp (Xiaomi Temperature)
2017-04-14 06:42:37.595 (Gwy_negozio) Humidity (Xiaomi Humidity)
2017-04-14 06:42:37.693 XiaomiGateway: New Switch Device Found (010c5930)
2017-04-14 06:42:37.693 (Gwy_negozio) Light/Switch (Unknown)
2017-04-14 06:42:37.697 {"cmd":"read_ack","model":"plug","sid":"158d00010c5930","short_id":43823,"data":"{\"voltage\":3600,\"status\":\"off\",\"inuse\":\"0\",\"power_consumed\":\"83964\",\"load_power\":\"0\"}"}
2017-04-14 06:42:37.798 XiaomiGateway: New Switch Device Found (0125938d)
2017-04-14 06:42:37.798 (Gwy_negozio) Light/Switch (Unknown)
2017-04-14 06:42:37.801 {"cmd":"read_ack","model":"plug","sid":"158d000125938d","short_id":62008,"data":"{\"voltage\":3600,\"status\":\"off\",\"inuse\":\"0\",\"power_consumed\":\"14732\",\"load_power\":\"0\"}"}
2017-04-14 06:42:37.902 XiaomiGateway: New Switch Device Found (01104c2a)
2017-04-14 06:42:37.902 (Gwy_negozio) Light/Switch (Unknown)
2017-04-14 06:42:37.905 {"cmd":"read_ack","model":"plug","sid":"158d0001104c2a","short_id":25300,"data":"{\"voltage\":3600,\"status\":\"off\",\"inuse\":\"0\",\"power_consumed\":\"31895\",\"load_power\":\"0\"}"}
2017-04-14 06:42:37.906 {"cmd":"read_ack","model":"sensor_ht","sid":"158d00015b2ef7","short_id":42729,"data":"{\"voltage\":2985,\"temperature\":\"2067\",\"humidity\":\"4896\"}"}
2017-04-14 06:42:37.905 (Gwy_negozio) Temp (Xiaomi Temperature)
2017-04-14 06:42:37.908 (Gwy_negozio) Humidity (Xiaomi Humidity)
2017-04-14 06:42:38.006 XiaomiGateway: New Switch Device Found (010dd9e8)
2017-04-14 06:42:38.006 (Gwy_negozio) Light/Switch (Unknown)
2017-04-14 06:42:38.010 {"cmd":"read_ack","model":"plug","sid":"158d00010dd9e8","short_id":34536,"data":"{\"voltage\":3600,\"status\":\"off\",\"inuse\":\"0\",\"power_consumed\":\"79632\",\"load_power\":\"0\"}"}
2017-04-14 06:59:49.045 User: Admin initiated a switch command (55/fancoil zona ufficio/On)
2017-04-14 06:59:49.196 (Gwy_negozio) Light/Switch (fancoil zona ufficio)
2017-04-14 07:00:06.827 User: Admin initiated a switch command (55/fancoil zona ufficio/Off)
2017-04-14 07:00:06.978 (Gwy_negozio) Light/Switch (fancoil zona ufficio)
