- DewGew
- Domoticz version: V4.10618
Re: Dashticz v2.0, custom positioning and multiple screens
Updated swedish langauage file for last update 2017-04-20
- sv_SE.zip
- (690 Bytes) Downloaded 69 times
- EdwinK
- Domoticz version: BETA
I do have a Nexus 7 (old model) somewhere. Now, let's look that up and see if it still works.mlamie wrote: I use Chrome (full screen) on my Nexus 7 tablet. If you select add to home screen in the Chrome menu, a shortcut will be created, via this shortcut the address bar is not given. Secondly I use Power Toggles and enable Immersive mode which will hide the Android top bar and on screen buttons.
robgeerts
- Domoticz version: 3.7067
In console, there's a network-tab.freakshock wrote: No errors unfortunately.. only this output but I think that's not related to this problem:Code: Select all
index.html#1:8 Error parsing a meta element's content: ';' is not a valid key-value pair separator. Please use ',' instead. jquery.min.js:4 Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
If you click on the block wich opens the graph, you can see it calls an url... If you click on it, you see the output, what does it say?
\whiteduck wrote: In the attachment Chrome is on the left and while the available browser window size is different due to the headers I notice in Safari (on the right) I lose the bottom of the window and cannot scroll down to see it - looks like the window size is not being correctly picked up. Not a major issue but just wanted to let you know.
Well, the dashboard doesnt fit everything on the screen automatically..
You have to rearrange this to fit your screen on the device you will be using mainly.
Scrolling has been disabled because this conflicts with the slide function.
Try latest version!bierlaagh wrote: I have an UV meter, which gives the following output:
what do i have to change to replace On/off to the output (0.0 in this case)
Thanks, updated in latest version!DewGew wrote:Updated swedish langauage file for last update 2017-04-20
- gielie
- Domoticz version: latest β
Hi Rob,
Is there a problem with the "news" button, RSS feed?
I also created a second news item
But this doesn't work either.
Is this a common thing or local?
blocks['news_2'] = {}
blocks['news_2']['feed'] = 'http://feeds.feedburner.com/tweakers/nieuws';Is this a common thing or local?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
- htilburgs
See the several questions about the same in the previous posts, with al the same answer.gielie wrote:Hi Rob,
I also created a second news itemBut this doesn't work either.Code: Select all
blocks['news_2'] = {} blocks['news_2']['feed'] = 'http://feeds.feedburner.com/tweakers/nieuws';
Also noted on the Dashticz v2.0 wiki (http://www.domoticz.com/wiki/Dashticz-v ... Parameters)
REMARK: In some cases the Newsfeed wouldn't load and you get NO results.
You have to put https://crossorigin.me/ before the newsfeed-url, like:
blocks['news_2']['feed'] = 'https://crossorigin.me/http://feeds.feedburner.com/tweakers/nieuws';Hardware:
Nautilus
As this is already buried several pages back I'll post it again here in the hopes of getting feedback
1. I noticed the iframe block only grows in width (like the other blocks) where as to be able to fill the block nicely it would also need to grow in height - like for example the web camera block. Is this perhaps something that could be achieved with the custom.css or do you think it might be a good idea to implement this kind of behavior as default? I assume most use cases would benefit form this as otherwise the ratio of the block changes which (in most cases?) makes the iframe source look a bit funny.
2. When trying to fit stuff on my old (wall-mounted) iPad 2 I was thinking the "currentweather_big" takes a bit too much space. What would be the best way to make this a somewhat smaller, some custom.css approach perhaps?
- gielie
I see it now, sorry for the double question.htilburgs wrote: See the several questions about the same in the previous posts, with al the same answer.
- FIBARO FGS223
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
DarkAllMan
I want to create a custom screen. How do I add the Scene Switches?
- HansieNL
It is possible to add the idx for scenes AND groups as:DarkAllMan wrote:I want to create a custom screen. How do I add the Scene Switches?
s1, so for example, to add a scene or group with idx 1 and a lamp with idx 1:
columns[1]['blocks'] = ['s1',1]
Blah blah blah
maluko
HansieNL wrote:It is possible to add the idx for scenes AND groups as:DarkAllMan wrote:I want to create a custom screen. How do I add the Scene Switches?
Before you have to declare the scene in block
var blocks = {}
blocks['s1'] = {}
blocks['s1]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks['s1']['title'] = 'Living room' //if you want change the name of switch different then domoticz
blocks['s1']['icon'] = 'fa-eye'; //if you want an other icon instead of the default, choose from: http://fontawesome.io/cheatsheet/
blocks['s1']['image'] = 'bulb_off.png'; //if you want to show an image instead if icon, place image in img/ folderCode: Select all
http://www.domoticz.com/wiki/Dashticz-v2- rbisschops
- Domoticz version: 2.2563
@robgeerts:
Herewith some bugs and observations I noticed on the latest version (downoad at 19:15 today).
Bug: The new screen button has a little deviation in the selection on the + button. Only a part of the button is clicable (possibly some css error with margin or padding?)
Observation: The graph for gas and electricity are showing the value in the header as 1.650 m3 and 7.585 kWh). This should be coma seperated. Gas should be annotated as 1,650 m3. I know Domoticz is also not using localisation, so the problem might be comming from Domoticz
Obeservation/bug: graphs are showing a different annotation when hovered over the datapoints. E is using 0,0 and G 0.0. Water in my case is completely of. Should be in Liters (as is the header), now showing liters/1000. Might be that this is best set as a config item for the various types of water measurement.
Thanks again,
Ralph
Thanks again,
Ralph
RPi 3B (master): RFXtrx433, Harmony Hub, Z-Wave devices, CoCo units, Hue, Xiaomi Aquara
RPi 2B (slave): P1 connection, MySensors with custom built watermeter sensors on Aquadis+
RPi’s with: Mosquitto MQTT, Home Bridge, Home Assistant (for evaluation only)
Rob, do you know what causes this? Can we except a bugfix?
+I think whole bug reporting would be easier to follow if you migrate the project to GitHub and we can use GitHub's Issues page.
robgeerts
Will check some things tonight or tomorrow. @madrian, the bug is caused by your scriot when having more then 1 thermostats. I can look into this.
Ahh thanks!robgeerts wrote:Will check some things tonight or tomorrow. @madrian, the bug is caused by your scriot when having more then 1 thermostats. I can look into this.
And what about the graphical issue? The corners of the buttons are not clickable + icons are flashing. In original submit they functioned properly, but your buttons are much nicer.
+look what I found:
Combined device idea (Temp+Hum+Baro):
We should show combined blocks with a _combined suffix, example:
columns[4]['blocks'] = ['blocktitle_2',48,'24_combined'].
What do you think?
What do you think?
- EdwinK
If that is possible, that would be great for some devices
- mvveelen
Finally I managed to get some switches on the screen. I'm far from finished and I have some questions:
- whatever I try, I don't get the RSS news feed
- somehow the city 'Hoorn' isn't recognised. Hence I didn't get any weather info, so I'll pick a city nearby (...)
- How can I change every single switch-name when I have:
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Schakelaars';
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1','s1','s2',15,507,508,509,547,778,779,1179,1186,1461,1475,1529,1571,1815,2178,2179]
columns[1]['width'] = 5;
robgeerts
They are not flashing at my dashboard...madrian wrote: And what about the graphical issue? The corners of the buttons are not clickable + icons are flashing. In original submit they functioned properly, but your buttons are much nicer.
Anyone else with this problem? Maybe its because it is reloading the block every x seconds...
Will fix asap!madrian wrote: +look what I found:
It's nice but I dont think it fits well for smaller screens... ?madrian wrote:Combined device idea (Temp+Hum+Baro):
You have to add 'news_2' to the block-definitions like:mvveelen wrote: - whatever I try, I don't get the RSS news feed
var blocks = {} blocks['blocktitle_1'] = {} blocks['blocktitle_1']['type'] = 'blocktitle'; blocks['blocktitle_1']['title'] = 'Schakelaars'; blocks['news_2'] = {} blocks['news_2']['feed'] = 'https://crossorigin.me/http://feeds.feedburner.com/tweakers/nieuws'; var columns = {} columns[1] = {} columns[1]['blocks'] = ['blocktitle_1','s1','s2',15,507,508,509,547,778,779,1179,1186,1461,1475,1529,1571,1815,2178,2179] columns[1]['width'] = 5;
columns[1]['blocks'] = ['blocktitle_1','news_2','s1','s2',15,507,508,509,547,778,779,1179,1186,1461,1475,1529,1571,1815,2178,2179]
blocks[15] = {}
blocks[15]['title'] = 'Vet Dashboard';
var blocks = {}
blocks[15] = {}
var columns = {}
columns[1] = {}
robgeerts
Added to my todolist at:Nautilus wrote:As this is already buried several pages back I'll post it again here in the hopes of getting feedback
https://trello.com/b/qsNqHtie/dashboard
Just submitted a cosmetic bugfix: change switch's title/status position as it is for all other devices (first is status, second row is title).
Rob: maybe you are right, I am always thinking in tablet screen. Maybe we should create a poll about screen sizes?
