Page 61 of 66
Posted: Saturday 28 January 2017 18:49
by EdwinK
Yup... I see the following:
It's looking for '192.168.1.102', but I don't have that ip-address, and I can't find in what file it does call this.
Posted: Saturday 28 January 2017 22:57
by G3rard
The 192.168.1.102:8084 is from my Domoticz settings. That means you haven't changed that in frontpage_settings.js.
So change that
line to your Domoticz settings and that should work.
The 192.168.1.1 for the videostream is in line 290 of frontpage.html. So you can change that as well (or remove it).
Check this
readme instruction .
Posted: Saturday 28 January 2017 23:03
by G3rard
Trigun wrote:
Hi G3rard,
I was looking at this post and this is exactly what I would like to use.
I am able to control the sonos via HTTP but I can't get it to work with the PHP option in G3rards files.
perhaps you can help me out here?
maybe a noob question but how do I install the PHP server on the Domoticz Pi?
Thanks in advance!
Kind regards,
Is your question regarding installing PHP on a Pi? Then check
this.
If you have any questions regarding the config of the Sonos files, then show some more info on your setup and what is not working.
Posted: Saturday 28 January 2017 23:13
by G3rard
hpapagaj wrote:G3rard wrote:@hpapagaj,
Can you try this
var d = ((level + 10)/100 * 32) + 0.5;
Super it's working now.
Thank you!
Little glitch that one step is 6% instead of 3% (like in Domoticz):
50 to 56:
plus 50
in plus 19.7 50
SUCCES
56 to 62:
plus 56
in plus 21.62 56
SUCCES
Then just try to change the formula until it works for you.
Something like
var d = ((level + 10)/100 * 31) + 0.3;
should do the trick.
Posted: Sunday 29 January 2017 10:42
by EdwinK
G3rard wrote:The 192.168.1.102:8084 is from my Domoticz settings. That means you haven't changed that in frontpage_settings.js.
So change that
I had it changed. See below
// #### vvvvv USER VALUES below vvvvv #######
$(document).ready(function() {
$.roomplan=0; // define roomplan in Domoticz and create items below.
$.domoticzurl="http://192.168.0.10:8084";
//format: idx, value, label, description, lastseen(1 when lastseen is wanted, 2 is only time), plusmin button or protected (0 for empty, 1 for buttons, 2 for volume of Sonos, 4 for protected, 5 for zwave dimmer, 6 for protected when on), [override css], [alarm value]
$.PageArray = [
Check this
I had this line commented out with <!-- -->, but somehow that line was still being executed.
Posted: Sunday 29 January 2017 13:09
by G3rard
My guess would be that you have 2 frontpages and changed the settings in one of them, but open the other.
Because the log shows that it tries to open 192.168.1.102:8084 and that URL is only present in frontpage_settings.js.
https://github.com/gerard33/frontpage/s ... .168.1.102
Same applies for frontpage.html. Because if you have commented that line out, it will not try to open the url.
Posted: Sunday 29 January 2017 20:47
by EdwinK
That might have be the problem, because now it isn't trying to connect to the cam's anymore.
Posted: Monday 30 January 2017 16:37
by RobvdB
I've been busting my balls over this one. I have Gerards frontpage on an old ipad on the wall. all works like a charm, except for one wish. I have two camera's in screen 1 and 2, cell 3 and cell 2_3. I get a still image from these camera's, but what i want is a moving image. Adding in the stream URL does not work, and I think it never will due to lack of codec support on the ipad.
My question; how and where can I add a script of some kind to refresh the image every second. Or at least refresh when I tap it?
I've tried to add the below code in frontpage.js, but no luck:
function updateCamera() {
var d = new Date();
var t = d.getTime();
document.getElementById("popup_camera").src="http://<IPADDRESS>/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=******&pwd=********&"+t;
document.getElementById("popup_camera3").src="http://<IPADDRESS>/snapshot.cgi?user=*****&pwd=*****&"+t;
setInterval(updateCamera,1000);
Hope someone can help me with this, since I'm going crazy
Posted: Tuesday 31 January 2017 21:48
by ropske
hi, anyone using setpoint in this FrontPage?
I'm just wondering if it's also taking some seconds with you guys when it changes state? guess 2-3 seconds
so when i want to go from 16degrees to for example 20degrees, this takes long
i'm going up/down by steps off 0.5degree so i need to press 8 times on the temp up button (8x2sec = 16sec)
Posted: Wednesday 01 February 2017 9:07
by RobvdB
I'm using it. The same issue here too. The frontpage refreshes every few seconds, and in addition the path for an update of your setpoint is frontpage > domoticz > Nest cloud > domoticz > frontpage. So that adds some extra time.
As a suggestion it could be handy to open a small popup, set the value you want locally in frontpage, and then update accordingly. But I lack the skills to code that I'm afraid
Posted: Wednesday 01 February 2017 21:52
by ropske
yeah, like the popup-window now in domoticz when you change a setpoint
Posted: Sunday 05 February 2017 8:09
by franzelare
I like to add some graphs to my frontpage, anyone who knows how to do that? like by using the highcharts function that domoticz web interface is using?
Posted: Sunday 05 February 2017 14:22
by EdwinK
I thought I read a fix somewhere in this topic, but can't find it anymore.
What happens is that one of the cell 2_3 I'm using for one of my Pi's (LMS). The title of the playing song is just going all over the place. (see image)
image post
How can I fix this so that it is just in one cell? Btw.. it was just a random music-list playing
Posted: Monday 06 February 2017 14:26
by ErwinWes
Hi guys,
I see a lot of stuff what I can do with domoticz.
At this moment the only thing that I want is show the outside sensors (wind, rain, temp, etc.)
The only thing that I want is that the graphs are automatically made for use on websites.
How can I do that?
I make use of my Synology NAS in combination with the RFlink 868 mhz receiver.
Thanks for any answer.
Posted: Monday 06 February 2017 20:54
by barbaar
Right.. Has anyone succeeded with displaying a group?
I have entered the group into the roomplan, and added the line below to frontpage_settings.js:
['1','Status', 'cell11', 'Licht Beneden','1','0'],
The IDX is correct for sure..
But, the cell in Chrome stays empty. When I inspect the element, I get the following error:
Uncaught TypeError: Cannot read property 'length' of undefined
at Object.<anonymous> (frontpage.js:954)
at Function.each (jquery.min.js:4)
at Object.success (frontpage.js:953)
at c (jquery.min.js:4)
at Object.fireWith [as resolveWith] (jquery.min.js:4)
at k (jquery.min.js:6)
at HTMLScriptElement.n.onload.n.onreadystatechange (jquery.min.js:6)
Line 954 of frontpage.js is:
for( var ii = 0, len = $.PageArray_Scenes.length; ii < len; ii++ ) {
Any help would be appreciated!
Posted: Monday 06 February 2017 21:07
by ropske
anyone that can help us please?
ropske wrote:hi, anyone using setpoint in this FrontPage?
Posted: Tuesday 14 February 2017 22:29
by ubfssF
barbaar wrote:Right.. Has anyone succeeded with displaying a group?
What works for me is:
$.PageArray_Scenes = [
['2','Status', 'cell14', 'Thuis werken','0','0'],
['1','Status', 'cell15', 'HiFi systemen','0','0'],
Posted: Wednesday 15 February 2017 15:27
by barbaar
Works! Great, thanks!
Posted: Tuesday 21 February 2017 16:34
by Ewaldharmsen
I cannot get it to work.
Add a room, it got IDX 2
Extracted the file two times to get the frontpage.html
Edited line 250 to $.roomplan=2; That is the IDX of the "Ruimte" right?
Edited line 251 to $.domoticzurl="
http://192.168.0.116:8080";
Edited line 264 to ['3', 'UVI', 'cell21', 'UV straling (UVI)', 'color:orange', '>4'], as a test
Copied the file to the domoticz/www folder
browsed to 192.168.0.116:8080/frontpage.html, but no numbers there just the plain picture.
http://192.168.0.116:8080/json.htm?type=devices&plan=2 gives me the data I expected
What is going wrong?
Posted: Tuesday 21 February 2017 16:37
by Ewaldharmsen
Ah Room needs to be 0
