FlatZ Frontpage
Re: FlatZ Frontpage
Yes! They were all Axis camera's so after investigation I found that adding /mjpg/1/video.mjpg tot the IP and port it works!
- Domoticz version: V4.11375
Re: FlatZ Frontpage
Its seems that the weather is offline. I have nothing on the weathertab? It did work.
Are there others with the same issue?
Re: FlatZ Frontpage
Yes nothing on that page. I think a better solution is the we can put other weather items on the page, a bit like the camera page.SwordFish wrote:Its seems that the weather is offline. I have nothing on the weathertab? It did work.
- galadril
- Domoticz version: latest
Re: FlatZ Frontpage
Seems like the openweathermap now requires an apikey..SwordFish wrote:Its seems that the weather is offline. I have nothing on the weathertab? It did work.
http://openweathermap.org/faq#error401
You could switch to the yahoo weather api by changing the next lines in the weather.html:
api: "yahoo", //default: openweathermap (openweathermap or yahoo)
Re: FlatZ Frontpage
Guys,
Is it possible to make the used icons (and maybe other items too) unique compared to domoticz? Just had a conflict that messed up the regular domoticz energy graphs when copying the frontpage to my server. see http://www.domoticz.com/forum/viewtopic.php?f=6&t=8486
- galadril
Re: FlatZ Frontpage
Thanks for the heads up, ill look into thisSweetPants wrote:Guys,
- galadril
Re: FlatZ Frontpage
I've changed some thing for:
- better mobile view / navigation
- Push On buttons for the Switch panel
- Domoticz version: 4.10538
Re: FlatZ Frontpage
Nice development, is it possible to create a gui to configure this dashboard and integrate it into a standard Domoticz delivery?
Re: FlatZ Frontpage
@galadril
Are still working on adding scenes to the frontpage? I really mis that right now.
Edit;
Edit;
Problem solvedAnother question, i can open de the domoticz dahboard on my iphone from outside the house (on 3G/4G) but when i try to open frontpage it won't load the data?
Is there something that I mis?
Re: FlatZ Frontpage
Love this theme.Thank you.
Started updating and playing with the css forked a copy to add date (not sure if that was the right thing to do?)
Working on a couple of themes for this and some tweeks to the dimmer functions
- galadril
Re: FlatZ Frontpage
Great!bluepi wrote:Started updating and playing with the css forked a copy to add date (not sure if that was the right thing to do?)
So you made a new branch ?
Re: FlatZ Frontpage
And maybe put in scenes
- galadril
Re: FlatZ Frontpage
so 'graph1' matches with the id of the div above h4 cell7 in the graph.html?lukev wrote:I'm almost there... I suppose...
I can give this http command:
which results in this output (shortened...)Code: Select all
http://192.168.1.153:8084/json.htm?type=graph&sensor=counter&method=1&idx=139&range=day
I've set up this line in settings.js:Code: Select all
{ "d" : "2015-11-03 21:05", "eu" : "11583", "r1" : "0", "r2" : "0", "v" : "1164", "v2" : "96" }, { "d" : "2015-11-03 21:10", "eu" : "11820", "r1" : "0", "r2" : "0", "v" : "2844", "v2" : "0" }, { "d" : "2015-11-03 21:15", "eu" : "12074", "r1" : "0", "r2" : "0", "v" : "3048", "v2" : "0" }, { "d" : "2015-11-03 21:20", "eu" : "12314", "r1" : "0", "r2" : "0", "v" : "2880", "v2" : "0" }, { "d" : "2015-11-03 21:25", "eu" : "12381", "r1" : "0", "r2" : "0", "v" : "804", "v2" : "0" } ], "status" : "OK", "title" : "Graph counter day" }
But there is no output whatsoever....Code: Select all
// Graph screen User settings >>> (max 3 on screen) //format: idx, value (from json), replace label, description, chart label, chart color $.GraphTemperatureArray = [ //graph screen (3 fields) ['139', 'counter&method=1', 'day', 'cell7', 'Stroomverbruik (Watt)', 'graph1', '#b2c831', 'v'],
for me:
<!-- DONUT CHART -->
<div class="col-sm-3 col-lg-3 largemobilefix" >
<div class="dash-unit" style="height:190px;">
<dtitle id="desc_cell7"></dtitle>
<hr>
<div id="graph100" style="height: 13em;margin: auto;margin-top: -17px"></div>
<h4 id="cell7" style="margin-top:-35px;></h4>
<span class=" text" id="cell70" style="margin-top:-5px;float:right;padding-right:10px;font-size: 10px;color: #9E9E9E; "/>
</div>
</div>
['58', 'counter&method=1', 'day', 'cell7', 'Zonnepanelen (Watt)', 'graph100', '#b2c831', 'v'],
- So the div (<div id="graph100") gets the graph
- cell7 gets the description text
- galadril
Re: FlatZ Frontpage
Thanks for reminding meSwordFish wrote:And maybe put in scenes
I've put FlatZ frontpage on github, so you could help me on implementing scenes...
Re: FlatZ Frontpage
I really want to help. But I have no codingsskillsgaladril wrote:Thanks for reminding meSwordFish wrote:And maybe put in scenes
- galadril
Re: FlatZ Frontpage
I've added scenes / groups.SwordFish wrote:I really want to help. But I have no codingsskills
https://github.com/galadril/FlatZ-Frontpage
You can add them as switch:
['1', 'Status', 'cell111', 'Group Example', 'group'],
['1', 'Status', 'cell111', 'Scene Example', 'scene'],
hope you like it
Re: FlatZ Frontpage
Thanks very much. I will try this when I get homegaladril wrote:I've added scenes / groups.SwordFish wrote:I really want to help. But I have no codingsskills
hope you like it
Re: FlatZ Frontpage
Its works verry well. But i noticed that you had the url to the icons up and down for the ventilation changed in the methods.js.
Is it possible to give the "buttons" for the scene when they are off the same color as the button from the switch when they are off?
Now is the color the same as the on button from the switch.
And is het possible to cut cell7 in 2 so that you can have humanity and temp of the same room under each other?
But again thanks for adding scenes to the frontpage.
Re: FlatZ Frontpage
Thanks for the great work!
Is there any way I can make another page containing info? As a user of public transport, I would rather use real time status on my nearest tram/metro stop, then traffic.
The site url: http://mon.ruter.no/monitor/3010512/Sch ... imdalsgata
Thanks for any suggestions!
- Domoticz version: 3.4834
Re: FlatZ Frontpage
I am trying to add a page for my Evohome room temperatures.
I made an extra page, witch is called "Temperature". I have 6 temperatur blocks, just like in the frontpage (donut chart).
In the frontpage it is used for "woonkamer".
But i can't get any data in the blocks.
Does anyone have an idea? I made a temperature.html and i changed the settings.js.
- FlatZ-Frontpage-master.zip
- (6.33 KiB) Downloaded 120 times
Last edited by markiemajax on Monday 16 November 2015 23:47, edited 2 times in total.
