Page 7 of 8
Re: SolarEdge production throttling from Domoticz
Posted: Wednesday 13 August 2025 12:47
by 1kke
gizmocuz wrote: Wednesday 13 August 2025 12:39
This is quite odd as there is no reference to 3.11 in the Dockerfile... 3.13 should be installed
This is what I find in the container (:beta):
sh-5.2# cd /usr/lib
sh-5.2# ls
apt dpkg git-core init locale lsb mime os-release
python3.11 sasl2 ssl systemd terminfo tmpfiles.d udev x86_64-linux-gnu+
Posted: Wednesday 13 August 2025 14:05
by gizmocuz
Could you try the new docker version? Went back to Python 3.11-slim image
Posted: Wednesday 13 August 2025 14:15
by eddieb
It works again with the new image
Posted: Wednesday 13 August 2025 14:16
by 1kke
yes, pulled the :beta again (Version: 2025.1 (build 16758)
Build Hash: 79e16c172) and it's working for me also.
Posted: Wednesday 13 August 2025 14:31
by gizmocuz
Thanks for the feedback! Aldo I am happy about this... It is strange that when using the Docker image python:slim (which uses python 3.13) it does not work...
Posted: Wednesday 13 August 2025 17:37
by eddieb
tnx for fixing this @gizmocuz
Posted: Wednesday 13 August 2025 22:05
by 1kke
Weird thing is, I've build the image locally:
git clone https://github.com/domoticz/domoticz-docker.git
cd domoticz-docker
changed the Dockerfile:
FROM python:slim
and libpython3.9-dev to libpython3.13-dev
docker build -t domoticz:local .
and everything is running fine:
# ls /usr/local/bin
docker-entrypoint.sh idle3 normalizer pip3 pydoc pydoc3.13 pymodbus.server pyserial-miniterm python python3 python3.13
idle idle3.13 pip pip3.13 pydoc3 pymodbus.console pymodbus.simulator pyserial-ports python-config python3-config python3.13-config
Posted: Thursday 04 September 2025 16:06
by eddieb
jvdz wrote: Sunday 22 June 2025 10:28
Just have a look at my first post in this thread which is updated with the latest Status.
I don't know if you can run multiple instances of the plugin on your setup, but i couldn't and had to add any extra docker container that performs the role of modbus proxy after which i can run multiple.
For each change you will have to Perform the pip command to update the docker with the requirement.txt content.
I have added the required command to customstart.sh :
pip3 install -r /opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/requirements.txt
so it is done with each creation of the domoticz container.
I am hoping that somebody with an battery installation can give me some feedback on the MetersDev branch whether or not those Selector switched work and are usefull.
I just today bumped on the 2 pollers to 1 modbus...
Can you share the docker compose yml for docker proxy ? The stuff I found does not work
Posted: Thursday 04 September 2025 22:18
by jvdz
Think it was pretty strait forward to get it to work for me.
This is what I use currently:
IPaddresses:
SolarEdge : 192.168.0.10
Host Docker Domoticz&proxy: 192.168.0.20
Docker modbusproxyYAML
services:
modbusproxy:
image: modbus-proxy:latest
container_name: modbusproxy
restart: unless-stopped
ports:
- 5020:502
volumes:
- /data/docker/modbusproxy/modbus-proxy.yml:/config/modbus-proxy.yml
File: /data/docker/modbusproxy/modbus-proxy.yml
devices:
- modbus:
url: 192.168.0.10:502
listen:
bind: 0:502
Domoticz SOLAREDGEMODBUS PLUGIN setting:
Inverter IP Address:192.168.0.20
Inverter Port Number: 5020
Posted: Friday 05 September 2025 6:57
by eddieb
needed to modify the compose.yaml a bit to run in dockge on my rpi5
services:
modbusproxy:
build: https://github.com/tiagocoutinho/modbus-proxy.git
ports:
- 1502:1502
volumes:
- /opt/stacks/modbusproxy/:/config/
networks: {}
seems to run, going to test now
Posted: Friday 05 September 2025 7:50
by michealabroy
You can monitor SolarEdge production in Domoticz, but throttling (limiting output) usually isn't supported directly. It depends on your inverter and API access.
Posted: Friday 05 September 2025 7:57
by eddieb
the above compose.yaml for dockge works on rpi5
I am using the modbus-proxy.yml below to test
devices:
- modbus:
url: 192.168.0.10:1502
listen:
bind: 0:1502
logging:
version: 1
formatters:
standard:
format: "%(asctime)s %(levelname)8s %(name)s: %(message)s"
handlers:
console:
class: logging.StreamHandler
formatter: standard
root:
handlers: ['console']
level: DEBUG
Posted: Friday 05 September 2025 8:00
by jvdz
michealabroy wrote: Friday 05 September 2025 7:50
It should work with this version of the plugin or are you having issues? It is not using the local web/api but the modbus interface of the solaredge inverter.
Posted: Sunday 12 October 2025 12:35
by hjzwiers
I replaced the old version 'domoticz-solaredge-modbustcp-plugin.2.0.4' with the new version 'domoticz-solaredge-modbustcp-plugin-MetersDev' ran the requirements file but now I think I have new versions of the devices in the overview, how do I recognize the old version so I can delete them?
I have an 3 phase inverter with 23 kw batteries and was seeing some errors concerning the metering, so I though why run the newer version.
Anyone have this problem?
Posted: Sunday 12 October 2025 13:23
The ones not being updated anymore are the old ones. Should be noticable on the last seen date being old.
Posted: Sunday 12 October 2025 13:56
by hjzwiers
I deleted them all and add to the devices through a restart and the hardware switch.
Posted: Sunday 12 October 2025 22:43
by hjzwiers
I still get errors with the meters, its once a day. I have no idea where it is coming from:
2025-10-12 20:51:25.902 Error: SolarEdge ModbusTCP: Call to function 'onHeartbeat' failed, exception details:
2025-10-12 20:51:25.903 Error: SolarEdge ModbusTCP: Traceback (most recent call last):
2025-10-12 20:51:25.903 Error: SolarEdge ModbusTCP: File "/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin-MetersDev/plugin.py", line 928, in onHeartbeat
2025-10-12 20:51:25.903 Error: SolarEdge ModbusTCP: _plugin.onHeartbeat()
2025-10-12 20:51:25.903 Error: SolarEdge ModbusTCP: File "/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin-MetersDev/plugin.py", line 258, in onHeartbeat
2025-10-12 20:51:25.903 Error: SolarEdge ModbusTCP: meter = self.inverter.meters()[device_name]
2025-10-12 20:51:25.903 Error: SolarEdge ModbusTCP: ~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^
2025-10-12 20:51:25.903 Error: SolarEdge ModbusTCP: KeyError: 'Meter1'
2025-10-12 21:52:50.270 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection::start
After the error the system just goes on as usual
Posted: Sunday 12 October 2025 22:52
by jvdz
I will have a look tomorrow to see what it could be. Assume you have a battery as it is trying to work with the meters info?
Posted: Sunday 12 October 2025 22:57
by hjzwiers
Yes i have a SE10K inverter with 5 battery units and a SolarEdge meter in the electrical cabinet, I appreciate the help. i am running: domoticz-solaredge-modbustcp-plugin-MetersDev, and requirements.txt is run from within docker (and in the customstart.sh).
I just ran this version due to the newer files for the meters, which functionality does it have which is newer?
Posted: Monday 13 October 2025 7:21
by jannl
I think I have a similar issue with the 'original' plugin. I realized it can have something to do with the timing settings in the hardware tab.
Not tested yet
