Page 7 of 14
Re: NEST Account migration
Posted: Monday 24 February 2020 19:02
by Ptje
When I start it manual, I get
pi@raspberrypi:/ $ /home/pi/nest-api/get_nest.sh
/home/pi/nest-api/get_nest.sh: line 28: php: command not found
What does that mean ?
Posted: Monday 24 February 2020 19:19
by heggink
rolandbreedveld wrote:heggink wrote: ↑Sunday 23 February 2020 20:52
My cookie expired a couple of days ago. I now check so I can get the new cookie as soon as it expires. Took a few weeks...
Sent from phone.
I started it on 16-jan and never had to change the cookie, perhaps if the system is not running for a while, the cookie and or token will become invalid.
Weird. My system is in 24/7 but it still logged me out 5 days ago...
Sent from phone.
Posted: Monday 24 February 2020 20:18
by rolandbreedveld
Ptje wrote: ↑Monday 24 February 2020 18:41
Hello Roland,
What do you mean with terminate ? Do I have to remove the ' ?
Greetings
Peter
de cookienis between ‘’ and de line ends with a ;
Posted: Monday 24 February 2020 21:30
by Ptje
Hello Roland,
Thats the way I did it.
I edit the crontab and nothing updates in Domoticz. I get an error when I start it by hand.
Greetings,
Peter
Posted: Tuesday 25 February 2020 7:52
by rolandbreedveld
Ptje wrote: ↑Monday 24 February 2020 21:30
Hello Roland,
Greetings,
Peter
oh, i see, you don’t have php installed, also php-curl, perhaps some other library’s, it will tell you if your missing some. (apt-get install php php-curl)
Posted: Tuesday 25 February 2020 9:50
by Ptje
Hello Roland,
We are getting there. I installed php and php curl now. I think something was missing. I have no errors anymore. Now I see,
pi@raspberrypi:~ $ /home/pi/nest-api/get_nest.sh
Update TEMP to 19.3
Update HUMIDITY to 48.0
Update TEMPHUM to 19.3;48.0;0
Update SETPOINT to 19.9
I suggest my token and cookie is right now. Only in Domoticz nothing is getting updated. I have edited nest_devices.cfg
Device idx
SETPOINT 285
TEMP 286
HUMIDITY 490
AWAYMODE 288
ECOMODE 287
HEAT 289
TEMPHUM 511
DOMOTICZ 127.0.0.1:9090
Only HUMIDITY and TEMPHUM not. I don't use that.
When I execute the script, I see no reaction in Domoticz log. You have any idea ?
Greetings,
Peter
Posted: Tuesday 25 February 2020 10:09
by rolandbreedveld
Ptje wrote: ↑Tuesday 25 February 2020 9:50
Hello Roland,
Update TEMP to 19.3
Device idx
SETPOINT 285
TEMP 286
HUMIDITY 490
AWAYMODE 288
ECOMODE 287
HEAT 289
TEMPHUM 511
Greetings,
Peter
congrats, if you get info, your token and cookie are ok
what if you run:
php nest-api.php
note: if domotics is running on a different user than you do this command, you have to remove the cache files
Domoticz is normally on port 8080
and check if Domoticz is listening on local host (settings -> local networks) in my case 127.0.0.1;192.168.3.*
Posted: Tuesday 25 February 2020 10:19
by Ptje
Hello Roland,
pi@raspberrypi:~/nest-api $ php nest-api.php
Could not open input file: nest-api.php
pi@raspberrypi:~/nest-api $ sudo php nest-api.php
Greetings,
Peter
Posted: Tuesday 25 February 2020 10:31
by Ptje
Hello Roland,
Hoooooo Stop. !! It's working !!!! I had not secured the switches in Domoticz, so I never thought that the user and pass was the problem. I changed the settings at Local network to 127.0.0.1 and it is working.
Thank you very much for your patience. I am happy that my nest is working again with my domoticz.
Greetings,
Peter
Posted: Tuesday 25 February 2020 10:55
by Ptje
Hello Roland,
I see 2 things that are strange.
When I set in Domoticz the Switch "Away" on, the thermostaat itself goes to "Eco" And when I Switch "Eco" on, it also switches the thermostaat aan "Eco"
And when I update the setting point in Domoticz and I execute the script, it changes the settings back in Domoticz to the old setting point. When I change de set point on the Nest self and I execute the script, it updates Domoticz well.
Is this a wrong setting ?
Greetings,
Peter
Posted: Tuesday 25 February 2020 12:02
by rolandbreedveld
Ptje wrote: ↑Tuesday 25 February 2020 10:55
Hello Roland,
Yes I see this, it was in the original code from Guillaume Boudreau, seeline 745 of net.class.php:
public function setAway($away_mode, $serial_number = NULL, $eco_when_away = TRUE) {
It was build in to set ECO if you are away, while we want to do this by Domoticz events , I'll change it to FALSE in the new version
I think this won't happen if you wait a few seconds, take the iphone (or Android) Nest app next to you, I the trigger for setpoint runs the dzVents event, it takes a short time when it's evaluated by Google/Nest, in my case 1-3 seconds.
If you don't see your nest changing to the new setpoint, you'r dzVents-event is not there or not correct configured.
Posted: Wednesday 26 February 2020 20:23
by meel4chris
thanks for the script! I'm affraid I have some last issues I have to resolve
After following the steps I now get the following errors in the domoticz logs, any ideas / suggestions?
I'm running on a fresh installation of Buster.
2020-02-26 20:21:00.505 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: /home/pi/domoticz/dzVents/runtime/Utils.lua:1: module 'JSON' not found:
2020-02-26 20:21:00.505 no field package.preload['JSON']
2020-02-26 20:21:00.505 no file '/home/pi/domoticz/scripts/dzVents/JSON.lua'
2020-02-26 20:21:00.505 no file '/home/pi/domoticz/dzVents/runtime/JSON.lua'
2020-02-26 20:21:00.505 no file '/home/pi/domoticz/dzVents/runtime/device-adapters/JSON.lua'
2020-02-26 20:21:00.505 no file '/home/pi/domoticz/scripts/dzVents/dzVents/JSON.lua'
2020-02-26 20:21:00.505 no file '/home/pi/domoticz/scripts/dzVents/scripts/JSON.lua'
2020-02-26 20:21:00.505 no file '/home/pi/domoticz/scripts/dzVents/../lua/JSON.lua'
2020-02-26 20:21:00.505 no file '/home/pi/domoticz/scripts/dzVents/scripts/modules/JSON.lua'
2020-02-26 20:21:00.505 no file '/home/pi/domoticz/scripts/dzVents/generated_scripts/JSON.lua'
2020-02-26 20:21:00.505 no file '/home/pi/domoticz/scripts/dzVents/data/JSON.lua'
2020-02-26 20:21:00.505 no file '/home/pi/domoticz/scripts/dzVents/modules/JSON.lua'
2020-02-26 20:21:00.505 no file '/usr/local/share/lua/5.3/JSON.lua'
2020-02-26 20:21:00.505 no file '/usr/local/share/lua/5.3/JSON/init.lua'
2020-02-26 20:21:00.505 no file '/usr/local/lib/lua/5.3/JSON.lua'
2020-02-26 20:21:00.505 no file '/usr/local/lib/lua/5.3/JSON/init.lua'
2020-02-26 20:21:00.505 no file './JSON.lua'
2020-02-26 20:21:00.505 no file './JSON/init.lua'
2020-02-26 20:21:00.505 no file '/usr/local/lib/lua/5.3/JSON.so'
2020-02-26 20:21:00.505 no file '/usr/local/lib/lua/5.3/loadall.so'
2020-02-26 20:21:00.505 no file './JSON.so'
Posted: Thursday 27 February 2020 14:23
by rolandbreedveld
meel4chris wrote: ↑Wednesday 26 February 2020 20:23
These files are not in these locations on my pi, so the errors are correct, but what's causing them, is this after you created the enclosed dzvents script? If so, did you create it with the "graphical" event editor from domoticz?
Posted: Friday 28 February 2020 11:19
by meel4chris
Thanks for your help!
I'm getting these errors after I copied the file "dzVents_script_Nest_Setpoint.lua" to the folder "domoticz/scripts/dzVents/scripts/".
I added the .lua extension to the template file.
The content I did not change, the Thermostat device (subtype setpoint) is called "Nest" in domoticz.
Posted: Friday 28 February 2020 13:28
by flemm
I have a question about the dzvents script, as well. After some struggle I got your script to work, and it's awesome! Finally able to control my Nest properly through domoticz. Thanks a lot.
One question though, since I added the dzevents setpoint script, my CPU usage increased quite a bit. From <1% to about 5%, with bumps to 7%. I know it's still not much, but it surprises me that such a simple script could increase it so much. And i'm quite a freak when it comes to running things as smooth as possible.. When I disable the script, it immediately drops back to the previous values. I'll post a graph as well.
Is there something i can do to make it less heavy on the CPU? Maybe limit the numbers of checks or something? Or is this a dzevents-related side effect? I have absolutely no experience in scripting or knowledge about how this plugin works, so maybe i'm just asking stupid questions..
Posted: Friday 28 February 2020 13:50
by flemm
meel4chris wrote: ↑Friday 28 February 2020 11:19
As far as i know, and how i got it to work, was by adding that script via the Domoticz GUI (Setup - More Options - Events). You can add a Dzvents script there, and that worked for me. But as you can see above, i'm not quite sure about it. I might have done it wrong myself
Posted: Friday 28 February 2020 14:01
by meel4chris
flemm wrote: ↑Friday 28 February 2020 13:50
Thanks for the suggestion, I just tried it but it gives me the same errors
Posted: Friday 28 February 2020 17:37
by rolandbreedveld
Better create the event in Domoticz events, create a new one remove the default content en cut-and paste the template in it
Posted: Friday 28 February 2020 17:42
by rolandbreedveld
flemm wrote: ↑Friday 28 February 2020 13:28
strange, I don't have that behaviour, I also shouldn't be, because it's only fired on a device change, did you created it from the domoticz event gui, create a new event->dzvents->device ?
Posted: Friday 28 February 2020 18:52
by meel4chris
rolandbreedveld wrote: ↑Friday 28 February 2020 17:37
That's what I tried this afternoon but that resulted in the same errors...
